NL Hydro Power Outages: Check Status, Report Outages and Prepare
Newfoundland and Labrador can experience power interruptions during winter storms, freezing rain, high winds and other system events. When service stops, a clear plan helps protect food, communications and household safety while the utility assesses damage and restores power.
This guide explains how NL Hydro customers can check outage updates, report an interruption and prepare for the next event. First confirm who supplies electricity to your address. NL Hydro provides retail service in parts of the province, while Newfoundland Power serves many customers on the island. Check your bill or utility website before reporting an outage.
How Can You Check NL Hydro Power Outage Status?
Reliable information helps you decide which safety steps and backup measures are appropriate. Use NL Hydro’s official channels to follow current and planned outages across its service territory.
Check the NL Hydro Outage Map for Current Updates
Use the official outage map to view current and planned events, affected accounts and available updates. The NL Hydro power outages map states that information updates every five minutes, although restoration estimates may change as crews assess damage, access and safety conditions. A current power outage map can also help readers find the correct provincial utility and understand why early estimates are provisional.
Use myNLHydro to View and Report Outages
myNLHydro is tied to your account and lets customers view and report outages and manage notifications. It complements the public map. Check the breaker panel from a safe location, and report the interruption if your address is not listed or remains without power after nearby homes are restored.
Sign Up for Power Outage Notifications
NL Hydro customers can use myNLHydro to receive text or email notifications for planned and unplanned outages. For an NL Hydro power outage update tied to your account, confirm that the service address and notification settings are current. During widespread events, details may change as field assessments continue.
Check NL Hydro Advisories for Planned Outages
Planned interruptions may be scheduled for maintenance, repairs or system upgrades. To check NL Hydro planned power outages today, review the official Advisories page and the planned view on the outage map. Dates and times can change with weather and operating conditions, so check again shortly before the stated window.
How Do You Report an NL Hydro Power Outage?
Report an unlisted interruption promptly so the utility can compare customer reports, system data and field conditions. First confirm the correct service provider and follow its reporting channel.
Check for an Existing Outage Before Reporting
Start with your utility’s outage map or account portal. If your area is already listed, the utility is tracking the event. Then check the breaker panel from a safe location to determine whether the issue may be limited to your home.
If the interruption is not listed, report it to your electricity provider. The overview of NL power outages can help distinguish the province’s two utilities and their reporting channels. Contact your provider again if nearby homes regain service while yours remains off, because your connection may have separate damage.
Report an Outage Through myNLHydro
If you are an NL Hydro customer and the outage is not shown, report it through myNLHydro. Confirm the service address on the account and include useful observations, such as whether neighbouring homes are also without power.
Contact NL Hydro by Phone When Needed
If internet service is unavailable or you need to report by phone, NL Hydro’s 24-hour outage and emergency number is 1-888-737-1296. Have your civic address or account details ready. If Newfoundland Power serves your home, use that utility’s outage reporting service instead.
Treat Energized Downed Power Lines as an Emergency
Treat every downed or dangling power line as energized, even if it is not sparking. Keep people and pets at least 10 metres (33 feet) away, avoid anything touching the line, and call 911 and the appropriate utility. NL Hydro’s winter power-line guidance confirms the 10-metre minimum and advises reporting the hazard immediately.
How Does NL Hydro Restore Power After an Outage?
Restoration work follows safety and system needs. Crews first assess hazards and damaged equipment, then repair sections that can restore service to groups of customers. A nearby home may regain power before yours when it is connected to a different line or when your service has separate damage.
Restoration Priority
Focus Area
Why It Matters
Emergency hazards
Downed lines, damaged electrical equipment, immediate safety risks
Crews must make dangerous areas safe before broader restoration work can continue
Essential services
Hospitals, emergency services, water systems, and other critical infrastructure
These services protect public health and support emergency response
Equipment serving the most customers
Main lines and larger distribution equipment
Repairs can restore power to a large number of customers at once
Smaller areas and individual services
Local lines, small groups of customers, and individual service damage
These repairs are handled after larger system and safety issues are addressed
The sequence can change with weather, road access, the severity of damage and whether repairs involve customer-owned equipment.
Restoration Time Depends on the Cause and Location
Restoration time varies with the cause, location, weather and access. A localized equipment fault may be resolved relatively quickly, while damage to remote transmission or distribution infrastructure can require specialized crews, replacement materials and safe access. A power station can support selected household loads while repairs continue, but runtime still depends on capacity and demand.
Crews Prioritize Emergencies and Essential Services
Utilities generally address immediate hazards and critical infrastructure before working through repairs that restore service to larger groups and then smaller areas or individual connections. The sequence can change with safety conditions, access and the location of damage.
Widespread Outages May Require More Extensive Repairs
A winter storm may damage several sections of a distribution line. Crews isolate hazards, assess access and repair equipment in stages. Restoration times can change as additional damage is found or weather limits safe work.
System Damage Can Affect the Restoration Process
Sometimes a feeder is live and nearby homes have power while a few properties remain dark. Damage to a customer-owned service mast or weatherhead may require repair by a qualified electrician before the utility can reconnect service. Confirm responsibility and inspection requirements with the utility and provincial authority.
EcoFlow DELTA 3 Max Plus Portable Power Station(2048Wh)EcoFlow DELTA 3 Max Plus Portable Power Station(2048Wh)
What Should You Do During an NL Hydro Power Outage?
A few sensible habits during a blackout protect the food in the fridge, spare your electronics, and keep the family comfortable.
