How Does a Gas Geyser Work? A Complete South African Guide
Reliable hot water is essential for every South African home. With rising electricity costs, varying water pressure, and different household needs, choosing the right hot water system can make a significant difference to both comfort and energy bills. If you are comparing a gas geyser with a standard electric geyser, you may want faster heating, lower reliance on electricity, or a setup that works better with your home’s plumbing. This guide explains how a gas geyser work and what you should check before choosing one for your home.
How Gas Geysers Heat Your Water Step by Step
If you are wondering how do gas geysers work, the basic answer depends on the type of system. A traditional electric geyser stores hot water in a tank, while a gas geyser heats water only when you open a hot water tap.
Here is what happens when you turn on a hot water tap:
1. Activating the Flow Sensor
The heating process starts when you open a hot water tap, such as a shower, bathroom basin, or kitchen sink. Cold water enters the inlet pipe and begins flowing through the gas geyser. A built-in flow sensor or diaphragm detects this movement and signals the unit to start the heating cycle.
2. Igniting the Burner
Once the unit detects enough water flow, it opens the gas valve and ignites the burner. Many gas geysers use battery ignition or an electronic spark system to light the flame automatically. In South African homes, most domestic gas geysers run on LPG from a cylinder, while natural gas models are only used where piped gas supply is available.
3. Heating the Water Through the Heat Exchanger
After ignition, the burner flame heats the internal heat exchanger. Cold water passes through this heated section and absorbs heat as it moves through the unit. Because the water heats while it flows, the geyser does not need to store a full tank of hot water.
4. Delivering Hot Water to the Tap
The heated water then flows directly to your open tap or shower. As long as the tap stays open and the system continues receiving water and gas, the geyser keeps heating the water on demand. This creates a continuous hot water flow without waiting for stored water to reheat.
5. Shutting Off Automatically
When you close the hot water tap, water movement stops inside the unit. The flow sensor detects that the demand has ended, the gas valve closes, and the burner switches off. The geyser then returns to standby until you open a hot water tap again.
Common Types of Gas Geysers in South Africa
Low-Pressure vs High-Pressure Gas Geysers
Water pressure is one of the first things to check when comparing gas geysers, as it affects how easily the unit ignites and keeps heating while water is flowing.
  • Low-Pressure Gas Geysers: These units are built for weaker or less consistent water flow. They are commonly used on smallholdings, farms, holiday cottages, or homes with a raised JoJo tank, borehole system, gravity-fed supply, or unreliable municipal pressure. Because they activate at lower flow, they help reduce burner cut-outs when pressure drops. However, they are usually better suited to lighter use, such as one shower, basin, or kitchen tap at a time.
  • High-Pressure Gas Geysers: These units are designed for stronger, steadier incoming water pressure. They are more common in urban and suburban homes with stable municipal supply, modern plumbing, or a pressure pump. A high-pressure model can deliver stronger shower flow and better comfort, but only when the geyser size is matched to demand. Larger 16L, 20L, or higher models are better suited to homes with heavier hot water use.
Outdoor vs Indoor Gas Geysers
  • Outdoor Gas Geysers: Outdoor models are common in South Africa where there is suitable external wall space. They are designed for outside installation and usually have a weather-resistant casing. Because they sit outdoors, exhaust gases are released into open air, which can make the setup simpler.
  • Indoor Gas Geysers: Indoor models are used when an outdoor position is not practical, such as in some townhouses, flats, kitchens, or utility rooms. These units need the correct flueing and ventilation to move exhaust gases outside the building.
LPG vs Natural Gas Geysers
  • LPG Gas Geysers: Most South African homes use Liquefied Petroleum Gas (LPG). This usually means refillable or exchangeable cylinders, such as 9kg, 19kg, or 48kg bottles, supplied by fuel stations or gas distributors.
  • Natural Gas Geysers: Natural gas models need a suitable piped gas connection. This option is limited to specific areas, mainly parts of major metros, so most households use LPG instead.
Core Benefits of Installing a Gas Geyser
1. Instant Hot Water on Demand
Gas geysers use an on-demand heating system instead of storing hot water in a large tank. When you open a hot water tap, cold water passes through the unit and heats up as it flows. This gives you hot water within seconds for showers, washing dishes, or kitchen use, without the usual geyser heat-up time of a traditional electric storage system.
2. Space-Saving Installation
Traditional electric geysers require bulky, heavy storage cylinders that usually occupy significant space inside ceilings, roof spaces, or dedicated utility cupboards. Most gas geysers feature a streamlined, wall-mounted configuration that requires a much smaller physical footprint. This design allows you to install the unit neatly onto external walls or within compact indoor utility areas, freeing up valuable storage space around your property.
3. Reduced Reliance on Grid Electricity
Water heating accounts for a significant share of household electricity consumption in South Africa. As Eskom tariffs continue to rise and many homeowners pay closer attention to the electricity cost per kWh, switching from an electric storage geyser to a gas geyser can help reduce reliance on grid electricity for daily hot water. Most gas geysers use battery-powered electronic ignition rather than mains electricity, allowing them to continue providing hot water during many power outages, provided there is sufficient water pressure and LPG available.
