Finding the Best Solar Export Tariff UK Households Can Get From Their Panels
- How Do Solar Export Tariffs Work, and Who Can Get One?
- How Do the Leading Solar Panel Export Tariffs Compare?
- Is the Highest Export Rate Always the Best Solar Export Tariff?
- How Does Battery Storage Change the Export Tariff Decision?
- Solving Common Export Tariff Headaches With Home Energy Storage
- Conclusion
- FAQ About the Best Solar Export Tariff UK
Solar panels do not always generate electricity when a household needs it. On a bright afternoon, they might produce more power than the home is using, while demand rises again in the evening. That extra electricity can go to the grid, and an export tariff pays the household for each eligible unit supplied.
Finding the best solar export tariff UK homeowners can access takes more than choosing the highest advertised rate. Some tariff schemes will allow customers to purchase electricity from an external supplier and other tariffs will demand that you change your import supplier or use compatible equipment. This is important because if the electricity package has a higher cost to the exporter, the export package may not be as attractive.
It is also worth looking at how much solar power you use at home. An export tariff rewards surplus generation, but using that electricity yourself can reduce the amount you need to buy from the grid. Home energy storage adds another option by storing some of the daytime surplus for use later, helping households make better use of their solar generation.
The best solar export tariff UK households can access is one that fits their installation, metering arrangements and wider energy costs. For many homes in Great Britain, the Smart Export Guarantee (SEG) is the starting point.
How the Smart Export Guarantee Pays for Surplus Solar Electricity
The Smart Export Guarantee is a government-backed scheme introduced in January 2020. It requires certain licensed electricity suppliers to pay eligible small-scale generators for low-carbon electricity exported to the grid. Suppliers price their services and agree their terms of contract, and SEG payments are based on export meter readings. The tariff rate is to be kept above zero.
In practice, your payment depends on the amount of electricity you export and the rate agreed with your supplier. If, for example, 1,000 kWh were exported at 5p/kWh, the export tariff would give a £50 profit before making any other adjustments as per the tariff criteria.
When comparing the best export tariff for solar options, look at whether the rate is fixed or variable, how long the agreement lasts and whether you must buy electricity from the same supplier. The best UK solar export tariff for one home might not suit another that has different import costs or exports a different amount of electricity.
Eligibility Requirements for Solar Export Payments
Before applying for the best export tariff for solar panels, check that your system meets the supplier's requirements. Under the standard SEG framework, eligible technologies include solar photovoltaic (PV), wind, hydro, anaerobic digestion and certain micro-combined heat and power systems. The installation must be in Great Britain and fall within the relevant capacity limits.
Applicants generally need installation and installer certification through the Microgeneration Certification Scheme (MCS) or an equivalent recognised scheme. They also need a meter capable of recording half-hourly export readings, usually a suitable smart meter. You cannot receive SEG export payments for electricity if you are already receiving export payments under the Feed-in Tariff scheme.
Some suppliers offer export arrangements outside the standard SEG framework, including routes for certain installations without conventional certification. This is a deal from the supplier and not a mandate to exempt from SEG requirements. Inquire as to who the supplier and what evidence is required for your system.
Export Tariffs for Commercial Solar Systems
Businesses need to consider more than the headline payment per kWh. A search for the best commerical solar export tariff should take account of system capacity, expected export volumes, metering and the terms available to commercial customers.
A business that uses most of its solar generation during working hours has a different energy profile from a warehouse that exports large amounts of electricity at weekends. Larger installations may also need negotiated export arrangements rather than a standard domestic offer.
Avoid entering an agreement without reading through the terms in writing. The export rate, contract period, metering, settlement and all other charges should be put in the quotation. Discuss those details when contrasted with the use of electricity on-site.
The best solar export tariff UK becomes easier to identify when you compare how each deal works, not just the number displayed beside its name. Some tariffs pay a flat rate for every exported unit. Others use variable prices or time-based rates linked to market conditions.
Published rates are subject to change, so use published rates as a guideline and not a commitment to the rate you will receive for the year. Always check the terms and conditions of the offer before switching suppliers.
Fixed and Variable Export Rates Explained
A fixed export rate involves a contractual payment amount per unit over a certain time. It simplifies the calculation of earnings, but may not provide the best rates at all times. A variable tariff may alter according to the stipulations of its agreement, and a market-linked option can utilize fluctuating prices of the day.
For instance, a household which exports primarily during the middle of the day may experience a different return than a household which can export in a more valuable time period. What counts is whether the tariff is appropriate for your actual generation pattern, not just the advertised rate.
When comparing the best export tariff for solar panels UK, check how often the supplier can change the rate, how it communicates changes and whether leaving the tariff carries a fee. Predictability might matter more to one household than the chance of earning a higher payment at certain times
Standalone Tariffs Versus Customer-Exclusive Tariffs
A standalone export tariff allows you to sell surplus electricity to one supplier while buying electricity from another. A customer-exclusive tariff, by contrast, requires you to take your import supply from the same company. Some offers also depend on a compatible import tariff, battery or other equipment.
