Can I Bring a Power Bank on a Plane? Best Portable Power Banks For Travel
You’re packing for a flight and want to stay powered up, especially on long layovers or red-eye routes. But can you bring a power bank on the plane? The short answer is yes, but not without limits. Our guide breaks down airline regulations in Canada and internationally and helps you choose the right portable charger for your trip.
Are Portable Power Banks Allowed on Planes?
Yes, you can bring power banks on planes, but only in your carry-on or personal item. Most airlines and regulatory bodies prohibit power banks in checked luggage due to their lithium-ion batteries, which are considered a fire risk when stored in cargo. Always keep your device within reach and ensure it meets airline capacity limits.
Canadian Air Transport Security Authority (CATSA) Rules and Regulations
CATSA allows passengers to carry lithium-ion power banks in their hand luggage, provided the battery capacity does not exceed 100 watt-hours (Wh). If your charger is between 100–160Wh, you’ll likely need airline approval. Anything above 160Wh is generally prohibited on passenger flights.
IATA Regulations
The International Air Transport Association (IATA) sets global guidelines for most airlines. Like CATSA, IATA limits lithium-ion power banks to under 100Wh without restriction. Devices between 100–160Wh require airline approval, and each passenger may carry no more than two. Always check specific airline policies before you travel.
What Is the Best Power Bank To Take on a Plane?
When choosing a travel-friendly power bank, consider battery capacity, size, weight, and compatibility with your devices. A compact, airline-compliant power bank that magnetically connects to your phone can make travel days much smoother.
Short-Haul and Domestic Flights
You don’t need excessive capacity for short trips, just something lightweight that keeps your essentials topped up. The EcoFlow RAPID Magnetic Power Bank (5000mAh) fits snugly in your hand or bag and attaches magnetically to your phone for effortless, cable-free charging while you’re on the go.
Long-Haul and International Flights
Longer flights call for higher capacity to power phones, earbuds, or tablets throughout your journey. The EcoFlow RAPID Magnetic Power Bank (10,000mAh) offers ample juice in a compact design, while remaining compliant with airline limits. Its dual ports and magnetic design make it a versatile travel essential.
Can I Use a Power Bank During the Flight?
In Canada, the Canadian Air Transport Security Authority (CATSA) advises travelers to check with their specific airline regarding the use of lithium battery-powered devices, such as power banks, during flights. While CATSA provides general guidelines on transporting batteries, individual airlines may have their own policies concerning in-flight usage.
For instance, Air Canada and WestJet, two of Canada's major airlines, allow passengers to carry power banks in their carry-on luggage, provided they meet certain capacity requirements. However, specific rules about using these devices during the flight can vary. Some airlines may permit the use of power banks during cruising altitude but restrict their use during takeoff and landing. Others might have more stringent policies, especially in light of safety concerns associated with lithium-ion batteries.
Understanding the Difference: Power Banks vs. Portable Power Stations
Not all backup power solutions are created equal. While power banks are compact and designed primarily for mobile devices, portable power stations offer greater capacity and can support a wider range of electronics, from laptops to mini fridges. If you're unsure whether your charging needs require something more robust than a travel power bank, it's helpful to understand the key differences between portable power stations and power banks. Power banks are usually the more convenient and compliant option for air travel.
What About Wireless Charging?
As smartphone technology evolves, more travellers are choosing chargers that support wireless power transfer. This reduces cable clutter and allows for more flexible use in transit. Some travel-friendly options, like EcoFlow's RAPID Magnetic Power Bank series, offer magnetic attachment and wireless charging compatibility for certain devices. If you’re weighing your options, take a closer look at the differences between wireless chargers and traditional power banks to see which one fits your travel habits best.
Can I Bring 20000mAh Power Bank on Plane?
Yes, 20,000mAh is approximately 74Wh, which falls well below the 100Wh limit set by CATSA and IATA. You’re allowed to bring it in your carry-on, but it must not go in checked baggage.
How Do I Know if My Power Bank Is TSA Approved?
Check the power bank label or specs. If the capacity is under 100Wh (or around 27,000mAh at 3.7V), it’s generally approved by TSA, CATSA, and most international authorities. Still, always confirm with your airline for specific limits.
What Is the Biggest Power Bank I Can Take on a Plane?
Without airline approval, the maximum is 100Wh. With airline approval, you may carry up to 160Wh (roughly 43,000mAh). However, each passenger is usually limited to two devices in this range. Anything above 160Wh is not allowed.
You can bring a power bank on your flight, as long as it’s in your carry-on and meets capacity rules. Whether you’re flying across the country or halfway around the world, choosing the right charger matters. The EcoFlow RAPID Magnetic Power Bank (10,000mAh) offers smart, airline-friendly performance that keeps your devices powered wherever you land.
