3000W-Power Past the
1800W AC Standard
Easily power more appliances at once
Ready in Just 43 Mins [1]
5 charging methods
10 Years of Reliable Power [2]
EV-grade full-tab LFP batteries
Power That
Grows With You
2–10kWh scalable
capacity
Uninterrupted Power
<10ms switchover — fastest-in-class UPS
Smarter, Safer, 24/7 Protection BMS
ARM Cortex chipset
Cloud intelligence algorithm
Extend Power for Your Most Important Devices
Smart Output Priority Tech
EcoFlow DELTA 3 Max Plus (2048Wh)
• 2~10kWh capacity, 2kWh built-in power
• 3000W rated output
• 6000W surge output
$1,399.00
$2,599.00
Shop Now
EcoFlow DELTA 3 Max (2048Wh)
• 2kWh capacity
• 2400W rated output
• 4800W surge output
$989.00
$2,099.00
Shop Now
A New Era of Power Performance
25% More Power [3]: 3000W Output, 2kWh Capactiy
Next-level energy for next-level peace of mind.
All Your Essentials. All at Once.
EcoFlow DELTA 3 Max Plus (2048Wh) delivers 3000W AC rated output (6000W surge). With X-Boost™ 3.0 technology, it supports devices up to 3800W—effortlessly taking on your heavy-duty appliances.
That's enough to run your microwave, kettle, fridge, and blender all at once without a flicker. In the Kitchen?
Go full throttle. No unplugging, no interruptions—just seamless power. [4]
With a powerful 3000W AC output, DELTA 3 Max Plus outperforms competing products, supporting simultaneous operation of multiple high-wattage appliances.
3000W Output, 6000W Surge —
Powerful. Stable. Built to Handle It All.
The inverter samples AC voltage and current every 33μs with high precision using a DSP chip, ensuring pure sine wave output with beyond grid-level stability—ideal for powering sensitive electronics reliably.
Kitchen
Living Room
Office
Garage
Laundry Room
RV Camping
Pick Your Priority Outputs, Extend What Matters Most
Smart Power Reserve | Set your desired battery threshold (%) to automatically shed non-essential loads during outages
With app-based presets, DELTA 3 Max Plus (2048Wh) automatically follows your priority settings during outages—shutting off lights while keeping your fridge running. Wake up to fresh food and plenty of power left—just like nothing happened.
A New Level of Fast
Ultra-versatile 5 charging options, 43-minute fast charge [1]
Remote charging control for added peace of mind.
5 Ways to Charge Up — Ready in Just 43 Mins [1]
Wall Charging
Generator Charging
Alternator Charging
Solar + Alternator Dual Charging
Automotive-grade full-tab LFP cells
Automotive-grade Full-Tab LFP Cells: Next-Level Battery Reliability
DELTA 3 Max Plus (2048Wh) is equipped with automotive-grade full-tab LFP cells. The full-tab design reduces resistance, enhances efficiency and safety, and provides higher capacity with less heat, resulting in a long battery lifespan.
25% more
efficient power flow (thanks to lower resistance: 1.5 mΩ vs. 2 mΩ) [11]
25% less
self-heating [12]
Unrivaled Balance for Unmatched Battery Longevity
With 27% fewer cells per kWh, [13] our 16-cell design runs cooler, lasts longer, and delivers greater stability. Each cell is rigorously tested for capacity, voltage, and internal resistance—resulting in a highly uniform pack that protects against overcharging, imbalance, and premature wear.
16-cell uniform set per 1 kWh
Rigorously tested for capacity voltage, and internal resistance
Built to Last
From battery chemistry to structural design, DELTA 3 Max Plus (2048Wh) is engineered for extreme durability, environmental resilience, and whisper-quiet performance—delivering power you can count on for over 10 years. [2]
Easily Scales Up—From Hours to Days
2–10kWh expandable capacity
Compatible with Smart Generators for unlimited runtime
Covers essential power needs during a 4–8 hour outage—keeping food fresh, heat running, lights on, and communication devices charged. [16]
Light
(10W)
3
6
hrs
Phone
(11W)
0
1
times
Wi-Fi Router
(10W)
3
6
hrs
50" TV
(110W)
0.3
0.5
hrs
Refrigerator
(200W)
6
12
hrs
Microwave
(1300W)
5
10
mins
Electric Blanket (50W)
3
6
hrs
Hair Dryer
(1600W)
7
15
mins
- Half-Day Outage
- 1-Day Outage
- 2-Day Outage
- 3-Day Outage
Pair DELTA 3 Max Plus (2048Wh) with EcoFlow Smart Generators to achieve longer runtime—automatically switching between fuel and battery to keep you powered through multi-day outages or off-grid adventures. [19]
Go Hybrid—Extend Backup with a Smart Generator
Learn more about
EcoFlow Smart GeneratorsUnlock unmatched power and reliability with the EcoFlow Smart Generators and EcoFlow DELTA 3 Max Plus (2048Wh) hybrid setup. Featuring fast charging and high efficiency, they excel in various scenarios, from backup power to on-the-go charging.
