How Residents of Houston Can Prepare for Power Outages
Power outages are a frequent phenomenon in Houston, primarily caused by hurricanes, storms, and heatwaves. The outages can last from hours to days, generally causing widespread disruption. For example, the derecho storm and Hurricane Beryl in 2024 left millions without power, underlining the necessity to be prepared. In this article, we'll explore why power outages occur in Houston, how they impact daily life, and the practical steps you can take to stay ready for when the lights go out—especially by taking advantage of new technologies like EcoFlow's portable power stations.
Why Power Outages Occur in Houston
Houston's power grid is disrupted on a regular basis due to a variety of things. Being a Gulf Coast city, Houston is vulnerable to hurricanes, high winds, and floodwaters. But Mother Nature is not the sole reason for power disruptions. Houston's primary electricity utility, CenterPoint Energy, is buckling under an old system and growing demands for electricity. Air conditioners add more strain on the grid in the summer months, and blackouts will always ensue. Thunderstorms also regularly knock over trees and power lines, causing prolonged outages. While less common, heatwaves, when they do occur, greatly increase the demand for electricity, once more adding more pressure on the grid and again increasing the likelihood of power outages.
Workshop with desk and aquariumWorkshop with desk and aquarium
The Impacts of Power Outages on Daily Life
Power outages can be disruptive to nearly every aspect of daily life. During summer, without air conditioning, indoor temperatures can rise to life-threatening levels, and susceptible populations like children, elderly persons, and individuals with medical illnesses become vulnerable to heat-related illnesses such as heat exhaustion or heatstroke.
The other essential issue is food storage. Without electricity, freezers and refrigerators can no longer function, and food deteriorates. Medical equipment, like oxygen concentrators or insulin refrigerators, cannot be used, resulting in drastic health risks.
Aside from these direct issues, outages also influence communication and access to essential services. Stores can shut down, schools can suspend classes, and essential services like emergency response can be delayed.
Major Steps to Prepare for Power Outages in Houston
1. Assess Your Power Needs
The first part of preparing for a power outage is identifying what you need to keep your house running after the grid goes down. Keep a list of your most vital devices and appliances that consume electricity, such as medical equipment, refrigerators, and fans. This will help you estimate how much backup power you will need.
Example power needs:
  • Critical devices: Refrigerators, medical devices, security systems, and phones.
  • Comfort items: Fans, lights, computers, and televisions.
  • Essential appliances: Water pumps, filtration systems.
Now that you know your needs, you can decide whether a small portable power station will suffice or whether you'll require a large backup system to power your whole house.
2. Invest in Good Backup Power Solutions
Gasoline generators have been the backup power benchmark, yet they're not without several flaws:
  • Noise: They are loud, which is disturbing to your peace and to your neighbors.
  • Emissions: Gasoline generators produce dangerous fumes and pollutants.
  • Maintenance: The generators require fuel, regular maintenance, and storage.
  • Fuel dependency: You could run out of fuel during a prolonged outage or have difficulty obtaining more in an emergency.
A cleaner and more efficient option is portable power stations. These battery-powered devices, which use lithium-ion batteries, store electricity and can supply power for essential appliances during an outage. They offer many advantages over traditional generators:
  • No emissions: They're environmentally friendly and don't produce any harmful gases.
  • Portability: They're lightweight and easy to carry, unlike cumbersome gas generators.
  • User-friendly: Most models are plug-and-play straight out of the box with minimal setup.
  • Fuel independence: Simply recharge when not in use, and they're ready to power your home when needed.
EcoFlow's portable power stations, like the DELTA 2 and RIVER 2 models, are perfect for Houston homeowners. They can power everything from medical devices to refrigerators and lights. With their fast-charging capabilities, they can be up and running in minutes—not hours like a gas-powered generator.
3. Take Advantage of Solar Power for Greater Resilience
One of the best things about portable power stations is that they can be combined with solar panels. For Houston residents, where sunshine is plentiful, solar power is a clean and reliable way of refueling your backup system even when the grid is down. Solar panels keep your power station charged continuously, acting as a renewable backup in case of prolonged outages.
EcoFlow solar panels such as the 220W and 110W are built to be compatible with their portable power stations. They'll charge your DELTA 2 or RIVER 2 with no issues at all, ensuring that you have a constant power supply even during extended power outages.
4. Conserve Energy When the Power's Out
Now that you've got your backup power system in place, conserve energy when there is an outage. To maximize the use of your backup power, prioritize the most essential devices:
  • Refrigerate: Turn on the refrigerator to prevent food spoilage.
  • Cool: Turn on fans to circulate air and stay cool.
  • Conserve: Avoid turning on non-essential appliances to conserve energy.
For larger power stations like the EcoFlow DELTA 2, you can charge multiple devices at once, but it's still a good idea to manage usage so as not to drain the battery too quickly.
5. Stay Informed and Have a Plan
In the case of predicted severe weather, stay informed about power outages and when they will be restored. Sign up for alerts from your power provider, such as CenterPoint Energy, for real-time updates on the status of the outage. Have an emergency contact list and a plan in place on where to go in case of an extended outage.
Ensure that all individuals within the house understand the backup power system, and ensure an emergency kit that includes food, water, drugs, and other essentials in case the power outages last for longer than expected.
House at night with battery systemHouse at night with battery system
Preparing for the Next Power Outage
While Houston power outages are inevitable, there is no need for their impact to. By assessing your power needs, investing in a good backup power system, and utilizing solar power to recharge your system, you can keep your home secure and functional even when the grid is not.
EcoFlow portable power stations provide a convenient, green solution to keep your home powered during outages. If you prepare and are aware of your options, you can approach the next power outage with confidence, whenever it happens.
