Ring of Fire: What Happens If the Volcanoes Erupt?
Mr. Johnny Cash — the late great Man in Black — was far from the only person to find themselves in a burning ring of fire.
The entire Pacific Ocean is encircled by a ring of volcanoes that could erupt at any moment, potentially without warning.
Recent studies suggest that nearly a billion people could be at risk if the Ring of Fire volcanoes, but it’s not just lava that scientists are concerned about.
So, what is the Ring of Fire?
And what are the potential risks?
What Is the Ring of Fire and How Was It Formed?
The Ring of Fire is a vast horseshoe-shaped network of volcanoes that encircles the Pacific Ocean, stretching over 25,000 miles.
It’s not a continuous “belt,” but rather a series of boundaries between the tectonic plates that make up the Earth’s crust.
On a global scale, the phrase “On solid ground” is actually a misnomer.
Tectonic plates are enormous, irregular slabs of solid rock that comprise the planet’s outer shell, and they’re in constant motion.
There are two main types of crust that make up tectonic plates, which can be hundreds or thousands of miles in size and around 20 to 100 miles thick.
  • Oceanic crust that’s relatively thin, and typically made up of basaltic rocks.
  • Continental crust is typically thicker, less dense, and composed primarily of granitic rocks.
Plates of each type float on a hotter, more malleable “upper mantle” of the Earth called the asthenosphere.
Tectonic plates typically shift and move on the asthenosphere very slowly — far too gradually to be perceptible by humans — but enough to reshape the Earth’s surface over millions of years.
Despite typically moving in slow motion, shifts and interactions between tectonic plates also cause earthquakes, volcanic eruptions, and even the formation of lakes, oceans, and mountain ranges.
Plate tectonic boundaries are classified into three main categories:
  • Convergent boundaries are areas where two tectonic plates are moving towards each other. What happens when they collide depends primarily on the types of crust.
    • Oceanic-Continental Convergence: The denser ocean crust bends and slides under the lighter continental plate, resulting in subduction. Subduction often creates deep ocean trenches and a chain of coastal volcanoes like the Andes Mountains.
    • Oceanic-Oceanic Convergence: Two oceanic plates converge with one subducting the other, resulting in a deep trench and a curved chain of volcanic islands, like the Mariana Islands.
    • Continental-Continental Convergence: Subduction is unlikely. Instead, the plates collide and force the crust upwards, creating enormous mountain ranges like the Himalayas.
  • Divergent Boundaries are areas where two plates are moving apart. Magma from the asthenosphere rises to the surface, and new crust is formed as the plates separate. A divergent boundary between tectonic plates formed the Mid-Atlantic Ridge, a massive underwater mountain range.
  • Transform Boundaries are the most well-known and potentially destructive of plate tectonic boundaries. For example, the San Andreas Fault, frequently cited as the most likely culprit of causing the Big One in California, is a transform boundary. Plates slide horizontally past one another at transform boundaries, neither creating new nor consuming old crust. Instead, the tectonic plates grind together, often resulting in seismic events and sometimes in catastrophic earthquakes.
Plate Tectonic Convergent Boundaries Forge the Ring of Fire
The Ring of Fire was formed over millions of years by the constant movement, friction, and violent collisions between oceanic and continental tectonic plates.
When dense oceanic plates collide with lighter continental plates, subduction occurs, creating volcanoes, significant seismic events, and intense geographical activity.
The Ring of Fire was created by multiple collisions between oceanic and continental plates. The heavier oceanic crust is subducted below the Earth’s mantle, where it experiences extreme heat and pressure.
When combined with ocean water, mantle rock melts and forms magma.
Magma rises to the surface and eventually erupts, forming a chain of volcanoes and volcanic mountain ranges.
Friction and collisions between tectonic plates also cause extreme seismic and powerful, potentially devastating earthquakes.
For example, the 2011 Tōhoku Earthquake was an undersea megathrust earthquake with a magnitude of 9.0–9.1 that lasted for approximately 6 minutes.
Also known as the Great East Japan Earthquake, it triggered a massive tsunami that reached heights of up to 133 meters and reached up to 6 miles inland.
