What Appliances Use the Most Electricity? A South African Guide to Lower Bills
- Key Takeaways
- Which Household Appliances Use the Most Electricity?
- What Do Household Appliances Cost to Run in South Africa?
- Practical Ways to Cut Electricity Use by Appliance
- How Can Efficient Appliances and Solar Power Further Reduce Costs?
- Consider More Efficient Water Heating
- Conclusion
- FAQs
- What Appliances Use the Most Electricity When Turned Off?
Electric geysers, heaters, air conditioners and pool pumps are useful starting points when checking what appliances use the most electricity in a South African home. However, a high wattage does not always mean the highest monthly cost. Running time, cycling and your electricity tariff all matter. Comparing monthly consumption, checking your own appliances and calculating costs can show where everyday changes will help and when spending on efficient equipment or solar storage may be worthwhile.
Key Takeaways
Compare monthly kilowatt-hours (kWh), not wattage alone, to find your largest electricity expenses.
Match your checking method to the appliance, then calculate costs using your own electricity tariff.
Reduce avoidable consumption before paying for replacement appliances or an alternative energy system.
A portable power station paired with compatible solar panels may replace some grid electricity purchases; savings depend on actual use and total system costs.
Running time and operating patterns can put a lower-wattage appliance ahead of a higher-wattage one in monthly electricity use. The figures are illustrative estimates for a 30-day month, not measured South African averages. Actual results depend on the appliance, programme and usage.
Appliance | Assumed input | Assumed use or energy figure | Monthly kWh | Seasonal context |
Electric geyser | 3,000W | 3 active heating hours/day | 270 | Year-round; demand varies |
Electric heater | 2,000W | 3 hours/day at full power | 180 | Winter heating |
Air conditioner | 1,500W | 3 equivalent full-power hours/day | 135 | Seasonal cooling or heating |
Pool pump | 750W | 4 hours/day | 90 | Schedule and pool needs vary |
Tumble dryer | 2,500W | 3kWh/cycle × 12 cycles/month | 36 | More use in wet weather |
Fridge/freezer | 150W | 24 hours connected; assumed label: 365kWh/year | About 30 | Year-round; ambient heat matters |
Electric oven | 2,000W | 0.5 active heating hours/day | 30 | Depends on cooking habits |
Kettle | 2,000W | 9 minutes/day | 9 | Depends on boiling habits |
These scenarios show why a kettle can have a higher wattage than a fridge yet use less electricity per month. Heating hours mean active or equivalent full-power operation, not total time switched on. The dryer calculation uses energy per cycle; the fridge uses 365kWh/year ÷ 365 × 30, not 150W × 24 hours. Seasonal heating and cooling figures should not be extended across the whole year without checking actual use.
Once you have an energy estimate, convert it into rand using the rate that applies to your supply.
Compare Monthly Running Costs by Appliance
For illustration, assume a 30-day month and a hypothetical VAT-inclusive energy rate of R4/kWh. Monthly consumption is estimated from assumed operating times or cycle use. The costs cover energy charges only and exclude fixed service charges; actual amounts depend on your appliance use and electricity tariff.
Monthly energy cost (R) = Monthly electricity use (kWh) × Applicable energy tariff (R/kWh)
Appliance | Monthly electricity use | Monthly energy cost at R4/kWh |
Electric geyser | 270kWh | R1,080 |
Electric heater | 180kWh | R720 |
Air conditioner | 135kWh | R540 |
Pool pump | 90kWh | R360 |
Tumble dryer | 36kWh | R144 |
Kettle | 9kWh | R36 |
Under these assumptions, the geyser, heater and air conditioner account for much larger monthly costs than the kettle. Their running time and energy demand therefore deserve particular attention when choosing which appliance habits to change. Your household’s ranking may differ, so substitute your own consumption figures and applicable energy rate before estimating savings.
How Your Electricity Tariff Changes the Cost
Check whether Eskom or your municipality supplies your home. Their tariffs are not interchangeable. Prepaid describes how you pay; it does not by itself guarantee cheaper electricity or lower night-time rates. Some municipal tariffs charge different prices for successive consumption blocks. Eskom removed inclining blocks from its residential tariffs in 2025; its current tariff information also distinguishes applicable energy and fixed charges.
For example, Cape Town’s residential tariff information shows block energy rates on certain tariffs and separate service charges. Fixed charges can remain when you buy fewer kWh. Calculate savings using the energy rate for the units avoided, rather than dividing the entire bill by consumption and treating that average as the saving rate.
Hypothetical VAT-inclusive rate | Energy charge for 100kWh |
R3/kWh | R300 |
R4/kWh | R400 |
R5/kWh | R500 |
These are calculation examples, not official national tariffs. Use your supplier’s current schedule and include applicable fixed charges separately when estimating the full bill.
Reducing unnecessary hot-water use, heating time and drying cycles can lower running costs without replacing appliances. Choose changes that suit each appliance’s operating needs and your household’s routine.
