Bowfishing Guide: Essential Equipment and Power Solutions for Your Next Trip
Bowfishing has become a fast-growing movement within the outdoor industry. It combines the challenge of archery with the excitement of fishing.
Bowfishing can be as simple as picking up a bow and heading out, but the right preparation makes a big difference. You need suitable bowfishing gear and reliable lighting for nighttime trips, with a reliable power source. For example, the EcoFlow DELTA 3 Max Plus can power a full multi-light setup through a long night on the water, while the EcoFlow DELTA 3 Classic offers a lighter option for short trips. So let's steer through this bowfishing prep guide so you can spend more time focusing on the water.
What Is Bowfishing?
Bowfishing uses a bow and specialized arrow, along with a reel system to catch fish. The arrow attached to the line allows you to retrieve the fish after making a shot. Bowfishing requires you to spot the fish before taking a shot, which makes it different from traditional fishing.
This means that visibility of your target is key, especially when you are going for night bowfishing. To overcome this hurdle, artificial lights are set up to illuminate the water. Pair it with the right bowfishing equipment, and you are good to hunt and retrieve fish.
Bowfishing can be done from boats, kayaks, docks, and other suitable platforms. Do check the local regulations and the fishing environment before embarking on the trip.
Since most of the activity involves being around water, choosing durable and water-resistant equipment and preparing your power sources before leaving home are two very important parts of the trip.
Essential Bowfishing Equipment and Gear Checklist
The success of a bowfishing trip starts with thorough and thoughtful preparation of the right equipment. Every piece you pack should serve a purpose and must be suitable for the conditions you expect to encounter out there.
Bowfishing Bow, Reel, and Arrows
Bowfishing Bow
The bow is at the heart of your setup. Bowfishing bows handle repeated shots, so they use specialized fishing arrows. You can choose between different bow styles:
  • Recurve bows are simple in design, which makes them easier for beginners to maintain.
  • Compound bows use a system of cams + cables for added control and shooting performance.
Bowfishing Reel
The bowfishing reel is attached to the bow and holds the line that is connected to the arrow. Common reel systems include bottle-style reels, drum reels, and spinning-style setups. You should pick the reel that matches your shooting style.
Bowfishing Arrow
Bowfishing arrows are heavier and more durable than standard archery arrows. They penetrate fish and remain connected to the reel line, which makes it easier to retrieve your catch. Bowfishing arrows should be compatible with your selected bow type, so you need to pick wisely to enjoy the intended fishing conditions.
Other Essential Bowfishing Gear
The bow and arrow are part of the basic setup. You need to throw in some additional items to make your time on the water worthwhile.
  • Polarized sunglasses reduce glare on the water's surface, which makes it easier to see fish during daylight.
  • Gloves protect your hands when handling equipment, fishing, and fishing lines.
  • Fishing boots are for your protection and better footing when you are working around wet surfaces.
  • Fish stringers are a convenient way to keep your catch together.
  • Nets help with landing and handling fish, especially when you are fishing from a boat or other platform.
  • Storage equipment, such as waterproof containers or tackle bags, comes in handy for keeping small items like arrows and tools/electronics organized.
Pro Tip: Keep your gear organized at night. When visibility is limited, knowing exactly where everything is can save time and prevent equipment from being displaced.
Bowfishing Lights for Night Fishing
Angler on a lit boat bowfishing on a river after darkAngler on a lit boat bowfishing on a river after dark
Your night bowfishing is heavily dependent on good lighting. This requires mounting lights around a boat or fishing platform. Properly illuminated water gives anglers an edge to spot fish and judge their position before they take a shot. Pay attention to these factors:
  • Brightness (Lumens): More lumens can provide greater illumination, but the size of your fishing area and the water conditions will affect the ideal brightness.
  • Waterproof Rating: You should be able to withstand splashes, moisture, and wet environments.
  • Power Consumption: Higher-powered lights provide more illumination, but they also drain a battery faster, so choose wisely.
