What is Energy Efficiency? 7 Ways to Conserve Energy at Home
We all want a comfortable home, but no one likes a high energy bill. Finding the right balance between comfort and cost is a common goal for homeowners. The key to achieving this is energy efficiency—a straightforward approach to using less energy without sacrificing the way you live. This guide will explain what energy efficiency is and how it differs from energy conservation. Then, it will lay out seven practical strategies to help you reduce your energy use and save money.
Energy Efficiency vs. Energy Conservation: What's the Difference?
To effectively save energy, it helps to first understand the two main approaches: using better technology and changing habits. Though they work together, they are two distinct ideas.
Energy efficiency means using technology that performs the same task with less energy. It's about using smarter equipment, not about cutting back. The best example is the lightbulb. An LED bulb and an older incandescent bulb both light up a room, but the LED uses up to 80% less electricity to produce the same amount of light. The function is identical; the energy required is not. That is efficiency in action.
What is Energy Conservation?
Energy conservation is about behavior. It's any action you take to use less energy. When you switch off a light as you leave a room, you are conserving energy. This isn't about technology; it's a conscious choice to reduce how much power you are using at that moment.
The best results come from combining these two methods. When you use an efficient LED bulb (efficiency) and also remember to turn it off when it's not needed (conservation), you achieve the maximum possible savings.
The 7 Key Strategies for Home Energy Savings
Now that you have a good grasp of the ideas, let's look at the best ways to use them. These seven strategies focus on the most energy-intensive parts of a normal home and give you steps you can take right away to start seeing results.
Close-up of a portable heater with glowing orange heating elementsClose-up of a portable heater with glowing orange heating elements
Control Your Heating and Cooling
The heating, ventilation, and air conditioning (HVAC) system in your home uses the most energy. In fact, it's often responsible for almost half of all the energy used in a home. Getting this beast under control is the best way to save money.
  • Install a Programmable or Smart Thermostat: This is an important update. With a programmed thermostat, you can set it to lower the temperature on its own while you are at work or asleep. A smart thermostat can even be changed from your phone and learns how you use it. Either choice can cut your yearly heating and cooling costs by up to 10%.
  • Perform Regular Maintenance: Like any other complicated machine, an HVAC system needs regular maintenance to work at its best. The easiest thing to do is change or clean the filter once a month. When the filter gets clogged, airflow is limited, which makes the device work harder and use more power. Also, make an appointment for professional cleaning once a year to make sure the unit is clean and working right.
  • Use Fans Strategically: A ceiling fan is a useful tool for staying comfortable all year. In the summer, its breeze can make a room feel several degrees cooler, so you can turn up the temperature without giving up comfort. What's called "wind chill" In the winter, turn the fan around so it spins counterclockwise at a slow speed. This will push the warm air that comes back down into the room.
Seal Your Home's "Envelope"
Air leaks in your home's structure are insidious energy wasters, equivalent to leaving a window cracked open all year long. Heat escapes in the winter and seeps in during the summer, forcing your ac system into overdrive. Sealing these gaps is one of the most cost-effective energy-saving measures you can undertake.
  • Weatherstrip Doors and Windows: Gaps around moving components are a primary source of drafts. Apply self-adhesive rubber or foam weatherstripping to the frames of doors and the sashes of windows to create a tight seal when they are closed.
  • Caulk and Seal Air Leaks: For stationary components, caulk is the solution. Use it to fill gaps around window and door frames, plumbing and electrical penetrations through walls, and other non-moving joints.
  • Check Insulation: Insulation provides thermal resistance, slowing the transfer of heat. Verify that your attic, exterior walls, and crawl spaces are insulated to the recommended levels for your climate zone. Proper insulation is critical for preventing heat loss in winter and heat gain in summer.
Modernize Lighting and Appliances
The cumulative energy draw from lighting and major appliances constitutes a substantial portion of your electricity bill. Upgrading from older, inefficient models to modern, energy-conscious ones can yield significant long-term savings.
  • Switch to LEDs: If you still have incandescent or even CFL bulbs, replacing them with LEDs is a must. LEDs use a fraction of the energy, last up to 25 times longer, and are now available in a wide range of brightness levels and color temperatures.
