How to Get Cheap Overnight Electricity and Make Every Night Hour Count
Running the washing machine at midnight sounds like an easy way to cut your energy bill. There is a catch, though. The saving only happens when your electricity tariff charges less during those hours. Finding cheap overnight electricity starts with checking your rates, not changing your bedtime. The right deal could suit a home with an electric car, storage heaters or a large hot-water cylinder. Other households might pay more overall because their daytime rate is too high. There is also another option: home energy storage lets you keep cheaper electricity for the hours when the family needs it most.
How Does Cheap Overnight Electricity Work in the UK?
Cheap overnight electricity is power billed at a lower unit rate during specified off-peak hours. Your supplier and tariff determine when those hours begin and end.
What Counts as Cheap Overnight Electricity?
Look at your electricity bill first. If you pay one unit rate throughout the day, running appliances at night does not reduce the price per unit. You would need a multi-rate or time-of-use tariff to benefit.
With a suitable deal, electricity costs less during certain hours and more during others. That difference is the reason cheap electricity overnight attracts households looking to lower their bills.
The clock alone makes no difference. A single-rate customer who starts the dishwasher at 2 am pays the same unit rate as someone who starts it after lunch. Check your tariff before rearranging your routine.
How Economy 7 and Economy 10 Set Cheap Overnight Electricity Rates
Economy 7 gives customers seven hours of overnight cheap rate electricity in each 24-hour period. The remaining hours carry a higher rate. The off-peak window varies by supplier, location and metering arrangement. Economy 10 offers ten cheaper hours, often split between overnight and daytime periods. This can be appropriate for houses with electric heating systems and require a greater flexibility of heating water or charging storage heaters.
However, neither tariff will automatically reduce your bills. If you use very little electricity during the cheaper hours, the higher daytime rates could cancel out any savings. Before switching, compare the cheap overnight electricity rates with what you pay during the day. Ofgem also explains how multi-rate tariffs work in its guidance on electricity unit rates and standing charges.
How Smart Time-of-Use Tariffs Work
Smart tariffs use meter data to charge different rates at different times. Some offer a fixed overnight window, while others change prices according to demand or market conditions. EV owners may be subjected to tariffs that are based on overnight charging. Other offers are directed at homes equipped with heat pumps or "flexible" electricity consumption.
Before choosing a cheap overnight electricity tariff, check the hours, meter requirements and any conditions attached to the advertised rate. A deal designed for an EV owner is not automatically suitable for a household without one.
Who Can Get a Cheap Overnight Electricity Tariff?
Most households can explore time-of-use pricing, but eligibility depends on the supplier, meter and particular tariff.
Meter Requirements for an Overnight Tariff
Electricity consumption must be recorded on your meter during the applicable pricing periods. This is typically one of two Economy 7 meters or a compatible smart meter installed. A smart meter doesn't mean that you'll automatically switch to a lower nightly rate. An eligible tariff is still required and your supplier needs to correctly program the meter.
Older Radio Teleswitch Service (RTS) meters need particular attention. The RTS phase-out was completed on 31 March 2025. The system was used to assist some older meters to change from peak to off-peak rate, or to manage heating/hot water loads. Suppliers are swapping out affected meters—typically with a smart meter that has similar functionality.
If your home still has an RTS meter, please contact your supplier ASAP. The malfunctioning switching arrangement may impact your heating program, as well as your electricity bill. A cheap overnight electric tariff only works as intended when the meter records the correct usage periods and your supplier applies the agreed rates.
Which Homes Benefit Most from Overnight Rates?
Homes with electric storage heaters, immersion heaters, EVs or heat pumps get the most from overnight cheap electricity. These appliances use substantial amounts of electricity, and their operating times are easier to schedule. Consider two households. One charges an electric car overnight and heats its water before breakfast. The other uses gas for heating and does most of its cooking in the evening. The first household has more opportunities to use cheaper electricity.
