When Is the Best Time to Buy Prepaid Electricity in South Africa for Better Savings
Many households use prepaid electricity to manage monthly energy costs, but buying at the wrong time can make budgeting more difficult. This is why many households ask when is the best time to buy prepaid electricity. This article explains the best purchase timing and practical ways to make prepaid electricity last longer.
How Prepaid Electricity Works
Prepaid electricity is a pay-as-you-go system where households buy electricity before using it. Instead of receiving a monthly bill after consumption, electricity credit is purchased in advance and loaded onto a prepaid meter through a token or digital recharge.
Here is how it works:
  1. Buy electricity credit: A household purchases prepaid electricity through a banking app, retailer, online platform, or approved prepaid electricity vendor.
  2. Receive a token: After payment, a token number is issued and entered into the prepaid meter.
  3. Load units onto the meter: The meter accepts the token and adds the purchased electricity credit or units to the available balance.If your meter becomes blocked or shows an error, you may need a specific code to unlock a prepaid meter.
  4. Use electricity as normal: Appliances, lights, geysers, heaters, and other devices consume electricity from the available balance.
  5. Track the balance: As electricity is used, the meter deducts units automatically and shows the remaining credit.
  6. Recharge when needed: When the balance runs low, the meter usually gives a warning so the household can buy more electricity before disconnection.
This system helps households monitor electricity use more directly. Because payment is made upfront, it becomes easier to manage a monthly budget, avoid unexpected bills, and see how quickly high-consumption appliances can use up prepaid electricity.
Best Time of the Month to Buy Prepaid Electricity
Knowing the best time of the month to buy prepaid electricity can help households manage their electricity cost more effectively. A practical monthly plan is to buy the main portion early, check usage in the middle of the month, and use small top ups near the end if needed.
Early in the Month: Buy the Main Portion
The beginning of the month is usually the best time to buy the main portion of prepaid electricity. In areas where municipal prepaid tariffs use monthly block pricing, the lower-priced units are generally used first after the monthly cycle resets, while later usage may move into a higher block.
At the start of the month, households can:
  • Check the prepaid meter balance after the tariff cycle resets
  • Estimate the normal monthly electricity need based on past usage
  • Buy enough units for essential appliances such as lights, fridge, geyser, cooking equipment, and basic electronics
  • Set a clear electricity budget before other household expenses build up
  • Reduce the need for repeated emergency top-ups
A practical approach is to review the previous month’s usage and buy most of the expected amount early, rather than making many small purchases without tracking the total.
Mid-Month: Check the Balance and Adjust Usage
The middle of the month is a good time to check whether prepaid electricity is being used faster than expected. Compare the remaining balance with the number of days left in the month. If the meter balance is already low, it may be a sign that high-consumption appliances are running too often.
During a mid-month check, households should look at:
  • How many units are left on the prepaid meter
  • How many days remain before the next tariff cycle
  • Whether the geyser, heater, air conditioner, oven, tumble dryer, or pool pump has been used more than usual
  • Whether daily habits need to change before buying more electricity
  • Whether a small top-up is enough to cover the rest of the month
This step is useful because it helps identify the real reason behind fast electricity use. For example, a geyser running all day, a heater used every evening, or a pool pump running too long can quickly reduce the prepaid balance.
Late in the Month: Make Small Top-Ups Only If Needed
Near the end of the month, small top-ups are usually more practical than large purchases. If most of the monthly electricity has already been bought, a large late-month purchase may push extra units into a higher tariff block under some municipal prepaid tariff structures.
A small top-up near the end of the month can help cover basic needs such as:
  • Lighting
  • Refrigeration
  • Cooking
  • Phone charging
  • Internet router use
  • Essential household appliances
The goal is to buy only enough electricity to reach the next monthly cycle. This helps avoid overspending before the tariff blocks reset and keeps the household budget easier to control.
How to Make Your Prepaid Electricity Units Last Longer
Track Your Meter at the Same Time Each Day
Checking your prepaid meter at the same time each day makes it easier to understand your normal electricity usage. For example, if you check your balance every evening, you can see roughly how many units your household uses in 24 hours. Use this simple habit to spot changes early:
  • Write down your meter balance once a day
  • Compare today’s balance with yesterday’s balance
  • Notice days when your units drop faster than normal
  • Check whether a geyser, heater, air conditioner, pool pump, or tumble dryer ran longer than usual
  • Adjust usage before your meter reaches a low balance warning
Regular meter checks give you more time to respond. Instead of waiting for the warning beep, you can change appliance use or plan a small top-up earlier.
Set a Daily Electricity Unit Target
A daily unit budget can help your prepaid electricity last until the end of the month. Divide your remaining units by the number of days left in the month. This gives you a practical guide for how much electricity your household can use each day.
