Big White Ski Season 2026–2027: Opening Dates and Planning Tips
Planning a Big White ski trip comes down to price versus snow. Lower-cost periods can occur before all terrain is available, while January often brings deeper coverage. The resort schedules the 2026–2027 season from Thursday, November 26, 2026, to Sunday, April 4, 2027, subject to snow, safety and mountain conditions. The dates are only part of it. Check the Big White ski resort weather, snow report, holiday crowds, road conditions and lodging prices before booking. This article covers the scheduled dates, when to visit, what to prepare and what to budget.
When Does Big White Ski Resort Open for the 2026–2027 Season?
Big White usually opens in late November, but the exact date depends on how much snow is on the lower mountain and which runs are ready. The dates in this guide are projections, so check the resort’s updates before you book anything around opening week.
Expected Opening Date for the 2026–2027 Season
Big White has scheduled opening day for Thursday, November 26, 2026, or as soon as snow, safety regulations and mountain conditions permit. Confirm the latest lift and terrain status before arranging a trip around opening week.
Factors That Could Affect the Opening Schedule
Natural snowfall is the main factor because Big White relies largely on what falls rather than on extensive early-season snowmaking. A stubborn high-pressure ridge or inversion can delay lift openings, while an early run of Pacific storms can open more terrain sooner. Snow isn’t the only thing that decides which chairs spin on opening day. Each lift has to pass its Technical Safety BC inspection, and the avalanche risk in the alpine snowpack has to be managed before the upper chairs open.
EcoFlow DELTA 3000 Gen4 Portable Power StationEcoFlow DELTA 3000 Gen4 Portable Power Station
How Do You Choose the Right Time to Visit Big White?
The best time to go depends on what matters most to you: settled snow, quieter slopes, lower prices or access to more terrain. The table below gives a rough comparison of the main travel windows; conditions and rates vary from year to year.
Travel Window
Snow Quality & Depth
Crowd Density
Relative Accommodation Cost
Late Nov – Mid Dec
Variable early-season base
Low
Low
Christmas – New Year
Deepening mid-mountain cover
Very high
Peak
January
Often deeper, colder snow; conditions vary
Moderate (weekdays quiet)
Moderate
February (Family Day)
Typically deeper coverage; terrain varies
High
Peak
March – Early April
Soft spring snow, bluebird skies
Moderate
Low to moderate
Choose Travel Dates Based on Expected Snow Conditions
January through mid-February is the window for deep, dry, reliable powder, when cold Interior temperatures keep it light. Those same weeks bring the “snow ghosts” too. Freezing fog and wind coat the trees in rime ice until they look like white statues. If warmer weather and longer days suit you better, late March offers soft, forgiving snow for easy cruising.
Compare Ski Season Prices Before Booking
Midweek stays outside long weekends and school breaks may offer better value, while Christmas, New Year, Family Day and spring-break periods can bring higher demand. Compare live lodging, package and Big White ski pass prices for your exact dates before booking because availability and discounts change.
Consider Crowd Levels and Holiday Demand
Lines at busy chairs such as the Bullet Express and Ridge Rocket can be longer on weekends and statutory holidays. Midweek visits may reduce waits, but lift access, grooming and powder conditions depend on weather, operations and visitor demand.
Check Terrain Availability for Your Skill Level
Advanced riders looking for cliff drops and steep chutes in the Cliff or Gem Lake areas should aim for mid-January onward. By then the snow has usually had time to bury the rocks and deadfall. Families and beginners can stick to green runs like Easy Street or Highway 33, which open much earlier because the ground underneath is already smooth.
EcoFlow DELTA 3 Classic Portable Power StationEcoFlow DELTA 3 Classic Portable Power Station
What Should You Prepare Before Visiting Big White?
Big White takes more planning than a weekend in the city. Pack for mountain weather that can change quickly, book rentals or lessons early during busy periods, and check the forecast and road conditions before driving up from Kelowna. A portable power station can support selected trip electronics when its rated output, capacity and operating-temperature limits match the planned loads.
Pack Layers and Waterproof Ski Clothing
A practical ski trip packing list starts with three layers, plus accessories:
  • Base Layer: Moisture-wicking merino wool or synthetic thermal tops and bottoms.
  • Mid Layer: A breathable fleece or a light down jacket to keep your core warm.
  • Outer Shell: A windproof, waterproof jacket and bibs with a minimum 15,000 mm rating.
  • Accessories: Polarized goggles with a low-light storm lens, insulated mitts with hand-warmer pockets and a helmet that fits.
Reserve Ski Equipment and Lessons
Rentals and lessons can fill up during busy weekends and holiday periods, so check live availability and book ahead when needed. Confirm equipment sizing, lesson duration, meeting points and cancellation terms before arrival. Solar generators may be useful for vehicle-supported winter trips, but solar charging varies with daylight, weather, panel position and battery temperature.
