"Smart" Electrical Panels: The New Standard for 2026 Renos?
Aging electrical grids, increasing extreme weather events, power outages, and rising electrical bills have Canadians looking for smarter power options. As a result, home electrical systems in Canada are getting a major upgrade as we add solar panels, battery storage, and EV chargers. To make home electrification simple, smart electrical panels are quickly replacing traditional ones that only distribute power. Their ability to monitor, manage, and optimize how you use and generate electricity has made them an essential consideration for code-compliant, future-ready homes.
The Push For Smart Load Centres
Smart electrical panels distribute electrical loads just as a traditional, or “dumb,” panel does. However, it’s also an Energy Management System (EMS), which is a collection of software and hardware tools that monitor, manage, control, and optimize energy use in your home. It allows users to monitor and control the various circuits in their home via Wi-Fi or Bluetooth using an app on their phone. This enables them to monitor exactly how much energy each circuit is using, remotely turn circuits on or off, and prioritize certain circuits over others, such as those running refrigerators, freezers, or medical devices. If you have solar panel integration, it will also help you manage energy production, optimize battery charging, and use your solar power more efficiently.
Why Smart Panels Are Becoming So Popular
Energy management systems are becoming increasingly popular as power bills continue to rise and extreme weather events become more frequent and severe. An EMS helps make your home more energy efficient, saving you money on your electrical bills and helping reduce your carbon footprint. As a result, there is a significant push for smart panel installation when building a new home or renovating an existing one.
For instance, the EcoFlow Smart Home Panel 2 is an intelligent subpanel for home battery systems, offering a 20 ms automatic switchover so that it acts as an Uninterruptible Power Supply to protect your sensitive electronics and appliances. With the easy-to-use EcoFlow app on your phone, you can manage and optimize your energy production, storage, and consumption, making your home safer, more efficient, and more cost-effective to run.
The New UL 3141 Standard For Power Control Systems
The new UL 3141 standard is the highest safety standard from Underwriter Laboratories for Power Control Systems (PCS). A PCS is a special category of energy management systems, like a smart panel, capable of managing multiple power sources and controlling their use to keep power consumption within user-defined limits or prevent overloading.
UL 3141 defines the requirements for the safety and performance of PCS products and their components across residential homes, commercial buildings, and areas next to electrical panels. This new standard was recently published by Underwriter Laboratories in response to the growing complexity of PCS products. The new standard builds on older standards, but with specific requirements for these new PCS products.
In the USA, UL 3141 will be required in the 2026 National Electrical Code (NEC) to ensure safer, smarter home electrification and EV charging integration.
With expandable 4–48kWh capacity, the DELTA Pro 3 delivers up to 6000W to run everything from central ACs to essential appliances—anywhere. Enjoy 120V/240V output even while charging, auto-recharge via generator, and ultra-fast 50-min charging. Built for 4000+ cycles, it's portable, plug-and-play, and perfect for home, RV, or off-grid use.
The Canadian UL 3141 Equivalent
Of course, UL 3141 is more of a U.S. standard, so you may be wondering why it matters to Canadians.
In Canada, smart load centers must be certified to the Canadian Electrical Code (CEC) and CSA 22.1 standards, with key requirements including proper circuit protection, accurate labelling, correct grounding, and more. This generally requires either CSA or Underwriter Laboratories certification.
If you purchase equipment that is UL 3141-certified rather than CSA-certified, Canada does accept a joint Canada-U.S. National Standard, so it should work for you. But it's still a good idea to call the electrician who will be installing to confirm.
For instance, the EcoFlow DELTA Pro 3 home battery backup system is UL 9540-certified for fire safety, a certification recognized in Canada. And, the EcoFlow DELTA Pro 3 integrates seamlessly with your EcoFlow Smart Home Panel 2 so you can manage and optimize your home energy use.
EcoFlow DELTA Pro 3
The New Standards for Smart Panels and Renos in 2026
So, why are these new safety standards being developed? It’s because smart panels are taking off, quickly becoming the new standard for new builds and renos alike, because of how they help optimize energy consumption and production.
Since these products are still emerging technologies, the old safety standards don’t always apply, so regulators need to re-examine them and develop new standards better suited to these technologies. The end result will be safer, smarter, faster, and more convenient household electrification and EV charging.
This is why, if you plan to do a renovation or a new build in 2026, look into smart panels to help your home run more efficiently. They will also ensure that your home is future-proof to handle any additional electrification or energy production you plan to add.
Do Smart Panels Work During a Blackout?
Yes, if paired with a home battery system, many smart electrical panels can automatically switch to battery backup within milliseconds to protect appliances and sensitive electronics. They can also prioritize essential circuits like fridges, heating systems, and medical devices.
Are Smart Panels Required For Renovations in 2026?
While smart electrical panels are not universally required for renovations, the trend toward electrification is making them increasingly common in Canada. In the USA, UL 3141-certified smart panels will be required in the 2026 National Electrical Code (NEC) for safer home electrification and EV charging.
Advanced Electrical Panels Improve Energy Control, Safety, and Resilience
Smart electrical panels are no longer just a high-tech upgrade for energy enthusiasts. Instead, they are fast becoming an essential component of modern home design. As we shift towards greater electrification and battery energy storage systems, the ability to manage power loads is not just a safety requirement but also a significant financial advantage through energy savings. If you’re doing a reno this year, the EcoFlow Smart Home Panel 2 will help you prepare for rising energy costs, blackouts from extreme weather, and future upgrades you don’t even know about yet.
Home Backup
