How Do Heat Pumps Work in UK Homes?
Heat pumps can seem confusing at first. They use electricity, yet their main job is not to create heat like a conventional electric heater. Instead, they move heat from one place to another. That simple difference explains much of their efficiency. So, how do heat pumps work in a UK home? They extract the available thermal energy from the outside and increase its temperature by going through a refrigeration cycle, thereby sending the heat inside. In both air-source and ground-source systems, the heat source is the same, but the one used in each case is different.
This raises other practical questions. What happens when winter temperatures fall? How much electricity does a heat pump use? And what about heat pump tumble dryers? Understanding these answers also helps explain why energy monitoring, smart controls and home energy storage can become useful when heating demand rises.
How Do Heat Pumps Work?
Heat Pumps Transfer Heat Instead of Generating It Directly
How do heat pumps work is best answered by looking at what the system does with heat. A heat pump transfers thermal energy from a lower-temperature source to a higher-temperature area. It does not rely on electrical resistance to produce all the heat directly.
Electricity still matters. It powers the compressor, fans, pumps and control systems. However, most of the useful heat delivered indoors comes from the heat source itself. That is the key idea behind the question, heat pumps how do they work, which some people also type as how do heat pump work. The system uses electricity to move heat rather than simply turning electricity into heat.
The Basic Heat Pump Cycle
The heat pump cycle happens continuously while the system is heating.
  1. Heat is absorbed: The system collects thermal energy from outdoor air, the ground or another suitable source.
  2. The refrigerant carries the heat: A refrigerant absorbs this low-temperature heat and changes state within the system.
  3. The compressor raises the temperature: The compressor increases the refrigerant's pressure, which also raises its temperature.
  4. Heat is released: The hotter refrigerant passes through a heat exchanger and transfers heat to the home's heating system.
  5. The cycle repeats: The refrigerant passes through an expansion device and returns to the start of the cycle.
This is a vapour-compression refrigeration cycle, similar in principle to the process used by a refrigerator, but operated in the opposite direction for heating.
What Are the Main Parts of a Heat Pump?
The main components are the evaporator, compressor, condenser, expansion valve and refrigerant. The evaporator absorbs heat from the source. The compressor raises refrigerant pressure and temperature. The condenser releases heat into the building. The expansion valve reduces pressure before the refrigerant returns to the evaporator.
Indoor and outdoor heat exchangers connect these stages. Together, they allow the system to keep transferring thermal energy rather than producing all its heat from electricity.
How Do Air Source Heat Pumps Work?
An air source heat pump extracts thermal energy from outdoor air and transfers it into a building. The outdoor unit contains a heat exchanger where refrigerant absorbs available heat from the air. There is thermal energy in the air even when it's cold. The refrigerant absorbs it before the compressor increases the pressure and temperature of the refrigerant.
The resulting heat can then be transferred indoors. UK government guidance recognises air source heat pumps as systems that use air as their heat source and transfer that energy into useful heat for buildings. This also answers how do air heat pumps work. Searches such as how do heat source pumps work usually refer to the same broad principle, although specific systems can be designed for different applications.
How Do Air Source Heat Pumps Heat a Home?
An air-to-water heat pump transfers heat into a wet central heating system. Depending on the installation, that heat can be distributed through radiators or underfloor heating. Some systems use air-to-air distribution instead. These systems deliver warm air directly into rooms through indoor units.
The building itself also matters. A well-insulated, draught-controlled home loses less heat, so the heat pump does not need to work as hard to maintain the desired indoor temperature. There may be existing radiators that are suitable, but this cannot be assumed. Since heat pumps are most effective at lower flow temperatures than boilers, they should be sized with the radiators and the system design in mind before installation.
How Do Heat Pumps Work in Winter?
The answer to how do heat pumps work in winter is straightforward: they continue extracting available thermal energy from the heat source, even when outdoor temperatures are low. However, performance can change as conditions become colder. The heat pump may need to work harder to maintain the required indoor temperature. Cold and humid conditions can also cause frost to form on an outdoor heat exchanger, so some systems periodically run a defrost cycle.
This means winter performance depends on more than the outside temperature. System sizing, insulation, heat distribution, controls and the building's heat loss all influence electricity consumption.
How Do Ground Source Heat Pumps Work?
These systems help to harvest thermal energy from the ground rather than from the outside air. A ground loop is buried in the ground or installed through boreholes. A fluid, usually containing water and antifreeze, circulates through the loop and absorbs heat from the surrounding ground.