Check Mountain Weather and Road Conditions
The drive from Kelowna includes winter mountain conditions, so check DriveBC and posted roadside requirements before departure. British Columbia requires winter tires or chains on most designated routes from October 1 to April 30, although some routes end the requirement on March 31. Follow the signs on the route you are using and confirm any separate rules for private resort roads.
Reliable Cold-Weather Power for Winter Road Trips and Van Campers
Cold can reduce the available runtime of phones, cameras, GPS units and other batteries. Avoid relying on the vehicle’s starter battery for non-essential charging. For a day trip or a vehicle-supported overnight stay, a compatible portable power station can support selected devices and heated gear within its output, capacity and temperature limits. Keep the unit ventilated and follow its operating instructions.
The EcoFlow DELTA 3 Classic Portable Power Station provides 1,800W rated output and can support compatible ski-trip electronics or selected appliances when their running and surge requirements remain within the unit’s specifications. Actual runtime varies with load and temperature.
1800W Powerful Output: 3600W surge output. With X-Boost™ tech, it supports high-demand devices up to 2600W, such as microwaves, refrigerators, laptops, and heated blankets.
For extended vehicle-supported journeys or winter tailgating, the EcoFlow DELTA 3000 Gen4 Portable Power Station provides 3,072Wh of capacity and 3,600W rated output. Check the starting and running requirements of any mini-fridge, block heater or work equipment before connecting it. Cold temperatures, short daylight hours, shading and panel position can reduce practical solar charging, so charge the unit indoors within its specified temperature range before departure.
3kWh capacity. 3600W output. UPS backup with <10 ms transfer time. With just 3W standby and 14W no-load power consumption, DELTA 3000 Gen4 reduces energy loss when left on between uses, delivering longer runtime for low-power essentials.
How Much Does a Big White Ski Trip Cost?
What you’ll spend depends on when you go and whether you stay in the village or drive up from Kelowna. If you plan a road trip, compare route time, road conditions and parking with village lodging. Lift tickets are only part of the budget. Big White ski resort accommodation, transportation, meals, rentals and lessons can increase the total, especially during school breaks.
Lift Ticket and Season Pass Costs
For 2026–2027, Big White lists adult full-day online prices of $124 Monday to Friday, $139 Saturday and Sunday, and $189 during published peak periods. Prices are in Canadian dollars, exclude GST and the card fee, and may change. Window rates are higher. Compare day tickets, multi-day products and season-pass options on the resort’s current ticket pages before purchasing.
Accommodation, Transportation, and Meal Costs
Lodging, transportation and meal prices vary by date, property, occupancy and booking channel. Use live quotes for your exact dates and check what taxes, resort fees, parking, transfers and meal inclusions add to the total:
  • Ski-in/Ski-out Condos & Chalets: Compare live rates, occupancy limits, minimum stays and cancellation terms.
  • Valley Lodging (Kelowna): Compare the room rate with winter driving time, parking and transfer costs.
  • Airport Shuttles: Confirm current fares, pickup times, luggage limits and whether advance reservations are required.
  • Dining: Review current menus and opening hours; groceries may help travellers control chalet meal costs.
Ski Rental and Lesson Costs
Rental and lesson prices depend on equipment category, lesson type, participant age, duration and travel date. Check Big White’s live booking pages for current rates, taxes, availability and cancellation terms before comparing group and private options.
Big White rewards a bit of planning. Pick dates that match what you want out of the trip, whether that’s fresh powder, family-friendly runs or just a few days in the mountains. Book lodging and lessons early for busy periods and leave room in your plans for shifting snow and road conditions. Get that sorted before you leave, and by the time you’re clicking in at the Ridge Rocket, the only question is how many runs you can fit in before last chair.
Is Big White Ski Resort Good for Beginners?
Yes. Big White is widely considered one of Canada’s best mountains for beginners and skiers building their skills. Gentle green runs make up roughly 18% of the terrain and wide blue cruisers account for another 54%. That means more than 70% of the mountain suits skiers who aren’t ready for the steep stuff yet. Every major chairlift serves at least one well-groomed green run back to the base, so beginners always have an easy way down.
What Can You Do at Big White Besides Skiing?
Activities beyond downhill skiing vary by date, weather and operator. Depending on current operations, visitors may find tubing, skating, snowshoeing and other winter experiences. Confirm availability, age limits, booking requirements and operating hours directly before travelling.
Does Big White Offer Night Skiing?
Night skiing is weather- and operations-dependent. Big White’s 2026–2027 ticket page currently lists the night-skiing start date as TBA, so check the resort’s weekly lift status, operating hours and ticket information shortly before visiting.
How Many Days Do You Need at Big White Ski Resort?
Three to four days gives you time to explore the resort’s 119 marked runs and get a feel for the different terrain in the Black Forest and Gem Lake areas, with some flexibility if the weather turns.
Outdoors