If you are comparing cheap overnight electricity UK deals, check your smart-meter data where available. Your actual usage pattern tells you more than guesswork. Citizens Advice offers further help with choosing an electricity tariff, including options for households with storage heaters.
Note: off-peak hours, tariff availability and pricing vary by supplier, meter and region, and change over time. Check the Ofgem website and your supplier for current guidance before switching.
How to Compare Cheap Overnight Electricity Tariffs
The lowest advertised night rate is not always the cheapest deal. Look at the whole bill and how your household uses electricity.
Looking Beyond the Night Rate
Compare three figures: the night unit rate, the daytime unit rate and the daily standing charge. Each affects what you pay. A very low night rate looks tempting. However, the savings may be lost if the price of electricity during the day is also high and you use a lot of electricity after work. A slightly higher night rate with a lower daytime charge might produce a better result. Use your annual electricity use and what percentage of that use is at night to determine the best cheap overnight electricity tariff for your home. Compare the costs per year, as well as the upfront cost.
Length and Timing of the Off-Peak Window
Seven cheaper hours are useful only if they match your routine. If a home is late, they may end up with a window that won't be fully charged before the car is time for pick-up. Check the start and finish times, too. Some tariffs offer one continuous overnight period, while others split cheaper hours across the day. Different cheap overnight electricity tariffs suit different households. Check that your hot-water system, vehicle charger and other high-use appliances fit the available hours before switching
Contract Terms, Exit Fees and Price Changes
Fixed tariffs keep agreed rates in place for a defined period, subject to the contract. Variable tariffs allow prices to change under their terms. Read the small print before committing. Look for exit fees, contract length, payment conditions and rules for changing prices. In addition, some specialist tariffs may also demand an appropriate smart meter or a qualified vehicle.
When comparing a cheap overnight electricity tariff UK deal with your current arrangement, calculate the estimated annual cost. Include standing charges and daytime consumption. A lower night rate is no bargain if the rest of the tariff costs more.
How to Shift Your Electricity Use to the Cheapest Hours
Once you have the right tariff, small changes to your routine help you use more electricity during cheaper periods.
Running Appliances Overnight
Many washing machines and dishwashers have delay-start functions. Set them to run during the off-peak window instead of starting them straight after dinner. Check the manufacturer's instructions before leaving appliances running unattended. Keep filters clean, avoid overloaded sockets and follow all fire-safety guidance. Never leave a tumble dryer running unattended if its instructions prohibit it.
There is no need to move every household task to the middle of the night. Start with appliances that use substantial electricity and are safe to schedule. Heating water at the right time can also help where your system supports it. The simple answer to how to get cheap overnight electricity is to shift any appropriate electricity use to the cheaper hours, without making day-to-day management harder.
Charging an Electric Vehicle on Overnight Rates
An EV offers a definite chance to take advantage of off-peak electricity. It can affect the charging rate because it takes more energy to charge a car than to power most small household appliances. Schedule the car or home charger to charge at the lower-price time of day or week. Always read the schedule and compare with your supplier's actual hours, particularly if your tariff has variable rates.
Smart charging features can handle the timing automatically. Still, check whether the vehicle, charger and tariff work together as expected. When considering costs, factor in charging losses, as well as any subscription fees.
Where Overnight Savings Stop
Some electricity use is difficult to move. Families cook dinner, boil kettles, switch on lights and watch television during the evening. These activities tend to be on the higher price end. It isn't possible to change all your habits. It may be run later in the day, but no one wants to wait until late to have dinner.
That leaves a gap between when electricity is cheapest and when the home needs it. Another solution is a battery, which can be charged during the low-price hours of the day and used at night.
How Can You Use Cheap Overnight Electricity During Peak Hours?
A home battery stores electricity for later use. For households on suitable time-of-use tariffs, this creates a way to use cheaper power after the off-peak period ends.
