How Far Should a Generator Be From the House? Safety and Placement Guide
When the power goes out, generator placement matters for safety and performance. The right generator distance from house helps reduce carbon monoxide, ventilation, and fire risks.
For a battery-powered alternative, the EcoFlow DELTA Pro 3 Portable Power Station can power essential household devices without gasoline engine exhaust.
Good portable generator safety starts with proper placement, which depends on the generator type, manufacturer requirements, and local codes.
For a portable generator, the U.S. Consumer Product Safety Commission recommends running it outdoors at least 20 feet from the house, with exhaust directed away from the home and other buildings. Windows, doors, vents, and other openings near the exhaust path should stay closed.
Standby generators work quite differently from their portable cousins. Since they're permanently installed and built with specific enclosures, exhaust systems, and airflow requirements, the required clearance depends on the individual generator model and the local codes that apply in your area.
Homeowners searching for how far from the house should a Generac generator beshould always check the specific model's installation manual, since required clearances vary based on the generator's design and installation conditions.
For example, certain Generac home standby models are listed for installation with the rear of the generator as close as 18 inches from a structure, but that doesn't mean the generator can automatically sit 18 inches from windows, doors, vents, or fresh air intakes. Generac spells out additional clearances and requires compliance with applicable codes and the individual installation manual.
Portable Generators
Portable generators are typically moved outdoors during an outage and stored in a shed or garage when they're not needed for a while.
Since their location changes, safe placement must be considered each time you use the generator.
Important considerations include:
  • Keep the generator outdoors and at least 20 feet from the home.
  • Point the exhaust away from the house and other occupied buildings.
  • Keep it away from windows, doors, vents, and other openings.
  • Use properly rated outdoor extension cords when required.
  • Maintain adequate space around the generator for cooling and airflow.
  • Keep the generator protected according to the manufacturer's instructions without enclosing it in a space that can trap exhaust.
Portable generators should never come indoors just because the weather turns bad.
If you live in a condo or multifamily property, using a generator can be especially tricky. A guide on using a generator in an apartment covers this in more depth.
Standby Generators
A standby generator gets permanently installed outside the house and usually connects directly to the home's electrical system through an automatic transfer switch that senses power loss.
Unlike portable generators, standby systems are designed for a single fixed installation site.
Their placement may depend on:
  • Generator model
  • Wall construction
  • Windows and doors
  • Fresh air intakes
  • Exhaust direction
  • Fuel connections
  • Required service access
  • Local fire and building codes
Because these systems connect directly to a home's electrical and fuel infrastructure, professional installation is generally the right call.
Generac also tells homeowners to check the exact installation guide for their generator, since dimensions and clearance requirements vary by model.
Why Generator Distance From House Matters
Generator placement isn't just about finding an empty patch of yard to stick it in. Safe spacing protects both the people living inside the home and the generator itself from harm.
Prevent Carbon Monoxide Exposure
Fuel-powered generators produce carbon monoxide while running, and this applies to every type of combustion generator on the market.
Carbon monoxide is especially dangerous since you can't see it or smell it. If exhaust collects near a home, CO can sneak in through openings such as windows, doors, vents, and other gaps.
The CPSC specifically warns against ever running portable generators inside homes or garages, even with doors or windows open. It recommends operating at least 20 feet from the home, with exhaust facing away from the home.
Important generator safety practices include:
  • Never run a portable generator inside the house.
  • Never operate one in a garage, basement, crawlspace, or other enclosed space.
  • Keep the exhaust pointed away from buildings.
  • Keep nearby windows and doors closed.
  • Install carbon monoxide alarms throughout the home.
The CPSC recommends battery-operated CO alarms or models with battery backup on every level of the home and outside sleeping areas.
Reduce Fire and Heat Risks
Generator engines and exhaust systems run very hot during extended operation. Adequate space keeps heat away from nearby combustible materials while providing the engine with the fresh airflow it desperately needs to run smoothly.
Keep the operating area free from items such as:
  • Dry leaves
  • Grass clippings
  • Wood
  • Stored fuel
  • Cardboard
  • Outdoor furniture
  • Other combustible materials
Poor airflow can also contribute to overheating.
