How to Set Up a Solar Panel Kit for Cabins, RVs, and Backyard Sheds
Solar energy is becoming ever more popular, and it’s clear to see why. This sustainable and renewable energy source offers a great, guilt-free way to supply power to your home or on-the-go RV setup and is easy to use once installed.
If you’re interested in investing in your own solar panel kit, you’ve come to the right place. Below, we discuss the basics of these kits and offer some buying tips to consider as you search for your backup power system.
Why Use a Solar Panel Kit?
Solar panel kits typically offer an all-in-one setup for your backup power needs. There are a ton of solar kits on the market, making it easy to find one best suited to your specific needs.
EcoFlow 500W Solar Kit (4 x 125W Bifacial Modular Solar Panel)
How to Set Up Your Solar Panel Kit
Choose Your Location
The first step to properly setting up your solar system is to find the right spot to place your panels. The location you choose must be considered for optimal performance, so don’t be afraid to take your time with this step.
You should always try to find a location in direct sunlight, as a heavily shaded location will dramatically impact the effectiveness of these panels. Once you have found the right spot, you’re ready to move on to the next step.
Mount the Panels
You can choose to mount your panels in a variety of ways. Some homeowners prefer to mount their panels on the roof, though this will typically require the help of a professional.
Mounting solar panels on your own is easy with the right device. EcoFlow’s 125W Bifacial Modular Solar Panel (125W, 250W, 500W kits) is easy to install and can be up and running in just a few minutes. The bifacial design is user-friendly, making it simple to set up on any flat surface in your yard or lot.
Connect Your Panels to a Battery and Inverter
Once the panels have been securely installed, it’s time to connect them to your chosen battery converter. These devices help store and transmit energy to other appliances throughout your home.
Enjoy Your Renewable Energy Source
It genuinely is as easy as those three simple steps. Once you’ve safely installed and tested your unit, you’re good to go.
EcoFlow DELTA Pro 3 in shed
Choosing the Right Solar Kit for Your Needs
Power Usage Needs
Solar kits come in a variety of models. In order to find the right one for your needs, you need to take the time to look at the specific devices you wish to provide power to. For example, if you are in search of a system to supply backup power to your larger appliances, you will need a much more powerful kit than if you were instead only trying to supply power to a small, outdoor shed.
Run a quick audit to decide precisely what you plan on using your solar kit for to better understand your required power output.
Where You Intend to Use It
Do you want a system that is easy to take on the go for your next camping adventure? Or are you looking for a more permanent setup to keep you home powered up?
These questions will help you narrow down your search and help you find the perfect solar kit for your needs.
Installation Requirements
If you would rather save money on the setup costs associated with traditional solar systems, consider choosing an all-in-one, easy-to-install system like the EcoFlow DELTA Pro 3 Solar Generator (PV400W).
This simple yet powerful system is perfect for on and off-grid uses. With the solar panel and generator included in your purchase, you can easily have this system up and running in no time.
Harness up to 2600W of solar input with dual PV ports for versatile setups. Enjoy faster charging with high conversion rates and 99% MPPT efficiency. Power all your essentials with massive AC output and manage everything seamlessly through the app—from charging priorities to real-time energy stats.
How Many Solar Panels Do I Need to Power My Cabin?
The number of solar panels needed will ultimately depend on the size of the cabin and what you plan to power throughout it. Basic cabins with minimal appliances will require fewer panels than cabins loaded with tons of high-power appliances, so try to figure out your usage needs and invest in the number of solar panels that makes the most sense for your space.
How Many Solar Panels Do I Need to Run Everything in My RV?
You will typically need at least 2 or 3 solar panels to run appliances in an RV. You will need to take into account the energy requirements of the appliances you intend to run to fully understand how many solar panels will be needed, but it is safe to assume you will need two panels at the very least to keep your RV connected.
How Many Solar Panels Do I Need to Run a Shed?
Backyard sheds come in a variety of sizes and are used for various purposes. If you have a small shed and are only looking for a way to power indoor lighting, you will likely only need one 100W solar panel. If, on the other hand, you wish to have enough energy to power tools or even control the climate of your shed, you will need to invest in more solar panels to get the job done.
Solar Panel Kits Enable Easy Access to Clean Energy
As you can see, setting up a solar panel kit is quite simple once you know the basics. These powerful backup power units are great investments and will help ensure you stay connected.
Want to learn more about your solar panel kit options? Take a look at the EcoFlow 220W Bifacial Portable Solar Panel, the perfect introduction for anyone interested in investing in solar energy.
Solar Panels