The fluid then passes through the heat pump's heat exchanger. The refrigeration cycle will raise the temperature of the extracted energy before it is delivered to the home's heating system. The cooled fluid then flows back underground and picks up more heat.
How Ground Source Systems Differ From Air Source Systems
The main difference is the heat source. An air source system uses outdoor air, whose temperature can change considerably from day to day. A ground source system uses heat stored in the ground, where temperatures are generally more stable.
That stability can be useful, but ground source installations normally require more space or specialist ground works. Depending on the property, this could mean horizontal ground loops or deeper boreholes. Neither system is automatically right for every home. The property, available space, heating demand, insulation and installation requirements all need to be considered.
How Do Hybrid Heat Pumps Work?
A hybrid heat pump combines a heat pump with another heating source, such as a boiler. The system can then use controls to decide which heat source should operate under particular conditions. For example, the heat pump may handle normal heating demand while another source provides additional heat when conditions or demand make that useful. The exact arrangement depends on the system design and control strategy.
This is relevant when considering how do heat pumps work uk because UK homes vary widely in age, insulation, heating systems and energy demand. A hybrid approach may suit some properties, although it is not automatically the most efficient choice for every household. It is also worth noting that current UK Boiler Upgrade Scheme grants do not cover hybrid heat pump systems, so homeowners should check the latest eligibility rules before making decisions.
Note: Government grant schemes and eligibility rules change over time. Before you decide on a heat pump or hybrid system, check the current Boiler Upgrade Scheme rules on the official GOV.UK website.
How Do Heat Pump Dryers Work?
How Do Heat Pump Tumble Dryers Work?
They use a heat pump to move and reuse heat within the drying system. Warm air passes through wet clothes and absorbs moisture. Instead of simply exhausting that warm air, the dryer passes it through a heat pump system. Moisture is removed, while useful heat is recovered and reused.
This makes the process different from a conventional vented dryer, which continually pushes warm, moist air outside. The same question is sometimes written as heat pump tumble dryer how do they work or heat pump tumble dryers how do they work. The answer remains the same: the dryer recovers and reuses heat while removing moisture from the clothes.
How Do Heat Pump Clothes Dryers Differ From Conventional Dryers?
How do heat pump clothes dryers work compared with conventional models? The key difference is how they handle heat. A heat pump dryer recirculates warm air and recovers heat during the drying process. This can reduce electricity consumption compared with conventional designs, although exact energy use varies between models and programmes.
They also tend to dry clothes at lower temperatures. That can be gentler on some fabrics, but cycles may take longer. So, how do heat pump dryers work is not quite the same question as how a home heating system works. The technology is related, but the purpose is different. Anyone wondering about heat pump dryers how do they work will find the answer in heat recovery and moisture removal rather than space heating.
Are Heat Pump Dryers the Same as Home Heating Heat Pumps?
No. Both systems use heat transfer, but they serve different purposes. A home heating heat pump moves thermal energy into a building to provide space heating or hot water. A heat pump dryer uses the same broad principle to manage heat and remove moisture from clothes. That distinction matters because the equipment, operating conditions and heat-transfer path are completely different.
How Efficient Are Heat Pumps When Electricity Demand Is High?
Why Heat Pump Electricity Use Changes With Heating Demand
A heat pump can be highly efficient while still using a meaningful amount of electricity. The amount required depends on the conditions under which it operates. During colder weather, a home usually loses heat more quickly. The heating system may therefore run for longer or work harder to maintain the indoor temperature.
Electricity consumption can be influenced by:
  • Outdoor temperature
  • Indoor temperature settings
  • Building insulation
  • Heat loss
  • Heat pump size
  • System efficiency
  • Heating and hot water demand
This is why efficiency and electricity consumption should not be treated as the same thing. A system can transfer heat efficiently while household electricity use still rises because heating demand has increased.
Why Efficient Heating Can Still Create a Large Household Load
A heat pump may become one of the larger electricity loads in a home during cold weather. Other appliances can add to the demand at the same time. Cooking, hot water heating, washing machines, tumble dryers and electric vehicle charging can all compete for electricity. The important point is not to avoid using these appliances. It is to understand when they operate and how much electricity they consume.
Managing Electricity When Your Heat Pump Runs More Often
Use Energy Monitoring to Understand Heating Demand
Energy monitoring can show when household electricity demand rises and which periods create the largest loads. Instead of guessing, homeowners can look at actual consumption patterns. They may discover that the heat pump runs most heavily during certain hours, while other appliances are also operating. That information can help households make better decisions about when flexible loads should run.
