How Much Does It Cost to Run a Fan Hourly and Nightly in the UK?
Many UK households use fans during the summer months to stay cool without regularly turning on their air conditioners. One of the most frequent inquiries homeowners have is just how much does a fan cost to run and use electricity and is it really that much added to their bill if they leave it on throughout the night.
The bright side is that a lot of the fans consume much less energy than the other larger cooling devices. But the running cost still differs according to the type of fan, its wattage, energy tariff and the duration the fan runs during the day. For those seeking long-term solutions for managing their energy resources, households can also consider smart home energy solutions and energy storage systems available at the official EcoFlow UK store, which offers enhanced energy efficiency.
How much does a fan cost to run per hour in the UK?
The running cost of a fan depends primarily on its wattage and your electricity rate. Most household fans operate from 30W to 100W and are relatively inexpensive compared to air conditioners or electric heaters.
Assuming that electricity costs an average of 27–30p per kWh in the UK in 2026:
  • A 30W fan runs at about 1p per hour.
  • The 50W fan runs at 1.5p/h.
  • A 100W fan runs at a rate of around 3p per hour.
While the price is relatively low, fans use electricity when operating continuously, day or night, which can be significant over time.
How much does it cost to run a fan overnight?
The cost of running a fan overnight is a question many people ask themselves, particularly during heatwaves, when fans can be in use for 8-10 hours at a time. Luckily, fans are still one of the least expensive cooling methods used in UK residences.
For example:
  • An 8-hour operation of a 40W fan can be about 8-10 p.m. overnight
  • Running a 50W tower fan will cost about 12p a night.
  • A bigger 100W fan can cost approximately 24p a night
Fans are by far more energy efficient than portable air conditioners. But cutting down on wasted runtime and improving home energy efficiency can still save the household some extra money on their monthly electricity bills.
How much does an electric fan cost to run by fan type?
One important factor to consider is the type of fan you use, as it significantly affects the operating cost. Generally, smaller fans require less power, while larger or more sophisticated ones require more.
There are also various types of fans used for different cooling purposes, and this will also affect how long they may operate daily.
How much does a 100w ceiling fan cost to run?
If you use a ceiling fan regularly, the cost to run it varies with the fan size and speed setting. Most ceiling fans consume between 15 and 75 watts.
A medium-sized ceiling fan at medium speed is approximately:
  • Around 1–2p per hour
  • Roughly 10–15p overnight
Small desk fans can be less effective in moving air around in larger areas than ceiling fans.
How much does a 50w tower fan cost to run?
One of the questions throughout the summer is how much a tower fan really costs to operate, and why are tower fans so popular for bedrooms and living rooms? The typical power consumption of most tower fans is about 40W-60W.
At the current electricity prices in the UK:
  • The cost of running a tower fan is approximately 1–2p an hour.
  • Internet access is usually available for an extra charge of 10–15p per night, depending on the required speed.
Tower fans are considered to have the right amount of cooling power and power consumption.
How much does a desk fan cost to run?
The smallest cooling devices on the market are personal small fans. Most desk fans consume only 20W–40W of electricity, so if you are wondering how much a desk fan costs, the answer is that it will not cost more.
This means:
  • The cost of running a desk fan is less than 1p an hour.
  • Overnight use is often low-cost, at just a few pence per person.
Desk fans are perfect for a home office, study room, or small bedrooms to cool a person without using full-room cooling.
How much does a Dyson fan cost to run compared to standard fans?
The design, quieter operation, and extra features of premium bladeless fans are popular, and many homeowners want to know how much a Dyson fan costs to run compared to a regular fan.
The power consumption of Dyson fans ranges from 40W to 60W, depending on the model and fan speed setting. This means:
  • The running cost of a Dyson fan is approximately 1-2p per hour.
  • Overnight use may cost approximately 10-16p
  • Higher speed settings consume more electricity; they will use more electricity.
The running costs are still far less than those of portable air conditioners for those who are curious how much it costs to run a Dyson fan. But, the fan motor designs are simpler and lower the wattage; hence, standard desk or tower fans tend to be slightly less expensive.
