One-Step Balcony Solar System: Transform Any Space into a Solar Power Station
This adaptive solar solution transforms any sunlit surface into a mini solar power station from rooftops to balconies, gardens to vertical walls.
Choose Your Balcony Solar System
Dawn to Dusk, Rain or Shine: Power Your Home Even in Low Light
The EcoFlow STREAM Balcony Solar System excels even in low light. The microinverter activates with just 3W of solar input, ensuring a steady power supply to your home, even during early morning or dusk hours.
60% More Power:
A Smart Tracker Unlocks Maximum Solar Efficiency
60% More Power: A Smart Tracker Unlocks Maximum Solar Efficiency
The EcoFlow Single-Axis Solar Tracker 2 helps your balcony capture more solar energy, even in limited space. It automatically adjusts its angle to maximise energy production, compensating for sunlight variations throughout the day. It also adapts to nearby trees or buildings casting shadows, optimising overall energy efficiency.
Energy Mastery with AI
Powered by Eco-AI, the EcoFlow app offers smart energy management like never before. AI-TOU Mode maximises bill savings by analysing grid and solar data, while the AI Energy Assistant gives you 24/7 control with one tap. Customize energy routines and control appliances remotely, whether you're home or away.
Seamless Smart Home Integration
Effortlessly connect with multiple third-party smart meters and digital energy platforms for real-time monitoring and control of your home’s energy usage via the EcoFlow app.
Your 24/7 AI Energy Assistant: Smarter, Simpler Power
Integrates effortlessly with multiple third-party smart meters, allowing real-time monitoring of your household energy usage through the EcoFlow app.
One-Tap Energy Insights
Track all types of energy data in real-time, directly through the AI assistant.
AI-Driven Energy Report
222222222222222222
Instant Product Support
222222222222222222
Plug & Play:
Start Generating Power in Just xx Minutes
No Drilling Required
The drill-free design allows flexible placement and easy movement—perfect for renters.
DIY Solar System: Easy Setup, No Electrician Needed
With a plug-and-play design, set it up yourself in no time—no need for an electrician.
Flexible DIY Solar Panels to Capture Every Watt
Easily Upgrade to Energy Storage in One Simple Step and Save More on Your Bills
Seamless integration with the EcoFlow STREAM Series: easily connect and store. Scalable capacity from 2-12kWh lets you customise your storage units.