Use Smart Controls to Manage Household Loads
Smart controls can help coordinate flexible electricity use. For instance, a household can plan to wash the washing machine or other ‘non-essential load' at a time when the heating load is not as high.
The goal is not to interfere with essential heating. Comfort and safe operation should remain the priority. The best way to use smart control is to let it adapt to the home's actual energy consumption, not a set schedule that is never varied.
Can Home Battery Storage Help?
Home battery storage provides another option. Instead of using electricity only when it is generated or purchased, a battery can store energy for later use. With solar, surplus daytime generation can potentially be stored for use when heating demand rises later. Without solar, some battery systems can also charge from the grid when electricity is cheaper, depending on the tariff, controls and system configuration. Battery storage does not make the heat pump itself more efficient. It changes when stored electricity is available to the household.
Solving Higher Heating Demand With Home Energy Storage
A Practical Storage Option for Homes Without Solar
For a household starting without rooftop solar, EcoFlow STREAM 5000 provides a way to add battery storage around existing electricity use. Its 5,024Wh capacity and up to 3,000W AC output can help cover part of the demand created by heating and other household loads. Its automated energy modes can also reduce the need for constant manual adjustments. For households asking how do heat pumps work alongside a broader home energy plan, this type of storage can help separate when electricity is available from when it is needed.
EcoFlow STREAM 5000
Installed home battery for homes without solar. UK rules require installation, and the setup is designed to be simple 5024Wh capacity supports all-night home power use, expandable to 90kWh Up to 3000W AC output for high-demand appliances like stoves, dryers or kettles (when solar is generating or an Expansion Battery is paired) 5,000W solar input makes full use of your solar generation Up to 2500W AC charging for fast recharge Smart meter, main unit and solar panels are designed to connect easily, with step-by-step app guidance for setup Compact 45.9kg body with a built-in handle for easier placement during installation Residential-grade safety: pressure-release and fire-resistant materials, no overheating even with high-voltage solar panels 10,000-cycle lifespan, so you can charge to 100% or discharge fully without affecting battery health Local Mode keeps the system running and communicating even if the network drop
Adding Storage to an Existing Solar System
For homeowners who already have rooftop solar, EcoFlow STREAM AC 5000 is designed around adding battery storage to an existing solar setup. Its 5,024Wh capacity can retain surplus solar electricity for later household use, which can be useful when daytime solar generation does not match evening heating demand. The system also supports expansion, giving households a way to increase storage as their energy requirements change. For someone considering how do heat pumps work alongside existing solar, the key benefit is better timing between generation, storage and household consumption.
Installed home battery for homes with existing solar. UK rules require installation, and the setup is designed to be simple Works with existing rooftop PV systems, home battery systems and leading third-party meters 5024Wh capacity covers overnight home needs, expandable to 90kWh Up to 3000W AC output for heavy household appliances (when solar is generating or an Expansion Battery is paired) AC coupling adds storage alongside your current solar setup, with no rewiring needed when you expand later with a Gateway Compact 45.1kg body designed to fit into spaces around the home 10,000 cycles for durable, long-term battery health
Understanding how do heat pumps work starts with one simple principle: they transfer thermal energy instead of producing all their heat through electrical resistance. Air source systems extract heat from the outside air and ground source systems extract heat from the ground. Hybrid systems combine a heat pump with another heating source, while heat pump dryers apply similar heat-transfer principles to drying clothes.
Cold weather can increase heating demand, even when a heat pump remains efficient. That makes energy monitoring, smart controls and battery storage useful parts of a wider household energy strategy. Storage cannot improve the heat pump's mechanical efficiency, but it can help manage when electricity is available for heating and other loads.
If you want to use this electricity more intelligently, EcoFlow UK can provide home energy storage that suits different starting points, from people with no rooftop solar panels to those with existing rooftop PV systems. Explore the available systems and choose an approach that fits your home's heating and energy-use pattern.
How do heat pumps work?
They transfer thermal energy from an external source into a building. The refrigerant absorbs heat, the compressor compresses it, and the excess heat is conducted inside the house by the heat exchanger. Compressor, fans and controls are powered by electricity.
How do heat pumps work in winter?
Heat pumps can continue extracting thermal energy during winter. However, colder conditions can increase heating demand and affect system performance. Electricity use depends on outdoor temperature, insulation, system design, controls and the amount of heat the home needs.
How do air source heat pumps work?
They extract thermal energy from outdoor air. Refrigerant absorbs the available heat, the compressor raises its temperature, and the system transfers that heat indoors through a suitable heating system. The exact design depends on the installation.
Home Solutions
