How Long Does It Take for a Fridge to Get Cold?
A new refrigerator rarely reaches a food-safe temperature by the time the delivery truck pulls away. It may feel cool after a couple of hours, but the shelves, drawers and food compartment can take much longer to settle at an even temperature.
So, how long does it take a fridge to get cold? Depending on the model and starting conditions, the answer may be anywhere from a few hours to a full day. Room temperature, door opening and the amount of food inside all matter. The manual gives the model-specific waiting period; a refrigerator thermometer tells you when the compartment is actually ready.
How Long Does a Fridge Take to Get Cold in Different Situations?
A brand-new appliance starts with the whole cabinet at room temperature. A fridge coming back after a short outage may still have cold food and chilled interior surfaces, so it often has less cooling to make up. During an outage, a power station can help keep a compatible refrigerator running and limit how much the interior warms before utility power returns.
The ranges below are general. When timing and temperature disagree, trust the thermometer and the manufacturer's instructions.
Situation
Typical Cooling Time
When It Is Ready
Notes
New fridge after first plug-in
A few hours to about 24 hours
Interior is 4°C or lower
Follow the manufacturer’s instructions for that model
After a power outage
Several hours, depending on how warm it became
Interior has returned to 4°C or lower
A long outage may require a full cooling cycle
After being unplugged briefly
Often a few hours, but conditions vary
Thermometer confirms 4°C or lower
Recovery takes longer if the doors were open
After adding a large food load
Several hours
Food and cabinet temperature have stabilized
Warm food and blocked vents slow cooling
After changing the setting
Several hours; some models need 24 hours
Thermometer holds at the target temperature
Avoid repeated adjustments
New Fridge After First Plug-In
Most new refrigerators start to feel cool within a few hours, but reaching a stable, food-safe temperature can take much longer. In many cases, it’s best to allow several hours and, when needed, up to 24 hours for the temperature to stabilize. Use a refrigerator thermometer rather than judging by touch, and wait until the fresh-food compartment reaches 4°C or below before adding perishable food.
Starting temperature makes a difference too. A fridge delivered from a cold truck in February does not begin in the same condition as one carried into a hot apartment in July. If the unit travelled on its side, the manual may require it to stand upright before it is plugged in. That waiting period is about protecting the cooling system, not cooling the cabinet.
Place a refrigerator thermometer near the centre of the fresh-food compartment. Perishable groceries can go in once the temperature reaches 4°C or lower and the manufacturer's minimum wait has passed. Until then, leave them in a working fridge or properly iced cooler.
Fridge After a Power Outage
Recovery time depends on the length of the outage and whether the doors stayed shut. A two-hour interruption during a January ice storm may barely change the cabinet temperature. A long summer outage, followed by repeated checks of the milk, is another matter.
According to Health Canada's food and drinking-water safety guidance, an unopened refrigerator generally keeps food cold for about four hours. A full freezer may keep food frozen for roughly 48 hours, while a half-full freezer may do so for about 24 hours. If freezer storage is a concern, you can also review how long food can last in a freezer during a power outage. These time frames are planning estimates, not a substitute for a thermometer or food-safety judgment after the power returns.
Backup power can help keep the refrigerator from warming up as quickly during an outage, which can also shorten the time it takes to cool back down once power is restored. If your main goal is to keep a refrigerator, freezer, and a few basics running, the EcoFlow DELTA 3 Max Plus Portable Power Station(2048Wh) can be a practical fit. It gives you enough flexibility to power several everyday essentials at the same time, rather than having to choose between keeping food cold and charging other important devices.
25dB whisper-quiet operation. 6000W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3800W such as refrigerators, coffee makers, washers, and circular saws.
For a larger home backup setup, the EcoFlow DELTA Pro Ultra Whole-Home Backup Power makes more sense when you want to keep refrigeration, lights, and additional household needs powered during a longer outage. It is designed for a broader backup setup than refrigeration alone and can be expanded if your power needs grow.
