Winter Car Emergency Kit: Canadian Checklist
Each Canadian winter brings with it heavy snowfall, freezing rain, black ice, and whiteout conditions. With a sudden breakdown, a collision, or a highway closure, an ordinary drive can turn into hours of waiting in sub-zero temperatures.
Without warm clothing, food, water, or a reliable way to call for assistance, the wait becomes more than just an inconvenience. Cold exposure can set in faster than many drivers expect, especially on remote roads where help takes longer to arrive.
That is why a winter weather emergency kit for cars should be in your vehicle before the first storm, not after it. This guide discusses the necessary supplies, the benefits and drawbacks of ready-made and DIY kits, how to store and maintain your equipment, and how portable electricity can keep compatible devices running when your phone battery is your only connection to the outside world.
What Should You Include in a Winter Weather Emergency Kit for Your Car?
A spare tire and a basic toolkit are not enough for a Canadian winter, which is why every driver needs a winter weather emergency kit for car travel. A complete car emergency kit prepares you for the two situations that matter most: getting your vehicle moving again, and staying safe and warm if it will not move.
The Government of Canada's Get Prepared guidance and provincial emergency agencies recommend carrying supplies for both. Use the checklist below as a starting point and adjust it to your route, vehicle and passengers.
Winter Survival Essentials: Blankets, Food, Water and Warm Clothing
If you are stranded, staying warm is the priority. Pack thermal blankets, insulated gloves, winter hats, spare socks and an extra layer for every regular passenger. Cotton holds moisture and chills quickly, so wool and synthetic fabrics are better choices. Add non-perishable food such as granola bars, nuts or dried fruit, plus drinking water.
These supplies help you and your passengers stay safer while waiting for roadside assistance. Check your water containers regularly, because bottles can freeze and split or leak in a cold trunk. Leave some air space in each bottle, and replace food as it nears its expiry date.
Roadside Safety Tools: Shovel, Ice Scraper, Jumper Cables and Warning Lights
A compact snow shovel, ice scraper, and snow brush get rid of the most typical winter roadside issue: snow around and on windows. When stranded on ice, sand, salt, or non-clumping cat litter can help tires grip. Jumper cables or a suitable jump starter aid with cold-weather starting problems since low temperatures limit battery performance.
In bad weather, reflective triangles, flares, or LED warning lights make your car visible, while a flashlight lets you investigate or signal for help. Only utilize roadside equipment when safe. Instead of entering traffic on a busy route or in thick snow with limited visibility, wait in your car with your seatbelt on and call for help. If you use the engine to create heat, clean the exhaust of snow to prevent carbon monoxide from entering the cabin.
First Aid, Communication and Emergency Charging Supplies
Pack a first-aid kit, any essential medications and a printed list of emergency contacts, since a dead phone takes your contact list with it. Keep a charging cable and a suitable power bank in the vehicle too.
Staying in contact matters most on remote roads or during severe storms, when cell coverage may be patchy and emergency services may be delayed. A charged phone lets you share your location, check road conditions and update family. A whistle is a simple backup if your phone fails.
How to Choose and Organize a Car Emergency Kit in Canada
You can buy a ready-made emergency kit for car trips or assemble your own. The right choice depends on your conditions. A driver commuting short distances in an urban area has different needs from a family crossing the Prairies or Northern Ontario in January. Travel distance, vehicle size, the number of passengers and how far you are from services all influence what you should carry.
What to Look for in a Car Emergency Kit
When shopping for a car emergency kit, look at the contents rather than assuming every kit offers full winter protection. Many emergency car kits are designed for general roadside use and omit cold-weather basics.
Check that the kit includes first-aid supplies, visibility equipment, basic automotive tools and winter-specific accessories such as blankets or a shovel. Contents, prices and availability vary by kit and location, so compare items against the checklist above and fill any gaps yourself.
Ready-Made vs. DIY Winter Car Emergency Kits
Ready-made kits are convenient and save time. A DIY emergency car kit lets you tailor every item, including extra clothing, food, water, medication and supplies for children or pets.