  • Runtime: Anticipate how many hours you plan to fish so that you can match your lighting setup with sufficient battery capacity.
  • Mounting Options: Make sure you securely mount lights on your boat, kayak, or other fishing platform to prevent any mishaps or issues.
  • Durability: Take your time selecting outdoor lighting, as it should handle vibration, moisture, changing weather, and be suitable for regular use.
Note: Your lighting system and power source should go hand in hand. A powerful lighting setup is of no use if the battery dies on your trip.
Boat Power vs Portable Power Stations for Bowfishing
After you have arranged for the bowfishing lights, you need to arrange a power source. Generally, anglers make use of the boat's built-in electrical system as the primary power source.
However, a portable power station can provide additional flexibility when you need power for lighting and smaller electronics. These two options serve different purposes, so understanding the difference will help you in building a practical setup.
How Boat Power Systems Work for Fishing Electronics
You can easily access the boat's batteries because they are integrated into the boat's electrical system. It helps power equipment installed directly on the boat. This may include:
  • Navigation equipment
  • Fish finders
  • Built-in accessories
  • Boat-mounted lighting systems
The amount of power available to you is directly related to the battery capacity, the type of equipment connected, and the runtime of those devices. If you plug in several power-hungry accessories at once, it will increase the battery consumption.
Can You Use a Portable Power Station for Bowfishing Lights?
A portable power station can serve as a secondary power source for outdoor bowfishing lights and electronics. It is very useful during nighttime trips, when lighting and electronics need to run reliably for hours at a time.
A portable power station can support several parts of a bowfishing setup, including:
  • Powering LED bowfishing lights
  • Charging cameras, phones, and other small electronics
  • Providing portable power when additional outlets are needed
A portable power station is not meant to replace a boat's built-in battery system, which handles the boat's core electrical needs like navigation and the motor. The portable power source works alongside that system and gives anglers a flexible way to power lights and electronics when needed.
How to Choose a Portable Power Station for Bowfishing
Choosing a portable power station for bowfishing comes down to matching the unit's capacity and output with the equipment you plan to use during your trip. A small setup for a few lights and phones has different requirements than a boat with multiple LED lights, cameras, and other electronics.
Battery Capacity
Battery capacity is measured in watt-hours (Wh) and indicates the amount of energy stored in a power station. A 1,000Wh power station theoretically stores more energy than a 500Wh model, but it ultimately depends on how much energy the connected equipment consumes.
A good estimate of the expected usage total wattage of your bowfishing lights and other devices, along with their expected run time, can help you decide on the battery capacity.
Output Power and Compatibility
Beyond capacity, it's important to check that a power station can actually handle your gear. Look at the output wattage to confirm it can support your lights and electronics without overloading. Check the available AC and DC ports, along with USB charging options.
Match these specs against your equipment's power requirements ahead of time, as it helps avoid compatibility issues once you are out on the water.
Portability for Outdoor Use
A bowfishing setup already involves plenty of equipment, so size and weight matter. A power station should be compact in size and easy enough to transport to and from your boat or fishing location.
Best EcoFlow Portable Power Stations for Bowfishing
Night bowfishing requires reliable lighting, but your boat's built-in battery may not always be enough to handle additional equipment. A portable power station can help meet the extra power required for compatible LED lighting, cameras, phones, and other fishing electronics without replacing the boat's main electrical system.
EcoFlow's portable power stations give anglers a flexible way to keep essential equipment powered while spending time on the water.
With 2,048Wh of capacity and 3,000W of AC output, the EcoFlow DELTA 3 Max Plus is best for anglers running demanding bowfishing setups. It provides enough power for multiple LED lighting rigs, cameras, phones, and other fishing accessories throughout longer nighttime trips. Its capacity is also expandable from 2–10kWh to give you additional flexibility for extended time on the water.
