A Consumer Unit Upgrade Could Be the Safety Step Your Home Is Missing
A consumer unit upgrade replaces or improves the fuse box that distributes electricity around your home. It may become necessary when an installation has damaged components, insufficient circuit capacity or protection that no longer meets the requirements for proposed electrical work. Many homeowners only think about the consumer unit when renovating a kitchen, converting a loft or installing an electric vehicle (EV) charger.
Searches for consumer unit upgrade cost and consumer unit upgrade price show that budgeting is part of the decision, but price should not be the only consideration. A modern electrical system must also accommodate the home's wiring, protective devices and expected demand. This guide explains when an upgrade may be appropriate, what current UK requirements mean, how costs vary and why solar panels or home energy storage deserve consideration before work begins.
When Do You Need Consumer Unit Upgrades?
A consumer unit upgrade is worth considering when the existing installation is damaged, lacks suitable protection for planned work or cannot safely accommodate additional circuits. Age alone does not settle the question; an electrician needs to assess the actual installation.
Signs Your Fuse Box Is Outdated
Older consumer units may contain rewirable fuses or circuit breakers without modern residual current protection. Other warning signs include cracked or discoloured enclosures, exposed components, burning smells, unusual buzzing or repeated unexplained tripping.
Do not remove the cover to investigate these problems yourself. If you notice scorching, smoke or a burning smell, stop using the affected equipment and seek urgent electrical assistance; if there is smoke or fire, call the emergency services.
An old fuse box is not automatically unsafe. Electrical Safety First's guidance on consumer unit replacement explains that older fuses can still provide overcurrent protection and that an enclosure's age or material alone does not establish that replacement is necessary. An electrician should assess the condition, earthing, wiring and available protective measures. <Cite refs={["turn334680search52"]}/>
Home Extensions and Additional Circuits
An extension, loft conversion or new kitchen can introduce lighting, sockets, heating and cooking equipment that the original installation was never designed to serve. The existing consumer unit may have no spare ways, or the supply and circuits may need reassessment.
A larger consumer unit is not always the answer. The electrician must check the number of circuits, cable condition, protective devices and the capacity of the incoming supply before deciding whether to extend the installation or replace the board.
Plans to Install High-Demand Equipment
EV chargers, electric showers, heat pumps and induction hobs can place substantial demands on a domestic electrical installation. Some require dedicated circuits, and several appliances operating simultaneously can expose limitations in an older setup.
If you plan to upgrade consumer unit arrangements as part of a renovation, tell the electrician about every planned appliance, not just the one being installed first. Designing around future demand may avoid unnecessary repeat work, although an upgrade should only be specified where the assessment supports it.
What Does a Consumer Unit Upgrade to Current Regulations Involve?
A consumer unit upgrade to current regulations involves more than fitting a new box. The electrician must assess the existing installation, select appropriate protective devices, test the circuits and ensure that the completed work complies with the applicable requirements of BS 7671 and building regulations.
Modern Circuit Protection, RCDs and RCBOs
A residual current device (RCD) detects certain imbalances between the current flowing through live and neutral conductors and disconnects the supply when its operating conditions are met. This can provide important protection against electric shock and some electrical fire risks.
A residual current circuit breaker with overcurrent protection (RCBO) combines residual current protection with protection against overloads and short circuits. Individual RCBOs can help isolate a fault to one circuit rather than disconnecting several circuits together.
Miniature circuit breakers (MCBs) protect against overloads and short circuits, but they do not provide the same residual current protection as an RCD. The correct combination depends on the circuit, wiring and intended use.
Surge Protection and Fire-Resistant Enclosures
Surge protective devices (SPDs) help limit transient overvoltages that can damage electrical equipment. Whether an SPD is required or recommended depends on the applicable wiring regulations, the risk assessment and the consequences of equipment damage. An electrician should explain the proposed arrangement rather than assume every home has identical requirements.
Consumer units installed under modern UK wiring standards generally use suitable non-combustible enclosures, subject to the applicable rules and exceptions. The enclosure, connections and cable entries must all be appropriate for the installation. A new board cannot compensate for defective wiring elsewhere in the property.
Electrical Safety Inspections Before You Upgrade
An Electrical Installation Condition Report (EICR) records the condition of an existing electrical installation following inspection and testing. It can identify problems involving earthing, bonding, insulation, damaged circuits or inadequate protection.