What affects the cost of running a fan?
There are several factors that influence the cost of running a fan in UK households. As with most appliances, a fan can be relatively inexpensive, but its electricity consumption depends on how it's used.
The most significant factors are:
  • Fan wattage and motor size
  • Number of hours used daily
  • Electricity tariff rates
  • Fan speed settings
For instance, the running cost of a 50w fan will obviously be less than that of a 100w industrial fan. Likewise, if a fan is run all day long during the warm season, the monthly electricity bill will be higher, even though the hourly charge may seem attractive, than if the fan is turned off during the day.
Is running a fan expensive compared to other appliances?
Fans are relatively inexpensive to run compared to most household appliances. Larger fans use significantly less electricity than air conditioners, electric heaters, ovens or tumble dryers.
For comparison:
  • The cost of a standard fan is 1-3p per hour.
  • Portable air conditioners range in cost from 20–50p per hour
  • Electric heaters are usually over 60p an hour.
This makes fans one of the cheapest cooling solutions used in UK homes. When there are many small appliances that use electricity every day, such as fans, routers, TVs, kitchen appliances, and chargers, the cost can still add up over time.
The smarter way to reduce even small electricity costs
Anything from basic appliances to more sophisticated equipment can add up in a big way when operating regularly over the course of a year. While large appliances are often the first items considered, small equipment such as fans, lighting, and electronics also affect a home's energy budget.
That is why homeowners are opting for smarter energy management solutions to help them avoid relying on costly grid electricity.
How solar energy helps reduce everyday electricity costs
Solar power enables households to run everyday appliances such as fans, lights, routers, and entertainment devices. Residential buildings don't have to depend entirely on the grid; they can draw power from the sun during the day and from storage at night.
This creates a cushion to offset any impact from increasing tariffs as well as making day-to-day use of appliances more affordable. Low-cost running appliances can be even more cost-effective when powered by solar-stored energy rather than grid electricity.
EcoFlow STREAM solutions for everyday energy savings
Modern home energy storage systems make it easier for households to manage small and large electricity costs more efficiently. The EcoFlow STREAM series is designed to store solar energy and help reduce daily dependence on grid power.
These systems support smarter energy usage by allowing households to power common appliances more efficiently throughout the day and evening.
EcoFlow STREAM Ultra X Home Solar Battery
Battery capacity of 3.84kWh Built around LiFePO4 (lithium iron phosphate) chemistry Rated cycle life of 6,000 cycles to 70% capacity The smart home solar battery system is a device designed to store energy for everyday use. Stores surplus solar electricity for use at peak rate times Reduces the amount of electricity required by fanning and lighting systems Flexible solution to reduce grid reliance in the long term
EcoFlow STREAM All-in-One Home Storage Kit
Generates up to 2,218kWh annually, meeting 71.3% of household power needs Dual-mode 2800W solar input, maximising power generation from every sunlit area A fully integrated home energy storage solution for UK homes. To boost energy efficiency and save on electricity bills Charges up stored solar energy for use in daily applications Facilitates households to deal with the escalating price of electricity better
Estimate your savings on household electricity with solar storage
After understanding the cost of operating a fan, households should consider their overall electricity consumption. It might be a cheap appliance, but using it month after month and year after year can add up.
These long-term costs can be diminished by households using solar storage systems to:
  • Install more on-site power generation systems.
  • Curb the use of costly peak-hour fares
  • Reduce the overall energy use in the house.
  • Reduced electric costs for a variety of appliances
In the UK, where many households rely on solar power for a portion of their energy needs, storing electricity for use is an attractive option that enhances the sustainability and cost-effectiveness of this renewable source.
5 simple ways to reduce the cost of running a fan
  1. Use the right fan size for the room
A lot of people have oversized fans and use them in small rooms. For bedrooms or home offices, you can typically use a desk fan or a tower fan; for larger spaces, ceiling fans are more effective. If you can select the right fan, you will not need to compromise on the comfort level without worrying about how much does a fan cost to run per hour.
