Solar Power Stations That Keep Your Appliances Running
Solar power stations give you a dependable way to keep essential appliances running without fuel, noise, or fumes. By pairing a portable power station (PPS) with solar panels, you can generate and store energy anywhere, whether camping, living off-grid, or facing a power outage. With the right capacity and surge output, these systems can handle everything from laptops to refrigerators.
Learn what portable power stations are, how to choose the right rating for your needs, and which appliances a solar power station can support.
Understanding What Portable Power Stations Are
A portable power station is a large but portable battery that stores energy for later use. It’s similar to on-the-go battery banks for recharging cell phones, but with the capacity to charge everything from laptops to lights and even small appliances.
Unlike a traditional generator, a portable station doesn’t use oil or gas. Portable power stations work by storing electricity in their internal battery, which you can recharge from a standard wall outlet, your car’s 12V socket, or even solar panels.
For solar, you’ll need to pair the power station (the battery) with a solar generator to convert sunlight into usable power. Options like the EcoFlow DELTA Pro 3 Solar Generator (PV400W) have a high input and AC output to keep your household running without downtime.
Once charged, you simply plug your devices into their ports to draw electricity. Most models include a mix of USB ports and AC outlets to run everything from smartphones to blenders. Remember that running large appliances or multiple devices at once will drain the battery faster, so plan your usage carefully.
You can use a portable station for so many situations, including:
  • Camping
  • Emergency backup energy
  • Off-grid living
Unlike noisy generators, power stations are completely silent and fume-free, so they’re safe to use in your home. They’re large enough to run essential technology or appliances, but portable enough that you can easily move them when you’re on the go.
EcoFlow DELTA Pro 3 in garage
Capacity, Output, and Surge for Real-World Use
Solar power stations come in a wide range of sizes and capacities, so you need to understand the capabilities of the system and how it compares to the devices you want to charge. Choosing the right portable station comes down to understanding three key specs: capacity, output, and surge power. These numbers determine what devices you can plug in and for how long.
Consider these factors to pick the best power station for your needs:
  • Capacity: Capacity is measured in watt-hours (Wh) and tells you how much total energy the power station can hold. The higher the Wh, the longer it can run your devices. You can estimate the runtime by dividing the station’s Wh rating by the running watts for a device. For example, a 500 Wh power station running a 100 W mini fridge will last about 5 hours (500 ÷ 100 = 5).
  • Output: Output is measured in watts (W), which determines what types of devices the station can run. Lower-output models around 200 to 300W can handle small electronics, like smartphones and LED lights. Larger models that are 1000W or more can power bigger appliances like TVs, heaters, and refrigerators.
  • Surge power: Any appliance with a motor (like a refrigerator) needs an extra jolt of electricity to start up. This is called surge power, or starting watts. The appliance will run at a lower wattage after starting up, but your power station still needs to be able to support this. So, if your appliance requires 1000W to start but only 500W to run, your power station needs at least 1000W surge capability.
There are other considerations to consider before buying a power station, too. For more flexibility, make sure it offers multiple recharging options, like wall outlets and solar panels. The power station should also include a mix of USB and AC ports for charging your devices. If the station doesn’t include enough ports, you’ll likely need to buy more to run all of your essential devices.
Powering Everyday Devices: TVs, Laptops, Refrigerators, and More
Portable power stations can run all kinds of appliances. One of the biggest perks of a PPS is its versatility. With a mix of USB, AC, and DC ports, these stations can run almost anything, from your phone to your fridge. The key is knowing how much energy each device uses and choosing a station that can handle it.
If you want to charge your phone or LED lights (anywhere from 10 to 100W per device), you can go with a smaller battery with a capacity of 150 to 500Wh. Small devices sip energy, so a compact 150Wh station works fine for quick charges. If you plan to run a laptop for hours or multiple devices at once, consider a battery with 500Wh or more.
Medium appliances like TVs, fans, and coffee makers (30 to 700W per device) require a larger solar station with 500 to 1000Wh. However, if you plan on running an appliance continuously, like a fan, go with a higher capacity battery.
Large appliances like refrigerators, AC units, and space heaters use anywhere from 800 to over 1000W. They’re a great option in the event of a disaster or electricity outage, but you’ll need a power station with up to a 2000Wh capacity to run these appliances for several hours.
Remember, large appliances have motors that require a startup surge. For example, a refrigerator may run at 100–800W but spike to 1500W on startup, so choose a station with at least 1500W surge capacity. Space heaters can use up to 1500W continuously, which will drain even large stations quickly. Plan for 2000Wh or more and consider using solar panels to extend runtime off-grid.
Charge Up: Recharging by Wall Outlet or Solar Panels
The great thing about opting for a portable power station is that you can recharge it in many ways. The simplest way to charge a portable power station is by plugging it into a standard wall outlet. Even if you plan on being in the woods for a few days, it’s always best to start your trip with a full battery.
However, solar panels are a real game-changer for getting electricity off-grid. They convert sunlight into electricity that recharges your power station’s internal battery. Options like the EcoFlow RIVER 3 Max Plus + 220W Solar Panel let you extend your runtime indefinitely during camping trips, power outages, or emergencies.
However, like power stations, solar panels come with different capacities. Larger, higher-watt panels around 200W collect more energy than smaller 60W panels. The availability of sunlight is also a big factor in how much energy the panels can provide, as well as your devices and the power station’s capacity.
Solar panels may not produce enough electricity to run big appliances (like space heaters or fridges) on their own. Still, they’re excellent for topping off your battery and extending the runtime for essential devices. Because of these variables, solar recharging can take several hours or even most of a day. It’s ideal to charge during daylight hours so your station is ready to run lights, fans, or other essentials at night.
Person using EcoFlow DELTA 3 Plus
Are Portable Solar Power Stations Worth It?
Portable power stations are worth it because they offer a clean, quiet, and travel-friendly source of energy. Whether you want to run a fan while camping or need to run your fridge during a big storm, portable solar stations are a user-friendly and economical alternative to gas generators.
What Is the Difference Between a Solar Power Station and a Solar Generator?
Some people use the terms interchangeably, but they aren’t quite the same. A solar station contains a battery, which means it can store electricity for later. A solar generator is a part of the system that converts sunlight into electricity through solar panels. Put simply, the power station is the portable battery, and the generator makes it possible to create and store energy.
Solar Power Stations Deliver Capacity, Output, and Reliability
Solar power stations are a clean, quiet, and reliable source of energy in many situations. Run your fridge after a big storm, brew a morning cup of joe while camping, or recharge your family’s devices while on vacation.
However, you need to shop carefully to find the right solar power station for your situation. When choosing the right one, focus on the capacity (Wh) for runtime, output (W) for running bigger devices, and surge power for appliances with motors or compressors. Pairing your station with solar panels can extend the battery indefinitely, making it ideal for camping, RV trips, or emergency backup during outages.
Harness the power of the sun to stay charged while on the go. Add the EcoFlow DELTA 3 Plus Solar Generator (PV220W) to your travel or home backup kit to get reliable electricity, no matter the situation.
Solar Energy