Remaining Units
Days Left
Daily Unit Guide
120 units
15 days
8 units per day
90 units
10 days
9 units per day
60 units
12 days
5 units per day
40 units
8 days
5 units per day
If your household uses more than the daily guide for several days, you can adjust early instead of waiting until the balance becomes too low. Small changes may include:
  • Shortening the geyser running time
  • Limiting heater or air conditioner use
  • Washing full laundry loads
  • Reducing tumble dryer use when clothes can dry outside
  • Avoiding unnecessary appliance use during the evening
Watch Your Biggest Power Users
In prepaid homes, large appliances can reduce the meter balance quickly. Instead of focusing only on small devices, households should pay closer attention to appliances that use more power over longer periods. Common high-consumption appliances include:
  • Geysers
  • Electric heaters
  • Air conditioners
  • Pool pumps
  • Tumble dryers
  • Electric ovens
  • Kettles
  • Washing machines
These appliances do not always need to be avoided completely, but they should be used more deliberately. For example, a geyser can be used during specific times instead of running all day, laundry can be done in full loads, and tumble dryers can be limited when clothes can dry outside. Managing these appliances usually has a bigger effect on the prepaid electricity balance than simply switching off small electronics.
Use Low Balance Alerts to Adjust Usage
A low balance alert should not only remind you to recharge. It can also show that your household used electricity faster than expected. If the warning appears earlier than usual, check what changed during the month. Before making a large top-up, ask three quick questions:
  • How many days remain before the next tariff cycle?
  • How much electricity do we need for essential use?
  • Did any high-power appliance use increase this month?
If the month-end is close, a small top-up may cover your basic needs until the next cycle begins. This helps you avoid unnecessary late-month purchases and keeps your prepaid electricity spending more predictable.
Keep Backup Power for Essential Devices
Backup power gives your household more control when prepaid units run low or when a power outage affects your area. It can keep important devices running, including phones, routers, lights, laptops, and small appliances used for work, communication, study, and daily comfort.
This is especially useful near the end of the month, when you may want to reserve your remaining prepaid units for essential household use. With a reliable backup power source, like a portable power station, you can keep selected devices powered separately and manage your main meter balance with more flexibility.
For households using prepaid electricity, the EcoFlow DELTA 3 Max Portable Power Station offers a practical way to keep essential power available when meter credits are running low or during outages. It can store electricity in advance and supply power to important devices such as lights, phones, routers, laptops, and small household appliances, helping reduce pressure on prepaid electricity when the balance is low.
The DELTA 3 Max offers a 2048Wh battery capacity and 2400W output, delivering reliable power for household appliances during daily use or outages. It supports four fast charging methods, providing flexible energy options, and uses an intelligent output priority system to keep essential devices running while reducing unnecessary power consumption. With a durable, highly adaptable battery design, it delivers over 10 years of reliable performance, making it an ideal long-term home backup power solution.
For larger homes or households with higher power needs, the EcoFlow DELTA Pro 3 Portable Power Station offers a stronger solar-ready backup option. It supports high solar input, allowing households to store more solar energy during the day and use it when essential appliances need power. With its expandable capacity and powerful output, it can support larger household devices such as refrigerators, air conditioners, and other high-demand appliances, helping prepaid homes manage daily energy needs with more flexibility.
DELTA Pro 3 is a powerful and versatile energy solution with a 4096Wh battery capacity, expandable up to 12kWh, and a 230V/4000W AC output that can meet the needs of nearly all household appliances. It supports X-Stream fast charging, reaching 80% in just 50 minutes, and offers 6 independent charging modes plus 18 combined modes for highly flexible power input. Through the EcoFlow app, it can easily monitor and manage energy consumption, helping optimise daily electricity usage. Its portable design, equipped with ergonomic handles and wheels, ensures convenient use at home or during emergencies.
Understanding when is the best time to buy prepaid electricity is not only about timing purchases, but also about building better control over daily energy use. By combining simple planning with smarter energy tools and alternative power options, households can reduce pressure on the main grid and maintain more stable electricity access throughout the month. With the right approach, managing prepaid electricity becomes more predictable, efficient, and easier to handle in the long run.
Is it cheaper to buy prepaid electricity at night?
No, in most South African homes, prepaid electricity is not cheaper simply because you buy it at night. The price is usually based on your municipality or Eskom tariff structure, not the time of day you purchase the token. The cost may be affected more by monthly tariff blocks, where units become more expensive as you buy or use more electricity within the same monthly cycle. That means the month-to-date purchase amount matters more than whether you buy at night, in the morning, or during the day. However, customers on specific Time-of-Use tariffs may pay different rates for electricity used during peak and off-peak periods, so it is always best to check your local tariff plan.
What affects how fast prepaid electricity is used?
The speed at which prepaid electricity is consumed depends mainly on the number and type of appliances in use, as well as how long they run each day. High-energy devices like air conditioners, heaters, and electric ovens can drain electricity much faster than smaller electronics. Seasonal changes and simultaneous use of multiple appliances can also significantly increase daily electricity consumption.
Where can you buy prepaid electricity in South Africa?
In South Africa, you can buy prepaid electricity through banking apps, mobile payment apps, supermarkets, petrol stations, ATMs, or online electricity platforms. After payment, you will receive a token number, which must be entered into your prepaid meter to load the units. Always check your meter number before buying, as tokens are linked to a specific meter.
Save Bills
