Powering a Pellet Smoker with a Portable Power Station: What Size Do You Need?
Want to BBQ anywhere? Here's how to pick the right battery for your pellet grill.
You're at your favorite camping spot. You've got the perfect brisket ready to smoke. But there's no power anywhere. Your pellet grill just sits there while everyone else cooks hot dogs over a campfire.
This doesn't have to happen. Portable power stations can run your pellet smoker anywhere you want to cook. You just need to know what size to buy.
Here's exactly what you need to take your BBQ anywhere.
How Pellet Grills Use Power
Pellet grills need electricity in two ways:
Starting up: A big jolt to light the pellets (usually 300-500 watts for 5-20 minutes). Running: Much less power to keep going (typically 30-60 watts)
It's like starting your car. You need lots of juice to turn the engine over. Once it's running, it barely uses any energy to idle.
Most people only think about the running power. They buy a battery that handles 50 watts but can't give the 400 watts needed to start. The grill won't even turn on.
What Your Grill Actually Uses
Here's what normal pellet smokers need:
When starting up (first 5-20 minutes):
  • Small portable grills: around 100-200 watts
  • Regular home grills: 300-400 watts
  • Big grills: up to 500 watts
While cooking (the whole time):
  • Most grills: 30-60 watts
  • About the same as a small fan
Check your grill's manual for the real numbers. You might find a sticker on the grill too.
Things that make your grill use more power:
  • Cold weather makes the grill work harder
  • Wind blows away heat and wastes electricity
  • Opening the lid forces the grill to heat back up
  • Bigger grills usually need a bit more power
BBQ Takes a Long Time
Pellet smokers are built for slow cooking. That means many hours:
  • Ribs: 5-6 hours
  • Whole chicken: 4 hours
  • Pork shoulder: 12+ hours
  • Brisket: 15+ hours (sometimes 20 hours when it's cold)
These are rough guesses. Every piece of meat is different. Weather, how thick the meat is, and how often you look all change the time.
BBQ rule: "Cook until it's done, not until the clock says so." Your meat is ready when it hits the right temperature inside.
Here's how much battery juice you need:
What You're Smoking
How Long
Battery Power Needed
Baby back ribs
5-6 hours
175-360 Wh
Whole chicken
4 hours
140-240 Wh
Pork shoulder (8 lbs)
12 hours
420-720 Wh
Brisket (10 lbs)
15 hours
525-900 Wh
Brisket (cold day)
20 hours
700-1200 Wh
Wh means watt-hours. Think of it like gallons in your gas tank.
Pick the Right Size Battery Station
Your portable power station needs to do two things:
1. Handle the Big Startup Jolt
Your power station must give enough watts when the grill fires up. Look for:
  • At least 500 watts steady
  • 1000+ watts for short bursts
Many newer battery stations have "boost" modes. These let them power bigger devices for a few minutes. Perfect for pellet grill startups.
2. Store Enough Power
This decides how long you can cook. Here's the easy math:
Cooking Time = (Battery Size × 0.85) ÷ What Your Grill Uses
The 0.85 is because you lose some power when the battery converts electricity for your grill.
Example: You have a 1000Wh battery and your grill uses 50 watts: (1000 × 0.85) ÷ 50 = 17 hours of cooking
For most long BBQ sessions, you want at least 700-1000Wh.
What Features Really Matter
Clean Electricity
Your pellet grill has computer parts inside—controllers, fans, and motors. They need steady, clean electricity. Make sure your power station gives "pure sine wave" power. Stay away from "modified sine wave" units that can break your grill.
Good Battery Type
Look for power stations with LiFePO4 batteries (that's a fancy lithium type). These:
  • Last 3000+ times of charging (about 10 years of daily use)
  • Works better when it's really hot or cold
  • They are much safer than older types
  • Let you use 80-90% of their power without damage
Different Ways to Charge Back Up
You want several options to fill the battery:
  • Wall plug: Quick charging at home
  • Solar panels: For camping without any power
  • Car plug: While driving to your spot
Extra Plugs
Get several AC outlets plus USB ports. You'll want to charge phones, run a meat thermometer, and maybe power some lights.
EcoFlow DELTA 2 equips modern families with backup power for any emergency. Incredibly fast charging: 0%-80% in 50 min. Be prepared, always.
