How Many Watts & Amps Does an Air Fryer Use?
Air fryer wattage changes depending on the model, the capacity, and how many cooking drawers it has. Standard single-drawer air fryers usually sit around 1,500W, while bigger twin-drawer models can climb close to 2,600W. Electrical Safety First lists these numbers as typical examples, not hard rules.
If you want to run an air fryer off portable power, the EcoFlow DELTA 3 Plus Portable Power Station handles plenty of standard models within its output range. For higher-wattage appliances, longer cooking sessions, or several devices running together, the EcoFlow DELTA 3 Max Plus (2048Wh) gives more capacity and output. Always check the rating label on your air fryer before picking a power source.
Air Fryer Power and Electricity Use Explained
How much electricity an air fryer uses comes down to three things: wattage, cook time, and supply voltage. Understanding each piece makes estimating energy use, amps, and running costs easier.
Typical Air Fryer Wattage by Size and Type
So, how many watts does an air fryer use? There’s no single answer here.
Smaller, compact air fryers don’t pull much power. Bump up to bigger baskets, dual drawers, or oven-style models, though, and that number climbs.
Typical categories look like this: compact air fryers often run lower-wattage motors, standard single-drawer models sit around 1,500W, large-capacity units run 1,500W or higher, dual-drawer models can land near 2,600W, and air fryer ovens vary by brand and design.
Electrical Safety First notes that single-drawer air fryers hover around 1,500W, while twin-drawer models climb closer to 2,600W.
These numbers are general guidelines, not guaranteed specs. Before you plug it into an outlet, inverter, or power station, check the label first. That’s where you’ll find the exact air fryer watts for your specific unit.
How Much Energy Does an Air Fryer Use per Cooking Session?
Rated wattage is just the power demand. What you actually use depends on how long the thing runs for. Use this formula:
Wattage ÷ 1,000 × Operating Time in Hours = Electricity Consumption in kWh
For example, a 1,500W air fryer running for 30 minutes would theoretically use:
1,500W ÷ 1,000 × 0.5 hours = 0.75kWh
Real electricity usage tends to run lower because the heating element cycles on and off once the air fryer hits its set temperature. Which? uses this same wattage-and-runtime approach when estimating appliance energy use, though it notes calculations assuming constant maximum power don’t always match how appliances actually run.
Air fryers can also burn less electricity than full-size ovens for smaller meals since they heat a smaller cooking chamber and often finish faster.
How Many Amps Does an Air Fryer Draw?
Wondering how many amps does an air fryer use? It really just comes down to wattage and whatever voltage your outlet supplies. Use this formula:
Amps = Watts ÷ Volts
For a typical 120V US electrical supply:
Air Fryer Wattage
Approx. Current at 120V
1,000W
8.3A
1,200W
10A
1,500W
12.5A
1,800W
15A
2,000W
16.7A
For example:
1,500W ÷ 120V = 12.5A
Voltage differs by country, so plug in your local supply voltage when running these numbers.
High-wattage cooking appliances can strain a circuit. Avoid running an air fryer alongside other power-hungry appliances on the same circuit if it exceeds safe limits.
How Much Electricity Can an Air Fryer Use in One Hour?
The link between wattage and maximum hourly use is simple:
  • A 1,000W unit uses up to about 1kWh per hour.
  • A 1,500W unit uses up to about 1.5kWh per hour.
  • A 1,800W unit uses up to about 1.8kWh per hour.
That said, most air fryer cooking cycles run shorter than a full hour. Actual energy use can also come in lower since the heating element doesn’t run nonstop at full power.
This is exactly why people ask, do air fryers use a lot of electricity? The wattage number can look big on paper. But since cooking times are usually short, the actual energy used tends to stay pretty modest.
How Much Does It Cost to Run an Air Fryer?
Want to work out the cost? Just multiply how much electricity you use by your local rate.
Electricity Used (kWh) × Electricity Rate ($/kWh) = Estimated Cooking Cost
Say your session eats up 0.75kWh. If your rate is $0.20 per kWh, here’s the math.
0.75kWh × $0.20 = $0.15
Honestly, what you pay comes down to a few things: the wattage, how long you’re cooking, how often you fire it up, and what your area charges per kWh.
The Energy Saving Trust has found that for small portions, air fryers usually work out cheaper than ovens, mostly because there’s just less space that needs heating. For bigger batches though, an oven still makes more sense.
