Power Backup for Home: A Guide to Choosing the Right System
When the power goes out, it is usually the small things that become frustrating first: no WiFi, no lights, a warm fridge, or a work call that cuts out halfway. A reliable power backup for home keeps daily essentials running when the grid fails. This guide compares the main backup options, shows how to size your system, and explains what households should check before choosing one for everyday use.
Types of Power Backup Systems for Home Use
Portable Power Stations
Portable power stations are compact battery units that work straight from the box. They are easy to move, quiet indoors, and useful for keeping essentials such as WiFi, phones, laptops, lights, and small appliances powered during an outage.
Many models can recharge from a wall plug, car socket, or compatible solar panels. They are not designed to run an entire home, but they work well when you need a simple battery backup option for everyday essentials without installation.
Inverter Trolleys
Inverter trolleys are a familiar sight in South African homes. They combine a battery and an inverter on a wheeled frame, giving households a movable backup setup that can support basic everyday loads during outages. Older lead-acid and gel models still exist, while lithium versions offer a more modern option.
Fixed Inverter and Battery Systems
Fixed inverter and battery systems sit inside the home’s electrical setup. They usually connect to selected circuits, so key parts of the house can keep running when the grid drops.
This option feels more seamless than a movable unit because selected circuits can switch over without plugging in devices one by one. It also needs professional installation, correct inverter sizing, and proper electrical compliance when connected to the distribution board.
Solar Hybrid Systems
Solar hybrid systems add solar panels to the battery and inverter setup. The panels generate power during the day, the battery stores energy, and the hybrid inverter manages the flow between solar, battery, grid, and household loads.
This is the most complete battery-based option for homes that want longer backup time and less dependence on grid charging. It suits households with suitable roof space, a higher budget, and a longer-term energy plan.
Petrol and Diesel Generators
Petrol and diesel generators create power from fuel instead of stored battery energy. They are still used for higher power needs, especially on farms, standalone properties, workshops, and homes where outdoor operation is practical.
Their downsides matter in residential areas. They make noise, release fumes, need fuel storage, and require regular maintenance. Many estates, townhouse complexes, and sectional title schemes may also restrict generator use because of noise, safety, fumes, and body corporate rules.
Quick Comparison of Home Backup Power Options
System Type
Backup Role
Setup Level
Best Fit
Main Limitation
Keeps essential devices running from a built in battery
No electrical installation
Renters, flats, home offices, and small backup needs
Limited capacity for large appliances or whole home backup
Inverter Trolley
Provides basic battery backup for common household loads
No electrical installation for normal use
Households that want a familiar movable backup setup
Bulkier than portable power stations, especially with older battery types
Powers selected home circuits more seamlessly during outages
Professional installation needed
Homeowners who want automatic backup for key circuits
Higher upfront cost and electrical compliance requirements
Solar Hybrid System
Combines solar generation, battery storage, grid power, and home loads
Homes with roof space, higher usage, and a longer term energy plan
Requires a larger budget, proper sizing, and suitable solar conditions
Produces power from fuel for heavier or longer outdoor use
No for standalone use, yes if connected to home circuits
Farms, workshops, standalone homes, and high power loads
Noise, fumes, fuel storage, maintenance, and possible estate or body corporate restrictions
What to Look for in a Home Power Backup System
Size Your Essential Loads First
Before buying any power backup for home, decide what you actually need during an outage.
Most households should start with essentials:
  • Internet router
  • A few LED lights
  • Phones and tablets
  • Laptop or home office screen
  • Fridge or freezer
  • Alarm system or security camera
  • Gate motor backup where needed
  • A small medical device, if approved by the device manufacturer
A simple sizing method works well:
Appliance wattage (W) × Running time (h) = Energy needed (Wh)
For example, if your router uses 20W and you want it to run for 5 hours, it needs about 100Wh. Add the totals for each appliance, then include a buffer of around 20% so you do not run the battery completely flat.
Check Output Power and Surge Capacity
Capacity tells you how much energy the battery stores. Output tells you how much power it can deliver at one time. This matters because appliances do not all draw power the same way. A router uses very little power. A fridge may need a higher surge when the compressor starts. A kettle, microwave, heater, hairdryer, air fryer, or iron can draw far more power and drain a battery quickly.
Before choosing a power backup for your home, check:
  • Rated AC output: How much power the system can supply continuously
  • Surge or peak output: How much short burst power it can handle when appliances start
For households that need more than basic WiFi and lights, the EcoFlow DELTA 3 Max Portable Power Station gives more room to handle mixed home backup needs. Its large battery capacity, strong AC output, and extra X-Boost support make it suitable for everyday essentials such as a fridge, router, laptop, lights, camera system, or small kitchen appliance, depending on the total load. The UPS function also helps connected devices stay on when the grid drops suddenly, making it more practical for work, study, food storage, and home security.
The DELTA 3 Max offers more room than a small backup unit without requiring a fixed inverter setup. Its 2048Wh capacity, 2400W rated output, and 3200W X-Boost output suit mixed household use, while wall charging takes it from 0 to 80% in 51 minutes and 500W solar input helps it recover between outages. Its< 10 ms UPS function also helps keep connected devices running when the grid drops suddenly.
Compare Recharging Options
A good home backup system should give you more than one way to recharge. Grid charging works when power returns, but solar charging can help during longer outages or daytime interruptions.