Keep Refrigerators and Freezers Closed
Keep refrigerator and freezer doors closed. Health Canada states that an unopened refrigerator keeps food cold for about 4 hours, while a full freezer can hold temperature for about 48 hours, or 24 hours when half full. Do not rely on outdoor winter temperatures to keep food safe because conditions can vary and food may be exposed to contamination or animals.
Protect Electronics From Power Surges
Power restoration can be accompanied by voltage fluctuations that may damage sensitive electronics. Unplug computers, televisions, microwaves and game consoles after the power goes out, and leave one lamp switched on to show when service returns. Reconnect devices gradually after conditions stabilize.
Keep Important Devices Powered and Connected
During a long outage, a phone may carry emergency alerts and weather information. Use low-power mode, reduce screen brightness and charge it from a power bank or portable power station when needed so you can continue receiving updates.
Check on Family, Neighbours and Other Vulnerable People
Cold indoor temperatures can pose greater risks for older adults, infants and people with some health conditions. Check whether nearby family members or neighbours have blankets, non-perishable food, safe lighting and a warm place to go if needed.
Stay Safe Around Generators and Carbon Monoxide
Do not run a fuel-burning generator, barbecue, camp stove or propane heater inside a home, garage, shed or enclosed porch. These devices can produce carbon monoxide, an odourless gas that can cause serious illness or death. Keep working carbon monoxide alarms in the home and operate generators outdoors, well away from doors, windows and vents, following the manufacturer’s instructions.
Keep Warm Safely During Winter Outages
Monitor the indoor temperature. Blankets, layered clothing and a properly operated heat source can help for a time, but move to a warming centre or another safely heated building if the home becomes too cold, especially when children, older adults or people with health conditions are present.
How Can You Prepare for Future NL Hydro Power Outages?
Preparation can make a multi-day outage more manageable. Build a kit, plan for warmth and communications, and decide in advance which electrical loads matter most.
Build an Emergency Power Outage Kit
A Canadian household emergency kit should be easy to reach and contain supplies for at least 72 hours. The federal emergency kit checklist is a useful starting point:
  • LED flashlights and headlamps, far safer than open flames
  • More spare batteries than you think you need
  • A battery-powered or hand-crank radio for local emergency information
  • At least 2 litres of drinking water per person per day, plus water for cooking and hygiene
  • A manual can opener and shelf-stable canned food you can eat cold
  • A well-stocked first-aid kit and any prescription medication you cannot skip
  • Warm wool blankets, thermal socks, and cold-weather sleeping gear
Plan for Essential Home Loads
For selected everyday loads, the EcoFlow DELTA 3 Max Plus Portable Power Station(2048Wh) has 2,048Wh capacity and 3,000W output. It can support devices such as a refrigerator, router, lights and phone chargers during some outages. Actual runtime depends on appliance wattage, compressor cycling, temperature, battery settings and the number of devices connected.
EcoFlow DELTA 3 Max Plus Portable Power Station (2048Wh)
25dB whisper-quiet operation. 6000W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3800W such as refrigerators, coffee makers, washers, and circular saws. Ready in just 43 mins (0-80%) with generator charging.
Consider Backup Power for Extended Outages
When a coastal storm stalls or road access is limited, a rural outage in sub-zero weather may last longer than expected. If you plan to support more than a refrigerator, lights and communications, calculate each load and its required runtime before choosing a backup system.
The EcoFlow DELTA Pro Ultra Whole-Home Backup Power offers scalable storage from 6kWh to 90kWh and 7.2kW output. When connected through compatible equipment and installed as required, it can support selected high-demand household loads during an extended outage. Actual coverage and runtime depend on the configured capacity, connected loads, installation and operating conditions.
6kWh-90kWh capacity, whole house backup for weeks with comfort. One hour of solar for one day of power. Powers through the most challenging situations. With a 7.2kW output, EcoFlow DELTA Pro Ultra effortlessly runs even energy-hungry household items.
Outages are easier to manage when you know which utility serves your home, where to check updates, how to report a problem and how to stay safe until service returns. For NL Hydro customers, the official outage map, myNLHydro notifications and the 24-hour outage line are the main information channels. A practical emergency kit and appropriately sized backup power can help keep communications and selected essential devices operating during a longer interruption. Preparation will not shorten restoration work, but it can reduce disruption while crews respond.
What Causes NL Hydro Power Outages?
Severe weather is a common cause. Heavy wet snow, freezing rain, wind and ice can damage lines or equipment, while equipment failures, vehicle collisions and wildlife can also interrupt service. The cause and repair time vary by location and event.
Where Does NL Hydro Get Its Power?
Hydroelectric facilities are a major part of Newfoundland and Labrador’s electricity supply, including Churchill Falls, Muskrat Falls and Bay d’Espoir. Thermal generation and other resources also support the system, so the mix can vary with demand, maintenance and operating conditions.
What Does "Planned Outage" Mean?
It is a temporary interruption scheduled in advance so crews can safely maintain or repair electrical equipment. NL Hydro says it communicates planned outage details with as much notice as practicable, and timing may change with weather or operating conditions.
Are Newfoundland Power and Newfoundland Hydro the Same?
No. They are separate utilities operating different parts of the provincial electricity system. Newfoundland Power distributes electricity to most customers on the island, while NL Hydro generates and transmits bulk power and provides retail service in many rural and remote communities. Check your bill or utility website before reporting an outage.