  1. Avoid running fans all day unnecessarily
Although fans consume less power than air conditioners, when they are kept on for long periods, they still contribute to electricity costs. Control operating hours using timers, sleep modes or smart plugs. It can be particularly useful if you wish to reduce how much does it cost to run a fan overnight.
  1. Clean fan blades regularly
Dust accumulation makes fans work harder and airflow less efficient. Efficiency is enhanced and electricity consumption is reduced through simple maintenance. Especially when the house is wondering about how much does an electric fan cost to run during summer.
  1. Combine fans with better ventilation
Opening windows at night during cooler periods to allow natural cooling will help cool domestic rooms more quickly with fans. With improved airflow, lower fan speed settings, and lower energy costs. This has a considerable effect on how much does a ceiling fan cost to run during the summer season.
  1. Use solar energy to offset everyday appliance costs
Other household equipment, such as small appliances, routers, TV sets and chargers, adds up to increased electric bills. When homes are combined with solar storage systems, they can reduce the amount of costly grid electricity they use. This is one of the smartest means to minimise the long-term cost of a fan.
Knowing how much a fan costs to run can help UK households make informed choices about cooling during the summer and about electricity consumption. The cost of a fan is usually relatively low, but it can add up if it is used every day or night. The actual running cost will vary depending on wattage, fan type, run time, and electricity costs.
If saving more money on a house is the goal, it is even better to combine energy efficiency with solar storage systems. EcoFlow STREAM Ultra X Home Solar Battery and EcoFlow STREAM All-in-One Home Storage Kit are a few solutions that reduce the cost of using appliances powered by solar energy stored in a battery, making it more affordable and efficient in the long run.
  1. How much does a fan cost to run per hour in the UK?
The answer depends on the fan’s wattage and your electricity tariff. Most standard-type fans are in the 30-100-watt range and are therefore quite affordable compared to those with higher power ratings. For calculating the cost of running a fan per hour, these are the key factors:
  • A 30W fan will run at about 1p per hour.
  • The typical cost of a 50W fan is 1.5p to 2p per hour.
  • If a 100W fan costs 3p – 4p per hour, the price of the fan will be approximately 3p – 4p per hour.
Despite the UK's rising energy costs, fans remain one of the least expensive ways to cool a house. Energy-efficient fans and minimising unnecessary airflow time can further reduce costs.
  1. Is it expensive to run a fan overnight?
For most homes, it is not too costly to run a fan overnight rather than an air conditioning system. However, the total cost still depends on the type of fan, the wattage, and the number of hours the fan operates.
For instance, if you are interested in knowing how much does it cost to run a fan overnight, a 50-watt fan will cost approximately 12p to 18p, depending on the average UK electricity cost used for 8 hours. A tower fan or desk fan is typically lower in operating costs than a larger pedestal or high-power cooling fan.
  1. How much electricity does a fan use per day?
It depends on the fan’s power rating and how long it runs. Smaller fans with less wattage consume very little energy, while high-powered models use more electricity over extended periods. When you are looking to estimate how much does a electric fan cost to run, you need to keep these points in mind:
  • A 30W fan running for 8 hours uses about 0.24 kWh daily.
  • A 50W fan running for 10 hours uses about 0.5 kWh daily.
  • A 100W fan running all day could consume over 2 kWh.
Although each individual fan has its own costs, multiple appliances running daily can significantly increase the household's total electricity usage. Solar storage systems can help offset these small but constant energy demands.
  1. Are fans cheaper than air conditioning?
Yes, fans are significantly cheaper to operate than air conditioners in nearly all situations. Fans only circulate air around the room, while air conditioners actively cool it using compressors that consume much more electricity.
For households, comparing how much does a fan cost to run versus an AC unit, a fan may cost only a few pence per hour, while portable or central air conditioning systems can cost 10 times more costs. Using fans strategically, alongside improved ventilation and solar energy solutions, can reduce cooling costs while maintaining indoor comfort.
Home Solutions
