How Much Electricity Does a Geyser Use? A Detailed Breakdown
- Key Takeaways
- How Much Electricity Does a Geyser Use per Hour, Day, and Month?
- Calculating the Monthly Cost of Running a Geyser
- Key Factors That Influence Geyser Electricity Consumption
- Practical Ways to Reduce Geyser Power Usage
- Can a Portable Power Station Help Manage Household Energy When a Geyser Uses a Lot of Electricity?
- Conclusion
- FAQs
Hot water is essential in most homes, but heating it can account for a large portion of the monthly electricity bill. If you are wondering how much electricity a geyser uses, the answer depends on several factors, including the heating element, household hot water demand, thermostat setting, insulation, and the temperature of the incoming water.
This guide breaks down typical hourly, daily, and monthly geyser consumption in South Africa and explains how to estimate the electricity cost.
Key Takeaways
A typical 150L–200L geyser has a 2–3kW heating element, meaning it consumes about 2–3kWh during one full hour of active heating.
Total use depends on demand, inlet temperature, thermostat setting, and insulation, not just switch-on time.
In South Africa, one electricity “unit” equals 1kWh.
Monthly cost = element power × daily heating hours × tariff × 30 days.
Tariffs vary by municipality and customer category, so use the energy charge on your own account rather than relying on a single national average.
Timers, sensible thermostat settings, better insulation, and lower hot water demand can help reduce geyser electricity use.
Most 150L to 200L geysers in South Africa use a 2kW or 3kW heating element.
A 3kW element consumes 3kWh for every hour of active heating.
A 2kW element consumes 2kWh for every hour of active heating.
Since one electricity unit is equal to 1kWh, a 3kW geyser uses about 3 electricity units during one full hour of continuous heating, while a 2kW geyser uses about 2 units.
A geyser does not normally heat continuously. Its thermostat switches the element on when the water falls below the selected temperature, usually between 55°C and 60°C.
Daily consumption varies widely with household size, hot water use, inlet temperature, thermostat setting, and heat loss. For planning purposes, a household can compare low, moderate, and high-use scenarios rather than relying on a single national average. For this reason, the element rating alone cannot tell you how many units a geyser will use each day.
How Many Units Does a 150L or 200L Geyser Use to Heat a Full Tank?
As a theoretical example, heating an entire tank from about 20°C to 60°C requires roughly:
Tank Size | Approximate Energy to Heat Full Tank by 40°C |
150L | About 7.0kWh / 7 units |
200L | About 9.3kWh / 9.3 units |
These figures describe the energy required to heat a full tank of cold water and should not be treated as normal daily consumption. In everyday use, the geyser usually reheats replacement water after showers, baths, or other hot-water use while also compensating for standing heat loss.
Geyser Monthly Electricity Consumption
Illustrative Usage Level | Daily Consumption | Monthly Consumption | Energy Cost at R4.00/kWh* |
Low | 6kWh | 180kWh | R720 |
Moderate | 10kWh | 300kWh | R1,200 |
High | 15kWh | 450kWh | R1,800 |
*The R4.00/kWh figure is an example for calculation, not a national tariff. Municipal electricity prices vary by customer category, meter type, consumption block, and location. Fixed service, capacity, or network charges may also apply but are household account charges rather than electricity consumed directly by the geyser.
Use the following formula:
Geyser power (kW) × daily heating hours × electricity tariff × 30 days
When estimating daily heating time, count only the periods when the heating element is actively drawing power, rather than all the hours the geyser remains switched on. The total varies with tank size, element power, incoming water temperature, hot water use, thermostat settings, and insulation quality.
For example, if a 3kW geyser heats for four hours per day and electricity costs R4.00 per kWh:
Daily consumption: 3kW × 4 hours = 12kWh
Monthly consumption: 12kWh × 30 days = 360kWh
Monthly cost: 360kWh × R4.00 = R1,440
2026/27 Municipal Tariff Examples
Electricity tariffs differ substantially between South African municipalities and customer categories. The examples below show how 300kWh of variable electricity consumption can translate into different costs. Fixed account charges are shown separately because they are not caused specifically by running the geyser.
Municipality and Example Category | Approx. 300kWh Energy Charge | Monthly Fixed Account Charges |
City of Johannesburg — Residential Prepaid High, Block 1 | About R870 | R210 (R70 service + R140 network capacity) |
City of Cape Town — Domestic Credit, Block 1 | About R1,241 | R74.77 service and wires charge |
*These are tariff examples rather than average geyser bills. Johannesburg and Cape Town use different tariff structures, and the amount a household pays can change with consumption blocks, meter type, customer category, property or qualifying support tariffs.
To estimate the electricity cost of running a geyser, use the applicable per-kWh rate. Do not add the full household fixed charge to the geyser operating cost, because that fee would generally remain on the account regardless of whether the geyser was used.
1. Thermostat and Heating Cycles
When hot water leaves the tank, cold water replaces it, triggering another heating cycle. Around 60°C is commonly recommended as the hot-water storage temperature. Some households may use a setting near 55°C, but excessively low settings should be avoided for hygiene and safety reasons.
A higher thermostat setting increases the temperature difference the geyser must overcome and can also increase standing heat loss.
