Do You Need a Permit to Install Solar Panels in Canada?
Now you can harness the power from the sun and save on utility bills by installing solar panels on your roof. Before you can reap this advantage and save the earth, though, you have to acquire permits. When in Toronto, solar installations must comply with a number of local and provincial codes, regulations, and requirements, depending on the type and scale. That is why in this blog we will provide all the details regarding the permits.
Why Are Permits Required?
Permits are necessary for more than compliance with the law—the proper permits will also help ensure the installation is in compliance with safety regulations and electrical code. A correctly installed solar system will be unsafe if installed incorrectly, violate building regulations, or cause fines or the system being shut off. So obtaining the proper permits is crucial in making sure the installation complies with all the laws and prevents issues in the future.
Common Permits Required for Solar Panel Installation in Canada
Solar panel installation permits vary across Canada depending on the type of system being installed and the local municipality's regulations. However, the following permits are generally needed:
Building Permit
This permit is required to ensure that the structure of your home or building can safely support the weight and installation requirements of the solar panels. It is typically needed for rooftop solar panel installations.
Electrical Permit
When bringing a solar system into connection with the grid, it requires a permit. The permit ensures the installation is in compliance with local electrical code. The permit ensures the building's electrical system integrates with the solar panels safely.
Environmental Permit (In Some Areas)
In certain regions, especially those with environmental protection zones, an environmental permit may be required. This is particularly true for off-grid solar systems that may be installed in ecologically sensitive areas.
Common Permits for Solar Panel Installation in Canada
Permit Type
Description
When Is It Needed?
Additional Notes
Building Permit
Ensures the structure can support the solar system.
For all new installations, particularly rooftop systems.
Usually required when making any modifications to the building structure.
Electrical Permit
Ensures the system meets electrical code standards.
For all grid-connected installations.
Required for all solar systems connected to the grid, ensuring safety and compliance.
Required for installations in protected areas.
Especially for off-grid systems or installations in ecologically sensitive areas.
May require additional environmental assessments when installing in sensitive areas.
💡Important Note:
Each province in Canada and even each municipality has its own regulations regarding solar panels. Some provinces have minimal and comparable regulations, whereas others require more paperwork or procedures for approval.
For example, in Toronto, the following regulations must be followed when installing solar photovoltaic (PV) systems or solar water heating systems:
  • Building Permit: A building permit is required for solar systems with an installation area exceeding 5 square meters.
  • Electrical Safety Authority (ESA) Approval: All electrical installations must comply with the Ontario Electrical Safety Code and are subject to an inspection by an ESA Inspector.
  • Grid Connection: All solar PV systems must be approved by Toronto Hydro to ensure the system can be connected to the grid.
Solar installation professional reviewing permit documentation and regulatory requirements needed for legal solar panel installation in Canada.Solar installation professional reviewing permit documentation and regulatory requirements needed for legal solar panel installation in Canada.
How to Apply for a Solar Panel Installation Permit
Obtaining the permits will vary by location, but there will typically be a universal method for acquiring them. Below is what you will typically go through:
1. Contact Local Authorities
First, contact the building authorities or city office where you plan on placing the solar panel. You will learn about the local licenses required. Do this prior to filling out the paperwork.
2. Hire a Professional Installation Company
These companies will typically take care of the permits for you. A reputable company familiar with the local permitting procedure will save time and prevent errors.
You may have to submit various papers, such as design plans, technical details, and electrical schematics. For instance, in vancouver, the electrical plans and specifications are required to be submitted with the permit application.
3. Wait for Approval and Schedule Inspections
Once the form has been completed, it may take some time before the form is approved. When the form is approved, someone will attend the land and inspect the area before the final approval.
How Long Does It Take to Get a Permit
The typical timeline for obtaining a solar panel installation permit is between 1 and 4 weeks. However, the exact duration can vary based on several factors:
What Affects the Permit Time
● Review Speed of Your City: The processing time can differ based on the location and efficiency of the local authorities.
● Time of Year: Spring and summer are typically the busiest months for permit applications, which may lead to longer wait times.
● Completeness of Your Application: Incomplete plans or documents can cause delays in the approval process.
Expected Timeline
● Small Towns or Rural Areas: Usually takes 1 to 2 weeks.
● Mid-Sized Cities: Generally takes 2 to 3 weeks.
● Large Urban Centers (e.g., Toronto, Vancouver): Typically requires 3 to 4 weeks.
To avoid delays, it's advisable to submit your permit application well in advance, especially before the busy seasons. While the permit is in the process of being approved, you can consider getting a good quality backup power supply. The EcoFlow DELTA Pro 3 Portable Power Station has up to 3600W of power and is excellent for powering various appliances. Its large battery ensures you can have crucial devices operational at all times without interruptions. Furthermore, the DELTA Pro 3 charges rapidly, so the wait will not be long. You can transfer it wherever it is required and maintain a constant source of power by setting up the solar system.
EcoFlow DELTA Pro 3 offers 4000W and dual 120V/240V output. Easy setup, ultra-quiet operation. Perfect for home or on-the-go. Shop today!
Consequences of Installing Solar Panels Without Permits
When setting up solar panels, there is a need for the proper permits. Failure to have the proper permits may lead to lawsuits, financial issues, and safety concerns that may damage the performance of the system in the long run. Below are the key concerns in setting up the solar panels without the proper permits:
● Fines and Penalties: Non-compliance with local building and electrical codes can lead to significant fines.
● Forced Removal: If the installation is found to be unpermitted, the system may need to be removed, incurring additional costs for dismantling and disposal.
● Safety Risks: Unpermitted installations may not meet safety standards, increasing the risk of electrical hazards.
● Impact on Property Value: An unapproved installation can lower the resale value of your property.
● Insurance Issues: Home insurance may not cover damages caused by an unpermitted installation.
● Grid Connection Problems: Without the proper permits, you may not be able to connect your solar system to the grid.
Installing solar panels without the required permits can lead to both financial losses and safety concerns. To avoid these risks, it is essential to ensure all necessary permits are obtained before installation, ensuring compliance and enjoying the full benefits of solar energy.
Ensuring a Smooth and Compliant Solar Installation Journey
Installing solar panels in Canada is easier than you think. Follow the right steps, understand the permits, and work with experts, and you'll enjoy clean, renewable energy without delays or legal issues. While waiting for permits, the EcoFlow DELTA Pro 3 Portable Power Station gives you reliable backup power, keeping your home running smoothly. Just follow local regulations, and your solar panel installation will be a breeze.
3 FAQs About Solar Permits
Q1: What is the cost of a solar panel installation permit?
A: Permit costs vary by region and installation size. Building and electrical permits generally cost between 100 CAD and 500 CAD. Fees may vary based on system size or location. It is best to check with local authorities for accurate costs.
Q2: Can I apply for a permit online?
A: In many regions, yes. Most municipalities offer online permit applications, which can save time. However, some areas may still require in-person submissions or additional paperwork for complex installations.
Q3: What happens if my permit application is denied?
A: If your solar panel permit application is denied in Canada, you'll be informed of the reasons, such as incomplete documents or non-compliance with codes. You can make the necessary corrections and resubmit the application. If you disagree with the denial, you can appeal through a local committee. It's recommended to work with a professional company to ensure your application meets all requirements and reduces the risk of denial.
Solar Panels