The tsunami overwhelmed the power supply and cooling systems at the Fukushima Daiichi Nuclear Power Plant, causing a Level 7 reactor meltdown known as the Fukushima Nuclear Disaster.
Official estimates found that the combined events of the Great East Japan Earthquake resulted in 19,759 deaths, 6,242 injuries, and 2,553 people missing.[1]
The economic impact was staggering, estimated at $220 billion to $360 billion — making it the costliest natural disaster in recorded history.
How Many Volcanoes Are In the Ring of Fire?
The Ring of Fire is unquestionably the most volcanically and seismically active region on Earth.
Estimates of the exact number of volcanoes in the belt vary, but it contains the vast majority of the planet’s volcanoes and is the source of about 90% of earthquakes.
Depending on the criteria, authoritative estimates range from 452 to 915 for the number of volcanoes in the Ring of Fire.
The estimates include active, inactive, and erupting volcanoes.
Map showing currently active volcanoes
(Source: Global Volcanism Program)
According to the Smithsonian Institution’s Global Volcanism Program, 46 volcanoes are currently erupting worldwide as of August 6, 2025.
The most recent notable seismic event in the Ring of Fire was the 2025 Kamchatka Peninsula Earthquake, which caused tsunami warnings in Russia, Japan, the United States, and other countries in late July and early August.
Map showing site of Kamchatka Earthquake
(Source: CNN)
The Mw 8.8 megathrust earthquake struck near the eastern coast of the Kamchatka Peninsula in Russia, within the Ring of Fire.
Despite being the most powerful earthquake since the 2011 Tōhoku Earthquake, damage from the quake and resulting tsunamis was minimal.
What Volcanoes and Mountains are in the Ring of Fire?
With estimates of volcanoes running from over 400 to just under 1,000, many of the volcanoes and mountains in the Ring of Fire are far from household names.
Estimates often include undersea volcanoes and volcanoes that have been inactive for thousands of years.
However, some of the most well-known volcanoes and mountains in the world fall within the Ring, including:
Asia
  • Mount Fuji: Japan
  • Krakatoa (Krakatau): Indonesia
  • Mount Pinatubo: Philippines
  • Mount Merapi: Indonesia
  • Mount Mayon: Philippines
The Americas
  • Mount St. Helens: USA (Washington)
  • Popocatépetl: Mexico
  • Mount Rainier: USA (Washington)
  • Ojos del Salado: Argentina/Chile
  • Cotopaxi: Ecuador
Ring of Fire Volcanic and Seismic Risks
Around 75% of the world’s active volcanoes are part of the Ring of Fire, and seismic volatility in the region is the source of 90% of the world’s earthquakes, including 81% of the highest-magnitude quakes.
Hundreds of millions of people live close enough to the region to be directly at risk.
At the same time, the aftermath of catastrophic earthquakes or volcanic eruptions in the Ring could impact virtually everyone — and all life — on Earth.
While it’s considered highly unlikely, some scientists believe an earthquake could theoretically trigger a chain of eruptions along the Ring of Fire.
According to the Daily Mail, “While it is almost certainly impossible in reality, if this entire volcanic chain were to erupt at once, the results would be utterly cataclysmic.”
Rather than focus on the worst-case scenario, here’s a summary of more likely —  even imminent — risks.
Earthquake Risks
  • Intense Ground Shaking: Not surprisingly, the primary and most immediate danger is the Earth quaking, leading to the catastrophic collapse of buildings, bridges, and other infrastructure. This is the leading cause of death during an earthquake.
  • Tsunamis: Undersea megathrust earthquakes can displace enormous volumes of water, generating massive waves that inundate coastal communities miles inland, as seen in the 2004 Indian Ocean and 2011 Japan disasters, which killed an estimated total of around 250,000 people in 15 countries
  • Landslides: Earthquakes can destabilize slopes, triggering rapid landslides that can bury entire communities, block roads, and dam rivers, leading to further flooding risks.
  • Liquefaction: A hazardous process where water-saturated soil loses its strength and behaves like a liquid, causing buildings and infrastructure to sink, tilt, or collapse.