An EICR is particularly useful before substantial renovation or where a property has an uncertain electrical history. However, it is not a guarantee that every concealed defect will be found. The electrician should inform the client of any restrictions and provide guidelines for any remedial work that must be completed before or during replacement.
Why You Need a Qualified Electrician
In England and Wales, replacing a consumer unit must comply with Part P of the Building Regulations. The work needs to be notified through a registered competent-person scheme or building control. Once the work is complete, ask your electrician for an electrical installation certificate and the relevant building regulations compliance documents.
BS 7671, commonly known as the IET Wiring Regulations, provides the technical framework for electrical installation design, construction, inspection and testing. The applicable edition and amendments should be confirmed when the work is planned.
Scotland operates a separate building standards regime. Its requirements depend on the nature of the work and whether a building warrant or other approval is needed. The Scottish Government's current technical handbooks provide guidance on electrical safety and the relevant standards.
Choose an electrician with the appropriate competence and registration for the work. Ask who will notify or certify it, what testing is included and which documents you will receive when the job is complete.
How Much Does a Consumer Unit Upgrade Cost?
A consumer unit upgrade cost depends on the board, circuit protection, existing wiring and work needed to bring the installation into a safe condition. There is no single price that applies to every UK home.
What Affects Consumer Unit Upgrades Cost and Price?
Cost guides published in 2026 generally show a simple replacement of a consumer unit at around £350 to £800. The amount increases for so-called larger houses with more circuits, an RCBO board or repair work. Different labour rates in different places also affect the final price.
The main cost factors include:
  • Number of circuits: Larger properties may require a bigger board and more protective devices.
  • Protection type: Individual RCBO protection can cost more than some shared-RCD arrangements.
  • Existing wiring: Defects, inadequate earthing or bonding and damaged cables may require additional work.
  • Access and location: Difficult access or moving the board can increase labour time.
  • Testing and certification: Confirm what inspection, testing and notification costs are included.
A sensible consumer unit upgrade price comparison should cover the same scope of work, not just the replacement box. Ask each electrician to inform you about the exclusions in their estimate and how they will charge for unexpected problems that may arise.
Note: Costs shown are indicative estimates, not quotations. Your actual consumer unit upgrade cost depends on your property, the condition of the existing wiring and your electrician. Get several itemised quotes from registered electricians.
Consumer Unit Upgrade in London, East London and Scotland
A consumer unit upgrade London quotation may be higher than one in another region because labour rates, travel and access costs vary. The same applies to a consumer unit upgrade east London project, where parking, property type and the condition of an older installation may influence the final bill.
For a consumer unit upgrade Scotland, confirm the applicable building standards and certification arrangements as part of the quotation. Do not assume the process is identical to England and Wales.
Obtain at least three comparable written quotes from appropriately registered electricians. Ask for the board specification, protective devices, testing, certification and any likely remedial work to be itemised.
How Do Solar Panels, EV Chargers, Heat Pumps and Batteries Affect Your Electrical Needs?
Adding new electrical equipment changes how a property uses and sometimes generates electricity. Before installation, a professional should assess the consumer unit, incoming supply, circuits and the equipment's connection requirements together.
Electrifying the Home: EV Chargers and Heat Pumps
The power consumption of an EV charger can be quite high for several hours and a heat pump can consume a lot of energy for a long period of time when the temperature gets very cold. If used simultaneously, an induction hob or electric shower increases the demand.
The electrician should check the supply capacity, circuit ratings, protective devices and expected simultaneous demand. Load management may help control when equipment operates, but it does not automatically remove the need for additional circuits or a consumer unit replacement.
Solar Panels and Home Battery Storage
Solar panels and batteries introduce additional equipment and connection arrangements. Depending on the design, the installation may need appropriate isolation, overcurrent protection, residual current protection, metering and arrangements for exporting electricity.
An existing consumer unit may be suitable for some systems but not others. Have an electrician and the equipment manufacturer confirm compatibility before buying. Depending on the generation or storage installation, notification or approval from the distribution network operator (DNO) may also be required. G98 and G99 are relevant UK connection procedures for certain small-scale generation installations; the applicable process depends on the equipment and proposed connection.
Managing Peaks in Household Electricity Demand
Laundry and vehicle charging combined with cooking and heating can often increase the demand within households. If the devices and household schedule permit, it is possible to shift the movable processes to other time periods.
