The Best Power Bank for iPhone in 2025: Top Picks for Fast Charging and Long Battery Life
In 2025, iPhones continue to dominate the smartphone market, but even the latest models can’t escape the occasional battery drain. Whether you’re a frequent traveler, a busy professional, or an outdoor enthusiast, a reliable iphone power bank is essential. This guide highlights best power bank for iphone, factors to consider when buying one, and answers to common questions.
5 Best Power Banks for iPhone in 2025
From MagSafe-compatible models to high-capacity power banks that double as laptop chargers, we’ve tested and ranked the best power bank chargers for iPhone to keep your devices powered up. Below, discover our top 5 picks for the best power banks for iPhone in 2025.
EcoFlow RAPID Magnetic Power Bank
The EcoFlow RAPID Magnetic Power Bankis the ultimate power solution for iPhone users in 2025, combining high capacity, fast charging, and innovative features. Here’s why it stands out:
- Cutting-Edge Wireless Charging
With a 10,000mAh capacity, it offers ample power. Its Qi2-certified 15W wireless charging is twice as fast as Qi1’s 7.5W, providing quick and safe top-ups for on-the-go use.
- Magnetic Convenience and Compatibility
Designed for iPhone 16 series, it magnetically attaches to MagSafe cases and doubles as a foldable stand with upright and side-view modes, perfect for hands-free use.
- Ultra-Fast Wired Charging
The USB-C port supports 30W wired charging, compatible with iPhones and MacBooks, making it versatile for both mobile and desktop devices.
- Smart Digital Display and App Control
Equipped with a smart digital display and app control, users can monitor charging speed, activate “Healthy Charging Mode” to extend battery life, and locate the power bank with a built-in buzzer.
- Advanced Thermal Management
An advanced cooling system ensures efficient heat dissipation during fast charging, preventing overheating and extending the power bank’s lifespan.
- Sleek and Travel-Friendly Design
Compact and easy to carry, it balances robust features with a sleek design. Though slightly bulkier than competitors, its superior functionality makes it a worthwhile investment.
Anker MagGo Power Bank
Anker’s MagGo Power Bank (10K) combines 10,000mAh capacity with a strong magnetic grip for seamless wireless charging. It delivers 15W via Qi2 and 30W via USB-C, ideal for fast iPhone 16 charging. The integrated stand enhances usability for desk setups, and its slim profile (0.58 inches thick) makes it easy to carry. However, its glossy finish attracts fingerprints, and wireless charging speeds lag behind wired options. For those looking to charge phone and laptop while camping, this power bank provides the perfect balance of power and portability, especially if you’re outdoors and need to keep multiple devices running simultaneously.
Mophie Powerstation Plus Mini
For USB-C iPhone users, the Mophie Powerstation Plus Mini offers 5,000mAh capacity and a built-in USB-C cable for 20W fast charging. It’s ultra-compact and supports pass-through charging, letting you recharge the power bank while topping up your phone. A larger 10,000mAh version is available, but it’s bulkier.
Baseus Magnetic Foldable Power Bank
This budget-friendly MagSafe alternative features 10,000mAh capacity and a foldable kickstand. While it lacks Qi2 certification, its magnets are strong enough to hold an iPhone 15 Pro Max in landscape mode. The 20W USB-C port ensures fast wired charging, and its lightweight design makes it ideal for travel.
Anker 733 Power Bank
A powerhouse for multi-device users, the Anker 733 includes a 10,000mAh battery and a built-in 65W wall charger. It can refill an iPhone 16 twice and even charge a MacBook Air. The dual USB-C ports and USB-A port cater to all devices, though its weight (320g) limits portability.
What to Look for When Choosing Power Banks for iPhone
When choosing the best power bank for iphone, you need to consider the following key factors:
Charging Speed and Compatibility
iPhones require specific wattages for optimal charging:
- Lightning iPhones: 12W–20W via USB-C-to-Lightning cables.
- USB-C iPhones: 20W–30W for fast charging.
- MagSafe/Wireless: 7.5W (standard Qi) or 15W (Qi2/MagSafe).
For the iPhone 16 series, aim for 25W+ chargers to future-proof your setup.
Capacity vs. Portability
- 5,000mAh: Compact but only ~1 full iPhone charge.
- 10,000mAh: Balances capacity and size, providing ~2 charges.
- 20,000mAh+: Ideal for travel but heavier.
The high-capacity power bank like the Anker Prime (27,650mAh) suits extended trips but isn’t pocket-friendly.
Wireless vs. Wired Charging
MagSafe chargers like the RAPID magnetic power bank offer convenience, while wired options (e.g., USB-C PD) are faster. Hybrid models with both capabilities provide flexibility.
Safety and Durability
Avoid “voltage traps” by prioritizing certified chargers with:
- High conversion rates (≥90%) to minimize energy loss.
- Multi-protection systems (overcharge, short-circuit, temperature control).
- Quality battery cells (e.g., LG, Panasonic) for longevity.
Budget Considerations
- Under £30: Basic 5,000mAh models (e.g., Baseus Airpow).
- £50–£100: Mid-range options with MagSafe or 30W+ speeds.
- Over £100: Premium chargers with laptop compatibility (e.g., Anker 733).
Whether you’re looking to keep your iPhone charged or need a power bank that can charge laptop without charger, the options above cater to a variety of needs. From compact designs for everyday use to high-capacity models for extended trips, there’s a power bank for every scenario in 2025.
Choosing the best power bank for iPhone depends on your lifestyle. For everyday use, the EcoFlow RAPID Magnetic Power Bank strikes a balance between speed and portability. Frequent travelers should consider the Anker 733 for its wall-charger hybrid design, while budget shoppers can’t go wrong with Baseus. Always prioritize certified chargers to protect your iPhone’s battery health.
If you’re debating between a portable power station vs power bank, remember that the former suits heavy-duty needs like camping gear, while power banks are tailored for smartphones and tablets.
What power bank is recommended power bank for iPhone?
The EcoFlow RAPID Magnetic Power Bank is our top pick for its 15W Qi2 wireless charging, 30W USB-C output, and versatile design.
How much should you spend on a power bank?
Budget £25–£50 for reliable 10,000mAh models. Premium features like MagSafe or laptop charging cost £70–£120.
How much watt power bank is good for iPhone?
Aim for 20W–30W for fast charging. The iPhone 16 supports up to 25W wired and 15W wireless.
Can a power bank charge an iPhone?
Yes, but ensure compatibility with your iPhone’s port (USB-C/Lightning) and wattage needs. Wireless models require MagSafe/Qi support.
