Best MagSafe Power Banks to Keep Your iPhone Fully Charged
Tired of running out of juice on your iPhone while on the go? A MagSafe power bank might just be your best friend. Designed specifically for the latest iPhones, these handy gadgets snap magnetically to the back of your phone, delivering efficient and reliable charging. But with so many options, how do you pick the perfect one? We've rounded up some of the best MagSafe power banks available in the UK right now, so you can keep your phone charged and your worries at bay!
How to Choose the Right MagSafe Power Bank for You?
Not all MagSafe power banks are created equal, especially when it comes to charging speed, capacity, and everyday usability. Here’s what to look for before buying one that actually fits your iPhone needs and lifestyle.
1. Check Wireless Output Speed: iPhones support up to 15W MagSafe charging, but some models offer less than that. Go for 15W if you want faster top-ups, especially for iPhone 13 and newer.
2. Capacity Matters: A 5,000mAh bank gives you roughly one full iPhone charge, while 10,000mAh can cover 1.5–2 charges depending on your model. Useful for travel or long workdays.
3. Magnetic Strength: Look for N52 magnets or Qi2-certified alignment to avoid slipping, especially when using the phone while charging.
4. Wired Charging Can Be Much Faster: The best MagSafe battery pack comes with a USB-C port, which will charge your iPhone significantly faster than wireless charging, ideal when you're in a hurry.
5. Travel and Airline Rules: Power banks under 27,000mAh (or 100Wh) are allowed in carry-on luggage. Always check the specs if you're flying.
Best MagSafe Power Banks UK
Finding the best MagSafe portable charger isn't always easy. That's why we've selected the top models you can trust for performance, convenience, and compatibility. Let’s take a closer look at them.
EcoFlow RAPID Mag Power Bank
The EcoFlow RAPID Mag Power Bank(10,000mAh,7.5W, MagneticCharging) packs plenty of juice in a surprisingly sleek and slim body, perfect for your daily routine. Its 10,000mAh capacity gives you around one and a half full charges for most iPhone models, which is more than enough to get through a heavy day or two without hunting for a socket. The built-in adjustable stand is a thoughtful addition, ideal for watching videos or video calls while your phone charges.
EcoFlow RAPID Mag Power Bank (10,000mAh)
The EcoFlow RAPID Mag Power Bank delivers practical, no-fuss charging in an ultra-slim design that’s easy to carry and comfortable to hold. With a 10,000mAh capacity, it gives most iPhones about 1.5 full charges—ideal for day-to-day use. It supports 7.5W wireless charging and up to 30W via USB-C, with stable performance thanks to EcoFlow’s X-Cooling tech. Strong N52 magnets keep it securely attached to your phone, while the foldable, adjustable stand adds hands-free convenience when needed. A reliable pick for anyone who wants solid MagSafe-compatible charging without bulk or complications.
Wireless charging is handled at up to 7.5W, which is solid for casual top-ups, and if you need speed, the 30W USB-C port is there for fast wired charging. The N52 magnets keep things securely aligned, while EcoFlow’s smart cooling tech helps maintain safe temps during extended use.
Main Features:
  • 10,000mAh battery capacity
  • 7.5W wireless + 30W USB-C charging
  • Ultra-slim, lightweight design
  • Reliable magnetic attachment (N52 magnets)
  • Adjustable multi-angle stand
  • Intelligent cooling technology for safer charging
EcoFlow RAPID Mag Qi2 5K
The EcoFlow RAPID Mag Qi2 5K is the ideal power companion for busy, on-the-go lifestyles where quick, reliable charging is crucial. With 5,000mAh, it’s compact enough to slip effortlessly into a pocket yet robust enough to recharge your phone swiftly via its 15W wireless charging, twice the speed of standard Qi chargers.
What sets this model apart is its built-in 30W cable, letting you ditch extra cords entirely. Plus, its speedy recharge feature means it goes from empty to 70% charged in just about half an hour, perfect for last-minute power-ups as you dash out the door.
Main Features:
  • 5,000mAh battery capacity
  • Fast 15W Qi2 wireless charging
  • Integrated 30W cable for ultra-fast wired charging
  • Rapid self-recharge (0–70% in under 33 mins)
  • Compact, travel-friendly design
EcoFlow RAPID Mag Qi2 10K
EcoFlow RAPID Mag Qi2 10K effortlessly combines serious power with versatile features, tailored perfectly for those who need maximum functionality on the move. With a robust 10,000mAh capacity, this model can recharge your phone one and a half times, or even give your MacBook Air a substantial boost of extra hours, thanks to its powerful 65W output.