So, does the air fryer use a lot of electricity? Compared with some smaller appliances, its wattage can run high, but its shorter cooking cycles often keep total energy used fairly efficiently for smaller meals.
What Affects Air Fryer Electricity Consumption?
Two air fryers with nearly identical rated wattage can still burn through different amounts of electricity once you’re cooking with them.
A few things affect this.
  • Bigger cooking chambers need more power to fill.
  • Dual-zone models usually pull more than single drawers do.
  • Crank up the temperature, and you need more heat, obviously.
  • Cook longer, and you burn more energy; that’s just math.
  • Preheating adds extra use too.
  • Bigger portions can mean longer cooking times.
  • And every time you open the basket, heat escapes, so the unit has to work harder to catch up.
  • The heating element also clicks on and off throughout the cycle, and different cooking modes run at their own temperatures and patterns.
Match the appliance size to how much food you’re actually cooking, and you’ll cut down on wasted energy.
Can a Portable Power Station Run an Air Fryer?
Yes, a portable power station can run an air fryer if its AC output can handle the appliance.
Two specs matter here. Power station output, in watts, tells you whether the unit can run the air fryer. Battery capacity, in watt-hours, tells you roughly how long the appliance can keep running.
A simplified runtime formula looks like this:
Power Station Capacity (Wh) × Efficiency ÷ Air Fryer Wattage = Approximate Runtime
For example, dividing a 1,024Wh battery by a 1,500W load gives less than an hour of theoretical runtime, before factoring in losses.
Real-world runtime comes in lower since inverters and other parts eat up energy along the way.
Don’t just guess based on an average wattage. Check your air fryer’s actual rated number before trying to run it off a power air fryer with a portable power station.
How to Reduce Air Fryer Electricity Use and Power It Efficiently
Want to cut back on energy use? Pick the right size air fryer, skip preheating when you don’t need it, don’t keep opening the basket, and stick to the time and temp your food actually needs.
When running one off a portable power station, think about wattage, desired runtime, and whether other devices will draw power at the same time.
1,024Wh capacity and 1,800W AC output. Suitable for many standard air fryers, camping, road trips, RV cooking and short power outages. Always check appliance wattage before use.
The EcoFlow DELTA 3 Plus Portable Power Station offers 1024Wh capacity and 1800W AC output. It works well for plenty of standard air fryers within its output range and holds up for camping, road trips, RV cooking, and short outages. Check your appliance’s wattage before use.
2,048Wh capacity and 3,000W output. Suitable for higher-wattage air fryers, longer cooking sessions, multiple devices, vanlife setups and home backup.
The EcoFlow DELTA 3 Max Plus (2048Wh) brings 2048Wh capacity and 3000W output to the table. With its bigger capacity and higher output, it handles higher-wattage air fryers, longer cook sessions, multiple devices at once, vanlife setups, and home backup with room to spare.
Air fryer wattage really comes down to the model. Single-drawer units usually land around 1,500W, and the bigger twin-drawer ones can push close to 2,600W.
For a standard air fryer, the EcoFlow DELTA 3 Plus works fine, with 1800W output and 1024Wh capacity. Need more runtime or a heavier load? The DELTA 3 Max Plus bumps up to 3000W output and 2048Wh capacity.
Is 1,500 watts a lot for an air fryer?
Not really. Around 1,500W is common for a single-drawer air fryer, per Electrical Safety First. That said, it’s still a fairly high instantaneous load compared with small household electronics.
How many watts does an air fryer use in 30 minutes?
A 1,500W air fryer running at full power for 30 minutes would theoretically use 0.75kWh. Actual use may come in lower since the heating element cycles on and off.
How many amps does a 1,500W air fryer actually pull?
On a 120V supply:
1,500W ÷ 120V = 12.5 amps
That number changes wherever the supply voltage differs.
Will a 2000 watt inverter run an air fryer?
Potentially. A 2,000W inverter might run an air fryer rated below its continuous output, but check both the air fryer’s rated wattage and the inverter’s continuous and surge specs first.
How many watts does an air fryer use?
Air fryer power varies by model. Single-drawer models usually sit around 1,500W. Go bigger with a twin-drawer unit, and you’re looking at closer to 2,600W. For the exact number, just check the rating label.