  • Secondary Disasters: The aftermath of a quake often includes widespread fires from ruptured gas lines, flooding from damaged dams, and a total breakdown of communication and transportation systems.
Volcano Risks
  • Pyroclastic Flows: The deadliest volcanic hazard—a superheated, fast-moving avalanche of ash, rock, and gas that incinerates everything in its path at hundreds of miles per hour.
  • Lahars (Volcanic Mudflows): A thick, heavy slurry of volcanic debris and water that flows down river valleys like liquid concrete, capable of traveling for dozens of miles and burying entire towns.
  • Ashfall: Volcanic ash can travel hundreds of miles, collapsing roofs under its weight, contaminating water supplies, causing respiratory illness, and posing a significant threat to aviation by shutting down jet engines.
  • Lava Flows: Often slow-moving, molten rock lava streams are unstoppable, destroying all property, infrastructure, and agricultural land in their wake.
  • Volcanic Winter: A massive eruption injects huge quantities of sulfur dioxide and ash into the stratosphere that blocks out sunlight, causing global climate cooling  and disruption of agriculture and ecosystems worldwide.
Photograph showing house with lightning and DELTA Pro 3 portable power stations in garage.
Earthquakes, volcanic eruptions, and tsunamis originate in the Ring of Fire, and there’s nothing we can do to stop them.
The best you can do is be vigilant about following warnings and advisories from reliable government agencies and be prepared for disasters and emergencies.
EcoFlow whole-home backup generators can help keep you safe during power outages caused by natural disasters and extreme weather events.
Check out our selection today.
Resources Cited
  1. “What Is the Ring of Fire? : Ocean Exploration Facts: NOAA Office of Ocean Exploration and Research.” 2025. Noaa.gov. 2025. https://oceanexplorer.noaa.gov/facts/rof.html.
  2. Gonzaga, Shireen. 2023. “The Ring of Fire, Where Volcanoes and Earthquakes Reign.” EarthSky | Updates on Your Cosmos and World. July 21, 2023. https://earthsky.org/earth/what-is-the-ring-of-fire/.
  3. “What Is a Tectonic Plate? [This Dynamic Earth, USGS].” 2025. Usgs.gov. 2025. https://pubs.usgs.gov/gip/dynamic/tectonic.html.
  4. “Plate Boundaries: Divergent, Convergent, and Transform.” 2020. California Academy of Sciences. 2020. https://www.calacademy.org/explore-science/plate-boundaries-divergent-convergent-and-transform.
  5. Reid, Kathryn. 2019. “2011 Japan Earthquake and Tsunami: Facts, FAQs, How to Help.” World Vision. May 8, 2019. https://www.worldvision.org/disaster-relief-news-stories/2011-japan-earthquake-and-tsunami-facts.
  6. “On This Day: 2011 Tohoku Earthquake and Tsunami.” 2021. National Centers for Environmental Information (NCEI). March 11, 2021. https://www.ncei.noaa.gov/news/day-2011-japan-earthquake-and-tsunami.
  7. “Global Volcanism Program | Current Eruptions.” 2025. Smithsonian Institution | Global Volcanism Program. 2025. https://volcano.si.edu/gvp_currenteruptions.cfm.
  8. Andrews, Robin George. 2025. “Why the Tsunami from Russia’s Earthquake Wasn’t as Large as Feared.” Scientific American. July 30, 2025. https://www.scientificamerican.com/article/why-the-tsunami-from-russia-earthquake-wasnt-as-large-as-feared/.
  9. Hunter, Wiliam. 2025. “Is THIS How the World Will End? Scientists Reveal Exactly What Would Happen If the 25,000-Mile ‘Ring of Fire’ Chain of Volcanoes Erupted - with Catastrophic Consequences.” Mail Online. Daily Mail. July 31, 2025. https://www.dailymail.co.uk/sciencetech/article-14957953/Scientists-reveal-ring-fire-eruption.html.
  10. ‌Omer, Sevil. 2025. “2004 Indian Ocean Earthquake and Tsunami: Facts and FAQs.” World Vision. July 25, 2025. https://www.worldvision.org/disaster-relief-news-stories/2004-indian-ocean-earthquake-tsunami-facts.
Home Backup