Always follow the clearance requirements in the owner's manual rather than assuming an open-looking space provides enough room.
Enhance Generator Performance & Maintenance
Proper placement of the generators also makes operating and maintaining the equipment easier.
Proper clearance may help:
  • Maintain airflow cooling
  • Reduce the risk of overheating.
  • Intake and exhaust areas are clear.
  • Regular inspections simplified
  • Allow access to oil changes and other maintenance.
  • Do not allow vegetation, snow, or debris to inhibit airflow.
Generac says it's best to leave space around the enclosure to allow free air circulation and maintain a clear distance from debris and snow, which can restrict airflow.
Choosing the right spot for a generator
The best location for a generator is a combination of safe distance, good ventilation, stable footing, and practical access.
Place the Generator in an Open Outdoor Area
For a portable generator, pick a location that is:
  • Outdoors
  • At least 20 feet from the house
  • Away from windows, doors, and vents
  • Positioned so exhaust faces away from occupied buildings
  • Flat and stable
  • Open enough for proper airflow.
  • Accessible for checking operation and fuel
  • Away from combustible materials
For permanent standby systems, the installer should weigh the property against manufacturer requirements and local codes before settling on the final position.
Avoid Common Generator Placement Mistakes
A generator can technically sit outdoors and still end up in an unsafe position.
Running a Generator in a Garage
A garage is not a safe location for a portable generator.
Opening the garage door doesn't eliminate the carbon monoxide hazard. The CPSC specifically warns against using portable generators inside garages, even when windows or doors stay open.
Exhaust can build up inside the garage or move through connecting doors and openings into the house.
Placing a Generator Under a Covered Area
Porches and carports might look convenient during rain or snow, but they can place a portable generator too close to the home and allow exhaust to collect.
CPSC guidance says portable generators shouldn't run on porches or in carports and should instead stay at least 20 feet from the house.
Any weather protection used with a generator should be specifically designed and positioned in accordance with the generator manufacturer's instructions, without restricting ventilation or trapping exhaust.
Installing Too Close to Windows or Doors
Distance from the exterior wall alone doesn't determine whether a location is safe.
You also need to consider:
  • Windows
  • Exterior doors
  • Dryer vents
  • Fresh air intakes
  • Crawlspace openings
  • Basement windows
  • Other ventilation openings
Wind can carry generator exhaust toward the house, so the direction of the exhaust outlet matters too.
Generator vs. Battery Backup System: Which Is Better for Home Backup?
Homeowners researching generator installation often stumble upon another option worth serious consideration: battery-based backup power systems for the whole household.
Both technologies can provide useful emergency electricity, but they work very differently.
For a more detailed comparison, check the breakdown of gas generators vs portable power stations.
Traditional Generator Considerations
Fuel-powered generators remain hugely popular because they can deliver substantial power and keep running as long as the fuel supply holds out reliably.
Advantages include:
  • High power output
  • Long potential runtime with sufficient fuel
  • Options for portable or permanently installed systems
  • Ability to support significant household loads
Challenges include:
  • Outdoor placement requirements
  • Carbon monoxide and exhaust
  • Engine noise
  • Fuel storage
  • Refueling
  • Routine engine service
  • Oil & filter changes
  • Considerations for standby system installation
Homeowners considering a permanently installed unit may also want to consider typical whole-house generator costs as they weigh backup options.
Battery Backup Systems as an Alternative
Battery backup systems provide electricity using stored electrical energy rather than running an internal combustion engine.
When operating from their batteries, portable power stations don't burn gasoline and therefore don't produce generator engine exhaust at the point of use. This eliminates many of the carbon monoxide and fuel storage concerns associated with a traditional portable gas generator.
Battery systems still require proper installation, charging, ventilation, and operation in accordance with the manufacturer's instructions.
For homeowners interested in a larger-scale option, look into a solar generator for whole-house setups.
For homeowners seeking flexible backup power for essential appliances and household equipment, the EcoFlow DELTA Pro 3 Portable Power Station offers a battery-powered alternative to a portable fuel generator.
A single DELTA Pro 3 provides 4kWh of battery capacity and 4,000W of AC output, with 120V and 240V output support. EcoFlow also offers options for expanding the system's storage capacity for longer outages.
