Cost of Living in Toronto in 2026: A Realistic Monthly Budget
Toronto is consistently ranked Canada's most expensive city to live in, but "expensive" on its own does not tell you what to actually budget. The real answer depends on whether you are single, part of a couple, or supporting a family, and on which neighbourhood you land in. This guide breaks down a realistic 2026 monthly budget: rent, groceries, transit, and utilities, using current Canada-specific data for singles, couples, and families.
Rent in Toronto: What to Expect by Bedroom Type
Rent is the single biggest line item in any Toronto budget. Here is the average by unit size across the Toronto Census Metropolitan Area, based on CMHC's October 2025 Rental Market Survey:
Unit Type
Average Monthly Rent
Bachelor/studio
$1,491
1-bedroom
$1,761
2-bedroom
$2,045
3-bedroom+
$2,294
All unit types (blended average)
$1,917
Two things worth understanding about this table. First, these are averages across all occupied units, including long-term tenants whose rent increases are capped under Ontario's rent control guideline, so a unit that just became available today will typically list higher than this blended average. Second, rent varies by neighbourhood: the downtown core generally rents above this CMA-wide average, with outer areas like Scarborough, Etobicoke, and North York running below it.
The commonly cited rule of thumb is that housing should take up no more than 30 percent of gross income. At the average 1-bedroom rent of $1,761 per month, that works out to a gross annual income of roughly $70,000, which is above what many entry-level salaries in the city provide, a gap that shows up again later in this guide.
Groceries, Transit, and Everyday Expenses
These are the categories with the most day-to-day control for budgeting, since you can adjust habits here in a way you generally cannot with rent.
average cost of living in torontoaverage cost of living in toronto
  • Groceries, family of four: an estimated $17,571.79 per year in 2026, or roughly $1,464 per month, according to Canada's Food Price Report, an annual forecast produced by a consortium of Canadian universities led by Dalhousie. Ontario is specifically flagged as one of the provinces expected to see food price increases above the national average next year.
  • Groceries, single person: meaningfully less than the family figure above, though no official body publishes a single-person estimate specifically for Toronto, so treat any single-person number you see elsewhere as a general estimate rather than an official statistic.
  • Transit: an adult TTC monthly pass currently costs $156. Starting September 1, 2026, the TTC is moving to a fare-capping system where riders pay per trip and automatically ride free for the rest of the month after 47 paid trips, replacing the need to pay for a monthly pass upfront for most fare types.
One line item that gets far less attention in most budgets, but adds up every month, is utilities.
Utilities in Toronto: The Line Item People Underestimate
For a typical Ontario household using roughly 700 to 750 kWh per month, the electricity portion of the bill runs approximately $130 to $160 per month, after the Ontario Electricity Rebate is applied. This follows the roughly 29 to 30 percent Regulated Price Plan increase that took effect November 1, 2025, which was partially offset by the province raising the electricity rebate from 13.1 percent to 23.5 percent, both set by the Ontario Energy Board, the province's electricity regulator.
Electricity specifically is worth calling out because, unlike rent, it fluctuates with time-of-use pricing and seasonal heating and cooling demand, and it is one of the only line items in this entire budget that a household can actively reduce rather than just shop around for once and lock in. Our breakdown of time-of-use hydro rates in Ontario walks through how those pricing periods actually work.
Most of the categories in a Toronto budget, rent, groceries, and transit, are largely fixed costs you negotiate or shop around for once. Electricity is different. It is a monthly cost you can actively manage, and a growing number of Toronto households are doing that with home battery storage: charging on cheaper off-peak electricity and drawing on that stored power during the city's most expensive hours. The right option scales with the same budget tiers as the rest of this guide, from a single person watching costs closely to a family managing a bigger household.
EcoFlow DELTA 3 Max Plus (2048Wh)
Holds 2,048Wh out of the box, expandable to 10kWh. 3,000W continuous output with a 6,000W surge, and a full charge from empty to 80% in about 43 minutes. Runs at a quiet 25dB with a 10ms switchover during an outage, and comes with up to a 5-year warranty. A practical fit for a single person or couple in a smaller apartment who wants to shave the utilities line item without a major purchase.
EcoFlow DELTA 3 Ultra Plus (3072Wh)
Starts at 3,072Wh, expandable up to 11kWh with add-on batteries. 3,600W continuous output with a 7,200W surge, and a full charge from empty to 80% in about 48 minutes using solar and generator input together. Runs at a quiet 25dB, switches over in 10 milliseconds, and comes with up to a 5-year warranty. Built for a family managing a bigger household budget and higher overall electricity use.
If a bigger step toward cutting the electricity line item makes sense for your household, it is also worth checking whether your home qualifies for a provincial rebate, our guide to the Ontario Home Renovation Savings Program covers current eligibility for battery storage specifically.
With the full monthly picture in view, here is what it means for how much income you actually need.
How Much Income Do You Need to Live Comfortably in Toronto?
cost of living in toronto ontariocost of living in toronto ontario
The Greater Toronto Area's living wage, the hourly rate research calculates a worker actually needs to cover basic expenses without relying on subsidies, is $27.20 per hour as of the 2025 rate release from the Ontario Living Wage Network, a coalition of employers, municipalities, and community organizations. For a full-time worker, that works out to roughly $56,600 per year gross for a single adult.
For comparison, Ontario's general minimum wage is $17.60 per hour as of 2025, rising to $17.95 on October 1, 2026, a gap of $9.60 per hour, or nearly $20,000 per year at full-time hours, below the calculated living wage for the region.
For a family of four, income needs to scale up considerably to cover a larger home, more groceries, and, in many cases, child care, which is one of the largest additional costs a two-income household with children faces in the GTA specifically.
Whether you are moving to Toronto or just budgeting for the year ahead, here is the summary.
Toronto's cost of living is genuinely high, driven mainly by rent, with utilities as a smaller but controllable line item by comparison.
Build your monthly budget starting with rent, since it is the largest and least flexible cost, then layer in groceries, transit, and utilities using the figures above. For more on managing home electricity costs specifically, see the EcoFlow CA blog's guide to saving energy at home.
How much does it cost to live in Toronto per month?
Rent alone averages $1,761 for a 1-bedroom, plus roughly $1,464 a month in groceries for a family of four, $156 for a TTC pass, and $130 to $160 in electricity. Add these together for a household-specific total.
Is Toronto the most expensive city in Canada?
Toronto is consistently ranked among Canada's most expensive cities for rent specifically, generally at or near the top alongside Vancouver.
How much rent should I expect to pay in Toronto in 2026?
The Toronto CMA average is $1,761 for a 1-bedroom and $2,045 for a 2-bedroom, with downtown core units typically renting above these blended averages and outer GTA areas below them.
What income do I need to live comfortably in Toronto?
The GTA living wage is calculated at $27.20 an hour, or roughly $56,600 a year gross for a single full-time worker, well above Ontario's $17.60 minimum wage.
How much do utilities cost in Toronto?
The electricity portion alone runs about $130 to $160 a month for a typical household using 700 to 750 kWh. Water, heating, and garbage add to that depending on your building and unit type.
Is it cheaper to live outside downtown Toronto?
Yes. Outer GTA neighbourhoods like Scarborough, Etobicoke, and North York generally rent below the downtown core, though commute time and TTC access should factor into that decision too.
Save Bills
