EcoFlow 400W
EcoFlow 400W
Portable Solar Panel
Portable Solar Panels
Power your everyday appliances at home and off-grid with sustainable solar energy.
    400W Portable Solar Panels
    Our 400W portable solar panel offers high solar output, conversion efficiency rating, and a convenient folding design so it’s ready to grab and go at any time.
      High Solar Output
and a One-piece Folding Design
      High Solar Output and a One-piece Folding Design
      Charge faster, wherever you go.
      A single portable solar panel with a unique folding design, our 400W portable solar panel combines powerful energy production with portability. To achieve a higher solar conversion efficiency of up to 23%, we use multi busbar monocrystalline cells, so you get even more energy to recharge your portable power station.
        An Integrated, Self-supporting Stand
        Optimize your energy.
        EcoFlow’s 400W portable solar panel comes complete with a protective case that doubles as a sturdy supporting stand. Simply set up your panel anywhere and conveniently adjust its angle to get the most sun possible.
          Balancing Portability With Protection
          Ready for the outdoors.
          Made from durable and flexible materials, the portable solar panel is perfect for off-grid living and travel. Its multi-layered design offers high impact resistance for the rugged outdoors, while its 27.5 lb light-weight means effortless carrying to a campsite. A rigid layer embedded in the carry case protects the panel from overbending when you carry or store it.
            IP68 Waterproof Rating
            Built to weather the storm.
            Our 400W portable solar panel can carry on collecting energy even during a downpour. With a protective ETFE film and a high IP resistance level of 68, the solar cells can withstand environments from humid and wet to dry and dusty.
              A Compact, Space-Saving Design
              Take solar power on the go.
              EcoFlow’s 400W portable solar panel is a camping or RV must-have. The compact design saves valuable space for your other travel essentials. When you’re ready to head off on your next adventure, simply collapse the panel down to store in your van or car.
                High-Efficiency Solar Cells
                Capture more rays.
                Made using highly efficient monocrystalline silicon cells. And with an exceptional energy conversion rate of 22-23%, you get more energy with every cell.
                Plus, when connected to an EcoFlow solar generator, the Maximum Power Point Tracking (MPPT) algorithm auto-adjusts, guaranteeing a constant and stable power supply.
              • Charge a DELTA Mini in
                3-6 hours
                with 1 x 400W portable solar panel.
              • Charge a DELTA in
                Charge a DELTA in
                4-8 hours
              • Charge a DELTA Max in
                3-6 hours
                with 2 x 400W portable solar panels.
              • Charge a DELTA Pro in
                3.5-7 hours
                with 3 x 400W portable solar panels.
              • You might also like
                View more
                • EcoFlow