4kWh capacity and 4,000W AC output with 120V/240V support. Expandable for longer home backup during outages.
It can be a practical choice for:
  • Emergency home backup
  • Refrigerators and essential appliances
  • Home electronics
  • Users who don't want to store gasoline
  • Households wanting a flexible backup system
  • Users who want a quieter alternative to a combustion generator
Since it stores electrical energy instead of continuously burning fuel, there's no gasoline engine exhaust during battery operation.
EcoFlow DELTA Pro Ultra
For larger homes or users comparing battery systems with more comprehensive standby-generator solutions, the EcoFlow DELTA Pro Ultra offers substantially greater capacity and output.
A DELTA Pro Ultra inverter and battery configuration starts with roughly 6kWh of storage and 7.2kW of AC output. EcoFlow states that compatible configurations can scale up to 90kWh of storage and 21.6kW of output when you combine multiple units.
Starts with 6kWh capacity and 7.2kW output, with expandable configurations for larger home power needs and extended outages.
It supports 120V and 240V appliances and can scale up to 90kWh of storage and 21.6kW of output. With compatible EcoFlow home backup equipment, it can also support automatic switchovers for more complete home backup.
How to Prepare Your Generator for a Power Outage
Safe generator use always starts well before the power actually goes out.
Before an Outage
Prepare ahead of time by:
  • Checking the generator's maintenance schedule
  • Testing the generator periodically according to its manual
  • Checking oil and other service items
  • Keeping properly rated extension cords ready
  • Planning the outdoor operating location
  • Checking that CO alarms are functioning.
  • Storing fuel according to applicable safety requirements
  • Keeping the generator's operating area clear
Don't wait until severe weather arrives to decide where the generator will go.
During an Outage
Before starting a portable generator:
  1. Move it to the predetermined outdoor location.
  2. Keep it at least 20 feet from the house.
  3. Point the exhaust away from the home and neighboring occupied buildings.
  4. Check nearby windows, doors, and ventilation openings.
  5. Keep combustible materials away from the unit.
  6. Observe the generator while running.
  7. Wire in electrical loads according to the manufacturer's instructions.
Do not refuel a generator while the engine is running or hot. Spilled fuel on hot engine parts can be a fire hazard.
After a power cut
When the grid power is restored:
  • Disconnect and de-energize loads per manufacturer’s instructions.
  • Properly shut down the generator.
  • Allow the unit to cool before handling or storing.
  • Regularly inspect the generator for service; store fuel and accessories securely.
  • Prepare the generator so it stays ready for the next outage.
Regular maintenance matters even more if the generator runs continuously for an extended period during the outage.
So, how far should a generator be from the house? Portable generators should be used outdoors at least 20 feet away, with exhaust directed away from the home. Standby generator placement depends on the specific model, manufacturer requirements, and local codes.
For a fuel-free alternative, homeowners can also consider battery backup systems like the EcoFlow DELTA Pro 3 or DELTA Pro Ultra.
How far away should a generator be from a house?
A portable generator should run outdoors at least 20 feet away from the house, according to the U.S. Consumer Product Safety Commission. Its exhaust should face away from the house and other occupied buildings.
Standby generator clearance requirements differ and should be determined by the manufacturer's installation instructions and local codes.
Can I put a generator right next to my house?
You shouldn't place a portable generator directly next to your house. Exhaust containing carbon monoxide can enter through windows, doors, vents, and other openings. The CPSC recommends maintaining at least 20 feet of separation for portable generators and directing exhaust away from the building.
A professionally installed standby generator may be permitted closer to a structure depending on its design and listing, but its specific clearance requirements must still be followed.
How far should a Generac generator be from windows?
There's no single clearance that applies to every Generac generator and every installation. Generac states that standby generator clearances depend on the model, installation conditions, and applicable codes.
Some Generac units may get approved for relatively close placement to a structural wall. Still, that reduced wall clearance shouldn't be interpreted as permission to place the generator equally close to a window, door, vent, or fresh air intake.
Always check the installation manual for the exact Generac model and have the installation evaluated against local requirements.
