The Best Power Banks for Samsung: Fast Charge All Devices
With cutting-edge technology and reliability, Samsung devices have become a top choice for millions worldwide. Having a reliable power bank is crucial to keep these powerful devices always charged on the go. In this blog, we’ll guide you through the selection process by exploring the best power banks for Samsung. We’ll also provide valuable insights on choosing the best one for your needs. Keep reading the ultimate guide to preparing your Samsung devices powered up at any time.
5 Best Power Banks for Samsung Devices in 2025
We’ve rounded up the best power banks for Samsung to keep your phone charged and ready, so you’re always powered up on the go. Read on!
1. EcoFlow RAPID Pro Power Bank (27,650mAh, 300W, 140W Built-in Cable)– Best Overall Power Bank for Samsung
The EcoFlow RAPID Pro Power Bank (27,650mAh, 300W, 140W Built-in Cable) is compact yet powerful. Boasting a 27,650mAh (99.54Wh) capacity, it meets air travel regulations and is effortlessly portable. Equipped with a USB - C port capable of up to 140W output, it lets you enjoy the ultimate convenience of rapidly charging devices like phones, tablets, and other accessories.
What makes it the best overall power bank for Samsung?
  • Ultra - fast Charging Speed: Charges to 80% in just 20 minutes.
  • 300W Multi-Device Parallel Charging: Compatible with 99% of daily electronics, it supports simultaneous fast charging for up to 4 devices—no waiting required.
  • Built-in 65W/140W Data Cable: The USB-C port supports a maximum output of 140W, meeting the high-power charging needs of laptops. The built-in cable can also be paired with a 65W GaN charger.
  • 60cm Built-in Integrated Cable: No need for extra charging cables—simply pull out the cable to charge, streamlining your travel essentials.
  • Smart Interaction: The intelligent LCD screen displays real - time power and output status. The companion app lets you enable battery optimization mode, extending both the power bank’s and your device’s battery life during charging.
The EcoFlow RAPID Pro Power Bank (27,650mAh, 300W, 140W Built-in Cable) stands out with its sleek design and robust performance. Its compact, portable form factor, paired with a 27,650mAh (99.54Wh) capacity, fully complies with aviation travel standards—ensuring worry-free charging during trips. Notably efficient, it reaches 80% charge in just 20 minutes, drastically cutting waiting time. For power output, it supports 300W multi-device charging: the 140W USB-C port is tailored for high-drain devices like laptops, while the four-port configuration flexibly meets fast-charging needs across various gadgets.
2. Samsung Galaxy Official 20,000 mAh Battery Pack – Best Samsung Power Bank
Though Samsung is famous for its well-made smartphones and other electronics like tablets, laptops, displays, etc., it also produces self-branded power banks. If you’ve owned higher-end Samsung phones, the Samsung 45W 20,000mAh battery pack is a reliable choice to power up. Just keep in mind: the 45W is the maximum charging input allowed for phones. Meeting the PPS Power Delivery standard, you can charge multiple devices simultaneously with this Samsung power bank.
What makes it the best power bank made by Samsung?
  • Massive capacity at 20,000mAh to charge Samsung phones multiple times.
  • Samsung Super-Fast Charging 2.0 technology allows you to charge your device in a flash.
  • The Triple-Port design gives you added convenience and power to charge 3 devices at once.
  • The 5A USB C cable is included. You can charge on the go.
3. Baseus Airpow Power Bank – Best Budget-friendly Power Bank for Samsung
If you’re on a tight budget, the Baseus Airpow Power Bank 20W 10000mAh could be the most suitable power bank for your Samsung devices. This portable charger is designed for speed and efficiency in a compact package, ideal for users on the move. Whether you’re on a trip or in need of a swift energy boost, it consistently provides reliable performance without straining your finances.
What makes it the best budget Samsung power bank?
  • Pack 10,000mAh capacity in the slim design.
  • 20W fast charging to power up your Samsung device.
  • Get the power bank back to full battery with the 18W recharging input.
  • A 30cm/1ft USB A to USB C cable is included for each power bank.
4. Anker Nano Power Bank – Best Portable Power Bank for Samsung
If you need a true power bank charger for Samsung phones, look at Anker Nano Power Bank (30W, Built-In USB-C Cable). Measuring only 4.09 × 2.06 × 1.02 inches, it can be put in your pocket effortlessly. Though compact, it still has a great 10,000mAh capacity. You can also benefit from the built-in USB-C cable for 30W input and output.