Monitor your energy usage, savings, and solar generation—all with one intuitive dashboard. Easily track battery status, real-time electricity rates, and financial savings.
Output
Solar Generation
Earnings [20]
Cut Costs, Not Comfort
DELTA 3 Max Plus (2048Wh) intelligently optimizes energy usage to help lower your electricity bills while powering your home sustainably. Set automated tasks to charge during off-peak evening hours and discharge during the day.
TOU Mode
Charge During Off-Peak, Use During Peak
TOU Mode lets you set custom charging and discharging schedules based on your local electricity rates. Charge when energy is cheapest, and discharge during peak hours to cut costs without lifting a finger. [20]
Self-Powered
Reduce Grid Dependency, Lower Electricity Costs
Self-Powered mode stores solar energy and powers your home once battery levels exceed a preset reserve. It minimizes grid use while maximizing solar efficiency—ideal for managing fluctuating energy prices and enhancing your energy independence.
To use this feature, update the software to V6.14.5 or above and upgrade the firmware to V7.80.99.52 or above.
Comparison
Explore The NEW EcoFlow DELTA Series
Disclaimer
1. 0-80% in 43 minutes was measured in optimal conditions using the EcoFlow Smart Generator 4000 (Dual Fuel).
2. Based on proper product usage, DELTA 3 Max Plus is estimated to have a lifespan of approximately 10 years, according to internal simulation test data. This information is for reference only; actual user experience may vary.
3. Compared with EcoFlow DELTA 2 Max.
4. The conclusion that multiple appliances can be powered simultaneously is based on internal testing. Actual performance may vary in real-world use.
5. All charging speed data comes from EcoFlow labs and is for reference only. The actual data may vary slightly depending on the usage environment, device condition, software version, and other factors.
6. Feature requires preset activation via the EcoFlow App.
7. To enable this feature, connect DELTA 3 Max Plus to the Smart Generator using the charging cable and enable the preset in the EcoFlow App. Communication is handled via Bluetooth or Wi-Fi.
8. EcoFlow Solar Panels are sold separately.
9. EcoFlow Alternator Charger Plus 1000 will be launched soon and is sold separately.
10. Compared with car cigarette port charging.
11. Refers to the internal resistance of EF Full-Tab LFP Cells being 1.5mΩ, which is 25% lower than the 2mΩ internal resistance of the previous EF #C33 Battery Cell.
12. A 25% reduction in single-cell internal resistance. According to the heat generation formula Q = I²Rt, under the same current, a 25% reduction in resistance leads to a proportional 25% decrease in heat generation.
13. Compared with the previous usage of EF #C33 Battery Cell.
14. Unless otherwise noted, all above data comes from EcoFlow labs and is for reference only. The actual data may vary slightly depending on the usage environment, device condition, software version, and other factors.
15. Noise levels measured at 0.5m under 25°C ambient: ≤25dB (600W) for charging/discharging.
16. Multiple appliances' backup time based on ideal conditions; actual results may vary.
17. Require connecting 1*DELTA 3 Max Plus + 2* DELTA 3 Max Plus Smart Extra Battery with EcoFlow Smart Extra Battery Expansion Adapter. The EcoFlow Extra Battery Expansion Adapter will be released soon.
18. Require connecting 1*DELTA 3 Max Plus + 2* DELTA Pro 3 Smart Extra Battery with EcoFlow Smart Extra Battery Expansion Adapter. The EcoFlow Extra Battery Expansion Adapter will be released soon.
19. EcoFlow Smart Generators are sold separately.
20. To use this feature, update the software to V6.14.5 or above and upgrade the firmware to V7.80.99.52 or above.
21. Unless otherwise noted, all images, videos, and screen display contents about the product itself on this page are for reference only. Actual product effects (including but not limited to appearance, color, and size) and screen display contents (including but not limited to backgrounds, UI, and illustrations) may vary.