Look for these charging options:
  • Wall socket charging when grid power returns
  • Solar charging during sunny daytime hours
  • Car charging for travel or emergency use
Wall charging is the simplest option, but it leaves you waiting for the grid to come back. Solar charging adds more flexibility, especially for homes with a sunny patio, garden, driveway, or roof area where panels can get direct sunlight.
Look at Expansion Potential
Your power needs may grow. Many households start with internet, lights, and phone charging, then later add a fridge, home office, security equipment, or longer backup time.
A system with expansion batteries or solar panel compatibility gives you more flexibility. This matters if you work from home, have young children, store food in a large fridge or freezer, or live in an area with frequent local faults. Replacing an undersized system can cost more than choosing a scalable option from the beginning.
For households that want serious backup capacity from the start, the EcoFlow DELTA Pro 3 Portable Power Station offers a strong foundation for home backup. Its large capacity and high output make it suitable for homes that need more than light emergency charging, while its expandable design gives you room to increase backup time as your energy needs change. You can use it as a core backup source during power cuts, then build around it with extra battery capacity or solar charging for a more resilient setup. This makes it a better match for families who want long-term power security.
DELTA Pro 3 is a high-capacity backup solution designed for demanding household energy needs in South Africa. With a 4096Wh capacity (expandable up to 12kWh) and 4000W output, it can support most home appliances, including high-power devices like geysers during peak demand. Its fast 80% charging in just 50 minutes, ultra-quiet operation, and multiple charging options make it ideal for load shedding situations. It provides reliable energy support while helping homeowners better manage electricity usage and reduce pressure on the grid during high-cost periods.
Consider Installation and Safety Requirements
Portable power stations and inverter trolleys usually work as plug-in options. You charge the unit, plug devices into it, and use it according to the manufacturer’s instructions. Fixed systems need more care. If you want backup power connected to selected circuits, a DB board, a transfer switch, or rooftop solar, use a qualified electrical installer.
Before installation, check:
  • Whether the installer can legally complete the work
  • Whether the system needs DB board changes
  • Whether a transfer switch or changeover switch is required
  • Whether your setup needs registration with Eskom or your municipality
  • Whether you will receive the correct electrical compliance documents
  • Whether the system can expand later
Tips for Getting the Most Out of Your Backup System
Check Outage Notices and Charge in Advance
Keep an eye on official Eskom updates, municipal outage notices, planned maintenance alerts, and severe weather warnings. Charge your battery while grid power is available, especially before evening demand periods, scheduled maintenance, or long periods away from home. Do not wait until the system is nearly empty before topping it up, as municipal faults and local repairs can take longer than expected.
Focus on Essential Appliances
Use backup power for the appliances that matter most instead of trying to run the home as normal. Prioritise the refrigerator, WiFi router, security system, lights, laptop, and phone chargers. High-draw appliances such as geysers, kettles, heaters, microwaves, ovens, and irons can reduce runtime quickly, so only use them if your system supports the load and you have enough battery capacity.
Optimise Solar Charging Hours
Position solar panels where they can receive direct sunlight for as many hours as possible. Midday sun usually gives stronger charging than early morning or late afternoon light. Clean dust from the panels, avoid shade from walls or trees, and adjust portable panels during the day when practical. This helps the system recover faster between power interruptions or periods of heavy household use.
Track Your Consumption
Use the display screen or app to monitor battery level, power input, output, and estimated runtime. This helps you see which appliances use the most electricity and when the battery drains faster than expected. If the runtime drops too quickly, unplug non-essential items and keep power for the devices you need most.
Prioritise Safe Storage and Operation
Place the backup system in a dry, well-ventilated space away from direct heat, flammable materials, and water exposure. For regular home backup use, battery type matters because it can affect cycle life, heat handling, and long-term reliability. Do not overload the unit, modify cables, or use damaged plugs. If you want to connect a backup system to your home’s distribution board, use a qualified electrician and make sure the installation meets local safety and compliance requirements.
Choosing the right power backup for home comes down to understanding your energy needs, the types of appliances you want to cover, and how often and for how long power outages affect your area.
Whether you start with a portable power station for the basics or choose a larger solar generator setup for a complete home backup, the important thing is having a plan in place before the next outage happens. Power cuts in South Africa may not disappear anytime soon, but the right backup system can make everyday life far more comfortable and reliable when they happen.
How long can a home backup system power my appliances?
How long a backup system lasts depends on two things: the battery size and how much power your appliances use. For example, a 2000Wh backup system running a fridge, WiFi router, and a few LED lights could last around 10 hours under normal use. But appliances like kettles, microwaves, and heaters use much more electricity, so they will drain the battery much faster.
What should I avoid running on home backup power?
Avoid high-draw appliances unless your system specifically supports them. Kettles, heaters, geysers, ovens, hairdryers, irons, air fryers, and microwaves can drain a battery quickly. For a longer runtime, focus on essentials such as the fridge, internet router, phones, lights, and work devices.
Do I need municipal approval to install a power backup system in South Africa?
It depends on how the system connects. Fixed inverter, battery, or solar hybrid systems connected to your distribution board usually need approval or registration from your electricity distributor, which may be your municipality or Eskom. Portable power stations and plug-in inverter trolleys are usually simpler if they work as standalone appliances and are not wired into the DB board. If any system connects to fixed wiring, solar panels, or the DB board, use a qualified electrician and check local CoC and registration requirements.
Home Backup