  • Look for the ENERGY STAR® Label: When purchasing new appliances like refrigerators, dishwashers, clothes washers, or dryers, look for the blue ENERGY STAR label. This government-backed symbol certifies that the product meets strict energy efficiency guidelines set by the U.S. Environmental Protection Agency, making it more efficient than standard models.
  • Right-Size Your Appliances: Bigger is not always better. An oversized air conditioner will cycle on and off too frequently, failing to dehumidify the air properly and wasting power. A refrigerator that is too large for your needs expends energy cooling empty space. Match your appliance size to your actual household requirements.
Address Your Water Heater
Most houses spend the second most on energy on heating water. Your water heater is always running, whether you're taking a shower, doing laundry, or washing dishes. A few easy changes can greatly lower the amount of energy it needs.
  • Lower the Thermostat: Most water heaters are set to 140°F (60°C), which is too high. Lowering the thermostat to 120°F (49°C) is enough for most home uses, saves a lot of energy, and lowers the risk of getting burned.
  • Insulate the Tank and Pipes: If your old hot water tank is in a room that isn't heated or cooled, like a basement or shed, putting an insulating blanket around it can cut standby heat loss by 25 to 45%. Also, insulating the first few feet of the hot and cold water lines that connect to the heater stops heat from escaping as it moves.
  • Use Less Hot Water: This is just a change in how you act. If you can, wash your clothes in cold water. Modern soaps are made to work very well without hot water. Cutting the length of your showers will also have an instant effect on how much hot water you use.
Vanquish "Energy Vampires"
It's surprising how much power things that aren't even being used use. Many gadgets today go into a "standby" mode, which means they keep drawing a small amount of power all the time. This "phantom load" or "vampire power" can use 5 to 10 percent of your home's overall electricity.
  • Use Smart Power Strips: Putting all of your tools on one power strip, like your TV, sound system, and streaming devices, is the best way to stop this from happening. Once that is done, you can use one switch to turn off the whole strip when not in use. Even better are "smart" power strips, which turn off peripheral devices immediately when a main device is turned off, like the TV.
  • Unplug Chargers: Phone, tablet, laptop, and other movable device chargers are known to waste a lot of power. Even when the device is fully charged or not plugged in at all, they keep pulling power from the outlet. Always unplug them when they're done with their job.
Cultivate Smart Laundry and Kitchen Habits
The kitchen and laundry room are hubs of activity and energy consumption. Adopting more efficient habits in these areas can lead to noticeable savings without requiring major investments.
  • Wash Full Loads: Your dishwasher and washing machine use roughly the same amount of energy and water regardless of how full they are. Make it a rule to only run them when you have a full load.
  • Wash Clothes in Cold Water: As mentioned earlier, about 90% of the energy consumed by a washing machine goes toward heating the water. Switching to cold-water washing for most loads drastically cuts this energy use.
  • Use Smaller Cooking Appliances: A large conventional oven consumes a great deal of energy to heat its entire cavity. For smaller meals or reheating leftovers, a toaster oven, air fryer, or microwave is far more efficient, using less energy and getting the job done faster.
Employ Windows and Coverings Strategically
Your windows are portals for light and heat. You can use them to your advantage, turning them into a source of free passive heating in the winter and a shield against unwanted heat in the summer.
  • Winter (Passive Heating): During daylight hours, open the curtains and blinds on your south-facing windows. This allows the sun's rays to stream in and warm your home naturally, giving your furnace a break. As soon as the sun goes down, close them again to trap the heat inside.
  • Summer (Blocking Heat): In the warmer months, the strategy is reversed. Keep curtains, shades, and blinds closed during the hottest parts of the day, particularly on south- and west-facing windows. This blocks the intense solar radiation, preventing your home from overheating and reducing the workload on your air conditioner.
Person carrying an EcoFlow branded gray carrying case across a grassy landscape with mountains in backgroundPerson carrying an EcoFlow branded gray carrying case across a grassy landscape with mountains in background
Combine Better Technology with Smarter Habits!
Lasting energy savings come from pairing efficient technology with smart daily habits. The seven strategies outlined here are proven ways to lower your utility bills and improve your home's comfort. You don’t need to do everything at once. Begin with the changes that are easiest for you, as each small adjustment will add up to significant savings over time.
Solar Energy
