Free Basic Electricity in South Africa: Who Qualifies and How to Claim
Free Basic Electricity can cover part of a qualifying South African household's monthly electricity use, but the amount and registration rules vary by municipality. If you are unsure whether you qualify, where to register, or how to collect your monthly units after approval, this guide walks through the process for prepaid and conventional meters. It also covers practical ways to stretch your FBE allocation and what to consider when you need backup power or additional energy.
Key Takeaways
  • Free Basic Electricity (FBE) provides eligible households with monthly electricity support to help cover essential energy needs, but eligibility, allocation amounts, and registration requirements vary by municipality.
  • Applying for Free Basic Electricity requires proper registration and supporting documents, including identity documents, proof of address, income information, electricity account details, and prepaid meter information where applicable.
  • Households can make their FBE units last longer by prioritising essential electricity use, tracking remaining prepaid units, and cutting unnecessary consumption.
  • For many prepaid users, registering for FBE and claiming the monthly FBE token are separate steps.
What Is Free Basic Electricity?
Free Basic Electricity (FBE) helps qualifying low-income households in South Africa cover part of their basic monthly electricity needs. As a general rule, qualifying households receive 50 kWh of free electricity per month, although the amount and eligibility rules can vary between municipalities.
FBE sits within South Africa's broader Free Basic Services programme, which helps qualifying households access essential municipal services. Two of the main services include:
  • Free Basic Water: Qualifying households generally receive at least 6 kilolitres (6,000 litres) of free basic water per month for essential needs such as drinking, cooking, and cleaning.
  • Free Basic Electricity: Qualifying households generally receive 50 kWh of free electricity per month to help cover basic household electricity use.
The 50 kWh figure does not apply equally across every municipality. Some local authorities provide a larger allocation or use different consumption rules, so the amount you receive can depend on where you live and who supplies your electricity. Current examples include:
Municipality
2026/27 FBE Allocation
City of Johannesburg
50 kWh per month for indigent households registered on the Expanded Social Package
eThekwini Municipality
65 kWh per month for qualifying indigent residential customers on the municipal FBE tariff who consume less than 150 kWh per month
City of Cape Town
Qualifying City-supplied Lifeline customers can receive 60 kWh per month when average monthly electricity received is up to 250 kWh, or 25 kWh when it falls between 250 and 450 kWh
*If you are unsure which municipality to contact, use the Government's provincial and local government directory to find the correct office, then check its current FBE eligibility and allocation rules and confirm the available claiming method with your electricity supplier.
Who Qualifies for Free Basic Electricity?
Free Basic Electricity mainly supports low-income households that meet their municipality's indigent criteria. There is no single national income limit for FBE. Each municipality sets its own financial and household requirements, then confirms which residents qualify for free basic services. In most cases, you need to register as an indigent household before you can receive FBE. Your municipality may consider factors such as:
  • Household income and financial circumstances: You generally need to fall below the income threshold set by your municipality and provide the required proof of household income.
  • SASSA grants and other income: Receiving a SASSA grant does not automatically give you FBE. Some municipalities accept a SASSA card or grant records as part of the financial evidence used to assess your household.
  • Meter type and electricity use: These factors can also affect eligibility. For households supplied directly by Eskom, a 20A prepaid supply can qualify for FBE, and a 60A prepaid household can qualify when the municipality confirms indigent status. Conventional-meter households may qualify when average electricity use stays below 150 kWh per month.
  • Property value and local tariff rules: Some municipalities also use property value or electricity consumption.
How to Register for and Claim Free Basic Electricity
Free Basic Electricity registration usually starts with your local municipality, which checks whether your household meets its indigent criteria. Once you qualify, your electricity supplier and meter type affect how you receive the monthly allocation.
1. Check Where and How to Register
Start by checking whether Eskom or a municipal electricity distributor supplies your home. Your local municipality confirms your indigent status and FBE eligibility, then shares the relevant details with the electricity supplier where required.
If you want to claim free basic electricity online, first check which digital services your municipality provides. Some municipalities allow online FBE or indigent registration, whereas monthly prepaid token claims may use separate channels. Johannesburg, for example, accepts online applications for its Expanded Social Package.
2. Prepare the Required Documents
Requirements vary by municipality, but you will commonly need:
  • Identity documents: A valid South African ID or other identification accepted by your municipality.
  • Proof of residence: A municipal account, rental document, or other accepted proof showing where you live.
  • Income information: Recent payslips, SASSA records, bank statements, or an affidavit where applicable.
  • Electricity and meter details: Provide your municipal or Eskom account number and prepaid meter number, if applicable. Before applying, check your electricity meter number and confirm that it matches your electricity account. If your municipality or supplier requires the meter to be linked or registered first, you may also need to register a prepaid electricity meter.
3. Submit Your Registration and Confirm Eligibility
Submit your application and supporting documents through the channel your municipality provides, such as its website, a municipal service centre, or a local registration point. The municipality will check your income, residence and electricity details against its indigent policy.
If your household qualifies, the municipality adds your details to its indigent register and arranges the FBE allocation with the relevant electricity supplier. Processing times differ, so follow up directly with your municipality if you do not receive confirmation or your FBE benefit does not appear.
