How to Create a Comfortable Camping Setup in Your SUV
SUV camping is a great way to experience camping without the extra hassle of tent and poles. Instead, you can convert an SUV into a comfortable, yet compact, camping space. This can be ideal for weekend trips, road adventures, or shorter off-grid getaways.
A comfortable camping experience requires a bit of prep work. SUV camping gear can include tools for cooking and staying connected. A reliable portable power source, such as the EcoFlow DELTA 3 Plus Portable Power Station, is also a useful addition to power electronics, lights, or other portable devices.
How to Set Up Your SUV for Camping
A solid SUV camping setup requires making available space work for you. You'll need enough space to sleep comfortably while also storing gear and being able to access items as you need them.
Shorter trips may not require you to bring more than a sleeping pad and personal basics. A multi-day camping trip might call for a sleeping platform, storage solutions, cooking equipment, and a dependable source of electricity.
Create a Comfortable Sleeping Space Inside Your SUV
You may not think that sleeping in your car can be comfortable, but with the right preparation, you can make the space work for you.
Familiarize yourself with the SUV and its options. Some allow you to fold down the rear seats to be completely flat. Others may let you remove the seats entirely. Either option will give you more space for a more comfortable sleeping arrangement.
Key things to consider when setting up your SUV sleeping area include:
  • Sleeping platform: Great if there are big gaps or uneven areas. Choose from existing products on the market made for camping or build your own using lightweight materials. The goal is to create a reasonably flat surface for more comfortable sleeping.
  • Mattress padding: Portability and space are key. Consider an inflatable mattress that can be deflated and stored. Folding camping mattresses or sleeping pads can also be stored easily and don't require inflation.
  • Bedding: Bring pillows and blankets appropriate for the season. You may also want to invest in a sleeping bag for colder conditions.
  • Privacy: Window coverings can prevent light and make the interior private while also providing insulation. Look into windshield shades that can be easily removed and stored when driving.
  • Ventilation: A car can get warm and stuffy overnight when you leave the windows closed. Ventiliation should be part of your setup to let fresh air in and keep the bugs out.
Maximize Storage Space and Organization
Staying organized and using the remaining space effectively can also make SUV camping more enjoyable. You can use labeled storage bins to know where everything is instead of wasting time rifling through piles of supplies. Grouping like items together, like one container for cooking supplies and a separate one for toiletries, can help you avoid unpacking the entire SUV just to find a toothbrush.
Wherever possible, consider bringing items that fold up. Collapsible tables and folding chairs can help you create an enjoyable campsite without being overwhelmed by furniture inside your car.
When extra storage is needed, consider exterior storage options like roof cargo boxes and cargo carriers. This can free up a lot of interior space as long as they are compatible with, and securely fastened to, your car's roof.
A camping attachment for SUV use is another interesting option. You can buy rear tailgate tents or awnings to give you more space once you're at a campsite.
Essential Gear You Need for SUV Camping
What you need for comfortable and fun camping may not be the same as someone else. While camping in SUV tips will vary, everyone should focus on keeping items small, lightweight, easy to put away, and multipurpose.
Sleeping and Comfort Essentials
For your perfect sleeping setup, always start with deciding the size and thickness you need for a sleeping surface. Mattresses and pads come in different shapes and comfort levels. This can be upgraded by adding extra pillows and blankets.
Even if your SUV includes tinted windows, you'll want to invest in window coverings. These add privacy and can even help with insulation to keep the inside of your SUV comfortable in changing weather conditions.
Sleeping-comfortably-during-SUV-campingSleeping-comfortably-during-SUV-camping
Cooking and Outdoor Living Equipment
One of the more fun parts of camping is cooking in the great outdoors. Portable cooking equipment designed for campers can make it easier to prepare meals no matter where you go. Whatever you bring, make sure the items are small, lightweight, and can be used for different tasks to manage camping with limited storage space.
A small camping stove can be helpful if you are not allowed to start a campfire. While cooking can get hot, you'll want to bring either a cooler or portable refrigerator to keep food fresh and drinks cold. Dedicated water storage containers make sure you have a supply of water for drinking, cooking, and cleaning.
Setting up foldable furniture outside is less enjoyable if you're sitting in the dark. Don't forget to pack a source of outdoor lighting. This can add comfort and safety to your camping setup.
