How to Choose the Right Heater for Room
A central furnace keeps most of a Canadian home comfortable, yet there’s almost always one room—a basement, a home office over the garage, or a drafty bedroom—where the chill still settles around your ankles. A space heater can help, but the right one comes down to where you plan to use it and how long it will run. Here’s how the main heater types compare, how to size one, and what to expect on your electricity bill.
What Type of Room Heater Is Best for Your Home?
Different rooms and routines call for different heaters. A model that warms you at a desk within seconds may be the wrong pick for a living room you want cozy all evening. The table below sets the main types side by side. When space is limited, a small portable heater still needs the clearance specified in its manual.
Heater Type | Best Used For | Heating Speed | Noise Level | Heat Retention |
Ceramic | Home offices, small bedrooms, quick spot heating | Very Fast | Low to Moderate (fan hum) | Low |
Oil-Filled Radiator | Bedrooms overnight, continuous living room heat | Slow | Silent | High |
Infrared | Drafty rooms, basements, workshops | Instant | Completely Silent | None (heats objects directly) |
Convection (Panel) | Medium-to-large enclosed rooms | Moderate | Silent to Low | Moderate |
Ceramic Heaters for Quick, Targeted Heating
In a ceramic heater, an electric current runs through ceramic plates that heat up quickly while a built-in fan pushes the warmth outward. That moving air is why you feel a warm breeze within seconds of flipping the switch. Most models are light enough to tuck under a desk for a workday at home and will shut off safely if a curious pet knocks one over. Once you turn the heater off, however, the room cools down just as quickly. When comparing a small heater for a room, also check the required clearance and the area the manufacturer says the model is designed to heat.
Oil-Filled Heaters for Quiet, Steady Warmth
An oil-filled heater looks much like an old cast-iron radiator, and inside its sealed fins an electric element heats the oil. Reaching full temperature takes 20 minutes to half an hour, but that much hot oil is slow to cool and keeps radiating gentle warmth long after the element cycles off. With no fan noise and no dry air blowing around, this type is an excellent choice for light sleepers who want steady overnight warmth in the bedroom.
Infrared Heaters for Direct Heating
Where most heaters warm the surrounding air, an infrared heater emits electromagnetic waves that directly heat the people and objects in its line of sight. The effect is much like standing in a patch of winter sunlight. In an uninsulated garage, a chilly hobby workshop, or a drafty basement, an infrared unit keeps your body warm without wasting power on air that is escaping anyway.
Convection Heaters for Even Room Heating
A convection panel heater needs little or no help from a fan because rising warm air and sinking cool air move heat around an enclosed room on their own. Many models mount flat against a wall or stand along the baseboard. Warmth spreads evenly through a medium-sized room, so you don’t get hot spots or cold drafts across the floor.
How Do You Choose the Right Heater Size for Your Room?
Square footage is a sensible starting point, but ceiling height, insulation, and whether you’re warming one person or the whole room all change how many watts you need. If outage planning is also part of the decision, a portable power station must be checked against the heater’s instructions, continuous load and intended runtime.
Match Heater Wattage to Room Size
For a standard room, the rule of thumb is 10 watts of heating power per square foot of floor space.
Small Room (up to 100 sq. ft. / 9 m²): A portable heater for a small room may be rated around 750W to 1,000W, but insulation, ceiling height and the manufacturer’s coverage guidance still matter.
Medium Room (100–150 sq. ft. / 9–14 m²): A 1,500W heater may suit some second bedrooms or guest rooms when heat loss and the product’s instructions are taken into account.
Large Room (150–250 sq. ft. / 14–23 m²): The best heater for a large room depends on insulation and layout; some spaces may need central heating support rather than multiple portable units.
Consider Insulation and Ceiling Height
The 10-watt rule assumes an 8-foot ceiling and reasonably tight modern insulation. Rooms with 10-foot ceilings or an open staircase lose warm air upward the way a chimney does. The large original windows in the heritage homes of older neighbourhoods let heat slip out through the glass. In a room like that, work from 12 or 13 watts per square foot, and go as high as 15 where the insulation is poor.
Choose Between Personal and Whole-Room Heating
If all you want is warm feet at your desk, a personal 400W to 500W ceramic mini-heater aimed at your chair costs far less than heating the entire 200-square-foot room. Keep the 1,500W fan or convection models for times when the whole space needs to be comfortable.
How Much Electricity Does a Room Heater Use?
The cost depends on the heater’s wattage, electricity rate and how many hours it actually draws power. Whether space heaters use a lot of electricity therefore depends on both power and runtime, not the label alone.
Understand Room Heater Wattage and Power Consumption
Many portable heaters draw up to 1,500W (1.5 kW) on high. Plug the heater directly into a suitable wall outlet, avoid sharing the circuit with other high-draw appliances, and follow the manufacturer’s electrical requirements. Health Canada’s electric-heater safety guidance also says not to use an extension cord or power bar and to choose a product with a recognized Canadian certification mark.
