How to Winterize an RV: A Beginner's Guide for Canadian Winters
With over 2.1 million RV-owning households in Canada, many people face the same winter fear. As a Canadian RV owner, you know the dread that comes with the first deep freeze. One frigid night can turn water to ice, bursting your pipes and causing massive, wallet-draining damage.
Keep your rig from becoming a winter casualty. It's not merely a recommendation to learn how to winterize an RV; it's the most important task of the year. This is your simple, step-by-step manual for taking care of your investment and ensuring it's ready for spring.
Why Winterizing RV is Non-Negotiable in Canada
Knowing how to winterize an RV is simply about preventing basic physics from costing you a fortune. Water expands by around 9% when it freezes, and the ice inside your plumbing system functions as a hydraulic press.
An RV's water system can be readily destroyed from the inside out by this tiny alteration, which generates enormous pressure. The fallout is a massive, expensive headache that includes:
  • Split pipes and cracked fittings
  • A destroyed water heater tank
  • A cracked water pump
The repair bill is staggering. According to Canadian insurance brokers and RV service centres, freeze-damage claims always happen. These claims often start at $2,000 and can easily soar past $8,000 for extensive damage.
This is an entirely avoidable expense. Proper RV winterizing is your best defence, ensuring you're planning your first adventure when spring arrives, not paying for heartbreaking repairs.
How to Winterize an RV: A Comprehensive Walkthrough
Using non-toxic RV antifreeze is the best approach, as this guide demonstrates. It's the top choice for the harsh Canadian cold. It's a simple DIY project that will save you much money on repairs.
Step 1: Gather Your Supplies
Let's first organize your gear. The work goes more quickly when everything is ready.
  • Non-Toxic RV Antifreeze: Take 2–3 gallons (8–12 litres). Make sure the pink stuff is made for RVs. Never use green or yellow car antifreeze. It is poison and will wreck your freshwater system.
  • An RV Winterizing Kit: This cheap hose lets your water pump pull the antifreeze from the jug. It's a huge time-saver and makes the job much cleaner.
  • Water Heater Bypass Kit: Your RV likely has this. These valves stop you from wasting 6-10 gallons of antifreeze to fill the empty water heater tank.
  • Basic Tools: You will most likely need a socket wrench. This is to remove the drain stopper, commonly known as the anode rod, from the water heater.
Step 2: Drain Every Drop of Water
This is the most critical step. You must get all the water out before the antifreeze goes in.
  • Empty Holding Tanks: At a sani-dump, drain your black water tank first, then the grey water tank. The soapy grey water helps clean your sewer hose. Give the black water tank a good flush.
  • Drain Fresh Water & Heater: Drain the fresh water tank using its low-point valve. After that, turn off and drain the water heater by pulling its plug outside.
  • Clear the Lines: Open the low-point drains for heat and cold. Enter, turn on all of the faucets, and flush the toilet. Shut everything off after the dripping stops.
Step 3: Pumping Antifreeze Through the System
It's time to use the pink material to protect the lines now that they are empty.
  • Bypass the Water Heater: Locate the valves on the rear of the tank. Flip them to the "bypass" position. This stops you from wasting 6-10 gallons of antifreeze to fill the tank.
  • Hook Up the Antifreeze: Connect the water pump to your RV winterizing kit. Place the transparent pipe from the kit directly into a pink antifreeze container.
  • Turn on the Pump: Activate the cold tap. Please turn it off after letting it run until the water turns pink. For the hot tap, do the same. Once it also runs solid pink, shut it off. Do this "pink check" again for each shower faucet, kitchen, and bathroom sink.
  • Flush the Toilet: Press and hold the flush pedal until pink antifreeze begins to flow into the bowl.
  • Don't Forget Extras: Run antifreeze down the lines of any outdoor shower, washing machine, or ice maker.
  • Treat the Drains: Lastly, treat the drains by running one cup of antifreeze each. Tank odours are blocked by filling the U-bend (P-trap). Add a cup to the toilet bowl to prevent the seals from drying.
Step 4: Final Winter Preps for Your RV
Your plumbing is safe! But knowing how to winterize an RV camper means protecting the whole rig for its long sleep.
  • Protect Your Batteries: A dead battery will swell, crack, and freeze. Turn off your propane. If you can, bring your 12V house batteries inside. Store them (not on bare concrete) and hook them to a battery tender.
