Cost of Solar Panels and Battery UK: Prices, Savings and System Sizes
The cost of solar panels and battery UK households depends far more than the number of panels on the roof. The actual quotation may vary because of the size of the solar arrays, battery storage, roof accessibility, type of inverter, and changes to the electrical system and installation complexity. This is the reason two homes with seemingly the same system can get different prices.
For comparison, it is estimated that the average cost of a domestic solar PV installation is about £5k and a typical 5kWh battery system is about £4k. In addition, there are some differences in the consumer prices recently posted by system sizes and suppliers, and the figures apply more to planning estimates than guaranteed prices.
This guide breaks down the average cost of solar panels and battery storage UK, including examples for 10, 12 and 16 panels, installation-cost components, property factors, savings, export payments and VAT. Households planning a complete installation can also consider a solar-and-storage system designed together from the outset.
Average Cost of Solar Panels and Battery in the UK
While a handy figure to have as a starting point can help households form a budget, the pricing of solar and batteries should always be linked to the system being offered. If you have a smaller home and don't use a lot of electricity, you may need much less equipment than a home with an EV, heat pump or high electricity use in the evening.
Current cost of solar panels and battery UK households can expect
It is estimated that average domestic solar panel costs are around £6k and £4k for the average 5kWh battery. Combined use of these figures provides a rough planning benchmark of around £7k for solar plus a 5kWh battery, excluding any savings from combined installation or additional project-specific work.
But there are different estimates currently. A typical 4.5kWp solar panel system can cost approximately £7k. in August 2026, demonstrating how headline averages can vary depending on the specification of the panels, the size of the system, and how the pricing is calculated.
Solar-only pricing compared with a combined solar-and-battery installation
The solar-only installation is cheaper upfront because it doesn't involve installing battery modules, additional storage controls or doing extra electrical work for batteries. Hence, PV can be first installed in a household and later storage capacity can be added if needed due to the consumption pattern of the household.
When both technologies are installed together, the initial cost will be higher, but it may be more efficient. Batteries may be more cost-effective to install if it is done concurrently with the solar installation, as the installer is already on the site and can include the equipment as part of the same project.
This is because the cost of solar panels and battery storage UK should not necessarily be taken as the total standalone solar energy cost plus the total standalone battery storage cost. Labor, commissioning and other installation costs can be shared among combined quotations.
Understanding the average cost of solar panels and battery UK as a guide rather than a fixed quote
The average cost of solar panels and battery UK is most useful for early budgeting, not for predicting the exact invoice. Solar quotations vary according to system output, equipment quality, battery capacity and the physical characteristics of the home.
For example, Energy Saving Trust identifies system size, roof accessibility, panel type and roof work as factors affecting solar installation costs. Battery prices likewise vary significantly by capacity, with current guidance putting household systems broadly between £1,500 and £10,000, depending on size and specification.
To make a realistic comparison, therefore, we must go deeper than one headline figure. Considering the number of solar panels and the overall system size is the next step to consider how this affects the cost, such as the various requirements for 10, 12 and 16 panel installations.
Solar and Battery Costs by Panel Number and System Size
Panel count is a good indicator for comparing system size, but can't be used as a direct price calculator. However, solar panels these days have different wattages; therefore, two 10-panel systems may have different capacities. The final quotation is also dependent on battery size, inverter needs and installation complexity.
Typical considerations behind the cost of 10 solar panels and battery UK
The cost of 10 solar panels and battery UK households receive in quotes depends on panel wattage, battery capacity and installation conditions. A ten-panel array using modern high-output modules may reach around 4–4.6kWp, but panel count alone does not determine price.
Adding a battery increases the upfront budget according to usable capacity, inverter arrangement and installation work. A ten-panel system may suit moderate household demand, but installers should size both the array and battery against annual consumption rather than assuming ten panels represent a standard package.
System sizing factors affecting the cost of 12 solar panels and battery UK
The cost of 12 solar panels and battery UK households pay will usually be higher than for a ten-panel system, but the difference is not simply the price of two extra modules. Twelve panels may provide greater generation capacity, which can justify a larger inverter and potentially more battery storage if the household regularly produces surplus electricity.