The EcoFlow DELTA Pro Ultra delivers 7.2-21.6kW. It features a scalable 6-90kWh capacity for weeks of backup. With Smart Home Panel 2 for auto-switchover, 5 charging modes, and self-heating for freezing weather, it’s the ultimate fail-safe power solution.
Actual runtime will vary based on how often the refrigerator compressor cycles, how much power the other connected devices use, and how much stored energy is available.
Fridge After Being Unplugged
A fridge unplugged briefly for cleaning may retain a good deal of cold, especially if the doors remain closed. It will usually recover faster than an appliance that has warmed completely to room temperature. There is no dependable two-to-eight-hour rule for every model.
After a longer disconnection, treat it much like a first start. Plug it in according to the manual, keep the doors closed and wait for a thermometer reading of 4°C or lower before returning perishable food. If the refrigerator was moved or tilted, follow the manufacturer's upright-rest instructions before reconnecting it. These differences in starting conditions are why there is no single answer to how long do fridges take to get cold.
Fridge After Adding Food or Changing Settings
A large grocery shop can raise the cabinet temperature even when the appliance is working properly. Cases of room-temperature drinks are especially demanding because all that liquid has to be cooled. A packed shelf can also block a vent and leave another part of the fridge warmer.
Changing the control does not produce an instant result. On many models, the display shows the selected setting rather than the temperature beside the food. Make one small adjustment, close the doors and allow the interval stated in the manual before changing it again. Some manufacturers recommend waiting a full 24 hours between adjustments.
EcoFlow DELTA Pro Ultra Whole-Home Backup PowerEcoFlow DELTA Pro Ultra Whole-Home Backup Power
What Can Slow Down Fridge Cooling?
The number on the control panel is only one part of the picture. Heat around the appliance, warm items inside it and restricted airflow can all lengthen the process.
Fridge Size, Starting Temperature, and Room Temperature
Fridge size alone is a poor predictor because cooling systems are designed for different cabinet capacities. Starting temperature often tells you more. A room-temperature appliance has to cool its liners, shelves and drawers as well as the air inside.
The kitchen matters. Direct afternoon sun, a nearby oven or a tight cabinet opening can make heat release more difficult. Follow the clearance requirements for the model rather than assuming every refrigerator needs the same gap. A second fridge in a garage or mudroom should also be rated for the temperatures that space reaches during a Canadian winter and summer.
Food Load and Door Opening
Some cold contents help a fridge hold its temperature, but loading a new appliance with warm groceries before it is ready creates extra work. Start with the temperature, not the idea that a full or empty fridge is automatically better.
Every door opening brings in warmer, more humid air. Checking the shelves with your hand every ten minutes slows the very process you are trying to measure. Put the thermometer where it can be read quickly, then give the appliance time alone.
Airflow, Temperature Settings, and Fridge Condition
Cold air needs a route through the cabinet. Packages pushed against interior vents or stacked tightly along the rear wall can create a cold corner and a warm shelf at the same time.
A dirty or damaged gasket lets room air leak past the door. Dust around manufacturer-accessible condenser areas, poor exterior ventilation or heavy frost can also interfere with cooling. Follow the manual before cleaning coils because many newer models do not have exposed condenser parts meant for routine owner service.
Turning the control to its coldest setting will not repair a stalled fan, failed sensor or weak compressor. If the cabinet remains warm after the basic checks and recommended cooling period, it is time for proper diagnosis.
How to Help a Fridge Cool Down Faster
There is no safe shortcut that replaces normal cooling. The useful steps are modest: keep new heat out, give cold air room to move and avoid confusing the controls with repeated changes.
Keep the Doors Closed While It Cools
Load shelves, install bins and check settings before the first cooling period where possible. Once the appliance is running, leave the doors closed. If something must be removed, decide what it is before opening the door and take it out promptly.
Set the Recommended Temperature
Health Canada recommends a refrigerator temperature of 4°C or lower and a freezer temperature of -18°C or lower. If you want a closer look at the recommended refrigerator temperature for everyday use and food storage, the correct setting can vary slightly by appliance and compartment. Begin with the setting in the manual rather than automatically selecting the coldest option at startup.