Octopus Energy provides a useful example of the difference. Its published tariff information lists its standard Smart Export Guarantee option at 4.1p/kWh, while Outgoing Octopus is advertised at 12p/kWh and requires an eligible Octopus electricity supply. These are published rates at the time of writing, and the applicable terms and prices can change.
The best solar panel export tariff is not necessarily the one with the highest headline payment. Calculate what you would pay for export earnings and compare it to the import rate and the standing charge you pay at present. While a higher export rate could be beneficial, the export numbers must justify this change.
Note: the rates shown are for illustration only. Export rates, eligibility and tariff terms vary by supplier and change over time. For the latest figures, check the supplier’s website and Ofgem’s Smart Export Guarantee guidance. |
Supplier Restrictions to Check Before You Switch
Read the tariff conditions before starting an application. A few details can determine whether a deal is practical for your home:
Import supply: Must you buy your electricity from the same supplier?
Metering: Is a smart meter capable of half-hourly export readings required?
Installation evidence: Do you need MCS or equivalent certification?
Equipment: Is a particular battery, inverter or import tariff required?
Contract terms: Is the rate fixed or variable, and are exit fees charged?
Payments: How often will you be paid, and how are export readings verified?
The best export solar tariff is one you qualify for and can use without accepting conditions that outweigh the extra income. If you need to switch in order to pay more for electricity all year round, do the calculation first.
How Octopus Export Tariffs Work in Practice
The best Octopus export tariff for solar panels depends on how the household generates, consumes and stores electricity. Octopus provides various schemes, such as flat rate export schemes, Agile Outgoing with half-hourly market prices, and battery-based schemes based on specific periods of imports/exports.
A household without a battery might favour a straightforward export rate that requires little day-to-day management. A home with a compatible battery could have more flexibility to store electricity and schedule when it imports or exports. However, a time-based tariff is not automatically more profitable: the result depends on the actual prices, equipment compatibility and how the household uses energy.
Check the tariff rules carefully if you intend to charge a battery from the grid and export electricity later. Eligibility requirements may vary and not all tariffs are equal with regards to stored grid electricity.
No. The export rate tells you what the supplier pays for electricity you send to the grid, but it does not show the full value of your solar system. You also need to consider the electricity you avoid buying, your import tariff and any costs involved in changing suppliers or adding equipment.
Why Using Your Own Solar Electricity Is Usually Worth More
Using solar electricity directly at home reduces the amount you need to buy from the grid. Generally, using a unit will save more than exporting it when import price is greater than export payment.
Imagine your panels generate surplus electricity while the washing machine is running. The appliance can use that solar power instead of drawing the same amount from the grid. If you run it after sunset, you will usually need electricity from the grid or a battery.
That is why best export tariff solar comparisons should include self-consumption. Exporting more electricity does not necessarily mean making the greatest overall saving. The relevant figure is the combined value of export payments and avoided import costs, minus the costs of any equipment or tariff changes.
What Independent Guides and Martin Lewis Say About Comparing Tariffs
People searching for best solar export tariff uk martin lewis often want a simple answer about which supplier pays the most. Independent guides, including MoneySavingExpert's solar export coverage, help explain the differences between standalone offers, customer-exclusive tariffs and deals linked to specific equipment.
Create a short list using comparison tables and refer to the supplier's own terms. Rates and conditions are subject to change and a tariff mentioned in a guide may not be available to all households. Before switching, compare the estimated annual export income with the likely annual cost of your import electricity under each option.
A quick maths calculation will help. Estimate the number of units you will export annually, multiply it by the proposed export rate, and compare it with what you are currently doing. Subsequently adjust for import rates and standing charges. This will provide a more accurate picture than export rate alone.
Matching a Tariff to How Your Household Uses Electricity
The best solar export tariff for your home depends partly on when you generate and consume electricity. If someone is home during the day, they might use more solar power for cooking, laundry or other appliances. A household where everyone is out until evening may export more of its daytime generation. Electric vehicle owners have another option: charging during sunny hours can use surplus electricity, while an appropriate time-of-use tariff might make overnight charging more economical.
Where possible, use smart-meter readings and your inverter's generation data to estimate monthly imports and exports. The amount of data you export in the summer is in contrast to what happens in the winter when generation is typically lower. A tariff that seems to be a good deal in the summer could end up with a different yearly figure.
A home battery changes when solar electricity is available for use. Instead of exporting every surplus unit as soon as it is generated, the system can store some of that energy for the evening or another period when household demand is higher.
Whether this improves the household's finances depends on the tariff, battery efficiency, installation cost and how often the stored electricity is used.
