The Best Power Banks for Apple in 2025: Charge Everywhere
As the Apple ecosystem evolves, the latest Apple devices are no longer limited to its lightning charging but now support USB-C ports and innovative features like MagSafe for magnetic charging. This expands the options for Apple power banks. With so many choices, which one is the best power bank for Apple? After reading this blog, you’re sure to get the answer. Here we’ve compiled 7 top portable chargers from industrial-leading producers. Read on to discover the best solution and say goodbye to low-battery anxiety!
7 Best Portable Battery Chargers for Phones in 2025
As we all know, you can charge iPhone 15 and later models with a USB-C cable. Therefore, a portable battery with a USB-C port can be used for both iPhones and Android phones. The following 7 portable battery chargers are more than the best power banks for Apple iPhones but for all phones.
1. EcoFlow RAPID Pro X Power Bank (27,650mAh, 300W)
The EcoFlow RAPID Pro X Power Bank (27,650mAh, 300W) redefines mobile charging with its fusion of ultra-portability and aviation-compliant design. Boasting a 27,650mAh (99.54Wh) capacity that strictly adheres to international aviation regulations, it ensures seamless air travel while its compact form factor—enhanced by a detachable magnetic shell—caters to both business pragmatism and personal style preferences.
Its standout feature lies in unparalleled charging velocity: leveraging a 320W charging station, it achieves 80% charge in merely 20 minutes. The 300W total power output, distributed across a versatile four-port configuration, supports simultaneous fast charging for laptops, smartphones, and tablets. The dedicated 140W USB-C port is engineered for high-drain devices like MacBook Pros, ensuring optimal performance even for power-hungry electronics.
Safety and durability are equally prioritized: the X-Guard chip continuously monitors battery vitals, complemented by a 3,000-cycle lifespan and 10-year warranty for long-term reliability. The integration of a smart LCD screen and EcoFlow APP enables real-time battery diagnostics and remote charging optimization, revolutionizing mobile power management across efficiency, safety, and convenience.
This power bank combines compact design with robust power, featuring a 27,650mAh (99.54Wh) capacity that fully meets air travel standards for effortless portability. Its charging efficiency truly impresses: with the EcoFlow RAPID Pro 320W charging station, it reaches 80% charge in just 20 minutes. Equipped with 300W multi-device charging via 3 ports, it supports simultaneous fast charging for multiple devices. The smart LCD screen allows real-time power status monitoring, while the EcoFlow app enables intelligent power control to extend the battery life of both the power bank and your devices during charging.
2. Belkin BoostCharge Pro Magnetic Power Bank with Qi2 15W 8K
The Qi2 certification makes Belkin BoostCharge Pro Magnetic Power Bank a good power bank for iPhones and other Qi2-enabled devices, with charging power up to 15W. Moreover, it has overcharge protection which keeps the battery healthy and delivers safe charging. What impresses us most is the Belkin’s design. The rectangular shape is perfect. It does not block the camera even when in use. The light-colored circle on the product indicates which side has the magnetic induction coil, making it easier for first-time users to start with. Better still, you can charge 2 devices simultaneously through the wireless and USB-C ports. Belkin also provides a USB-C to USB-C cable, saving you money for extra cable purchases.
3. UGREEN 300W 48000mAh Portable Charger Power Bank
Outdoor enthusiasts who need to stay out overnight often encounter the choice between a power station vs power bank. Then, this power bank emerges as the best option. The massive 480000mAh battery capacity is built to fill the gap between a mini power bank and a full-scale power station. Because there are 5 ports (2 for USB-A and 3 for USB-C), you can charge laptops and phones while camping, without worrying about power runout. It comes with a handle design. So, you can carry it everywhere like a small suitcase or pack it in your car. The 3 LED lights are another feature that makes it suitable for outdoor use. Besides regular high and low light, the SOS light is also available, making it more practical in case of emergency.
4. Shargeek 170
Shargeek 170 catches the eye of tech geeks for a full sense of technology at first sight. Applying IP66 dust-and-water-resistance materials, its triangular transparent design is inspired by the prism on the cover of Pink Floyd’s seminal album “Dark Side of the Moon”. You can see through the charging components inside while catching the charging process, power status, temperature alerts, and more on the large display. Moreover, even if all 3 ports (2×USB-C, 1×USB-A) are in use, you can still get up to 65W fast charging through any USB-C port. The 6 durable electric vehicle-grade batteries offer 24000mAh capacity and are built to last for years. It can maintain 80% capacity even after charging more than 800 times. If you want a durable power bank for iPhones and iPads, try it.