Roof layout, scaffolding, cable routes and electrical upgrades can also affect the final quote. For households with higher annual consumption, a twelve-panel design may offer a better balance between available roof space and expected generation. The important comparison is the system’s total kWp, usable battery capacity and installation scope, not panel number alone.
Higher capacity and household demand behind the cost of 16 solar panels and battery UK
The cost of 16 solar panels and battery UK households encounter generally reflects a larger PV array designed for higher electricity demand or greater available roof area. Sixteen modern panels can represent a substantially larger system than a typical small domestic installation, so inverter sizing, DNO requirements and battery capacity become more important to the overall design.
Homes with EV charging, heat pumps or high daytime consumption may benefit from the additional generation, but extra capacity only adds value when the property can use, store or export the electricity produced. Larger arrays may also require more mounting hardware, roof space and installation labour, so quotations should compare total system specifications rather than panel quantity alone.
What Is Included in a Solar and Battery Installation Quote?
A solar-and-battery quotation should show more than one headline price. Reviewing the equipment, installation work, electrical requirements and aftercare separately makes it easier to compare proposals fairly and understand what is actually included in the total.
Solar modules, inverter and battery equipment within the total price
The total cost of a complete quotation should show the main pieces of the hardware as separate items with no single total. Specifications are as important as quantity, and the equipment cost is typically heavily dominated by solar modules, the inverter and the battery. But even if two systems are the same size in terms of numbers of panels, the higher efficiency of the panels, the greater usable battery capacity, or the more capable inverter may make one system more expensive than the other.
The quote should therefore show the manufacturer, model number, wattage of the panels, inverter rating, and usable battery capacity. This facilitates easier like-for-like comparisons between competing proposals, and enables a clearer understanding of whether a higher price is indicative of better-specified equipment or a different design of system.
Mounting hardware, scaffolding and labour within the cost of installing solar panels and battery UK
The cost of installing solar panels and battery UK households receive should also account for the physical work required to put the system in place. Labor typically involves mounting the panels, installing the inverter and battery, running cables and electrical connections. The cost of scaffolding can be a significant expense, especially for properties that are higher or hard to reach and multi-story buildings.
Mounting rails, roof hooks and fixings and weatherproofing should also be provided if necessary. Homeowners should also determine if scaffolding, labour and mounting hardware have already been included or if they are a separate item on the quotation, as a seemingly lower quote may end up being higher once these are included as part of the installation.
Electrical upgrades, commissioning and installation documentation
There are other electrical jobs that may be required prior to the safe commissioning of a solar and battery system at some homes. A quotation could therefore include modifications to the consumer unit, modifications to the protective devices, upgrades to the cable, isolators or whatever else has been identified during the site survey. It should also include system testing, commissioning and documentation related to the installation.
The handover pack may comprise the MCS certificate, system information, commissioning data, electrical drawings, product data and maintenance information for an MCS certified solar installation. These records are important because they document the equipment installed and how the system was tested. Homeowners should make sure that the documentation, such as DNO, electrical and MCS paperwork requirements are included, is not an optional extra.
Monitoring equipment, warranties and optional backup components
A good quotation will also describe the optional resilience and monitoring/warranty mechanisms that will be provided by the proposed system. Monitoring can be done via an app, energy meter or gateway displaying the solar generation, household consumption and battery performance. Warranty terms should be written separately for the panels, the inverter, the battery, and workmanship, as they can vary from one to another. Sometimes, households can also ask for backup equipment, which enables certain circuits to supply power during a grid outage, but which is not inherent to all batteries. Homeowners should make sure that the quote includes only standard storage or also a backup-power system, as this may add more to the project costs.
Property Factors That Can Increase or Reduce Installation Costs
The price of a final installation of two households with similar capacity of panels and batteries can vary due to the differences in properties. The amount of work and equipment that an installer must include depends on roof access, the amount of solar area available for use, existing electrical infrastructure and the electrical load requirements.