Why Surplus Solar Electricity Is Exported at the Wrong Time
The demand for electricity at home is likely to be high before going to work, during mealtimes and after dark, whereas solar generation tends to be highest at midday. If there is an excess, the electricity can be supplied to the electricity grid.
This mismatch helps explain why best export tariffs for solar should be assessed alongside household demand. An export payment is useful, but storing a unit and using it later could avoid buying a replacement unit at a higher import price.
The difference is not guaranteed. Batteries lose some energy during charging and discharging, and the savings must be weighed against the cost of purchasing and installing the equipment.
Shifting Surplus Energy to Periods of Higher Demand
A battery stores excess solar generation for use when the panels are producing less. That can increase the share of solar electricity consumed at home and reduce grid imports.
Some tariffs also reward exports at particular times or use half-hourly prices. For households considering best export tariffs for solar panels, the question is whether the potential extra income from exporting at selected times outweighs the benefit of keeping electricity for household use. Battery controls, tariff rules and energy prices all affect the answer.
Review your usage before choosing a battery size. A system that is too small might not cover much of your evening demand; if it is too large, you may spend too much on the additional savings. The objective is to provide storage that is adequate for consumer demands and requirements.
How System Configuration Affects Tariff Eligibility
Adding a battery changes how electricity moves around a property. Depending on the installation, it can affect the inverter arrangement, meter readings and the way exports are recorded.
Before changing an existing system, ask your export supplier whether the proposed battery and its operating settings affect eligibility or payments. Some homes are excluded from an export tariff for a battery, but installation and metering requirements must comply with the applicable conditions.
Anyone comparing the best solar panel export tariff UK should confirm compatibility before buying storage. This can be answered early and can avoid unnecessary changes to installation and export registration.
Home energy storage gives households another way to manage surplus solar electricity. It can be useful when generation is high during the day but household demand peaks later, especially if the cost of imported electricity is considerably higher than the export payment.
Still, a battery is not a guaranteed route to a better financial return. Tariff rates, household consumption, battery efficiency, installation costs and system settings all affect the result. Export eligibility also depends on the full installation, not simply on the presence of a battery.
Planning Home Energy Storage for Households Exploring Solar
For households planning solar panels and storage together, the EcoFlow STREAM 5000 is an option to assess when deciding how to use more generated electricity after daylight hours. When comparing the best solar export tariff UK options, consider how much surplus could be stored and used at home rather than exported and later replaced with grid electricity. Its 5 kWh storage capacity provides a starting point for evening use, with expansion options for households that need more capacity. The likely benefit still depends on daily consumption, system configuration and the difference between import and export rates.
Adding Battery Storage to a Home That Already Has Solar
For a household with existing rooftop solar, the EcoFlow STREAM AC 5000 is designed for adding battery storage to an established system. It offers another way to make use of daytime surplus later, rather than exporting every available unit at the prevailing rate. When assessing the best solar export tariff UK, confirm that the proposed battery arrangement, metering and supplier terms work together before making a purchase. Compatibility with existing rooftop PV systems and mainstream third-party meters, along with Gateway-supported expansion options, can help with planning, but a qualified professional should still assess the installation.
Note: Rules for plug-in solar in Great Britain are new and still developing. EcoFlow STREAM 5000 and STREAM AC 5000 are home battery storage systems that need professional installation. They are not sold as plug-in solar products, and a battery does not qualify as a compliant plug-in solar microgenerator just because its setup is straightforward. Check current GOV.UK guidance and speak to a qualified installer about the requirements for your home. |
The best solar export tariff UK households can get depends on more than the advertised rate. Eligibility, supplier restrictions, import costs, contract terms and daily electricity habits all affect the final return. Standalone tariffs provide flexibility, and exclusive deals for customers might be more expensive with extra terms. Also, solar electricity at home may be more valuable than export and battery storage should be considered when looking at tariff comparisons.
EcoFlow's home energy storage options give households another way to manage surplus solar generation and use more of their own electricity later in the day. Explore the EcoFlow UK to compare storage options and plan around your home's energy needs.
How do you check you are being paid correctly for the electricity you export?
Compare your supplier statement with the export readings in your account or smart-meter data. Check the billing period, number of units and agreed rate. If the figures do not match, contact the supplier and ask for a breakdown of the readings and calculation.
Is solar export income taxable in the UK?
Tax treatment depends on the circumstances, including how the electricity is generated and whether the activity forms part of a business. Do not assume that every arrangement receives the same treatment. Review the relevant GOV.UK tax guidance or speak to a qualified tax adviser if you are unsure how the rules apply to you.
How do you apply for a Smart Export Guarantee tariff?
Choose a supplier and read its application requirements. You will generally need details of your generating system, relevant certification and meter information. Submit the required documents and wait for the supplier to confirm that your application has been accepted. Start with Ofgem's Smart Export Guarantee guidance, then follow the chosen supplier's instructions.