Appliance | Practical action | Main benefit |
Electric geyser | Reduce unnecessary hot-water use and arrange repairs for leaks to lower geyser power use. | Less water to heat |
Heater | Heat occupied rooms only; avoid unnecessary running time and close doors or windows. | Fewer heating kWh |
Air conditioner | Clean filters as instructed; use a suitable temperature setting. | Less avoidable heating or cooling demand |
Pool pump | Match operating hours to filtration, water-quality and equipment requirements. | Avoid excess running time |
Tumble dryer | Air-dry when possible and avoid unnecessary cycles. | Fewer heated drying cycles |
Fridge/freezer | Check door seals, ventilation clearance and recommended settings. | Avoid extra compressor operation |
Electric oven | Combine suitable dishes and avoid unnecessary preheating. | Less repeated heating |
Kettle | Boil only the water needed, within the manufacturer’s fill limits. | Less water heated per boil |
For a 2,000W heater drawing full power, reducing use from three to two hours daily saves 2 × 1 × 30 = 60kWh over 30 days. At the illustrative R4/kWh, that is R240. Reducing a dryer from 12 to eight cycles at an assumed 3kWh per cycle saves 12kWh, or R48. These are conditional calculations, not guaranteed household savings.
On a suitable time-of-use tariff, you may also save money with off peak hours electricity by moving suitable tasks to cheaper periods. This changes their price, not necessarily their kWh. Moving the same use to night-time offers no tariff saving on a flat-rate supply.
Hot water, cooling and refrigeration continue to cost money even when appliances are used carefully. More efficient equipment can reduce the energy needed for these tasks, while solar power can replace part of the electricity bought from the grid. Whether either option is worthwhile depends on the investment and the running costs it can realistically reduce.
Compare More Efficient Replacement Appliances
Compare energy labels for appliances with similar capacity and performance. For the fridge example above, assume a replacement uses 200kWh/year instead of 365kWh/year. The 165kWh difference would be worth R660 annually at the same hypothetical R4/kWh rate.
If purchase and installation cost an assumed R6,000, simple payback would be about 9.1 years, excluding financing, maintenance and future tariff changes. This helps you judge whether replacing a working appliance is worthwhile. When replacement is already necessary, compare the extra price of the more efficient option rather than its full purchase cost.
Apply the same approach to air conditioners, tumble dryers and pool pumps: compare energy use for a similar workload, then weigh the expected reduction against purchase, installation and servicing costs.
A high water-heating bill makes it worth comparing alternatives to a conventional electric geyser. Options include a heat-pump water heater or a solar water-heating system.
A heat pump transfers heat from the surrounding air into the water. A solar water heater uses solar heat directly and may still need backup heating when sunlight is insufficient. Compare the options against your hot-water demand, local conditions, installation requirements and maintenance costs. Obtain a system-specific estimate rather than applying a fixed savings percentage to the full household bill.
Use Solar Electricity and Storage for Selected Appliances
Solar power can reduce running costs by replacing some electricity bought from the grid. If solar energy delivered to appliances replaces 2kWh of grid purchases each day, the 30-day energy-charge reduction would be R240 at a hypothetical R4/kWh, before equipment, installation and ongoing costs.
To use that solar electricity after sunset, an EcoFlow portable power station can store energy from compatible panels for selected appliances. Choose its capacity around the energy your fridge, lights or home-office equipment need between charges. For capacity estimates, assume 80% of nominal battery energy is available to AC appliances after operating limits and losses. This is an illustrative planning assumption, not an official EcoFlow efficiency rating.
EcoFlow DELTA 3 Max Portable Power Station
For a measured fridge load of 1kWh/day plus 0.2kWh for lighting and a router, the EcoFlow DELTA 3 Max Portable Power Station offers about 1.64kWh per cycle under that allowance. It is worth assessing for this 1.2kWh daily target if compatible solar panels can replenish the energy used, without paying for storage you would leave unused.
EcoFlow DELTA 3 Ultra Plus Portable Power Station
For a larger measured evening load of 2kWh from a compatible fridge, television and home-office equipment, the EcoFlow DELTA 3 Ultra Plus Portable Power Station provides about 2.46kWh per cycle under the same allowance. Its larger battery and higher solar input suit that greater daily transfer requirement when panel output can support it. They do not guarantee a better return for the smaller 1.2kWh case.
Knowing what appliances use the most electricity helps you target the biggest avoidable costs in your South African home. Compare actual consumption, calculate costs using your own tariff and start by reducing unnecessary use and maintaining your appliances. Consider efficient replacements or solar storage when the expected savings justify the cost, then track your electricity use to see which changes make a difference.
Devices that appear switched off may still use electricity in standby. Televisions, gaming consoles, set-top boxes and entertainment systems are worth checking, especially when network or quick-start functions remain active. Compare measured standby consumption to identify the largest draws in your home. Switch off non-essential devices at the socket when appropriate, while keeping refrigeration, security and other necessary systems powered.
Does a Kettle Use More Electricity Than a Fridge?
Not necessarily. A kettle draws high power briefly, while a fridge consumes energy across the day. Compare kettle wattage and total boiling time with the fridge’s measured or energy-label consumption. The monthly examples above show how a short-use kettle can consume less.
Does Switching Off a Geyser Save Electricity?
Savings depend on hot-water demand, insulation, temperature and how long the geyser remains off. Switching it off does not remove the energy needed to reheat water later. A suitable schedule may reduce standing losses, but savings are not a fixed percentage for every home.
Do Prepaid Meters Always Offer Cheaper Electricity at Night?
No. Prepaid describes how you pay, not whether electricity rates change by time. Night-time use costs less only if your applicable tariff offers a lower rate during that period. Check your supplier’s tariff before changing appliance schedules.
How Can You Tell Whether Replacing an Appliance Will Save Money?
Compare your current appliance’s measured consumption with the replacement model’s energy-label estimate under similar usage. Multiply the potential kWh reduction by your electricity rate, then compare the estimated saving with the purchase and installation costs. Age alone does not establish whether replacement is worthwhile.