  • Evict Pests: Get rid of any food, paper, spices, and aromatic objects. To prevent mildew, clean the refrigerator and leave the doors open—place traps or mouse deterrents.
  • Care for the Exterior: Give the RV a thorough wash and wax to preserve its finish. To protect your tires from UV radiation, which can eventually shatter the rubber, cover them.
  • Use the Right Cover: Using a simple plastic tarp is not advisable. Because it retains moisture, it will result in a nightmare of mould and mildew. Use an appropriate RV cover that is vented and allows moisture to escape.
And that's it! You have completely safeguarded your investment by following these instructions. You may now unwind knowing that your RV will be secure and prepared for your next journey once the snow melts.
Powering Your Winter Adventures
However, what if you decide against storing your RV? It's an incredible experience to use your rig for a ski trip. The biggest roadblock, however, is power.
Running your furnace fan all night will drain your standard RV batteries flat by morning, leaving you freezing. And a traditional gas generator? It's not a good idea. Most campsites prohibit them after dark since they are noisy and smelly. Both you and your neighbours are unable to sleep with that noise.
This is the point at which a portable power station makes all the difference. Consider it a fume-free, silent "power-in-a-box" that you can use securely in your RV. These items are necessary equipment when camping in chilly climates.
  • The EcoFlow DELTA 3 Max Portable Power Station (2048Wh) is an excellent choice for most winter travels. Its contemporary LiFePO4 battery delivers clean, consistent power and is long-lasting. It quietly runs your furnace fan all night. No waking up cold. It also keeps your lights on, charges your phones, and runs small appliances.
When you’re on winter RV trips, the EcoFlow DELTA 3 Max (2048 Wh) keeps essential gear running all day—run a fish finder, lights and small heaters while still having headroom for chargers. Its 2,048 Wh LiFePO₄ pack and 2,400 W continuous (surge to 4,800 W) AC output handle RV loads reliably, and fast recharge via AC, solar or vehicle input gets you back to full sooner between stops. Compact, rugged and quiet, it’s built to keep your winter adventures powered and comfortable.
  • The EcoFlow DELTA 3 Max Plus Portable Power Station (2048Wh) is your power security for longer, extended trips far off-grid. It offers a massive amount of power. You are capable of more than simply ordinary running. No matter how low the temperature dips, you can rest easily knowing your RV will remain functional and toasty.
A silent power plant allows you to enjoy the winter splendour peacefully. To determine the right size for your needs, check this guide on finding the best portable power station.
Mastering how to winterize a travel trailer is one of the best skills you can have as a Canadian owner. It turns winter from a costly threat into just a simple off-season.
Taking one afternoon for this job protects your investment and saves you from thousands in potential repair bills. The best part is that your rig will be prepared to go as soon as spring hits. Don't wait for the first frost! Give your RV the security it needs by acting right now.
How long does it take to winterize an RV?
If it's your first time, take between 90 minutes and two hours to be cautious and proofread your work. It's a short task that takes 30 to 45 minutes once you know the steps. Waiting for all of the tanks to empty is the longest part.
Is using antifreeze or compressed air to winterize a camper better?
For novices in particular, antifreeze is the most reliable way. Even if you miss a little water, it guarantees that every component is protected. Compressed air use is dangerous. If you overlook one low location, the held water could freeze, burst a pipe, and cause significant damage.
How do I winterize my motorhome's ice maker?
For precise instructions on how to winterize motorhomes, refer to the owner's manual for your RV. After the antifreeze is in the main lines, you must let the ice machine run multiple times. You'll know you're done when the "ice" it makes comes out as slushy, pink antifreeze.
Can I live in my RV during a Canadian winter?
Yes, but it takes serious prep. You must use tank heaters and heat tape to heat your pipes actively. You'll also need skirting, more insulation, and a strong, dependable supply like an EcoFlow DELTA series power station to operate your furnace safely all night.
What happens if I forget to winterize my RV trailer?
In Canada, neglecting how to winterize an RV trailer can be extremely expensive. Water expands when it freezes with enough force to ruin your water pump and water heater, shatter your pipes, and crack your toilet. This guarantees you'll have thousands of dollars in repair bills.
