Calgary's Flood Risk: History, Maps, and How to Prepare
Calgary sits at the meeting point of the Bow and Elbow Rivers. This location helped shape the city's growth, but it also contributes to Calgary's long history of flood risk. This guide covers what happened in 2013. It covers how flood risk is mapped and monitored today. It also covers what a Calgary homeowner can actually do before the next warning.
Why Calgary Floods: Rivers, Geography, and History
Calgary's location at the confluence of the Bow and Elbow Rivers shaped the city's growth. That same feature is also the source of its long flood history. The rivers made the location attractive to settle in the first place. That same proximity has always carried a cost.
According to the City of Calgary, similar floods struck the region in 1879, 1897, 1902, 1929, and 1932. All of these came long before the 2013 event most residents remember. Flooding here isn't a new problem brought on by recent climate shifts alone. It's a recurring feature of the city's geography that's shown up for over a century.
Mountain snowpack melting into already-saturated ground is the recurring setup behind the city's worst floods. Add heavy rainfall over the Rockies' steep terrain on top of that, and water arrives faster than the ground or the rivers can absorb it.
The Bow River basin alone covers around 25,000 square kilometers. It draws meltwater and rainfall from a vast mountain catchment before any of it reaches the city. That scale is part of why Calgary's flood risk is so hard to eliminate. Even major infrastructure investment upstream can only reduce the danger. It can't remove it. A major storm across that much terrain can still generate an enormous volume of water.
Understanding where that risk concentrates today starts with the province's own mapping tools. A broader look at Alberta's flood maps and forecasting tools covers this province-wide, beyond Calgary specifically.
The history explains why risk exists. The 2013 flood is the clearest example of what that risk looks like in practice.
The 2013 Flood: What Actually Happened
2013 Calgary flood along the Bow and Elbow Rivers2013 Calgary flood along the Bow and Elbow Rivers
The City of Calgary calls 2013 the largest flood the city had seen since 1897. Heavy rain fell on melting mountain snowpack over the course of just a few days, and that combination overwhelmed the rivers fast.
The Bow River peaked at roughly 2,400 cubic meters per second, about eight times its normal flow. The Elbow River peaked even higher relative to its baseline, at around twelve times normal. That's part of why Elbow River communities saw some of the worst flooding in the city.
Between 75,000 and 100,000 people across 26 communities were evacuated. The flood caused one fatality in the city. Damage across southern Alberta totaled roughly six billion dollars. About 409 million dollars of that was direct costs to city infrastructure alone, making it one of the costliest natural disasters in Canadian history at the time.
Around 34,000 locations lost power. Eleven bridges were shut down. The city's C-Train system took significant damage as floodwaters undermined tracks and flooded tunnels in the Erlton area. The Saddledome flooded up to the ninth row of seats. The city's downtown core went without power until crews restored it on June 28.
A flood event like 2013 knocked out power to tens of thousands of properties at once. A sump pump or medical device with no backup doesn't wait for the grid to catch up.
EcoFlow DELTA 3 Ultra Plus (3072Wh)
•3600 W Powerful Output: 7,200 W surge output. With X-Boost™ mode, supports heavy-duty appliances up to 4,600 W such as clothing steamers, electric dryers, lawnmowers, and electric frying pans. •Smart Output Priority: Choose which circuits stay powered via the app. Prioritize what matters and extend runtime when it counts most. •3-11 kWh Expandable Capacity: Easily scale up, and can achieve longer runtime with an EcoFlow Smart Generator featuring automatic start and stop. • 6 Ways to charge, Ready in Just 48 Mins: Ready in Just 48 Mins (0-80%) with Solar + Generator Dual Charging
A flood this size doesn't happen every year, but the city still tracks and maps that risk continuously.
How Alberta Maps and Monitors Flood Risk Today
The City of Calgary runs a defined high-risk monitoring season. It runs roughly May 15 through July 15, when river flows are tracked most closely by city and provincial hydrologists.
In recent monitoring seasons, snowpack has run well above normal in some years. Sometimes it hits 120 to 150 percent of typical levels. Major rain events have pushed flows higher than usual on top of that. These conditions are exactly what forecasters watch for as early warning signs.
The Springbank Off-Stream Reservoir was completed after the 2013 flood. It diverted roughly 13 million cubic meters of water during its first operational season. It works alongside older measures like the Sunnyside barrier and Glenmore Reservoir management as part of a broader defense system. This is part of a broader look at how Canadian cities compare on flood risk across the country.