Option | Advantages | Limitations | Best for |
Ready-made | Quick to buy, compact, pre-packed | May lack winter items, fixed contents | Short commutes, first-time buyers |
DIY | Fully customizable, can match budget and needs | Takes time to source and assemble | Families, long-distance or rural drivers |
Hybrid (ready-made plus add-ons) | Fast start with winter upgrades | Needs a contents review | Most Canadian drivers |
Where to Store and How Often to Check Your Emergency Kit
Store your emergency kit for car use in a durable, easy-to-carry container, such as a sturdy bin or duffel bag. Keep frequently needed items like a flashlight, gloves and a phone charger within reach in the cabin, because a trunk may be buried or blocked after a crash. Secure heavier items such as shovels and jump starters so they cannot become projectiles during sudden braking.
Inspect your kit before winter and again during the season. Test flashlight batteries, replace expired food and medications, check water for freezing or leaks, and confirm that blankets and clothing are dry and in good condition. Pair it with safe winter preparation, such as our guide to winter tire safety, and review the full 72-hour emergency kit checklist for your home.
How to Keep Essential Devices Powered During a Winter Roadside Emergency
long highway closures or vehicle breakdowns in remote areas can cut off charging, navigation and communication just when you need them. Running the engine to charge a phone burns fuel and can drain the vehicle's starter battery, which is a risk if you are already dealing with a weak battery.
A portable power station is an optional addition to a winter car emergency kit. It can supply electricity to compatible electronics without drawing on your starter battery. When choosing one, consider battery capacity, output wattage, portability and operating temperature.
Portable Backup Power for Phones, Lights and Communication Devices
Winter storms can also knock out power at home. Picture a household waiting for electricity to return while trying to keep the refrigerator, lights and other compatible devices running. For higher-capacity needs like this, the EcoFlow DELTA 3800 Gen4 is built for extended outages.
It delivers 3,600W of continuous output and 7,200W of surge power, supporting a wide range of compatible home appliances. Its 3,763Wh capacity can run a refrigerator for up to 70 hours under specified conditions, and expandable capacity of 4–12kWh adds flexibility for longer outages.
Higher-Capacity Portable Power for Winter Road Trips
On a longer winter road trip or during a highway closure, you may want to power several devices at once: phones, rechargeable lights, communication equipment and a low-wattage electric blanket.
If you have enough vehicle storage space and need more capacity, the EcoFlow DELTA 3 Classic (1024Wh) is a strong option. Its 1024Wh battery and 1800W continuous AC output support phones, laptops, rechargeable lighting and communication equipment. Higher-wattage appliances reduce runtime significantly, so prioritize what you run.
Cold-weather safety: Batteries have manufacturer-specified operating temperature limits. The models above specify charging at 0°C to 45°C and discharging at -10°C to 45°C. Avoid leaving a power station exposed to extreme cold, keep it securely positioned in the vehicle, and never charge a battery below its permitted temperature. Planning a holiday trip? See our winter travel tips.
A well-prepared winter weather emergency kit is essential for Canadian drivers facing snowstorms, icy roads, breakdowns and unexpected highway closures. Carry warm clothing, blankets, emergency food, water, first-aid supplies and roadside safety tools, and compare ready-made and DIY kits against your vehicle, journey and household.
For compact device charging, consider the EcoFlow DELTA 3800 Gen4, and for higher-capacity power on winter road trips, the EcoFlow DELTA 3 Classic. Explore EcoFlow Canada's portable power stations to prepare for winter emergencies.
What Should You Put in a Winter Car Emergency Kit?
Add blankets, warm clothes, food, water, a shovel, an ice scraper, jumper cables, flashlights, warning lights, a first aid kit, and a power bank or phone charger.
What is the best car survival kit for winter driving?
Choose a kit based on your route and the number of passengers. Most drivers are suited for a pre-made kit with winter additions.
What are the 9 things I should keep in my car this winter?
Blankets, warm clothing, food, water, shovel, scraper, jumper cables, flashlight and first-aid kit.
What does an automobile emergency kit not include?
A written contact list, a whistle, a traction aid like cat litter or sand, and extra medication are frequently forgotten.
