How to Choose an RV Generator for Canadian Trips
- Which Type of RV Generator Fits Your Trip?
- Which Battery Options Fit Your RV Power Plan?
- How Much Power and Energy Does Your RV Need?
- How Will You Recharge Between Campsites?
- What Generator Rules Apply at Canadian Campgrounds?
- How Do You Use and Store RV Power Equipment Safely?
- Choose Power That Matches Your Next Trip
- FAQs
Choose an RV generator by checking what you'll run together and for how long. Then confirm where you can use it and how you'll refuel or recharge.
A serviced Canadian campsite may cover your needs, while an unserviced site needs more planning. Fuel generators and rechargeable power stations suit different loads, connections, and stops. This guide helps you compare them without assuming you need to power your entire RV.
Your power needs and campsite access determine which option makes sense. Check your existing setup before buying another unit.
Fuel-powered electric generators for RVs use an engine to generate electricity. A portable power station stores energy in a battery and releases it through its outputs. A solar generator usually combines that battery with solar panels, so cloudy days still affect charging.
Compare these options against your planned stops and devices.
Option | Where It Can Fit | Main Check or Limit |
Portable fuel generator | Longer off-grid demand where use is permitted | Fuel, exhaust clearance, noise, starting loads and outlet |
Installed RV generator | A compatible motorhome system or replacement | Installation, exhaust routing, fuel supply and servicing |
Portable power station | Selected devices at stops or between charges | Stored energy, outlet limits, weight and recharging |
Shore power or existing house batteries | A serviced site or a trip your setup already supports | Connection, battery charge and system limits |
If shore power covers each overnight stay, extra equipment may add little value. House batteries may also cover your lights and other built-in DC loads. Check their usable energy and charging system first.
Choose a battery around the devices you'll plug into it and your next charge. More stored energy adds time between charges, but it also adds weight.
A Smaller Plug-In Kit With DELTA 3 Classic
For a short stop, the EcoFlow DELTA 3 Classic Portable Power Station (1024Wh) gives you a separate supply for a laptop, lights, and other checked devices. Its 1,024 Wh battery and 1,800 W rated AC output suit a smaller load plan, not an entire RV by default.
At about 12.1 kg, it also needs a secure travel spot and a manageable lift. Plan a recharge before the stored energy runs low, and don't treat it as a dedicated 30 A RV supply.
More Stored Energy With DELTA 3 Max Plus
If your device list needs more energy between stops, consider the EcoFlow DELTA 3 Max Plus Portable Power Station (2048Wh). Its 2,048 Wh battery and 3,000 W total rated AC output support a larger checked load plan.
The trade-off is roughly 22.1 kg to lift and secure. Each of its four AC outlets has a 20 A limit, so one outlet can't supply the full 3,000 W. Its 30 A Anderson port supplies 12 V DC, not the 120 V AC of a TT-30 RV connection. Neither specification guarantees overnight air conditioning.
Phones alone may need only a small power bank. Sustained high loads may call for shore power or a correctly sized fuel generator instead.
Check both the load at one moment and the energy needed over time. Enough output doesn't guarantee enough stored energy for the whole stay.
Check Running Watts, Starting Demand and the Connection
Compare generators for RVs using the devices that run together, not the vehicle's length. When sizing an RV generator, build your load list in this order.
Read each device's input rating, rather than its advertised heating or cooking output.
Add the running watts of devices you'll use together.
Allow for motor starting demand, using the device's manual or verified measurements.
Check the source, outlet, cord, adapter, and RV circuit limits together.
Include the RV's converter if it starts charging the house battery automatically.
A 30 A, 120 V shore connection has a 3,600 W service ceiling. That isn't a minimum generator size for every trip. Your actual connection may allow less, even when the source's total rating is higher.
Build an Energy Budget Before Estimating Runtime
Multiply average watts by hours to estimate watt-hours, or Wh. This hypothetical example shows the method, not typical device ratings or a product test.
Illustrative Load | Assumed Use | Energy |
LED light | 10 W for 5 hours | 50 Wh |
Laptop | 65 W for 2 hours | 130 Wh |
Plug-in fridge | Assumed 45 W average for 8 hours | 360 Wh |
Total | Before losses, reserve or other loads | 540 Wh |
A real fridge cycles on and off, and heat can increase its energy use. Add conversion losses, inverter standby use, and a reserve before judging battery capacity.
