EcoFlow RIVER Pro
- Overview
- Specs
- Support
RIVER Pro
Step Into the Wild
Expandable Capacity up to
Charging
Up to
10 devices
600W
Up to 1800W
App Control
Expandable Capacity
Power for the long haul.
Take on the great outdoors with the EcoFlow RIVER Pro. This portable powerhouse comes in at 16.8lbs and packs a 720Wh capacity. Double up to 1440Wh with an extra battery whenever you need more juice for the long haul.
0W
More power to you.
With a 600W AC output, RIVER Pro makes easy work of powering your essential devices. Need more power? Turn on X-Boost to power high-wattage devices up to 1800W. And if you’re settling down and making camp, you can power up to 8 devices at the same time from one single unit.
Home Backup
Off-grid
Light
65.2Hrs
Refrigerator
4.5Hrs
Blender
1.2Hrs
50" TV
5Hrs
Hair Dryer
0.7Hrs
Coffee Maker
0.7Hrs
Projector
8Hrs
Charging
It’s the
world’s
fastest.
EcoFlow’s patented X-Stream technology brings in more power from the wall, going from 0–80% in 1 hour, and to full in 96 minutes.
Solar Panel
Going
off-grid
is easy.
Whether you’re powering your cabin, going camping, or looking for an extra source of power, going off-grid is easy with RIVER Pro.Connect two 110W solar panels to charge up as quick as 4 hours.
Car Outlet
In a rush? No problem. Plug in RIVER Pro to your car outlet to charge up on the go.
Peace of mind.
The EcoFlow battery management system has a proven track record in challenging environments, regulating current, voltage, and temperature in real time. This gives you a reliable battery that you can use both indoors and outdoors, whatever the occasion.
Monitor
Real-time energy insights on the go.
View battery status live anytime, anywhere.
Control
Control even from afar.
Easily turn on/off output and the connected appliances remotely.
Customize
Save more on electricity bills.
Optimize your home's energy use and reduce energy bills by smartly leveraging power from the sun, grid, and batteries during peak and off-peak hours.
Constant Updates
Constant updates for optimal user experience.
Regular upgrades to offer you industry-leading energy management.
You might also like
View more
EcoFlow RIVER 2 ProLearn More
EcoFlow DELTA 2Learn More
EcoFlow DELTA MaxLearn More