Shargeek 170
5. INIU SnapGo P73-E1 Wireless Charger Qi2 30W 10000mAh
If you prefer a slim model, you can’t go wrong with the INIU SnapGo P73-E1, which claims to be the slimmest magnetic power bank for iPhones and other devices available today. The exclusive TinyCell technology easily packs a 10,000mAh capacity into a 0.5-inch design, making it a real mini portable battery charger that can be put into your pocket. Thanks to the newest Qi2 certification, it can charge wirelessly up to 15W. With a cable, the output can be 30W. That is, depending on wired/wireless charging, your iPhone 16 will have a 39% or 50% charge in less than half an hour. The stand integrated into its compact body is another bonus. You can use it for video calls or audio/video entertainment, as well as easy access to StandBy mode.
6. 10000mAh Mi Power Bank 3 Ultra Compact
The 10000 mAh Mi Power Bank 3 is a compact and efficient portable battery charger. Weighing about 200g, you can easily put it in your pocket and even take it on air. This makes it a perfect choice if you are frequently on business. It has an impressive 22.5W fast charging capability and supports bi-directional fast charging. This reduces the time for self-charging. Plus, with the USB-A and USB-C ports, you can charge up to three devices at the same time. By tapping the “Check Battery” button twice, you can also activate the low-current charging for headphones, bands, earbuds, etc., making it an ideal power bank for iPhone and Apple watch. This can do a lot of good to the battery life of these low-current devices.
7. Anker PowerCore 10000 PD Redux
If you just need an easy-to-carry power bank without wireless charging, give this one from Anker a try. The 10,000mAh battery, compact size, and additional carrying strap make it a great travel companion. You can either carry it on your hands or keep it in the bag. This large-capacity power bank has two ports. One is USB-A with a maximum charging power of 12W; the other is USB-C, which uses Anker’s PowerIQ 3.0 charging technology and can output a maximum power of 25W for fast charging. It also has Anker’s unique low-current charging mode for low-power devices. This is the best way to avoid overcharging and can help extend the battery life.
What to Look for in a Portable Battery Charger for Phones
Choosing the right power bank ensures your Apple devices stay juiced up without compromising convenience and safety. Here’s a breakdown of key factors you should consider.
  • Battery Capacity: The battery capacity determines how many charges your phone gets. The higher the capacity, the more power you can get for devices. For example, a 6000mAh capacity can charge your smartphone 1.5 times, while a 10000mAh one can charge about 2 times.
  • Magnetic/CableCharging: Charging with a cable is the traditional way. If you expect for convenience of wireless charging, choose one with Qi certification (better for Qi2). This means the power bank can charge iPhones and Qi2-enabled devices safely.
  • Compatible Ports: Portable battery chargers can be used for more than phones. The USB-A/USB-C ports are a must if you want to charge laptops and phones while camping, or quickly recharge the power bank. Consider one with at least one Type-A and one USB-C port for charging different devices simultaneously.
  • Portability: It refers to the shape, dimensions, weight, etc. of a portable battery charger. Decide it by asking yourself where you will use the product most often. For example, when you want to put it in a pocket, a smaller one would be better while a large one is acceptable for a road trip.
  • Safety: Features like overcharge protection, short-circuit prevention temperature control, etc. are essential for protecting your devices.
Thanks to the compatible USB-C connector, the rules to choose the best power bank for Apple go with most smartphone portable battery charger selections. When comparing options like a power station vs power bank, the diverse options and breakdowns of key considerations outlined in this blog will help you find the perfect power bank for your needs. Whether you want to charge your Apple device or any other smartphone, tablet, or laptop, bookmark this post to keep your devices powered up with the best portable chargers of 2025!
Is 5000 mAh better than 10,000 mAh?
It depends. Generally, 5000hAh can charge your phone once. It is enough for several hours of out. However, if you need to charge your devices more than once, a 10,000mAh power bank is better.
Which power bank is better, 10,000mAh or 20,000mAh?
It is not a yes-or-no question. Typically, a 10,000mAh power bank can charge your phone twice. It is enough for all day out even for heavy users. However, if you need extended charging for multiple devices or longer trips, a 20,000mAh power bank is the better option.
Is a 7000mAh power bank good?
Yes, a 7000mAh power bank is a good choice for daily use or short trips. It can charge your phone once or twice, which can meet the demands of all-day moderate use.
Power Banks
