How Much Is Your Average Apartment Electric Bill in 2026
Electricity is something most people use every day. But few know how much it costs each month. Apartment renters in 2026 may see higher or lower bills depending on many things. If you want to understand your bill and reduce it, this guide will help you step by step.
Not every apartment uses the same amount of electricity. Bigger apartments often use more. Also, bills can be different in each state. But we can look at some average numbers to help you get a general idea.
Apartment Size Average Monthly Bill
Studio Apartment $50 – $80
One-Bedroom Apartment $60 – $100
Two-Bedroom Apartment $100 – $150
Three-Bedroom Apartment $120 – $200
Some people pay more or less depending on how they use electricity and where they live.
Factors that May Affect Your Apartment Electric Bill
As of May 2025, the average monthly electricity bill for a one-bedroom apartment in the United States ranges between $60 and $100, depending on many factors:
Location. Electricity prices change from state to state. In some areas like California, rates are high due to demand and local rules. In states like Texas or Florida, rates may be lower because of cheaper energy sources or better supply:
  • California: With higher electricity rates, the average monthly bill is around $155.37, based on an average usage of 491 kWh and a rate of 31.66 cents per kWh.
  • Texas: The average monthly bill is approximately $120.73, with an average usage of 855 kWh and a rate of 14.89 cents per kWh.
  • New York: Residents pay an average of $139.00 per month, with usage around 530 kWh and a rate of 26.2 cents per kWh.
Where you live is often the biggest reason your bill is high or low.
  • Season. Weather changes affect how much power you use. In summer, people use air conditioning to stay cool. In winter, heaters work harder to keep the room warm. Both seasons can push your bill up. Spring and fall usually have lower bills because you don’t need as much heating or cooling.
  • Appliance Use. Some devices need a lot of energy. Old fridges, ovens, and dryers often use more power than new ones. Energy-efficient models use less and can help save money over time. Also, large devices like gaming computers or large-screen TVs can add to your bill if used daily.
  • Number of People. More people means more lights, more devices, more cooking, and more showers. If you live with roommates or a family, your electricity use will go up. Even phone chargers and laptops add up when used by several people.
  • Time of Use. In some cities, power costs more during busy times of day. These are called “peak hours,” often in the late afternoon or early evening. Using power during “off-peak” hours, like early morning or late night, may cost less.
  • Building Type. Newer buildings are often built to save energy. They may have better windows, stronger insulation, or smart thermostats. Older buildings may let heat or cold escape more easily, which means more power is needed to keep a comfortable temperature.
  • Energy Habits. How you use power matters. Leaving lights on, running the AC with open windows, or using the oven often can lead to higher bills. Small habits repeated every day can lead to big changes in monthly use.
Portable power station and solar panels in yard.Portable power station and solar panels in yard.
10 Ways to Cut Your Apartment Electric Bill
If your bill feels too high, you can take action. Most steps are simple and cost little or nothing:
  • Switch to LED bulbs. LEDs use up to 85% less power than old bulbs. They last years and don’t get hot. Changing just a few bulbs can help your bill go down.
  • Unplug devices not in use. Many devices use power even when they’re off. This is called “phantom energy.” Unplug chargers, coffee makers, and TVs when not needed. Or use one power strip to shut them all off at once.
  • Use power strips. With a smart strip, one button turns off many devices. This helps you stop phantom energy use without unplugging things one by one. It also protects electronics from power surges.
  • Adjust your thermostat. Set it higher in summer and lower in winter. Even 1 or 2 degrees can help. If you’re gone during the day, adjust the setting so your AC or heater runs less. You can change it back when you get home.
  • Use fans instead of AC. Fans use much less power than air conditioners. Use them to help you feel cooler. In some cases, a fan is enough if the weather isn’t too hot. Try using both together so you can set the AC a bit higher.
  • Wash clothes in cold water. Most of the energy used by washing machines goes to heating water. Cold water works for most clothes. It also helps fabrics last longer and fade less.
  • Limit dryer use. Dryers use a lot of electricity. If you can, air-dry your clothes on a rack or hang them near a window. Even drying just half your loads this way can cut costs.
  • Run full loads only. Dishwashers and washing machines use the same amount of power no matter how full they are. Wait until you have a full load. This saves electricity, water, and time.
  • Close curtains at night. In winter, heat can escape through windows. Closing thick curtains keeps the warm air in. In summer, close curtains during the day to block out heat from sunlight.
