EcoFlow STREAM Plug & Play Solar System
Plug-and-Play—Turn Any Space into a Solar Station
NEMA 6
microinverter
solar panel
Saves you up to
$385
on electricity bills
Smart APP
energy management for maximum efficiency
10-year warranty
for long-term reliability
Easy
DIY installation
High efficiency with a
23%
conversion rate
UL1741-Certified IEEE1541-Certified
Full-system validation for electrical safety (over-voltage/short-circuit protection), device reliability (life/durability), and fire-proof stable operation in faults.
One-Step Plug & Play Solar System: Transform Any Space into a Solar Power Station1
This adaptive solar solution turns any sunlit surface into a mini solar power station—from backyards to rooftops, gardens to vertical walls.
Choose Your Solar System
Capture Sunlight, Power Your Home — Save $385 Annually
The EcoFlow STREAM Plug & Play Solar System seamlessly integrates solar panels with a microinverter, converting sunlight into ready-to-use electricity for your home. It can power your Wi-Fi router, refrigerator, TV, and radio during the day. Capable of generating up to 2,409 kWh annually, this system can help you save up to $385 per year on energy costs.
2,409kWh
2
Generates 2,409 kWh of solar energy annually.
$385
3
Saves you up to $385 on electricity bills.
22%
4
22% reduction in annual energy consumption.
No Drilling Required
The drill-free design allows flexible placement and easy movement—perfect for renters.
Easy DIY Setup
With a plug-and-play design, set it up yourself in no time—no electrician needed.
Flexible DIY Solar Panels for Optimal Energy Capture
IP68 Waterproof rating
Up to 23% Conversion Efficiency
All-black design that fits any house style
Dawn to Dusk, Rain or Shine: Power Your Home Even in Low Light
The EcoFlow STREAM Plug & Play Solar System performs reliably even in low light. Its microinverter activates with just 3W of solar input, ensuring continuous power supply from early morning to dusk.
Your 24/7 Energy Assistant: Smarter, Simpler Power
Seamlessly integrates with multiple third-party smart meters, enabling real-time monitoring of your home’s energy use via the EcoFlow app.
Status Overview
Monitor all energy data in real time.
Savings Calendar
Track your daily and weekly savings.
Remote Control
Manage connected devices anytime, anywhere.
Easily Upgrade to Energy Storage in One Simple Step and Save More on Your Bills
Seamless integration with the EcoFlow STREAM Ultra—just connect and store. Scalable capacity from 1.92–11.52kWh lets you customize your storage setup to match your energy needs.
1. Due to restrictions under the H.B. 340 Solar Power Amendments, this product is only available for plug-and-play installation within the state of Utah. Please consult with local professionals before installing rigid solar panels on rooftops or using the STREAM Microinverter with third-party rooftop installations.
2. Projected power generation values are based on the use of 1 × EcoFlow STREAM Microinverter under simulated conditions, calculated with 5.5 hours of sunlight per day in the U.S., including weather factors such as rain throughout the year.
3. The estimated savings are based on projected generation from 1 × EcoFlow STREAM Microinverter, combined with the average U.S. electricity rate. Actual savings may vary depending on regional utility rates, usage patterns, and environmental conditions.
4. Self-consumption is calculated using power generation estimates from 1 × EcoFlow STREAM Microinverter, aligned with average annual U.S. household electricity use. Results may vary based on location, climate, and system configuration.
5. Certain AI features in the EcoFlow app require a premium subscription. Please refer to the EcoFlow app for details on subscription plans and feature availability.
6. Due to restrictions under the H.B. 340 Solar Power Amendments, this product is only available for sale and plug-and-play installation within the state of Utah.