How to Power Your SUV Camping Setup
Camping gives people a chance to unplug, but that doesn't mean you can skip a power source. Remember that your phone, camera, lighting, or small appliances like a mini fridge all require electricity. Trying to run all of this off the SUV electrical system is impractical.
A portable power station can give you the electricity you need without impacting your car or requiring extra fuel.
Why Portable Power Is Important for SUV Camping
Portable power stations are ideal for SUV camping because they can easily be stored and brought with you. Unlike fuel-powered generators, they are quiet and don't require anything extra (like gasoline) to power. They can also be smaller and easier to pack away when not in use.
While going off the grid is appealing, camping with comfort can require electronics. Safety lighting, cell phones for emergency outreach, and small appliances can make all the difference between a frustrating or relaxing camping experience.
Choose a Portable Power Station for Your Camping Needs
The best power station for SUV camping depends on how much power you will need. This is determined by how many electric devices you bring with you and how long you will be away. You will want to have enough capacity to manage until you are close to a power outlet again.
The EcoFlow DELTA 3 Plus Portable Power Station is one option for SUV camping. It has a portable design and compact form factor, making it easy to stow away and bring out as needed. Its 1,024Wh capacity, which is expandable up to 5,000Wh, provides reliable power for everyday electronics and essential camping gear. It also offers solar charging compatibility for longer trips where extra power is needed.
The 1024Wh capacity and 1800W output provide reliable power for appliances, electronics, and essential devices. Fast 56-minute charging, multiple charging options, and a long-lasting LFP battery make it ideal for camping, RVing, emergencies, and home backup.
For extended camping trips, look for a high-capacity portable power station. The EcoFlow Delta 3 Max Plus (2048Wh) is great for camping excursions that are longer or when bringing power-hungry devices along for the ride. These can include portable refrigerators and larger outdoor setups with longer lighting usage.
EcoFlow DELTA 3 Max Portable Power Station (2048Wh)
The 2048Wh capacity and 2400W output provide reliable power for appliances and essential devices. Fast charging, long-lasting LFP battery technology, and a 10ms UPS make it ideal for home backup, camping, RVing, emergencies, and off-grid adventures.
SUV Camping Ideas for Different Outdoor Adventures
One of the best things about SUV camping is how flexible it can be. You can create a setup that suits your own needs and budget without the hassle of setting up and breaking down a tent every day.
Keep in mind the length of your trip when deciding what you need to bring with you.
  • Weekend trips: A sleeping platform and pad, cooking supplies, and a portable power station may be all that you need. Keep packing simple so you spend less time looking for items you could have left home.
  • Longer roadtrips: Depending on how large your SUV is, you can bring more equipment to ensure you are comfortable the entire time. You can also save money by sleeping in your vehicle rather than in a hotel.
  • National park visits: An SUV is a great base for between hikes. You can easily set up outdoor chairs and a table, or you can top recharge critical GPS devices or cell phones that can drain when in extended use.
  • Off the grid: You'll need to bring enough water, food, and power to live comfortably away from traditional campgrounds. For extended time away, bring a car camping power setup to power essential equipment.
SUV camping offers a flexible way to enjoy the outdoors without giving up the comforts of home. Adding a portable power solution like the EcoFlow DELTA 3 Plus Portable Power Station can help you create a practical base for trips of any length to any location.
FAQ About SUV Camping
Can You Sleep in an SUV for Camping?
Yes, many SUVs can be converted into comfortable sleeping spaces. Each make and model will offer different features and room to pack supplies. You should also check ahead of time to make sure where you plan to stay park permits overnight parking.
What Do I Need for Camping in My SUV?
Essential camping supplies include a sleeping setup, storage solutions, cooking equipment, toiletries, lighting, and a source of portable power. Keep in mind that camping in different weather conditions can require different gear.
How Can I Power My Devices While SUV Camping?
A portable power station offers a quiet, convenient way to charge electronics and operate equipment. Common devices you may need to power include phones, camping lights, small appliances, and portable refrigerators.
How Do I Make My SUV Comfortable for Overnight Camping?
A mattress or sleeping pad are important to give you a comfortable base to work with. Adding pillows or blankets can make the space more cozy. Window covers and screens can help with airflow and privacy concerns. Store equipment in clearly marked bins while keeping frequently used items within reach. Packing extra bedding and clothing can help during changing weather conditions.
Outdoors