Roof size, pitch and accessibility affecting installation complexity
Before even considering the solar equipment, there are costs involved in labour, scaffolding and mounting related to the roof. Easily accessible roofs that are simply pitched may be less complicated to prepare than other roofs that are steeply pitched, oddly shaped or have more than one level. Different mounting structures may even be required on flat roofs to provide an adequate panel angle and wind load resistance. The reason for existing roof condition is that it may make sense to repair it before the panels are installed, rather than removing the array at a later date. Homeowners concerned about structural work can review whether solar panel installations can affect a roof before obtaining quotations. Installers should assess roof condition and access during the site survey instead of relying entirely on photographs or generic pricing.
Orientation and available roof space influencing required solar capacity
The size of the roof area available for use influences system design and the number of panels that can be installed cost effectively. The amount of electricity a particular array can generate depends on the orientation, pitch and shading of the roof; therefore, a roof with less favorable conditions can require more of the panel's electrical capacity to match the electricity production of a roof with more favorable conditions. Further space losses can occur due to chimneys, roof windows and shaded areas. Homeowners should not just compare quotations based on the number of panels, but rather should look at the predicted annual generation for each proposed layout.
Existing electrical infrastructure affecting the average cost of solar panel and battery installation UK
The average cost of solar panel and battery installation UK can rise when the home's electrical system requires upgrading before new equipment is connected. There may be additional work involved if you have an older consumer unit, inappropriate protection equipment, restricted cable capacity or poor earthing. Depending on the inverter configuration, location and inclusion of battery backup, battery installations can add additional electrical requirements. These issues should be detected during a professional site evaluation and, if so, prior to the final quotation. The homeowner should then find out whether the electrical work is included or excluded from the estimate, or if it is included, if there are any contingencies, or unfinished work, since the jack-up can be much more expensive than originally quoted when the work is finished.
Future EV, heat-pump and household electricity demand influencing system design
Consider the future electricity needs when designing a solar-and-battery system, not just the current electricity bill. Installing an EV, a heat pump, electric heating or additional home-working equipment can significantly affect the overall yearly consumption and when electricity is required. Homeowners can review their average household electricity usage before deciding whether extra solar or battery capacity is worthwhile.
A slightly larger system may cost more initially but could avoid an early expansion if electricity demand is already expected to rise. Equally, paying for unnecessary capacity creates poor value, so future loads should be based on realistic plans rather than speculative assumptions about how the household might change.
Estimating Your Budget With a Solar and Battery Calculator
A calculator can transform the broad national averages to a more useful estimation for the household by taking into account factors such as electricity consumption, house properties and anticipated solar production. However, it should not be considered as a replacement for a detailed site survey and installer quotation, but more as an early planning tool.
Household electricity consumption in a cost of solar panels and battery UK calculator
A cost of solar panels and battery UK calculator should begin with annual household electricity consumption because system size needs to reflect realistic demand. Recent energy bills provide the strongest starting point, particularly where they show a full year of usage in kWh. Household occupancy and daytime electricity use also matter because they influence how much solar generation may be consumed directly. The solar panel calculator asks about property details, household occupancy and whether somebody is usually home during the day before providing personalised cost and savings estimates.
Solar generation estimates based on location and roof characteristics
The next calculation should estimate how much electricity the proposed array could realistically generate. Postcode, roof orientation, pitch, shading and total installed solar capacity all affect expected annual output, so a calculator based only on panel numbers can provide a misleading result. MCS standards also require certified installers to provide an annual generation estimate before a contract is agreed, while making clear that actual solar radiation varies between locations and years. Calculator results should therefore be treated as informed projections rather than guaranteed production figures.
Daytime and evening consumption for estimating useful battery capacity
Total annual electricity consumption is not enough information to size a battery. A calculator should take into account the amount of power consumed when solar panels are producing power and the amount of demand at night or in the evening. A house that consumes most of the electricity it generates from the sun might not require as much storage as a house that regularly sends excess electricity to the grid during the day, but imports a lot of it after dark. Battery capacity should, therefore, be based on the quantity of energy that is realistically available for storage, and can replace later demands. This helps prevent paying for capacity that is not fully utilized throughout the year. In the guidance for solar PV performance estimation, self-consumption is taken into account for solar PV systems with and without electrical energy storage.
Comparing installer quotations on equivalent system specifications
After using a calculator, homeowners should obtain several detailed quotations and compare equivalent specifications rather than headline prices alone. One proposal may appear cheaper because it includes fewer panels, a smaller battery, lower inverter capacity or excludes scaffolding and electrical upgrades.
