Things to Do in Kananaskis: Winter Trails and Mountain Scenery
Kananaskis gives you mountain views and snowy trails on a winter day trip from Calgary, without spending the day in Banff. You can walk to a frozen waterfall, follow a shoreline under a wall of limestone, or ski the groomed trails in Peter Lougheed Provincial Park — in winter you may well have it to yourself. What you trade for that quiet is planning. Days are short, and Hwy 40 over Highwood Pass closes for the season. Below are the stops worth building a day around.
Why Visit Kananaskis in Winter?
Winter changes the pace of the things to do in Kananaskis. Trails may be quieter, daylight is limited, and fresh snowfall can make familiar viewpoints look different.
Enjoy Snow-Covered Mountain Scenery
Fresh snow sharpens this landscape. After a storm, the limestone massifs of Mount Kidd and Mount Lougheed stand stark against a hard blue prairie sky, while the subalpine valleys fill with deep, powdery drifts. The roadside pullouts along Kananaskis Trail become the best free viewpoints in the valley once frost settles on the spruce and the low sun catches the wind-blown snow ridges.
Experience a Quieter Mountain Getaway
A winter visit may feel quieter than Banff or Canmore, but trailhead demand varies with weather, weekends and local events. Check parking and trail conditions before departure, and do not assume a short distance from the vehicle removes mountain-weather or wildlife risks.
EcoFlow DELTA 3000 Gen4 Portable Power StationEcoFlow DELTA 3000 Gen4 Portable Power Station
Which Trails and Scenic Spots Are Worth Exploring in Kananaskis?
Things to do in Kananaskis Country range from short roadside walks to snowier trails in Peter Lougheed Provincial Park. The table below compares distance, difficulty and suggested equipment.
Walk the Barrier Lake Interpretive Trail
Barrier Lake sits near the north end of Hwy 40, which makes it the natural first stop if you’re driving in from Calgary. The shoreline trail is level walking across wind-swept gravel flats, with short sections through forest and wide views over the frozen reservoir toward Mount Baldy, though wind is the thing to plan around. It funnels through the valley often enough that packed snow and slick patches are the norm, so microspikes are worth carrying on the shoreline even on a day when nothing else you do needs them.
Explore the Troll Falls Trail
Troll Falls has been a winter favourite for years, and the reputation still holds: an easy walk up a forested valley ends at a wall of cascading blue ice. The round trip runs 3.4 kilometres on a gentle grade — easy enough that people of all ages turn up, in numbers big enough that the crowd becomes the problem. All those boots polish the final approach into a ramp of ice at the point where you most want to be looking up. Bring microspikes.
Enjoy the Views at Upper Kananaskis Lake
Farther south, in Peter Lougheed Provincial Park, Upper Kananaskis Lake is where the scale changes. The lake sits cradled beneath sheer rock faces, and even a short section of the lakeside circuit puts Mount Lyautey and the peaks around it in front of you. Wind scours parts of the shoreline back to ice while filling the sheltered bays with deep drifts, so the same walk looks different week to week.
Explore Winter Trails in Peter Lougheed Provincial Park
Peter Lougheed is K-Country’s hub for deep-snow days. Maintained winter trails like the Lower Lake trail, or the paths toward Elkwood amphitheatre, meander between dense lodgepole pine and open meadow. The snow lies deeper here and holds more consistently than at the lower valley elevations to the north.
Destination
Distance (Round Trip)
Difficulty
Best For
Gear Needed
Barrier Lake
2–5 km (flexible)
Easy
Big lake vistas & quick access
Microspikes / Boots
Troll Falls
3.4 km
Easy
Frozen waterfalls & families
Microspikes
3–15 km (flexible)
Easy to Moderate
High-alpine panoramic views
Spikes or Snowshoes
Peter Lougheed Trails
Varies (2–10 km)
Easy to Moderate
Deep snow & quiet forests
Snowshoes / Warm layers
What Other Outdoor Activities Can You Enjoy in Kananaskis?
Walking is only one of the options. Depending on what the snow has done, you can strap on snowshoes, clip into cross-country skis, or stay in the car and watch for wildlife from the roadside.
Go Wildlife Watching Along Scenic Routes
A slow drive down Hwy 40 or the Smith-Dorrien turns up memorable sightings often enough to be worth planning for. Bighorn sheep gather on the cleared road shoulders to lick road salt, and moose browse the willows along the marshy valley bottoms. Do your watching from inside the vehicle. Winter is stressful enough for these animals without an audience on foot, and the distance keeps both sides safe.
For roadside photography stops, a compact power station can recharge compatible camera batteries in the vehicle, provided it is secured and operated within the manufacturer’s temperature limits.
Try Snowshoeing on Designated Winter Trails
The southern passes hold the deep powdery snow that snowshoers are after. On marked routes like the Penstock Loop or the Elkwood Loop, you float across untracked snow instead of post-holing through it. When a fresh storm drops 20 centimetres of dry Rocky Mountain powder overnight, that flotation is what gets you anywhere at all.
Enjoy Cross-Country Skiing in Kananaskis
Cross-country skiing is one of the main things to do in Kananaskis Village and the surrounding trail systems. Grooming status and open distances vary with conditions, so check the current trail report before choosing a route suited to your ability.
How Can You Plan a Road Trip to Kananaskis?
Winter driving here takes more planning than the map suggests. Check the route before you go, allow more time than the distance implies on paper, and carry enough clothing and supplies to sit out a change in the weather.
If the trip extends overnight, compare places to camp in Kananaskis by operating season, access, available services and current reservation status before choosing a site.
