New Brunswick Power Outage Guide: NB Power, Saint John Energy, and How to Stay Ready
Power outages happen often across New Brunswick, whether from a Maritime windstorm, an ice-covered line, or routine equipment work. Most residents rely on NB Power, but homes in the City of Saint John get electricity from a separate utility, Saint John Energy. Knowing which one serves your address, and how to use its outage tools, saves time when the lights go out. This guide walks through both systems and shows practical ways to keep essential devices running until power returns.
NB Power and Saint John Energy: Know Which Outage System Serves You
Most New Brunswick households get power from NB Power. Saint John Energy is a separate, municipally owned utility serving the City of Saint John. Mixing the two up means checking the wrong outage map when your power drops.
Atlantic weather is a big reason outages are so common here. Nor'easters, post-tropical storms, and freezing rain all hit the Maritimes hard, and power outage patterns across Canada show why coastal provinces face different risks than the Prairies or BC.
NB Power Outage Tools
NB Power offers several ways to check or report a New Brunswick power outage:
  • An interactive outage map showing affected areas, with a legend based on number of customers affected
  • A lookup tool where you enter your phone or account number to check your own status.
  • A regional table of current unplanned and planned outages by area.
  • An online outage reporting form.
  • A phone line for outages and downed lines at 1-800-663-6272.
  • Map data that refreshes roughly every 10 minutes.
Saint John Energy Outage Tools
Saint John Energy runs its own outage page for customers within Saint John city limits. It uses separate contact channels from NB Power, since the two utilities operate independently. Some other municipalities also operate their own utilities, so always confirm your provider before checking an outage map. If you are not sure who supplies your home, look at the name on your electricity bill. It is the quickest way to know which outage page to bookmark before the next storm.
NB Power
Saint John Energy
Service area
Most of New Brunswick
City of Saint John only
Outage map
Interactive map with customer-count legend
Dedicated outage page
Reporting
Online form, phone, or account lookup
Online reporting and phone
Update frequency
About every 10 minutes
Varies by report volume
Staying Safe While the Power Is Out
A brief storm can knock out a single street, while an ice event can affect thousands of accounts at once. Either way, a few safety steps apply:
  • Unplug sensitive electronics to avoid a surge when service returns.
  • Keep fridge and freezer doors closed to protect food.
  • Never run a gas generator indoors or in an attached garage.
  • Report downed lines right away and treat them as live.
Health Canada notes that a full freezer keeps food frozen for about 48 hours, and a half-full freezer for about 24 hours. Winter outages raise the stakes further, since preparing for a winter power outage also means planning safe heat and protecting pipes.
Once you know how to check your outage status, the next step is a way to keep essential items powered while you wait.
Building a Portable Backup Power Plan for New Brunswick Homes
Building a Portable Backup Power Building a Portable Backup Power
A portable power station gives New Brunswick households a quieter, fuel-free alternative to a gas generator. It runs safely indoors with no exhaust. For most homes, a mid-capacity unit covers the essentials without the cost of a full home standby system.
What a Mid-Capacity Station Can Cover
The essentials for most households fall into four groups:
  • Communication: phones, a router, and a radio
  • Health: a CPAP machine or other medical devices
  • Food: a fridge for shorter stretches
  • Light: LED lamps in the rooms you use most
Working out how to size a backup generator for your household's real wattage needs helps you avoid paying for more capacity than you use.
For the four groups above, the total usually falls well short of what a whole-house system is built for. A fridge, a CPAP, a router, and a few LED lamps make a mid-capacity job, and the EcoFlow DELTA 3 Max Plus is sized for exactly that. It charges from the wall ahead of a storm and takes over by itself when the grid fails, so the CPAP keeps running even if the outage starts at 3 a.m.
EcoFlow DELTA 3 Max Plus (2048Wh)
•3,000 W Powerful Output: 6,000 W surge output. With X-Boost™ mode, supports essential household devices and selected appliances during outages. • 5 Ways to Charge, Ready in Just 43 Mins: Ready in Just 43 mins (0-80%) with generator charging. • 2-10 kWh Expandable Capacity: Easily scale up, and can achieve longer runtime with an EcoFlow Smart Generator featuring automatic start and stop. • Smart Output Priority: Choose which circuits stay powered via the app. Prioritize what matters and extend runtime when it counts most.