2. Water Temperature and Season
Cold inlet water requires more energy to reach the thermostat setting. Geyser consumption can therefore rise in winter, but the size of the increase depends on local climate, inlet-water temperature, household demand, and the condition of the system.
3. Tank Size and Insulation
Larger tanks store more hot water but also have more surface area through which heat can escape. Older geysers often lose heat faster than modern SANS-compliant units. A geyser blanket and insulated hot water pipes can reduce standing heat loss.
4. Household Usage Patterns
When and how hot water is used directly affects the workload of the geyser element and the total electricity consumed throughout the day.
Showers vs. Baths: A standard bath in South Africa can use roughly 80 to 150 litres of hot water, while a 5-minute shower fitted with a water-saving shower head may use only around 30 to 45 litres. Switching from baths to shorter showers can significantly reduce both water and electricity consumption, especially in larger households.
The Evening Peak: Many households use hot water during the national peak demand period (17:00 to 21:00). While this doesn't change the units used, it puts pressure on the local grid. Using a geyser timer to shift heating cycles to off-peak hours can help manage household energy flow more effectively.
5. Installation and Heat Loss
External factors such as pipe length, exposure to cold air, and installation quality can also affect heat retention. Poor installation increases heat loss between the geyser and usage points, which indirectly increases electricity consumption.
Use a Timer
A timer can shift heating to the hours before hot water is normally needed and, where time-of-use pricing applies, away from more expensive tariff periods. However, a timer does not remove the energy required to heat the water your household actually uses. Its benefit depends on usage patterns, standing heat loss, insulation, and the applicable electricity tariff.
Adjust the Thermostat
Keep the thermostat around the recommended hot-water storage range rather than setting it unnecessarily high. If the water is consistently much hotter than needed and requires substantial cold water to be mixed in at the tap, the setting may be higher than necessary.
Improve Tank and Pipe Insulation
Install a geyser blanket and insulate the first 1.5–2 metres of exposed hot water outlet piping. This is especially useful for older geysers and tanks installed in cold roof spaces.
Reduce Hot Water Waste
Take shorter showers instead of baths.
Repair leaking hot water taps.
Avoid several long showers in quick succession.
Wash clothes with cold water where practical.
Run washing machines and dishwashers with full loads.
A geyser is one of the highest electricity-consuming appliances in many South African homes. When it is heating water, it can place a significant load on the household electrical system. Instead of using a portable power station to run the geyser directly, it can help manage other household electricity use during high-demand periods.
By powering selected appliances and essential devices from stored solar energy or electricity charged at suitable times, an EcoFlow power station can reduce the amount of electricity drawn from the grid while the geyser is operating. This can help households manage peak demand, maintain essential power during load shedding, and make better use of available solar energy.
EcoFlow DELTA 3 Max Portable Power Station
The EcoFlow DELTA 3 Max Portable Power Station can support everyday household energy management when the geyser is drawing substantial power. For example, it can provide stored energy for selected devices such as Wi-Fi routers, lights, televisions, computers, refrigeration, and other compatible appliances, helping reduce their reliance on grid electricity while the geyser is heating.
The EcoFlow App allows households to monitor energy use and solar generation and schedule charging or discharging. This makes it easier to prioritise essential loads and avoid running multiple high-consumption appliances at the same time as the geyser.
For households with greater energy requirements, the EcoFlow DELTA Pro 3 Portable Power Station offers a larger energy reserve and higher output. Its 4,000W rated AC output and 4,096Wh base battery, expandable to 12kWh, make it suitable for supporting a wider range of household appliances and essential circuits, depending on the installation.
A larger battery can help keep essential appliances running for longer while the geyser completes its heating cycle. However, battery capacity and inverter output should always be matched to the appliances being powered. A 3kW geyser element, for example, consumes 3kWh for every hour of active heating, so it is generally more practical to use the power station to support lower-power household loads rather than the geyser itself.
A geyser’s electricity use depends on active heating time rather than simply how long the appliance remains switched on. A typical 2kW or 3kW element consumes 2kWh or 3kWh for every full hour of active heating, but daily and monthly consumption varies with household demand, water temperature, tank size, insulation, and thermostat settings.
Understanding both kWh consumption and your local tariff makes it easier to estimate the real cost. Timers, sensible temperature settings, improved insulation, and reduced hot-water waste can lower consumption, while battery and solar storage can support broader household energy management where appropriate.
How many hours a day should I run my geyser?
There is no fixed number of hours that suits every household. The right schedule depends on tank size, element power, insulation, household size, hot-water demand, and how long the geyser takes to reach its thermostat setting. If you use a timer, schedule heating around the periods when your household normally needs hot water rather than relying on a universal two- or four-hour rule. The thermostat will stop the element from drawing full power once the target temperature is reached.
What happens if a geyser is left on for 24 hours electric?
If an electric geyser is left on for 24 hours, it does not heat continuously. The thermostat switches the heating element on and off to maintain the set water temperature. Electricity use depends on hot-water demand, thermostat setting, tank insulation, and heat loss, so leaving it on all day can increase standby energy use compared with switching it off when hot water is not needed.
Does switching off the geyser really save electricity?
Yes. Switching off the geyser can save electricity by reducing standby heat loss when hot water is not needed. However, the water must be reheated later, so actual savings depend on how long it stays off, tank insulation, and household hot-water use. A timer can make this easier to manage.