The standout feature here is the interactive digital screen, letting you effortlessly monitor charging details and even activate a battery-health mode to prolong your device's lifespan. Add in the built-in adjustable stand for easy hands-free viewing, and it’s clear this is an all-rounder that ticks every box.
Main Features:
  • 15W Qi2-certified wireless charging
  • Powerful 65W wired charging (supports laptops)
  • Digital display with smart app monitoring
  • Built-in stand for hands-free convenience
Bonus Tips: High-Capacity Chargers Worth Packing
If you’re someone who travels frequently or uses power-hungry devices, these high-output power banks from EcoFlow are well worth a look. While they don’t have MagSafe, they bring serious charging muscle to your iPhone, iPad, MacBook, and more.
EcoFlow RAPID Pro Power Bank
The EcoFlow RAPID Pro Power Bank(27,650mAh,300W,140W Built-in Cable) is EcoFlow’s top-tier portable charger for users who demand maximum power in a single unit. With a 27,650mAh capacity and a built-in 140W retractable USB-C cable, it’s designed to handle high-demand charging, like juicing up a MacBook Pro or fast-charging your iPhone multiple times over. The large color LCD gives you real-time power stats, and with support for up to 300W output when using multiple ports, it’s made to multitask.
Behind the scenes, EcoFlow’s X-Guard chip monitors heat and performance constantly, ten million times a day, to be precise, so even at full tilt, your devices stay protected. The Slow-Charging Mode is a thoughtful bonus for maintaining laptop battery health, especially during long work sessions.
Main Features:
  • 27,650mAh ultra-high capacity
  • 140W retractable USB-C cable
  • Up to 300W multi-port output
  • Full-color LCD screen with detailed stats
  • App control for settings and monitoring
  • Advanced thermal and battery protection
EcoFlow RAPID Power Bank
With a slightly smaller 25,000mAh capacity, the EcoFlow RAPID Power Bank(25,000mAh 170W) is still more than enough for most users who want to power a few devices confidently throughout the day. It supports 140W charging through a single port and up to 170W when using more than one device, perfect for pairing an iPhone with a tablet or laptop without slowing anything down.
Its compact, cylindrical shape makes it easy to slip into a bag or carry-on, and it’s fully compliant with airline battery size limits. You also get a crisp TFT display showing current charge and power use, along with EcoFlow’s proven X-Guard safety system that performs millions of thermal checks daily for dependable performance.
Main Features:
  • 25,000mAh capacity (air travel approved)
  • Up to 170W total multi-port output
  • 140W single-port fast charging
  • Slim cylindrical design
  • TFT display with real-time info
  • X-Guard chip with 8M daily thermal checks
A good MagSafe power bank keeps your iPhone going when you’re out and about, so you’re not stuck with a dead battery at the worst time. When choosing the best MagSafe power bank, consider what matters most—battery capacity, portability, charging speed, and any helpful extras. Some models are small and light for everyday use, while others deliver more power for longer days away. EcoFlow offers reliable options across this spectrum, giving you solid wireless performance and enough juice to support more than just your phone when you need it.
Why did Apple discontinue MagSafe Powerbank?
Apple quietly discontinued its MagSafe Battery Pack in 2023, likely to make room for newer accessories that align better with updated iPhone models and charging standards like Qi2. It may also reflect Apple’s shift toward USB-C and broader ecosystem changes. While the original MagSafe power bank was convenient, third-party options now offer faster charging, higher capacity, and more features, giving users more flexible choices than before.
Is MagSafe powerbank safe for iPhone?
Yes, MagSafe power banks are designed specifically for safe charging of iPhones. Trusted brands include safety features such as overheating protection, short-circuit prevention, and automatic power cut-offs, ensuring that your iPhone battery stays healthy while providing reliable and secure charging every time you use it.
How long does a MagSafe powerbank take to charge an iPhone?
The charging time for an iPhone using a MagSafe power bank can vary depending on the power bank's capacity and the iPhone model. On average, a MagSafe power bank can fully charge an iPhone 13 or later in about 2.5 to 3 hours. However, for faster charging, a higher capacity power bank or a direct connection to a higher-wattage charger is recommended.
Power Banks