Compare total PV capacity in kWp, expected annual generation, usable battery capacity, inverter rating, warranties, installation work and predicted self-consumption. MCS requires certified solar installers to provide generation and self-consumption estimates before contract award, helping customers compare proposed systems on a more consistent basis.
Savings, Export Payments, VAT and Long-Term Value
The upfront cost is just one aspect of investing in solar and battery. A realistic financial assessment should also take into account avoided imports to the grid, export income, the structure of the electricity tariff and the current VAT treatment and the time period the equipment is expected to yield useful savings.
Reduced grid imports through greater use of household solar generation
The benefits of solar are financial, starting with electricity that the household no longer purchases from the grid. The power produced by the panels is used by appliances as soon as it is made, and a battery can be used to store some of the energy for later use. The amount of saving will thus vary depending on the household's import tariffs, daytime consumption and the amount of stored electricity which replaces the evening use of the grid. A house that uses a higher percentage of the solar energy it produces could benefit in value more than the house that exports a higher percentage of solar energy at a lower price. When looking at the import figures before and after installation, it is more realistic to consider the savings on an annual basis rather than the figures mentioned in the headlines.
Smart Export Guarantee income from surplus solar electricity
Surplus solar electricity that is not used or stored can be exported to the grid, and eligible households may receive payments through the Smart Export Guarantee. Export payments can improve the economics of a solar installation, although they should usually be treated as one part of the financial picture rather than the sole reason for installing panels. Households should compare current SEG tariffs and check metering and eligibility requirements before estimating annual income from exported electricity.
Time-of-use tariffs and their effect on battery-storage economics
Time-of-use tariffs can change the value of battery storage because electricity prices vary depending on when power is imported. A battery may charge from surplus solar during the day and discharge later when grid rates are higher, while some systems can also charge during cheaper off-peak periods. The potential saving depends on the difference between off-peak and peak prices, battery efficiency and household demand. A smart tariff can improve storage economics, but it does not guarantee that every battery will achieve a short payback period.
Payback period versus lifetime financial value
Payback period is useful, but it should not be the only measure of long-term value. Solar panels can continue generating for decades, while batteries may have a shorter service life and eventually need replacement. Financial value therefore depends on installation cost, avoided electricity purchases, export income, tariff changes, maintenance and equipment lifespan. A shorter payback can be attractive, but a system with a longer payback may still deliver strong lifetime savings if it remains productive for many years. Homeowners should model several electricity-price and usage scenarios rather than relying on one optimistic forecast.
Choosing Battery Storage Without Overspending
Once homeowners understand the overall cost of solar panels and battery UK, the next step is deciding how much storage is genuinely useful. Battery capacity should reflect actual solar generation, evening electricity demand and future household needs rather than simply choosing the largest available system. This helps keep upfront costs proportionate while still leaving room for later expansion where required.
Matching battery capacity to actual household electricity patterns
Battery sizing should begin with real household consumption rather than a generic capacity recommendation. Smart-meter and solar-monitoring data can show how much electricity is exported during the day and how much is imported again after solar generation falls. A household with substantial afternoon surplus and high evening demand may benefit more from storage than one already using most solar electricity directly. Homeowners should also compare usable capacity, battery efficiency and expected charging patterns before deciding.
EcoFlow STREAM 5000 for households installing solar and storage together
For households installing solar panels and battery storage as one project, EcoFlow STREAM 5000 provides a practical route for planning generation and storage together. Its capacity can be matched with current consumption while retaining the flexibility to expand later if electricity demand grows.
EcoFlow STREAM 5000
5.24kWh energy storage capacity for household energy management. Supports up to 4000W PV input for a professionally planned solar installation. Provides up to 3000W off-grid AC output for supported off-grid operation. Intelligent Mode+ manages stored and generated energy according to household demand. Compact 45.4kg design reduces the space required for installation. Expandable up to 90kWh if household storage requirements increase later.
EcoFlow STREAM 5000 AC for existing solar homes adding battery capacity
For households that already have rooftop solar, EcoFlow STREAM 5000 AC is designed for the retrofit scenario. It allows storage to be added alongside an existing photovoltaic installation, making it relevant where surplus daytime electricity is regularly exported while the household imports power again later.