By contrast, a continuous 1,500 W load needs 3,000 Wh over two hours, before losses. That's more than either base battery above stores. A high output rating can't make up for that energy gap.
Plan the next reliable charge before you plan another night away from hookups. A larger battery still runs down if daily use exceeds the energy you replace.
At a serviced site, confirm charging permission and the circuit's spare capacity. Battery charging shares that supply with your other appliances, so reduce charging input when needed. Don't assume a shared outlet has enough room for maximum charging.
Solar can help, but shade, cloud, and limited daylight reduce what panels produce. Compare expected energy with your daily use, rather than relying on a panel's rated watts alone.
Vehicle charging needs the correct model pairing and connection. Classic's Canadian listing pairs it with a 500 W alternator charger. Max Plus lists an 800 W option, but that doesn't make the chargers interchangeable. Confirm the exact charger, cables, and installation requirements before buying. Panels and vehicle-charging accessories may cost extra unless included in your chosen bundle.
For fuel-based power, check expected consumption and refuelling stops against the generator's manual. Follow its shutdown and cooling instructions before refuelling.
Your booked campground's current rules control when you can use RV generators. A quieter engine doesn't create permission outside the allowed hours.
These examples reflect official guidance checked on 22 October 2026, not Canada-wide operating rules.
Location | Generator-Use Hours |
9–10:30 a.m. and 5–7 p.m. daily | |
8–10 a.m. and 5–7 p.m. under the 2026 bulletin |
Jasper's Overflow campground has a different evening period, from 5–9 p.m. Check which notice covers your site and whether newer restrictions apply.
General quiet hours don't mean you can run a generator at every other time. Confirm permission before booking an unserviced stay, especially if your plan depends on fuel-powered charging.
Safe use depends on the equipment, its location, and the full connection. Read both the RV and power-source manuals before your first trip.
Keep Portable Fuel Exhaust Away From People
Run portable fuel generators outdoors, never inside an RV, camper, tent, or vehicle. Health Canada's generator safety guidance calls for at least 6 m from buildings, with exhaust directed away from openings.
Also follow the RV and generator manuals for separation and exhaust routing. Account for neighbouring campsites, doors, windows, and vents. Professionally installed onboard generators have their own installation and exhaust requirements, unlike portable units.
Keep working carbon monoxide alarms in the RV and follow maintenance instructions. Automatic CO shutdown doesn't replace safe placement or alarms.
Protect Connections, Batteries and Ventilation
Keep equipment dry and stable, with clear vents and correctly rated, intact cords. Route cables away from traffic and sharp edges. Stop using a damaged cable instead of attempting a campsite repair.
Batteries produce no combustion exhaust during use, but cooling fans can still make noise. Don't treat a power station as silent, waterproof, or free from electrical risk.
Ask a qualified RV technician to confirm an unclear source-to-RV connection. Don't improvise parallel cables, alter grounding or feed power into a wall outlet. Follow each model's charging-temperature and storage instructions, rather than one storage percentage for all batteries.
Record one planned day's device use, then confirm your next charging or refuelling stop. Use that plan to compare output, energy, connections, and campsite permission before choosing an RV generator.
If battery power suits those checked loads, compare portable power stations against your energy budget and lifting needs. Keep the existing RV system when it already covers the trip, rather than carrying equipment you don't need.
What size generator do I need to run my RV?
Choose output that covers your simultaneous running loads and their starting demand. Check voltage and connection limits too, because an RV's shore-power rating gives a service ceiling, not a generator size every trip requires.
How much does a generator cost for an RV?
Cost depends on the power source, output, battery capacity, and installation needs. Compare full Canadian prices, including required accessories, charging equipment, or fuel, rather than judging units by their base prices alone.
Can I run an RV generator all night?
Only consider overnight use when campground rules permit it, and the equipment's instructions support safe operation. Fuel, maintenance, and exhaust still matter, while a battery needs enough usable energy for your actual overnight loads.
Will a portable power station charge my RV's house battery?
It may, through a verified compatible charging system, but a DC output isn't automatically a suitable battery charger. Include the converter's energy demand if it runs, and ask your RV manufacturer or a qualified technician to confirm the setup.