  • Let sunlight in during the day. Use free daylight instead of lamps. Open curtains or blinds in the morning and let the sun light up your room. This is especially useful if you work or study at home.
Can a Portable Solar Generator Help Reduce Your Apartment Electric Bill?
Expandable power, 10-year lifespan, 3400W output. Fastest recharge & solar input. Manage via app & enjoy a 5-year warranty!
Yes, a portable solar generator like the EcoFlow DELTA 2 Max can help reduce your apartment electric bill — but how much depends on how you use it.
Store Free Power from the Sun
Thanks to its dual solar input system with MPPT tech, DELTA 2 Max captures and stores solar energy efficiently—up to 1000W solar input. You can charge it daily on your balcony, rooftop, or near a sunny window (if permitted).
Once charged, you can use that stored energy to run your everyday essentials.
Run Common Appliances
DELTA 2 Max has 2048Wh capacity and supports up to 3400W output, meaning it can power:
  • Wi-Fi router for up to 97 hrs
  • TV for 15 hrs
  • Refrigerator for 14 hrs
  • Blender, microwave, and washing machine for short cycles
Instead of using grid electricity, you can run these on solar-charged power—cutting costs.
Smart Power Scheduling
Use the EcoFlow app to track power use and plan when to switch from grid to solar battery. For example:
  • Run your router and lights during peak hours using the battery
  • Charge the unit at noon with solar panels while rates are lowest or sunlight is strongest
You won’t fully replace your apartment’s electricity with this, but you can reduce your bill significantly—especially if:
  • Your utility has time-of-use pricing
  • You regularly use portable electronics
  • You want to power high-usage appliances for a few hours a day
For apartment renters who can’t install rooftop solar, DELTA 2 Max offers a flexible and impactful way to cut electric costs.
Feature Details
Battery Capacity 2048Wh (expandable up to 6144Wh with 2 extra batteries)
Output Power Up to 3400W with X-Boost (runs 99% of appliances)
Solar Input Supports up to 1000W solar input
AC Input Up to 1800W
Recharge Speed 0–80% in 43 minutes (AC + solar input combined at 2400W)
Battery Chemistry LFP (LiFePO4), 3000+ cycles to 80% capacity
Device Support Powers up to 15 devices at once (6 AC outlets)
Smart Control App control for output, input, battery priority settings
MPPT Solar Tracking 99% efficiency, dual independent MPPT input system
Portability Compact and lightweight for home or outdoor use
Use Cases Home backup, RV, outdoor trips, DIY power, emergency use
Mastering Your Apartment Electric Bill
Electric bills are part of apartment life. But they do not have to be a surprise or a burden. In 2026, most apartment bills fall between $60 and $150. That number can go up or down depending on where you live, how big your space is, and how you use power. With smart habits and tools like solar generators, you can take control and cut costs over time.
FAQs about Your Apartment Electricity
Q1: Why is my apartment's electric bill suddenly higher than last month's?
A: A sudden jump in your bill can come from seasonal changes, like running your air conditioner more often. It could also be caused by new appliances, longer use of heating, or guests staying over. Sometimes, your utility company may raise rates, or there may be a billing error. Check your usage history, and if the change is large or unclear, contact your electric company to ask for details.
Q2: How much electricity does a one-bedroom apartment usually use per month?
A: Most one-bedroom apartments use between 500 and 850 kilowatt-hours (kWh) each month. The exact number depends on your habits, appliances, and whether you use heating or cooling often. If you cook every day, work from home, or leave devices running, your usage will likely be at the higher end.
Q3: Can turning off lights really lower my electric bill?
A: Yes. Lighting can take up 10–20% of your total electricity use, especially if you use old-style bulbs. Switching to LED bulbs and turning off lights when you leave a room can reduce your bill by several dollars a month. Over time, that adds up.
Q4: Does using the oven raise my electric bill a lot?
A: Ovens use a lot of power, especially electric ones. If you bake or roast often, your electricity use will be higher. Using a microwave, air fryer, or toaster oven for small meals can save energy. Also, avoid running the oven and air conditioner at the same time, as the oven heats up your home.
Q5: What’s the cheapest way to keep cool in the summer without using too much electricity?
A: Use ceiling or standing fans instead of the air conditioner when possible. Keep curtains closed during the day to block heat. Open windows in the early morning or late evening to let cool air in. Wear light clothes and stay hydrated. If you use the AC, raise the thermostat a few degrees and run a fan at the same time to stay comfortable with less energy.
