RV Outdoor Storage Solutions: How to Maximize Space and Efficiency
Living or traveling in an RV? Then, you already know that storage solutions are the secret to a smooth and comfortable ride. With space sometimes feeling like a sardine can, every inch and every pound counts, so you’ve got to get creative to fit everything you want. But don’t worry—we’ve got your back.
From handy racks and bins to pop-up shelters and space-saving power kits, we have plenty of clever solutions to help you squeeze the most out of your room and keep your journey rolling in comfort.
Now, let’s dive in so you can hit the road.
Pop-Up Shelter
The first thing to consider when getting ready for RV living or traveling is to think about expanding your living area into the great outdoors. A pop-up shelter with screen sides and a water-resistant roof are the perfect choice to create an outdoor living room and dining area.
Thanks to the roof and sides, it will protect you from the sun, rain, and bugs. You can even run your EcoFlow WAVE 3 Portable Air Conditioner and make it as cozy as it is inside with the AC running – no need to sacrifice comfort.
The best part of a pop-up shelter is that it easily folds up and can be stored on your roof or cargo rack so that it won’t take up valuable indoor living space.
Foldable Outdoor Furniture
To complement your outdoor living and dining area, you will want lightweight chairs and tables that fold up flat. You can slide them into slim spots or put them on your roof rack or cargo carrier when not needed.
Portable Fridge/Freezer
If your RV doesn’t have a fridge/freezer, or even if it does and you like to go on day trips to the beach or other outings with a cooler, a portable fridge/freezer is an excellent option. They’re the same size as a cooler, so they fit under tables or benches or on your cargo rack.
The EcoFlow Glacier Portable Fridge even has a built-in freezer compartment and ice maker, so you can travel in luxury. It holds a charge for 40 hours and can be recharged with solar panels, so your battery won’t drain while it runs.
Bike Rack
A bicycle is a fantastic travel option for exploring your surroundings without packing up your RV. However, bikes don’t fold up, so they can take up valuable space. Installing a bike rack on the back of your RV or your tow hitch will easily solve that problem.
Tow Hitch Cargo Racks
If you’re not towing a car, use that tow hitch to hold a cargo rack that fits right onto the hitch. This is a great place to store bins, outdoor furniture, luggage, portable fridges, or other items you don’t want to take up valuable room inside.
Roof Rack
Adding a roof rack can also add plenty of extra storage. These are fantastic for bulky but relatively lightweight items like kayaks, pop-up tents, and outdoor furniture. If your RV doesn’t already have a ladder, consider buying a folding or mountable one to make getting things on and off the roof a breeze.
Power Kits
Power kits used to take up a lot of valuable room inside with bulky batteries and complicated wiring. However, EcoFlow’s new 5kVA Power Kit is designed specifically for simplicity and saving space in an RV, freeing up loads of valuable inside storage space that you could use for other things.
It’s easier to install, has more power, recharges faster, and cuts power loss by 20% with its DC integration. Then, you can run even more appliances with less.
Waterproof Bins
Waterproof bins are an excellent choice for storing things on your roof rack or hitch rack when you need to pack things that cannot get wet but don’t have room inside.
Some things, like a portable propane or gas generator, you don’t want inside your living space due to the gases. So, you can store your EcoFlow Smart Generator (Dual Fuel) in a waterproof bin instead. It takes propane or gas, allowing versatile RV power options without putting additional drain on your RV batteries.
Alternatively, if you want greener energy, you can get an EcoFlow Portable Power Station that you can recharge with EcoFlow Flexible solar panels you can attach to your RV roof and generate clean, green energy anytime the sun shines.
Inflatable Toys
If you travel with kids or like water toys for yourself, choosing inflatable kayaks, paddle boards, and pool toys will save a ton of space. They can be inflated when needed, then deflated and stored in a bin on your roof or cargo rack. They weigh much less than rigid versions and take up very little room once deflated.
Foldable Cargo Carrier
A foldable cargo carrier is a good option for attaching to your cargo or roof rack to store your outdoor living items. It can then be folded up when you don’t need it, which is a good option for staying in campgrounds with limited space.
How To Maximize Storage Space in an RV?
Utilizing bike, roof, and tow hitch cargo racks will maximize your RV storage space. You can also create an outdoor living space with folding furniture and a pop-up tent. Space-saving power kits, portable fridges, and portable solar panels will also allow you to maximize comfort with minimal room.
Traveling in an RV does not have to be a limitation that requires you to sacrifice one convenience for another. With some planning and the right tools, you can have your cake and eat it, too.
Installing racks and using car carriers, pop-up shelters, portable fridges, and a space-saving EcoFlow 5kVA Power Kit designed to give you more power with less space than before will allow you to travel comfortably. Now go out, hit the road, and let your RV take you on an adventure with all the luxuries of home.