EcoFlow DELTA 2: Works Great for Most Pellet Grills
The EcoFlow DELTA 2 is really good for pellet smoker power. Here's why:
Strong Power:
  • 1800 watts steady
  • X-Boost pushes it to 2200 watts for startup
  • Handles any pellet grill startup easily
Long-Lasting Battery:
  • 1024Wh battery
  • Can add more batteries to get 3kWh total
  • Perfect for 15-20 hour brisket cooks
Smart Battery:
  • LiFePO4 batteries last 3000+ charges
  • About 10 years of daily use before they wear out
  • You can safely use most of the power
Fast, Easy Charging:
  • Get to 80% full in just 50 minutes from a wall plug
  • Solar charging up to 500 watts
  • Car charging for road trips
Grill-Friendly:
  • Pure sine wave power protects your grill's computer parts
  • Runs quietly (unlike gas generators)
  • Safe to use inside or outside
  • Control everything from your phone
Let’s check the math for a long brisket cook:
  • 20-hour cook at 50 watts = 1000 Wh needed
  • DELTA 2 holds: 1024 Wh
  • Perfect fit with a little extra
For Shorter Cooks: EcoFlow RIVER 2 Max
If you mostly do shorter cooks like chicken or ribs, the RIVER 2 Max works great:
  • 512Wh battery (good for 8-10 hour cooks)
  • 500W steady, 1000W burst
  • Much lighter and easier to carry
  • Great for tailgating and car camping
Make Your Battery Last Longer
Save Power on Your Grill
  • Use a grill cover: Insulated covers keep heat in, especially when it's cold. Your grill won't work as hard.
  • Cook at a lower heat: 225°F uses less power than 275°F. For slow BBQ, this actually tastes better anyway.
  • Stop peeking: Every time you open the lid, heat escapes. The grill has to work harder to get back to the right temperature. "If you're looking, you're not cooking."
  • Light pellets by hand: Some grills let you light pellets manually. This skips the electric starter and saves that big power hit.
Get More From Your Power Station
  • Start with a full battery: Don't risk running out halfway through a 15-hour brisket.
  • Add solar panels: Even a small 200W solar panel can add lots of cooking time on sunny days.
  • Keep an eye on power: Use the EcoFlow app to check how much battery you have left and how much time that gives you.
  • Bring backup: For weekend camping trips, think about a second battery or more solar panels.
Two friends enjoy an outdoor meal, with an EcoFlow DELTA 2 Portable Power Station powering their appliancesTwo friends enjoy an outdoor meal, with an EcoFlow DELTA 2 Portable Power Station powering their appliances
Real Example: Weekend Brisket Cook
Say you're camping and want to smoke a 12-pound brisket:
Power you need:
  • Startup: 400 watts for 10 minutes
  • Running: 50 watts for 18 hours = 900Wh total
How EcoFlow DELTA 2 handles it:
  • Easily handles 400W startup (can do 2200W bursts)
  • 1024Wh battery covers the 900Wh you need
  • You have 124Wh left for phones, lights, etc.
Add solar:
  • A 200W solar panel in good sun adds about 1000Wh per day
  • You could cook all weekend with enough sunshine
Don't Make These Mistakes
  • Forgetting startup power: Your portable power station might handle 50 watts fine, but fail at the 400-watt startup. Check both numbers.
  • Guessing cook times wrong: Brisket "should" take 15 hours, but might take 20 in bad weather. Plan for longer.
  • Running too much stuff: Don't try to power your grill, charge laptops, and run a cooler all at once. Focus on your cooking.
  • Ignoring power loss: You lose about 15% of battery power when it gets converted. Factor this in.
Here's the Deal
Portable power stations open up a whole new world for pellet grill BBQ. No more hunting for power outlets. No more going only to places with electricity.
Match your power station to how you cook:
  • Short cooks (ribs, chicken): 500-700Wh battery
  • Long cooks (brisket, pork shoulder): 1000Wh+ battery
  • Weekend trips: Get systems you can expand or add solar to
The EcoFlow DELTA 2 handles most pellet grills perfectly. It has enough power for startup and battery life for the longest cooks. Add solar panels, and you can cook anywhere in the sun.
Don't let power outlets limit your BBQ. With the right battery setup, you can smoke perfect brisket anywhere you can haul your grill.
Ready to take your pellet grill anywhere? Check out the EcoFlow DELTA 2 and see how battery power can change your outdoor cooking.