Home energy storage can help move electricity use between charging and consumption periods, but it does not guarantee that a consumer unit upgrade will be avoided. Electrical safety, circuit capacity and the installation's design still need professional assessment.
Managing Higher Demand With Home Energy Storage
Home energy storage can complement a suitable electrical installation by storing electricity for use later. It can assist with power management when a household consumes electricity but it is not designed to take the place of the protective function of the consumer unit or correct faults in the existing power wiring.
A Flexible Battery Option for Homes Without Solar
EcoFlow STREAM 5000 is designed for households looking to establish a home energy storage setup, with a stated capacity of 5,024Wh and support for solar input. Its off-grid AC output is rated up to 3,000W, subject to operating conditions and configuration. Automatic energy-management modes can reduce the need for constant manual adjustments. Before including it in a consumer unit upgrade project, ask an electrician to assess the home's wiring, supply and proposed connections.
EcoFlow STREAM 5000
Installed home battery for homes without solar. UK rules require installation, and the setup is designed to be simple 5024Wh capacity, expandable to 90kWh with Expansion Batteries Up to 3000W AC output for high-demand appliances like stoves, dryers or kettles (when solar is generating or an Expansion Battery is paired) 5,000W solar input makes full use of your solar generation Up to 2500W AC charging for fast recharge Smart meter, main unit and solar panels are designed to connect easily, with step-by-step app guidance for setup Compact 45.9kg body with a built-in handle for easier placement during installation Residential-grade protection with pressure-release and fire-resistant materials, designed to reduce thermal runaway risk with high-voltage solar panels Rated for 10,000 cycles Local Mode keeps the system running and communicating even if the network drops
Adding Battery Storage to an Existing Solar System
EcoFlow STREAM AC 5000 is intended for households that already have rooftop solar and want to add battery storage. It can help retain surplus solar electricity for later use, with automatic energy management and expansion options within compatible configurations. The wider STREAM system can expand to a stated maximum of 90kWh when configured with supported units. Any consumer unit upgrade decision should follow an assessment of the existing system, product specifications and connection arrangements.
Installed home battery for homes with existing solar. UK rules require installation, and the setup is designed to be simple Works with existing rooftop PV systems, home battery systems and leading third-party meters 5024Wh capacity, expandable to 90kWh with Expansion Batteries Up to 3000W AC output for heavy household appliances (when solar is generating or an Expansion Battery is paired) AC coupling adds storage alongside your current solar setup, and a Gateway simplifies expanding later Compact 45.1kg body designed to fit into spaces around the home Rated for 10,000 cycles
Note: Compliant plug-in solar kits have been legal to buy and use in Great Britain since 27 August 2026. This rule does not apply to plug-in batteries or solar kits containing a battery. Devices such as the STREAM 5000 and STREAM AC 5000 are installed systems; therefore, always check what the latest government directives say and contact a specialist installer when choosing one.
A consumer unit upgrade may improve protection and prepare a home for new electrical demand, but replacement is not automatically necessary because a fuse box is old. Warning signs, extensions, new circuits and high-demand appliances are all reasons to arrange an assessment. The costs depend on the number of circuits, type of protection, the condition and location of the wiring, so compare itemised quotes and get the right inspection and certification.
EcoFlow provides home energy storage options for households planning to manage solar electricity and changing energy use. If you are reviewing your electrical system before adding a battery, explore the EcoFlow UK and discuss product compatibility and installation requirements with a qualified electrician before making a purchase.
FAQ About Consumer Unit Upgrade
Will my electricity be switched off during a consumer unit upgrade?
Yes, the supply normally needs to be isolated while the electrician replaces and tests the unit. The interruption will be determined by the complexity of the installation and any work required to ensure its success. Inquire into the length of time the supply will be unavailable, and make plans accordingly.
What happens if an electrician finds faulty wiring during a consumer unit upgrade?
Replacing the board does not repair defects elsewhere. Problems with wiring, earthing or bonding may need additional work before the installation can be safely completed and certified. Ask for the findings and any revised costs in writing.
Can I install a home battery without replacing my consumer unit?
Possibly. A replacement is not automatically required. A replacement depends on the condition of the old board, its capacity, circuit protection, and manufacturer's rules for the new battery. Have a qualified electrician confirm the suitable connection and protection arrangements before installation.
Home Solutions