EcoFlow DELTA 3 Max Plus for Bowfishing Setups (2048Wh)
The 2048Wh battery capacity supports demanding bowfishing setups and outdoor electronics, including LED lighting setups, cameras, phones, and other fishing accessories. Higher capacity makes it well-suited for anglers running multiple lights or longer nighttime trips where reliable and extended power matters most. Best for: Anglers with more demanding bowfishing setups who need higher-capacity portable power for extended outdoor use.
The EcoFlow DELTA 3 Classic (1024Wh) has 1,800W of continuous output, 1,024Wh of battery capacity, and a compact/lightweight build. This power station offers multiple charging options and keeps small lighting setups and personal electronics charged without taking up much space on the boat.
EcoFlow DELTA 3 Classic for Lightweight Bowfishing Needs (1024Wh)
The 1024Wh battery capacity offers a compact option for simpler bowfishing setups, ideal for small lighting setups and charging personal electronics. A lighter, more compact build makes it easy to bring along without taking up much space on the boat. Best for: Beginners and anglers who prefer a more compact portable power solution for simpler bowfishing trips.
Bowfishing Setup Tips for Beginners
Bowfisherman organizing equipment beside a pickup truck and boat rampBowfisherman organizing equipment beside a pickup truck and boat ramp
Bowfishing becomes a memorable experience when you prepare your equipment before getting on the water. A few minutes of preparation at home can save you from having to troubleshoot equipment while you are already on the water.
  • Check your equipment before heading out and inspect the bow, reel, arrows, lines, lights, and other essential gear.
  • Test your lights and power sources before leaving to ensure everything works properly.
  • Prepare backup charging options for your phone, camera, and other electronics you may need during the trip.
  • Organize your gear for easy access, as finding a small piece of equipment in the dark can be difficult.
  • Check the weather and water conditions before heading out, and make sure your equipment is appropriate for them.
  • Know the local regulations because bowfishing rules, permitted species, seasons, and equipment requirements can vary by location.
How to Maintain Your Bowfishing Equipment
Bowfishing equipment is exposed to water, moisture, dirt, and outdoor conditions. So you need to clean and maintain/store it properly. Taking care of your gear after every trip can make preparation much easier the next time you head out.
  • Clean bows and arrows after use to remove dirt, moisture, and residue. Dry them thoroughly before storage.
  • Inspect reels and lines for wear or damage and replace components when necessary.
  • Store lights properly in a dry, protected location when not in use.
  • Protect electronics from water exposure by using suitable waterproof or water-resistant storage when appropriate.
  • Recharge portable power stations correctly after trips and follow the manufacturer's storage and charging recommendations.
  • Keep equipment organized so you can quickly inspect everything before your next outing.
A successful bowfishing trip comes down to having the right equipment and preparing it before you get on the water. A suitable bow, reel, arrows, protective gear, and storage equipment give you the foundation you need. Reliable lighting is crucial for night bowfishing.
Furthermore, your boat's built-in electrical system is a reliable power source that handles many fishing electronics and boat-mounted accessories. Anglers who require additional energy can make use of EcoFlow's portable power stations as a flexible option for outdoor electronics and lighting. You can choose the capacity and output that matches your setup. Prepare your equipment before the trip, and you will enjoy your time on the water.
FAQ for Bowfishing
What equipment do you need for bowfishing?
Essential bowfishing equipment includes a bowfishing bow, specialized arrows, a reel and fishing line, gloves, suitable footwear, polarized sunglasses for daytime use, fish stringers, nets, and storage equipment. Night bowfishing also requires a suitable lighting setup and a reliable power source.
What type of lights are best for bowfishing?
The best bowfishing lights depend on your fishing environment and setup. Look for lights with sufficient brightness, a suitable waterproof rating, reasonable power consumption, enough runtime for your trip, secure mounting options, and durable construction. LED lights are commonly used for outdoor lighting because they can provide strong illumination while using relatively little power.
Can a portable power station replace a boat battery for bowfishing?
No. A portable power station is not designed to replace a boat's built-in battery or electrical system. Instead, it can provide additional portable power for compatible bowfishing lights, cameras, phones, and other electronics when you need extra outlets or want a separate power source.