Place a refrigerator thermometer near the centre of the middle shelf, away from a vent or the door. A built-in display may report the set point, not the temperature around a carton of milk.
Avoid Adding Too Much Warm Food at Once
Divide a large pot of leftovers into shallow containers so heat can escape more quickly, and refrigerate perishable food within two hours. Do not leave dinner on the counter all evening in an attempt to protect the fridge from warmth.
Wait until a new refrigerator reaches 4°C or lower before moving in perishable groceries. After that, stagger large loads of room-temperature drinks where practical and keep interior vents clear.
Leave Enough Space for Air to Circulate
Arrange food so air can move around the shelves and through the vents. Health Canada’s safe food-handling guidance advises against overfilling a refrigerator because cold air needs room to circulate.
Completely empty is not the goal. Once the fridge is cold, a reasonable amount of already chilled food helps provide some thermal mass. Just avoid packing the cabinet so tightly that vents disappear behind cartons and containers.
When Can You Put Food in the Fridge?
Cool shelves are not proof that a refrigerator is ready. The air near a vent may become cold while drawers and door shelves remain warm. Use a thermometer and respect the model's initial waiting instructions.
Fridge Area
Target Temperature
When to Add Food
Notes
Main refrigerator compartment
4°C or lower
Once the thermometer confirms the target
Place raw meat in sealed containers on the bottom shelf
Freezer
-18°C or lower
Once fully frozen conditions are reached
Frozen food can soften if added too early
Door shelves
4°C or lower, but temperatures fluctuate
After the main compartment is stable
Better for condiments than highly perishable food
Produce drawers
4°C or lower
After the fridge reaches a safe temperature
Keep produce separate from raw meat
Deli or temperature-controlled drawer
Follow the model setting
Once the drawer reaches its intended temperature
Settings differ by appliance
Bacteria grow quickly in the temperature danger zone between 4°C and 60°C. While a new or restarted fridge cools, keep perishable food in another working refrigerator, an adequately iced cooler or another safe cold-storage location. During an outage, a portable power station can also help keep a compatible refrigerator running while grid power is unavailable. Smell and appearance cannot confirm that food is safe.
A refrigerator may feel cool within a couple of hours yet need much longer to settle. Depending on the model, the official waiting period can range from roughly two hours to 24 hours. The deciding measurement is 4°C or lower in the fresh-food compartment and -18°C or lower in the freezer.
Keep the doors shut, use the recommended setting and leave interior vents open. After an outage, thermometer readings and food-safety guidance matter more than guesswork. If the appliance cannot reach 4°C after the manual's full cooling period, check the installation and arrange service if the straightforward fixes do not help.
How long do you have to wait to put food in a new refrigerator?
It depends on the model. Some current instructions call for about two hours; others specify 24 hours. Follow the manual and wait until a refrigerator thermometer reads 4°C or lower before adding perishable food.
How to fix a warm fridge?
Confirm the setting, keep the doors closed, clear interior vents and inspect the gasket. Check the required exterior clearances and make sure the appliance has steady power. If it remains above 4°C after the stated cooling period, arrange service.
Why is my fridge not cooling enough?
Common causes include frequent door opening, blocked airflow, a poor door seal, high room temperature, heavy frost or a fan or cooling-system fault. A thermometer can show whether the whole compartment is warm or only one area.
Should I unplug my fridge if it is not cooling?
Not automatically. Unplugging stops the remaining cooling and may not address the cause. Follow the model's reset instructions or contact the manufacturer. Move perishable food to safe cold storage whenever the compartment cannot hold 4°C or lower.
How long is too long for a fridge to get cold?
If a new or restarted fridge is still above 4°C after 24 hours with the doors mostly closed, review the manual and installation requirements. A blocked vent, leaking gasket, poor clearance or mechanical fault may be preventing normal cooling.