Store Overnight Power for the Evening Peak
The EcoFlow STREAM 5000 suits households that want battery storage without an existing solar installation. Its 5,024 Wh capacity gives homeowners a starting point for storing grid electricity during cheaper hours and using it later. Automatic energy-management modes reduce the need to keep changing settings throughout the day. The system also supports compatible third-party meters, helping households coordinate energy use with their setup. For a home that struggles to shift cooking, lighting and other evening activities, the STREAM 5000 offers another way to benefit from cheap overnight electricity. Actual savings depend on the tariff, charging losses, household demand and how the battery is configured.
EcoFlow STREAM 5000
Installed home battery for homes without solar. UK rules require installation, and the setup is designed to be simple 5024Wh capacity, expandable to 90kWh with Expansion Batteries Up to 3000W AC output for high-demand appliances like stoves, dryers or kettles (when solar is generating or an Expansion Battery is paired) 5,000W solar input makes full use of your solar generation Up to 2500W AC charging for fast recharge Smart meter, main unit and solar panels are designed to connect easily, with step-by-step app guidance for setup Compact 45.9kg body with a built-in handle for easier placement during installation Residential-grade protection with pressure-release and fire-resistant materials, designed to reduce thermal runaway risk with high-voltage solar panels Rated for 10,000 cycles Local Mode keeps the system running and communicating even if the network drops
Add Overnight Storage to an Existing Solar Setup
Already have rooftop solar? The EcoFlow STREAM AC 5000 is designed for households looking to add battery storage to an existing system rather than start from scratch. It has a 5,024 Wh capacity and supports energy management for compatible setups. Households can use solar generation and suitable off-peak charging arrangements to help cover electricity demand later in the day. For people who want cheap overnight electricity alongside their existing panels, adding storage creates more flexibility over when they use the energy they have available. Check system compatibility and installation requirements before buying.
Installed home battery for homes with existing solar. UK rules require installation, and the setup is designed to be simple Works with existing rooftop PV systems, home battery systems and leading third-party meters 5024Wh capacity, expandable to 90kWh with Expansion Batteries Up to 3000W AC output for heavy household appliances (when solar is generating or an Expansion Battery is paired) AC coupling adds storage alongside your current solar setup, and a Gateway simplifies expanding later Compact 45.1kg body designed to fit into spaces around the home Rated for 10,000 cycles
Note: Rules for plug-in solar in Great Britain are new and still developing. EcoFlow STREAM 5000 and STREAM AC 5000 are home battery storage systems that need professional installation. They are not sold as plug-in solar products, and a battery does not qualify as a compliant plug-in solar microgenerator just because its setup is straightforward. Check current GOV.UK guidance and speak to a qualified installer about the requirements for your home.
Cheap overnight electricity is most beneficial where the electricity tariff is in line with the way your house uses electricity. When switching providers, check the night/daily prices, standing charge, as well as the off peak hours and contract terms. Then plan appropriate use of appliances and EV charging during the lower priced window. When avoiding the evening peak is not possible, battery storage can be an alternative.
EcoFlow offers storage options for homes starting without solar and those adding a battery to an existing setup. Check out EcoFlow UK to see the STREAM product range and determine which one will suit the energy demands of your home.
Cheap Overnight Electricity FAQs
Does cheap overnight electricity change when the clocks go back?
It depends on the tariff and meter settings. Some arrangements are based on a clock-time schedule, others begin to shift the schedule in anticipation of seasonal changes in clock time. Please refer to your suppliers' terms to ensure you are aware of the on/off peak time.
Can renters get cheap overnight electricity?
Tenants who pay the electricity supplier directly can generally choose an eligible tariff. More attention must be given when a meter changes or changes in the heating controls are made. Inform the landlord of any planned works, particularly if this will impact the building's heating and hot water.
Do overnight rates apply to the whole home or only certain appliances?
On Economy 7 and most time-of-use tariffs, the cheaper rate applies to electricity used during the off-peak window throughout the home. It is not restricted to a particular appliance. Your tariff and meter determine how consumption is recorded and billed.