Calculate Daily and Monthly Electricity Costs
A thermostat may cycle the heater on and off as room conditions change, so active heating time varies with the setting, insulation, outdoor temperature and model. Use measured or observed active hours when estimating cost:
Daily cost = Power (kW) × Active heating hours × Electricity rate ($/kWh)
A 1,500W heater that’s left on for 8 hours but actively heats for 4 of them uses 6 kWh:
At $0.10/kWh: about $0.60 per day ($18 per month)
At $0.18/kWh: about $1.08 per day ($32 per month)
At $0.24/kWh: about $1.44 per day ($43 per month)
The same heater running flat out for all 8 hours uses 12 kWh, and the cost doubles to about $1.20–$2.88 per day.
Compare Heating Costs Across Different Heater Types
Every resistive electric heater turns nearly 100% of its electricity into heat, so 1,500 watts puts out roughly 5,120 BTUs whatever shape the unit comes in. Where running costs differ is in how that warmth reaches you. Because infrared heats people and nearby objects instead of the air, you feel the effect right away even at a lower wattage. With an oil-filled radiator, the element can rest while the hot fins keep warming the room.
How Can You Reduce Room Heating Costs in Winter?
If a heater runs most days, a few small changes around the room can bring the bill down. Sealing drafts and heating only the rooms you use are the practical first steps, and your utility’s rate plan may also affect when it makes sense to use electricity. Battery backup should be evaluated separately: a power station does not make a heater connection acceptable unless the relevant product instructions allow it.
Improve Room Insulation and Seal Air Leaks
Warm air slips out through small gaps around window frames, along baseboards, and under exterior doors. A clear shrink-film window insulation kit over single-pane or drafty glass can reduce radiant heat loss. Inexpensive draft stoppers under bedroom doors and removable caulk in the baseboard gaps keep the heater’s warmth from sliding out into an unheated hallway.
Adjust Thermostat Settings and Heating Schedules
Zone heating may reduce energy use when it lets the main system run less and avoids warming unoccupied rooms. Turn the furnace thermostat down to 17°C or 18°C overnight, and use a space heater only in the occupied bedroom to maintain 20°C. During the day, close the doors to unused guest rooms, laundry closets, and storage areas so the heater warms only the rooms you’re using.
Manage Household Energy Use with Home Battery Storage
Running a space heater through a Canadian winter can add to your daily electricity use. Sealing drafts and heating only the rooms you’re in can cut that use, while a home battery may let you choose when you draw power from the grid. On a time-of-use (TOU) plan, you may be able to charge the battery during cheaper off-peak hours and use that stored power when grid rates are higher. Whether this saves you money comes down to your local rates and your charging schedule.
EcoFlow DELTA 3000 Gen4 Portable Power Station: A 3,072Wh capacity and 3,600W rated output let this unit handle high-draw appliances. That leaves plenty of room to run a standard 1,500W space heater alongside your desk setup or a few lamps.
EcoFlow DELTA 3800 Gen4 Portable Power Station: If you want broader energy independence or longer runtime through a cold snap, this larger model starts at 3,763Wh and expands to roughly 12kWh. The modular design lets you begin with the base unit, then add storage to match your household’s daily use and keep heaters running through longer peak windows.
Note: Actual bill reductions depend on regional utility rate structures, your specific charge/discharge schedule, system configuration, and broader household energy habits. Always verify that your space heater’s operating wattage falls within the rated continuous output capacity of your portable power station.
The right heater fits both the room and how you use it. Ceramic models give you a quick blast of warmth at your desk, oil-filled radiators put out quiet, steady heat for hours, and infrared suits a drafty workshop. Seal the drafts and warm only the room you’re in, and you’ll stay comfortable without the heater running harder or longer than it needs to.
Does It Cost More to Run Central Heat or a Space Heater?
For the whole house, a natural gas furnace is usually cheaper than electric space heaters. For one room, turn the thermostat down a few degrees and run a single heater, and you’ll often pay less than keeping a 2,000-square-foot house at 22°C.
Does a Heater Make the Air More Dry?
The air will feel noticeably drier, but a space heater doesn’t actually take moisture out of it. Warming a room lowers the relative humidity, and that’s what your skin and nose pick up on. Fan-forced ceramic heaters are usually the worst because they blow nonstop, while oil-filled radiators and infrared units don’t move the air.
How Long Can You Leave a Room Heater On?
Run a space heater only while you’re awake and in the same room. Models certified by safety agencies (such as CSA or cUL) have automatic shut-off and overheat sensors. Even so, the NFPA and Health Canada advise against leaving one running unattended or while you sleep. For overnight warmth, rely on your central heating, or pre-warm the bedroom with an oil-filled radiator and switch it off at bedtime. Turn the heater off and unplug it whenever you leave the room or the house.
Where Should You Not Put a Space Heater?
Never set a space heater on furniture, a wet bathroom floor, or thick carpet that blocks the intake grille. Keep it at least 1 metre (3 feet) from anything flammable, such as curtains, bedding, and paper. Don’t plug it into a light-duty power bar or standard extension cord. Either can easily overheat under a continuous high-wattage load.