What makes it the true portable power bank for Samsung devices?
  • The compact design is easy to put in the pocket, measuring only 4.09 × 2.06 × 1.02 inches.
  • 10,000mAh worry-free power to charge Samsung phones several times.
  • 30W bi-directional charging to power up your phones, tablets, and laptops as well as recharge the power bank to 50% in just 45 minutes.
  • Stay informed for detailed charging information with a vibrant color display.
5. CUKTECH 20 Power Bank – Best Power Bank for Samsung Laptops
With a 25,000mAh capacity, the CUKTECH 20 Power Bank can charge devices quickly and is the best power bank for Samsung laptops. Besides the fastest 140W USB-C port, the other USB-C port can also reach 45W. This output is nearly as powerful as a traditional plug-in charger, making it possible to charge a laptop without a charger. What’s more, there is another USB-A connection. You can charge three Samsung devices at the same time.
What makes it the true portable power bank for Samsung laptops?
  • Massive 25,000mAh capacity for long flights or road trips. You can even charge your laptop and phone while camping, without worrying about low battery.
  • Ultra-speedy 110W input to recharge the power bank in no time. Just 19 minutes for a 40% boost and around 2 hours for a full charge.
  • Built to last with over 1000 charge cycles due to an auto-grade battery
  • The intuitive TFT display showcases real-time battery level, power, voltage, and current.
How to Choose the Best Power Bank for Your Samsung Device?
To pick out a good power bank for Samsung device, take the following key factors into account.
  • Capacity: The battery capacity determines how many times you can charge your Samsung devices. Choose a power bank with a capacity that suits your needs. For example, a 10,000mAh power bank is recommended for daily use because it can charge a Samsung Galaxy S21 approximately 2 times, while a 20,000mAh unit offers more charges for longer trips or multiple devices.
  • Compatibility: Samsung smartphones use the USB PD 3.0 standard with PPS for fast charging. Ensuring the power bank supports this fast-charging standard will maximize charging efficiency.
  • Output Ports: It would be better if a power bank could charge different Samsung devices simultaneously. So, look for a power bank with at least a USB-C and a USB-A port.
  • Portability: Check the size and weight carefully before purchasing. Slim and lightweight models are ideal for everyday carry while larger models are suitable for outings. When choosing between a portable power station vs a power bank, keep in mind that power stations are typically larger and heavier, offering more power for extended use.
  • Safety Features: Check for safety features like overcharge protection, short circuit protection, and temperature control to ensure the safety of your device.
This blog highlights 5 of the best power banks for Samsung devices, including the best overall, budget-friendly, portable, and laptop-compatible options. It also offers practical advice on selecting the best one by considering key factors like capacity, compatibility, safety features, and more. Read to pick the best of the best to keep your Samsung devices charged at all times!
Which power bank is best for Samsung?
The EcoFlow RAPID Pro Power Bank (27,650mAh, 300W, 140W Built-in Cable) is ideal for Samsung Android devices and beyond. With a 27,650mAh (99.54Wh) capacity and a 300W four-port configuration, it flexibly meets fast-charging needs for a wide range of devices—reaching 80% charge in just 20 minutes to minimize waiting time. Featuring a 140W USB-C port tailored for high-power devices like laptops, it offers versatile charging solutions for diverse scenarios.
Which brand of power bank is the best?
EcoFlow ranks among the top power bank brands, renowned for its innovative designs, high-performance outputs, and reliable power solutions. The newly released EcoFlow RAPID Pro Power Bank (27,650mAh, 300W, 140W Built-in Cable) distinguishes itself with a compact form factor and robust performance, delivering reliable and efficient charging for Apple, Samsung, and other Android devices. EcoFlow's superior quality and charging performance make it a trusted choice for users seeking dependable power solutions.
Can I charge my Samsung phone with a power bank?
Yes, you can charge your Samsung phone with a power bank. Just make sure the power bank you choose meets Samsung’s fast charging standards (USB PD 3.0 with PPS). There are so many choices from Samsung and other reliable producers. Among them, the EcoFlow RAPID Pro Power Bank (27,650mAh, 300W, 140W Built-in Cable) stands out as one of the best overall power banks for Samsung.
Power Banks