Check Road Conditions and Seasonal Closures
The high-elevation section of Highway 40 over Highwood Pass is seasonally closed from December 1 through June 14 to protect wintering wildlife. Before travelling, check 511 Alberta and Alberta Parks advisories for current closures and road conditions. Winter-rated tires are strongly recommended for snow and ice, and drivers should adjust equipment and plans to the posted conditions.
Pack Winter Clothing and Hiking Essentials
Mountain weather can shift from calm sunshine to a biting windchill within the hour. The three-layer system handles that range: a moisture-wicking merino base layer, an insulating fleece or down mid-layer, and a windproof, waterproof shell on top. You adjust as the day changes instead of dressing for the temperature at the trailhead. Keep microspikes, trekking poles with snow baskets, a thermos of hot tea and an emergency kit in the vehicle at all times.
Cold weather battery performance also affects phones, cameras and backup equipment, so begin with charged devices and plan runtime conservatively.
Keep Navigation and Camera Gear Charged
Sub-zero temperatures drain lithium-ion batteries far faster than normal. Cold air slows the chemical reactions inside each cell. That’s why a phone sitting at 50% can drop to zero the moment you pull it out to check an offline trail map or line up a shot of the falls. An inside jacket pocket, close to body heat, buys some of that back. Carrying reliable portable power buys the rest, keeping GPS units, drones and mirrorless cameras working all day.
A portable power station may support compatible navigation and photography equipment between stops, but actual runtime depends on temperature, load and battery condition.
Prepare for Limited Services and Charging Access
Travelling through Kananaskis in winter means amenities and places to plug in are sparse once you’re past Kananaskis Village. If you’re planning extended road trips, long hours at remote trailheads, or an overnight in a winter camper setup, work around it: the charge you arrive with has to last most of the day, with few places to top up. An off-grid portable power station covers what the cold takes.
For short road trips and daily charging needs, the EcoFlow DELTA 3 Classic Portable Power Station provides 1,024Wh of capacity and 1,800W of rated output. It can recharge compatible phones, mirrorless cameras and tablets while supporting suitable low-draw appliances; confirm each load and expected runtime before departure.
1800W Powerful Output: 3600W surge output. With X-Boost™ tech, it supports high-demand devices up to 2600W, such as microwaves, refrigerators, laptops, and heated blankets.
For multi-day winter trips or RV travel, the EcoFlow DELTA 3000 Gen4 Portable Power Station provides 3,072Wh of capacity and 3,600W of rated output. Confirm combined running and surge requirements, secure the unit for transport, and follow the manufacturer’s cold-weather operating and charging limits.
3kWh capacity. 3600W output. UPS backup with <10 ms transfer time. With just 3W standby and 14W no-load power consumption, DELTA 3000 Gen4 reduces energy loss when left on between uses, delivering longer runtime for low-power essentials.
What Should You Know Before Visiting Kananaskis?
A little preparation makes the day safer and considerably more comfortable. Check the pass requirements, review trail conditions, and plan around wildlife activity, snow and limited winter daylight.
Check Pass Requirements
Most vehicles parked at Kananaskis and Bow Valley provincial park trailheads or day-use areas need a valid Kananaskis Conservation Pass. You buy a day or annual pass online by registering your licence plate — register the vehicle you’re actually driving. Do it before you leave home.
Stay Aware of Wildlife
Wildlife activity varies by species and season, and encounters with cougars, wolves, lynx or bears are still possible. Carry bear spray where it is accessible, keep pets leashed where required, make noise around blind corners, and pack out food and waste.
Plan Around Shorter Days
December and January have limited daylight, with sunset arriving around 4:30 p.m. in many areas. In the valleys the sun drops behind the ridge earlier still. Start your hike early and allow extra time for snow, ice and delays. Carry a headlamp with fresh batteries even on days you’re certain you’ll be back before dark.
Prepare for Snow and Ice
Popular routes can become slippery from packed snow, while quieter routes may hide deep drifts and rocks. Check Alberta Parks trail reports for closures and grooming updates, and consult Avalanche Canada for the current regional forecast. Avalanche terrain requires appropriate training, route planning and rescue equipment.
Kananaskis suits a winter day of short walks, a scenic drive, or time on the ski trails. Pick stops that fit the weather and your experience, then check conditions before you go. Warm layers, traction and an early start take most of the hard edges off the day.
What Is Kananaskis Famous For?
Kananaskis is known for unspoiled Rocky Mountain wilderness, cross-country ski trails with a reputation well beyond the province, and outdoor filming locations. It’s the quieter natural counterpart to Banff National Park. Kananaskis also hosted the alpine skiing events at the 1988 Calgary Winter Olympics and the 2002 G8 Summit.
When Does Winter Start in Kananaskis?
Winter conditions typically arrive by late October or early November, bringing persistent sub-zero temperatures and snow that lasts through April. At higher elevations such as Peter Lougheed Provincial Park, substantial snow often stays well into May.
Is Hiking in Kananaskis Safe?
Winter hiking in Kananaskis is safe on marked, low-elevation day-use trails, provided you turn up with warm layers, traction cleats and some awareness of what else moves through the valley. Steeper backcountry terrain is a different proposition: avalanche hazard and sub-zero weather there call for specialized gear and route-planning experience.
What Are Some Kid-Friendly Hikes in Kananaskis?
Troll Falls and the Barrier Lake Shoreline Trail are two of the best kid-friendly winter walks in the region. Both have minimal elevation gain, and both give children something worth stopping for: a frozen waterfall at one, a big lake at the other. There’s plenty of room to explore safely with you close by.
Does Kananaskis Have a Ski Resort?
Yes, Nakiska Ski Area sits right in Kananaskis Country on the slopes of Mount Allan. Originally developed for the 1988 Winter Olympics, it offers family-friendly downhill skiing, snowboarding and a racing venue with an Olympic legacy, all about an hour’s drive from Calgary.
