Back to School: Powering Life on Campus With Portable Power Stations
To be successful in modern-day classes, you need reliable access to your devices. Laptops, tablets, and even phones have become a huge part of learning and curriculum, and we’re here to help make sure you have everything you need to stay powered up and connected, no matter what the school year may bring.
Below, we will dive into some of the more common power challenges faced by students as well as some simple solutions to help you prepare for a successful year ahead.
Starting the New School Year With Campus Ready Power
Whether you are a returning student or starting out at a new campus, these are some important steps to take to ensure you’re equipped with the knowledge and resources to stay powered up while at school.
Identifying Where and When You Will Need Extra Power
  1. Map Your Weekly Schedule: Start by making a clear list of where and when your classes will take place. Also, try to keep an on-call run time to see how much charge you will need to make it through.
  2. Pay Attention to Long Days on Campus: Some of your days on campus will likely be longer than others. Make note of these days and prepare for extra charging time, or plan to bring along the EcoFlow RAPID Pro X Power Bank for a quick charge on the go.
  3. Schedule Your Charging Times: During downtime between classes, plan where you can charge your devices on campus.
  4. Make a Plan for Backup Power Usage: If outlet options are limited on your route, consider bringing a portable charger to ensure your devices stay powered up for classes later in the day.
Power Challenges Students Face on Campus
Outlet Limitations
One of the most common and frustrating challenges faced by on-campus students is that open outlets are scarce. With the campus population increasing by the year, it’s no wonder that this has become a growing concern.
  • Outlets are often poorly placed and hard to access, especially when students are traveling from class to class.
  • Older buildings often lack reliable outlets for public use.
  • Overcrowded rooms like libraries and coffee shops are often packed with students who have already claimed one of the few available charging stations.
Power through your day with the EcoFlow RAPID Pro X Power Bank — a compact, flight-friendly 27,650 mAh powerhouse that recharges to 80% in just 20 minutes² and delivers 300W across three USB-C ports. With a modular magnetic design, smart LCD display, app-based battery optimization, and a retractable cable included, it’s the ultimate travel-ready charging companion backed by a 24-month warranty.
Choosing the Best Portable Power for Campus Life
While traditional outlets can be unreliable, there are numerous backup power options specifically designed for students on the go. Here are some key considerations to keep in mind when selecting a portable power solution for this year’s classes.
Portability
Some portable chargers are better for on-the-go use than others. If you have a smaller bag or backpack you intend to keep it in, be sure to find a device that’s easy to store without taking up too much space.
Battery Capacity
Are you looking for something like EcoFlow’s DELTA 3 Ultra Plus (3072Wh) that can charge your devices for hours at a time, multiple times throughout the day? Or are you just looking for something to quickly boost your phone battery before your next class? Understanding your exact needs will help you find a device with the battery capacity to best serve you.
Durability
If you plan to take your power bank to campus every day, consider investing in a model that boasts high durability levels. Some devices are more fragile than others and may not last very long if they’re thrown in your backpack every day.
Back-to-School Daily Habits for Reliable Power
It’s key to get into good habits during the school year to ensure you’re never caught short without power. Here are some quick tips to help you establish a routine and make sure you always have juiced-up devices:
Daily Routines That Keep Your Devices Charged and Organised
  1. Maintain a Charging Schedule: Charge your devices every night to ensure you start each day with a full battery.
  2. Top Off Your Battery During Short Breaks: Even if you still have a fair amount of charge on your device, try to use any downtime to quickly plug it in and top off your battery, in case you won’t have a chance to do so again soon.
  3. Use Low Power Modes: When you’re not actively using your device, you can turn it off or place it in a low-power mode to help maintain battery life.
  4. Consider Portability: When shopping for a portable power station or charger, you’ll want to be able to easily carry it between classes.
Can I Use a Portable Power Station Safely in My Dorm Room?
Yes, portable power stations are safe to use both indoors and outdoors, and can be great to bring along in on-the-go scenarios. There are plenty of chargers on the market, so make sure to do your research and find a device that is best suited for your needs.
Do I Still Need a Power Strip if I Have a Portable Power Station on Campus?
This will ultimately depend on how many devices you need to charge at once. Some portable power stations have multiple charging ports available, which may lessen your need for a power strip.
What Size Power Bank Is Best for Long Days on Campus?
An average student should have at least a 15,000mAh power bank, although long days on campus may require a power bank with upwards of 20,000mAh. Take a good look at your schedule and account for the hours you will be away from reliable charging options to make sure you purchase the best option for your needs.
Portable Power Supports Stress-Free Campus Life
With the increasing number of electronic requirements in the school setting, it’s crucial that you prepare yourself for a successful semester ahead. With these back-to-school power tips, you are on your way to a productive school year.
Staying powered while on campus is easier than ever before with EcoFlow’s DELTA 3 Ultra Plus (3072Wh). Get yours today and enjoy the peace of mind knowing you will be powered up for all of your back-to-school needs.
Off-Grid Power