Designed for households that already have solar panels and want additional storage capacity. Provides 5.24kWh of battery storage for retaining surplus solar electricity for later household use. Supports 800–3000W grid-connected AC output. Local Mode allows continued system operation when internet connectivity is unavailable. Intelligent energy management coordinates existing solar generation, battery storage and household consumption. Can operate as an extended storage device within an existing photovoltaic installation.
Expandable storage for households expecting electricity demand to grow
Expandable storage may mean that households do not end up paying for the maximum storage capacity required up front. However, the demand for electricity could be higher in the future with the arrival of cars on electric-powered batteries, heat pumps, more people living in the house and more working from home, but purchasing larger batteries years ahead of time can reduce the economic benefit.
An expandable system can be installed to meet the current consumption and still has the flexibility to meet the real needs in future. Solar generation, inverter capacity, electrical infrastructure and DNO requirements should also be verified for any subsequent expansion. The aim is therefore not to install the largest battery possible, but to keep the cost of solar panels and battery storage UK proportionate to useful capacity.
The cost of solar panels and battery UK households pay depends on system size, battery capacity, roof conditions, electrical work and installation complexity. While national averages can be used for initial budgeting, the best method is to compare multiple like-for-like quotes that are based on the amount of generation expected, household consumption and the equipment that is included. In addition to the upfront price, savings from the reduced grid imports, SEG payments and current VAT relief should be taken into account.
EcoFlow STREAM 5000 offers 5.24kWh storage for households who choose to combine solar with storage, with a maximum PV input of 4000W and expandable storage capacity for evolving energy requirements. If an existing solar household is interested in adding solar storage later, they should consider STREAM 5000 AC. Either way, designing the system around realistic electricity usage helps avoid overloading the system and maximizes the long-term value of a solar-and-battery investment.
Is it normally cheaper to install solar panels and a battery at the same time?
Often, yes. Installing solar panels and battery storage together can reduce duplicated labour, electrical work, commissioning and site-visit costs compared with completing two separate projects. It may also allow the inverter and battery system to be designed together from the beginning. However, the final cost of solar panels and battery UK still depends on battery capacity, inverter configuration and property requirements. Households should compare a combined quotation with the expected cost of adding storage later rather than assuming that bundling will always provide the lowest overall price.
Do solar panel and battery quotes usually include scaffolding and installation labour?
They often do, but homeowners should never assume every item is included in the advertised cost of installing solar panels and battery UK.
Before accepting a quotation, check whether it covers:
  • scaffolding, mounting hardware and installation labour;
  • electrical work, testing and commissioning;
  • DNO and applicable installation documentation.
A cheaper headline quote may exclude one or more of these costs. Asking installers for an itemised quotation makes it easier to compare equivalent systems and identify additional charges before signing a contract.
Are grants or financing schemes available to reduce the cost of solar panels and battery UK?
Some households can receive financial support, but there is no single universal grant covering every UK homeowner. Current 2026 guidance also allows qualifying domestic batteries installed alongside solar PV under the scheme. Eligibility depends on income, EPC rating, location and local-authority funding.
Funding arrangements differ across Scotland, Wales and Northern Ireland, so households should check current regional schemes before calculating their final project budget.
Can home battery storage charge from the grid when solar generation is low?
Yes, a suitable home battery can charge from grid electricity when solar output is insufficient, depending on the system configuration and tariff. This can be particularly useful alongside time-of-use tariffs that offer cheaper electricity during off-peak periods.
Potential benefits include:
  • charging when grid electricity is less expensive;
  • using stored power during higher-price periods;
  • maintaining useful battery capacity when solar generation is weak.
The government also confirms that standalone home batteries can operate independently of solar generation.
Can a home battery storage system provide electricity during a power cut?
Yes, but only when the battery system and household electrical installation are specifically configured for backup operation. Simply installing battery storage does not guarantee that household sockets or appliances will continue operating when the grid fails. A suitable backup arrangement may require dedicated switching, compatible inverter functionality and selected essential circuits.
Homeowners should therefore ask the installer which appliances can be powered, the available backup output and how long usable battery capacity could support them.
Solar System