A power station covers the basics. Longer outages, especially in rural areas, call for a way to recharge it once the first charge runs down.
Charging Options When a New Brunswick Outage Stretches Into Days
Rural parts of New Brunswick often wait longer for restoration than Fredericton, Moncton, or Saint John. Crews usually reach dense areas first because each repair restores more customers. That makes a recharging plan essential outside the cities.
Charging From Your Vehicle
Idling a parked car just to run a phone charger wastes fuel and wears the engine. Instead of letting a parked car idle for power, a dedicated alternator charger moves energy from the vehicle's electrical system into your power station while you drive.
The EcoFlow 800W Alternator Charger turns the daily drive to town into a recharge for the DELTA 3 Max Plus. It needs a compatible EcoFlow power station to work, and the Max Plus connects through the EcoFlow Alternator Charger Custom Fit Output Cable (2m), so add the cable to the same order.
• Turbo Charging: 800 W turbo alternator charges 8× faster than traditional in-vehicle auxiliary power outlets, topping up 1 kWh in only 1.3 hours. •3-in-1 Design: Functions as a fast charger, battery maintainer, and emergency jump starter to keep your battery in mint condition. • Vehicle Compatibility: Suitable for a variety of vehicles including SUVs, pickups, and RVs. •Easy Installation: Clean, straightforward setup designed to integrate seamlessly without permanent modifications.
Charging From the Sun
For households that prefer a stationary option, a portable solar panel offers quiet, fuel-free recharging during daylight. The clear, bright days that often follow a Maritime storm are the best time to use one, and the EcoFlow 400W Portable Solar Panel plugs straight into the DELTA 3 Max Plus to make the most of them.
• High-Input Solar Charging: Delivers up to 400 W of high-capacity solar input for significantly faster recharge times. •Up to 23% Conversion Rate: Utilizes premium solar cells to capture maximum sunlight and convert energy efficiently. • Durable & Weather-Resistant: Built with multi-layered protective materials and an IP68 waterproof rating for rugged outdoor use. • Self-Supporting Adjustable Design: Includes a protective carrying case that doubles as a kickstand to optimize sunlight angles. •Compact One-Piece Folding Frame: Folds down cleanly for convenient transport and seamless storage. • Included XT60 Cable: Comes bundled with the standard solar-to-XT60 charging cable for immediate plug-and-play setup.
Stretching Your Battery Between Charges
A few habits make each charge last noticeably longer:
  • Run the fridge on the power station in bursts, keeping the door closed in between.
  • Switch lights to LED and power only the rooms you are using.
  • Charge phones and laptops during the day, when solar or driving can refill the station.
  • Turn off the power station's AC output when nothing is plugged in, since the inverter draws power on its own.
Recharge Method
Best For
Watch Out For
Alternator charger
Rural homes where you still drive daily
Requires compatible cable and a healthy alternator
Portable solar panel
Clear days after a storm passes
Output drops under heavy cloud
Whether NB Power or Saint John Energy serves your address, knowing which outage map to check saves time during a storm. Pairing that knowledge with a portable power station keeps your essentials running. A reliable way to recharge it, from your vehicle or the sun, stretches that coverage through longer rural outages. A right-sized EcoFlow power station gives New Brunswick households a quiet, practical alternative to waiting it out in the dark.
How do I know if NB Power or Saint John Energy serves my home?
If you live within Saint John city limits, Saint John Energy is typically your utility. NB Power serves most of the rest of the province, though Edmundston has its own municipal provider.
How long do power outages usually last in New Brunswick?
It varies widely by cause and location. A local fault may be fixed within hours, while widespread storm damage can take several days, especially in rural areas.
Is it safe to run a generator indoors during an outage?
No. Gas generators produce carbon monoxide and should only run outdoors. A battery power station like the EcoFlow DELTA 3 Max Plus produces no exhaust and is safe indoors.
Can a portable power station run a well pump or furnace fan?
Some can, depending on the starting wattage. Check the appliance's starting watts against the power station's surge rating before relying on it.
Where can I get help preparing for emergencies in New Brunswick?
The Government of New Brunswick publishes emergency kit and planning guidance. The NB Emergency Measures Organization also runs a 24-hour line at 1-800-561-4034.