Flood plain maps mark the areas closest to the rivers as highest risk. Calgary residents can check a specific address against these maps directly through the city's flood resource pages.
For a property inside a mapped high-risk flood plain, the stakes are whole-home rather than a single appliance. A bigger backup solution starts to make more sense than a single portable unit.
EcoFlow DELTA Pro Ultra
•7.2 kW–21.6 kW High Output: Delivers robust power capable of running entire households, including high-load appliances like central air conditioners. • 6 kWh–90 kWh Scalable Capacity: Expandable energy storage that provides continuous whole-home backup power for weeks during extended outages. • Smart Home Panel 2 Integration: Features automatic switchover, prolonged outage support, and intelligent scheduling to lower utility bills. • 5 Versatile Charging Options: Offers multi-source recharging flexibility to ensure power redundancy under any condition. •Automatic Low-Temp Self-Heating: Built-in heating activates automatically below 0°C (32°F) to ensure uninterrupted battery performance in freezing climates.
Knowing the risk on a map is one thing. Getting a specific property ready before a warning is issued is another.
Protecting Your Home Before the Next Flood Warning
The City of Calgary recommends a few basic steps each spring before the high-risk season starts: maintain eavestroughs, confirm a basement is flood resilient, and test a sump pump.
A sump pump that fails during a power outage is one of the most common ways a manageable flood turns into a basement full of water. The pump itself might work fine. But if the grid goes down at the same time the water starts rising, a pump with no backup power is no better than no pump at all.
Pairing a sump pump with battery backup closes that gap directly. Matching a battery backup to a specific sump pump's draw is worth doing before the season starts, not during a storm. Sizing it correctly under pressure is much harder than doing the math in advance.
Reporting a clogged storm drain through Calgary's 311 app takes only a few minutes. So does signing up for the city's flood alert notifications. Both are free steps that can make a real difference in how much warning you get.
Preparation matters most in the moment a warning actually goes out, not after the water is already rising.
What to Do When a Flood Warning Is Issued
Calgary flood warning preparedness and emergency responseCalgary flood warning preparedness and emergency response
  • Move what matters first. Get vehicles, important documents, and anything irreplaceable out of a basement or ground floor as soon as a warning is issued, not after water starts to rise. Waiting even a short time can mean the difference between saving something and losing it.
  • Follow evacuation instructions immediately. If one is issued for a specific community, don't wait to see how bad conditions get first. Evacuation orders are issued with the expectation that conditions will worsen, not as an overcautious first step.
  • Charge everything in advance. Keep phones, radios, and any backup power charged before the warning is issued. Charging becomes difficult or impossible once flooding actually starts and power is affected.
  • Stay out of moving water. Avoid walking or driving through moving flood water at any depth. It takes surprisingly little fast-moving water, sometimes just a foot or two, to sweep a person or vehicle off course.
Calgary's location at the Bow and Elbow Rivers gives it a real, well-documented flood history. The 2013 flood remains the clearest example of what that risk looks like in practice.
Check a property against the current flood maps. Prepare a sump pump and basement before the high-risk season. Have backup power ready before a warning is issued. The DELTA 3 Ultra Plus and DELTA Pro Ultra linked above cover a single sump pump or a whole home, depending on what your property actually needs.
How often does Calgary flood?
Calgary has a documented history of flooding dating back to 1879, with significant events in 1897, 1902, 1929, 1932, and most severely in 2013. Smaller, more localized flooding events occur more frequently.
What caused the 2013 Alberta flood?
Heavy rainfall over the Rocky Mountains combined with melting mountain snowpack, sending both the Bow and Elbow Rivers to peak flows far above their normal levels within days.
How do I check if my Calgary property is in a flood plain?
The City of Calgary provides flood plain maps through its water and flooding resource pages, letting residents check a specific address against the current risk zones.
Does homeowners insurance in Alberta cover flood damage?
Coverage varies significantly by policy and insurer. Some policies include overland flood coverage as an add-on, while others exclude it entirely, so checking your specific policy directly is the only reliable way to know.
What should I do first if a flood warning is issued for my area?
Move vehicles, documents, and valuables out of basement or ground-floor spaces immediately, and follow any evacuation instructions from the city right away rather than waiting to see how conditions develop.
Can a sump pump keep working during a power outage?
Only if it's paired with a battery backup system. A standard sump pump relies entirely on grid power and will stop working the moment an outage begins, which is exactly when it's needed most.
Home Backup