4. Receive or Claim Your Monthly FBE Allocation
How you receive FBE depends largely on your meter:
Meter Type
How You Receive FBE
Prepaid meter
Claim a monthly FBE token through the channels available from your supplier or municipality. Eskom-configured customers can use an authorised vendor or the USSD codes *130*269# and *130*869#.
Conventional meter
The electricity supplier applies the free allocation to your monthly account, then charges you for consumption above that amount.
Eligible Eskom prepaid customers can claim an FBE token without buying additional electricity at the same time.
FBE Token Tips
  • Claim your token every month: Unclaimed FBE tokens do not accumulate for future months.
  • You do not need to buy electricity first: Eligible Eskom prepaid customers can claim their FBE token separately.
  • Use a claimed token during the same calendar month: A token that you claim but do not use becomes invalid in later months.
  • Only one FBE token applies per household each month: You cannot claim additional allocations from different municipalities.
  • FBE tokens have no cash value: You cannot exchange them for cash or another service.
How to Make the Most of Free Basic Electricity?
Your monthly FBE allocation covers basic electricity needs, so keeping an eye on where those units go can help them last longer and reduce how much extra electricity you need to buy.
Prioritise Essential Electricity Use
Use your FBE units for everyday essentials first, such as LED lighting, cellphone charging and refrigeration. High-power appliances such as electric geysers, heaters, kettles and stoves can use available units much faster, so use them carefully when you need to stretch your monthly allocation.
Track Your Prepaid Electricity Units
If you use a prepaid meter, check your remaining units regularly on the meter or Customer Interface Unit (CIU). This gives you a clearer idea of how quickly your household uses electricity and makes it easier to adjust your daily use before the free allocation runs low.
Reduce Everyday Electricity Waste
Small changes can help you get more from the electricity you already have:
  • Switch off lights, televisions and other appliances when you do not need them.
  • Boil only the amount of water you need in the kettle.
  • Use natural daylight during the day where practical.
  • Reduce standby power use from appliances and electronics.
  • Check your municipality's electricity tariff before buying extra units. Some municipalities use consumption-based tariff blocks, so the price per unit can change as monthly electricity use increases.
Beyond FBE: Managing Additional Energy Needs and Power Outages
Free Basic Electricity helps qualifying households cover part of their essential monthly electricity use, but the allowance does not cover every household need and does not provide backup when grid power goes out. Once the monthly FBE units run low, households may need to purchase additional electricity or use another energy source for essential appliances.
Backup Power for Essential Appliances During Outages
During an outage, the priority is usually to keep essential devices running, such as refrigeration, Wi-Fi equipment, lights, and mobile devices. A portable power station can provide stored backup power for these loads and help households manage short-term supply interruptions more easily.
The EcoFlow DELTA 3 Ultra Plus Portable Power Station works well for this type of household backup. It can support several essential appliances during an outage, and its UPS function can help connected equipment continue operating through short power interruptions. The EcoFlow app also lets you check battery level, current power use, and estimated remaining runtime, which makes it easier to manage stored energy during an outage.
- 3072Wh Capacity, 3600W AC Output - X-Boost™ up to 4700W, 7200W Surge Output - Expandable Capacity from 3kWh to 7kWh - < 10 ms UPS Auto-Switch - 5 Fast Charging Methods
Solar Storage for Longer-Term Energy Flexibility
Solar panels can help reduce the amount of grid electricity a household needs to buy, especially when daytime generation covers part of daily use. Adding battery storage allows households to save solar energy for evening use or power outages.
Pairing solar panels with the EcoFlow DELTA Pro 3 Portable Power Station can help households cover energy needs beyond their monthly FBE allocation. Its strong solar input supports faster daytime solar charging, and the expandable battery setup provides more stored energy for longer use. Strong AC output also supports a wider range of household appliances, while the EcoFlow app lets you monitor solar input, battery level, and power use in real time.
- 4096Wh Capacity, 4000W AC Output (230V) - Expandable Capacity from 4kWh to 12kWh - Up to 2600W Solar Input - 6 Charging Methods and 18 Charging Combinations, 0–80% Charge in 50 Minutes - Smart App Control for Energy Management
Free Basic Electricity can reduce the cost of basic household electricity, but the amount you receive and how you claim it depend on your municipality and meter type. Check your local rules, claim prepaid tokens each month where required, and keep track of your remaining units so you know when you need to buy additional electricity or use backup power.
Do I need to buy electricity to claim my FBE token?
No. You do not need to buy additional electricity just to collect your monthly FBE allocation. Eskom allows eligible prepaid customers to claim their token through an authorised vendor, and eligible Eskom customers can also use 130269# or 130869#. Claim your FBE token each month because unclaimed tokens do not roll over. If your municipality supplies your electricity, check its local claiming channels, as the available options may differ.
Why am I not receiving my Free Basic Electricity allowance?
If you are not receiving your Free Basic Electricity allowance, it may be due to issues such as incomplete registration, incorrect household information, or not being listed on the municipality’s indigent register. In some cases, delays in verification or changes to account details can also affect the allocation. Contact your local municipality or electricity provider to check your registration status and resolve any issues.
What happens to Free Basic Electricity when I move house?
When moving to a new address, your Free Basic Electricity support may not automatically transfer to your new property. You may need to update your information with the local municipality and provide details for the new electricity account or meter. The municipality will review your updated information and confirm whether your household remains eligible. Always check the registration requirements before moving to avoid interruptions in receiving your monthly allocation.
Local Policy