While a gas geyser handles hot water independently, essential appliances such as refrigerators, lighting, Wi-Fi routers, televisions, laptops, and medical devices still require electricity during outages. Pairing a portable power station like the EcoFlow DELTA 3 Ultra Plus Portable Power Station with a gas geyser creates a more complete home energy solution, keeping critical household devices powered while ensuring a reliable hot water supply and reducing overall dependence on the grid.
The DELTA 3 Ultra Plus is a smart and scalable home energy backup system designed for advanced energy management. Offering expandable capacity from 3–7kWh and up to 3600W output (7200W surge), it supports high-demand appliances with ease. Its intelligent load prioritisation via app control ensures critical devices stay powered during outages. With ultra-fast dual charging (0–80% in 75 minutes), 10ms auto-switching, and long-lasting LFP battery technology, it delivers reliable, efficient, and future-ready power for modern households seeking energy independence.
For larger homes or heavier appliance use, the EcoFlow DELTA Pro 3 Portable Power Station offers higher-capacity support. Its stronger output is better suited to demanding household appliances, while its solar input capacity allows you to make use of strong daytime sunshine. Paired with a gas geyser, it helps shift more of the home’s daily energy needs away from full grid dependence.
With a 4096Wh capacity and 4000W output, DELTA Pro 3 can support most home appliances, including high-power devices during peak demand. Its fast 80% charging in just 50 minutes, ultra-quiet operation, and multiple charging options make it ideal for power-demanding situations. It provides reliable energy support while helping homeowners better manage electricity usage and reduce pressure on the grid during high-cost periods.
4. More Efficient On-Demand Heating
A gas geyser only burns fuel when hot water is flowing. It does not keep a full cylinder of water hot throughout the day, which helps reduce standby energy waste. For South African homes replacing or reducing the use of an electric storage geyser, this on-demand heating style can make daily hot water use more efficient, especially for showers, handwashing, and kitchen routines.
Safety and Legal Installation Checks for South African Homes
  • Use a registered gas installer: Always use an installer registered with SAQCC Gas.
  • Check whether the appliance is permitted: Before buying a gas geyser, check the model on the LPGSA Permitted Appliances Database.
  • Ask for a Certificate of Conformity: After installation, the registered installer should issue a gas Certificate of Conformity (CoC).
  • Plan the installation position properly: Outdoor gas geysers are common where there is suitable external wall space. Indoor models need the correct flueing and ventilation, so they should only be installed where the appliance design and installer assessment allow it. Do not place an indoor unit in an enclosed space without proper exhaust routing.
  • Keep gas cylinders and pipework accessible: LPG cylinders, valves, regulators, and pipework should be easy to inspect and service. Avoid hiding them behind permanent structures, sealed cupboards, or areas where leaks would be difficult to notice.
  • Keep the paperwork: Store your CoC, appliance manual, installer details, and service records. These documents make future maintenance easier and help show that the gas installation was handled by the right professional.
A gas geyser is a practical and efficient solution for instant hot water, delivering reliable performance through on-demand heating. It offers a balance of convenience, energy efficiency, and consistent hot water for modern South African households. Understanding how a gas geyser works helps you choose a system that suits your home's water pressure, LPG setup, and daily hot water needs. For even greater energy resilience, pairing a gas geyser with a portable power station allows you to keep essential appliances such as refrigerators, lighting, Wi-Fi routers, and medical devices running during power outages, creating a more reliable and well-rounded home energy solution.
Is a gas geyser cheaper than an electric geyser in South Africa?
A gas geyser can be cheaper to run than an electric storage geyser for some South African households, especially when hot water use is regular and electricity tariffs are high. However, the actual saving depends on LPG prices, geyser size, shower length, installation cost, and how often your household uses hot water. For the most accurate comparison, check your appliance’s gas consumption rate and compare it with your current electric geyser usage.
What causes a gas hot water heater to go out?
A gas hot water heater may go out if the water flow is too weak, the gas cylinder is low, the ignition batteries are flat, or the burner cannot get steady gas supply. Blocked filters, scale build-up, poor ventilation, strong wind around an outdoor unit, or a faulty flame sensor can also cause the burner to cut out. If the unit keeps switching off or you smell gas, stop using it, turn off the gas supply, and contact a registered gas installer.
How long does a 9kg gas bottle last for a gas geyser?
A 9kg LPG bottle can last from about 6 hours of continuous use on a 10L/min gas geyser to around 12 days if the geyser runs for about 30 minutes per day. On a larger 16L/min unit, the same 9kg bottle may last only about 3.6 hours under high continuous use, so bigger geysers usually need larger cylinders for practical household use. For short daily showers, some homes may stretch a 9kg bottle to a few weeks, but actual usage depends on shower length, geyser size, water temperature, and the gas consumption rate.
Home Backup
