Polar Vortex 2025/26: Extreme Winter Cold Is Coming
Based on current projects, the 2025/26 winter season is going to be one for the books. With peak environmental factors at play, we’re in store for some record-breaking conditions that will mark one of the coldest seasons we have seen in the past decade.
While a freezing winter season is probably the last thing you want to prepare for, now’s the time to get everything you need to ensure you stay safe and comfortable even when the temperatures start to drop.
To ensure you and your family are equipped with the knowledge and equipment to survive the upcoming polar vortex, we have compiled some important tips on what you need to get in order to be ready. But first, let’s take a look at what this season has in store.
What Is a Polar Vortex?
This intimidating term refers to a weather phenomenon that occurs in the Arctic. As a large, low-pressure system, the polar vortex contributes to the frigid Arctic temperatures and can also have a profoundly influential impact on other regions of the world.
When this vortex weakens or becomes unstable, it can wreak havoc on surrounding regions. Disruptions to the polar vortex often encourage cold snaps and severe winter storms, which just so happens to be the case of the 2025/26 season.
What Is Making the 2025/26 Polar Vortex More Severe?
With a notable increase in instability throughout the Arctic region, the polar vortex is under a tremendous amount of strain, which is causing a higher risk of splitting and weakness. These early indicators are a clear sign that the upcoming months are going to be very cold and that these temperatures are likely to stick around for an extended period of time.
The upper Midwest and Northeast are likely to face the brunt of this severe weather, though impacts will be felt all across the northern region of the country.
Potential Impacts and Hazards
If you or a loved one lives in one of the regions mentioned above, you must educate yourself on the likelihood of these impacts and hazards as a result of the polar vortex.
Higher Strain on the Power Grid
With extended periods of freezing conditions, there is a guaranteed higher strain on the power grid in your area. This strain is a direct result of higher heating demand and is a common occurrence when weather temperatures reach these drastic lows.
Health Concerns
If you have to be outside during the worst of the conditions, please be aware of how this can impact your health. Frostbite, hypothermia, and other cold-related illnesses can occur very quickly in freezing conditions, especially if your wardrobe and other heating elements are not adequately prepared.
Travel and Transportation Disruptions
With freezing conditions and an increased risk of winter storms, there is a strong likelihood that roadways and public transportation will be affected. If you have a long commute or travel regularly, now is a good time to review your upcoming plans and be prepared for last-minute changes, depending on the severity of the outside conditions.
How to Prepare for Extreme Cold
A record-breaking, freezing winter season is hardly something to get excited about, but it’s critical that you allow yourself enough time to prepare. Here are some of the more essential things you should do before the worst of the weather makes its way to you.
Stock Up on the Essentials
With the polar vortex, there may be periods when the roads are too icy or snow-covered to travel on. To ensure you have everything you need, take stock of what you already have and gather any necessary supplies you may be missing.
Warm clothing and layers, even while you are at home, are essential to have in case the power goes out, and your access to heat disappears. You should also ensure that you have a sufficient supply of non-perishable food items and drinking water for you and your family in case power outages become a widespread concern.
Set Your Home Up for Success
Don’t wait any longer. Make sure your home is prepared for the extremely cold and long season ahead. Check your heating equipment and schedule any necessary tune-ups or service appointments now to avoid more significant concerns down the line.
Another great way to prepare is to lean into self-sufficiency and create a backup power plan in case the strain on the grid were to cause widespread blackouts in your region.
The Christmas season is intended to be warm and cozy, but without the proper tools, you may have no reliable way of heating up your space. With the risk of extended blackouts, having a backup home system is an excellent measure to protect your family during extreme cold.
Polar Vortex Forecasts Require Emergency Readiness
The polar vortex of 2025/26 is sure to be one to remember. If you live in the northern part of the country, now is your time to gather all the essentials and ensure you have everything you need to brave an extremely cold winter. From prepping your food and water supplies to staying updated with road conditions, make sure you’re clued up on what’s to come when severe weather hits.
Home Backup
