Automatic Backup for Your Essentials
Keep up to 10 selected circuits powered automatically when the grid goes down.
Keep essential circuits backed up, check home energy use in the EcoFlow app, and make better use of solar and stored power with your TITAN system.
Check total home energy use in the EcoFlow app—including loads beyond your backup circuits—with CT sensing.
Use solar and stored energy to buy less electricity when rates are high.
10 Circuit Breakers Included| Factory-Prewired Connections| Factory-Prewired Connections
Connect up to 10 selected circuits to TITAN + SHP10 for backup power. Check each connected circuit’s power use and turn it on or off in the EcoFlow app.
Keep the lights on, the refrigerator running, and essential outlets powered during an outage.
1
2
3
4
5
While the grid is on, your TITAN + SHP10 system can use stored energy to support household demand beyond the backup circuits. CT sensing measures total home energy use to help the system manage that power.
During an outage, backup power is limited to the selected circuits connected to SHP10.
Prepare for storms, switch to backup automatically, and prioritize the circuits you rely on—all with your TITAN + SHP10 system.
Powered by
With compatible rooftop solar, TITAN or TITAN Plus paired with SHP10 can store surplus solar for later. Use stored solar or electricity charged at lower off-peak rates to reduce grid purchases when rates rise.
Work With The Grid
Rooftop-grade Solar Input
Full Power. Lower Bills
AC Coupling requires TITAN or TITAN Plus and a compatible solar installation. Whole-home energy management operates while grid-connected. Savings depend on energy use and electricity rates.
Keep your compatible solar or home battery system. Add TITAN + SHP10 for more storage and backup power for selected circuits.
Share your delivery details and contact information.
We’ll reach out within 2 business days to confirm your installation time.
Our certified engineer installs and commissions your system—ready to use the same day.
Verify your system and start enjoying reliable whole-home power.
Personalize your setup, cost, and installation plan before you buy.
Free quotation | Online Appointment | Live Installation Guidance
Email us: liveinstallsupport@ecoflow.com
Call Today: +1 858-868-6364
* After submitting a quote request, a certified electrician will contact you within 2 business days to schedule your assessment. Depending on local service availability, the assessment may be conducted in person, via photos, or through a video call. This assessment is completely free and comes with no obligation to purchase.
Choose the backup power and solar capacity your home needs, paired with the right SHP10 version.
Essential 120V Backup
Keep essential 120V circuits powered during an outage, with control in the EcoFlow app.
Home Backup and Everyday Savings
Back up selected 120V/240V circuits and store surplus energy from compatible rooftop solar to reduce grid purchases.
More Solar. More Power for Your Home
Connect up to 8 kW of solar input. Power more of your selected loads with up to 10 kW output when solar and battery work together.*
*Up to 10 kW output on TITAN Plus requires compatible solar input working together with the battery. Battery-only output is up to 7.2 kW.
